Results for column generation with only elementary routes for m, p.139 ,
Results for column generation with only elementary routes for VRPTW, p.143 ,
Results for the construction of simple graph representations for, Like instances, p.171 ,
89]-Like instances with wide time windows (?: instances not solved in 7200 seconds), p.173 ,
Dual graph representation of transport networks, Transportation Research Part B: Methodological, vol.30, issue.3, pp.209-216, 1996. ,
DOI : 10.1016/0191-2615(95)00024-0
Recent exact algorithms for solving the vehicle routing problem under capacity and time window constraints, European Journal of Operational Research, vol.218, issue.1, pp.1-6, 2012. ,
DOI : 10.1016/j.ejor.2011.07.037
The multiple disposal facilities and multiple inventory locations rollon???rolloff vehicle routing problem, Computers & Operations Research, vol.33, issue.9, pp.2667-2702, 2006. ,
DOI : 10.1016/j.cor.2005.02.023
A branch-and-cut procedure for the vehicle routing problem with time windows, Transportation Science, vol.36, issue.2, pp.250-269, 2002. ,
Branch-and-Price: Column Generation for Solving Huge Integer Programs, Operations Research, vol.46, issue.3, pp.316-329, 1998. ,
DOI : 10.1287/opre.46.3.316
Adapting the savings algorithm for varying inter-customer travel times, Omega, vol.9, issue.6, pp.658-659, 1981. ,
DOI : 10.1016/0305-0483(81)90055-4
Adaptive large neighborhood search for the vehicle routing problem with time windows with a multigraph representation for the road network, 2017. ,
Empirical analysis for the VRPTW with a multigraph representation for the road network, Computers & Operations Research, vol.88, 2017. ,
DOI : 10.1016/j.cor.2017.06.024
A solution method for the multi-destination bi-objectives shortest path problem, CMP, vol.5, 2017. ,
Vehicle routing problems with road-network information: State of the art, Networks, vol.16, 2018. ,
DOI : 10.1016/j.trc.2008.01.004
A branch-and-price algorithm for the vehicle routing problem with time windows on a road-network graph, 2017. ,
Cut-First Branch-and-Price-Second for the Capacitated Arc-Routing Problem, Operations Research, vol.60, issue.5, pp.1167-1182, 2012. ,
DOI : 10.1287/opre.1120.1079
The vehicle routing problem: State of the art classification and review, Computers & Industrial Engineering, vol.99, pp.300-313, 2016. ,
DOI : 10.1016/j.cie.2015.12.007
Vehicle Routing Problem with Time Windows, Part I: Route Construction and Local Search Algorithms, Transportation Science, vol.39, issue.1, pp.104-118, 2005. ,
DOI : 10.1287/trsc.1030.0056
Vehicle routing problem with time windows, part ii: Metaheuristics. Transportation science, pp.119-139, 2005. ,
An empirical investigation of some bicriterion shortest path algorithms, European Journal of Operational Research, vol.43, issue.2, pp.216-224, 1989. ,
DOI : 10.1016/0377-2217(89)90215-4
A heuristic approach to long-haul freight transportation with multiple objective functions???, Omega, vol.37, issue.3, pp.600-614, 2009. ,
DOI : 10.1016/j.omega.2008.02.001
Vehicle Routing Problem with elementary shortest path based column generation, Computers & Operations Research, vol.33, issue.10, pp.2972-2990, 2006. ,
DOI : 10.1016/j.cor.2005.02.029
Time-dependent vehicle routing problem with waiting times, pp.197-200, 2015. ,
Scheduling of Vehicles from a Central Depot to a Number of Delivery Points, Operations Research, vol.12, issue.4, pp.568-581, 1964. ,
DOI : 10.1287/opre.12.4.568
A bicriterion shortest path algorithm, European Journal of Operational Research, vol.11, issue.4, pp.399-404, 1982. ,
Multicriteria path and tree problems: discussion on exact algorithms and applications, International Transactions in Operational Research, vol.19, issue.12, pp.63-98, 2012. ,
Arc routing: problems, methods, and applications, SIAM, vol.20, 2015. ,
DOI : 10.1137/1.9781611973679
Recent results on arc routing problems: An annotated bibliography. Networks Vrp with time windows, The vehicle routing problem, pp.50-69, 2001. ,
A tabu search heuristic for periodic and multi-depot vehicle routing problems, Networks, vol.30, issue.2, pp.105-119, 1997. ,
DOI : 10.1002/(SICI)1097-0037(199709)30:2<105::AID-NET5>3.0.CO;2-G
Analysis and Branch-and-Cut Algorithm for the Time-Dependent Travelling Salesman Problem, Transportation Science, vol.48, issue.1, pp.46-58, 2012. ,
DOI : 10.1287/trsc.1120.0449
Shortest paths in networks with vector weights, Journal of Optimization Theory and Applications, vol.46, issue.1, pp.79-86, 1985. ,
The traveling salesman problem on a graph and some related integer polyhedra, Mathematical Programming, vol.13, issue.1, pp.1-27, 1985. ,
DOI : 10.1007/BF01582008
Branch and Price for the Time-Dependent Vehicle Routing Problem with Time Windows, Transportation Science, vol.47, issue.3, pp.380-396, 2013. ,
DOI : 10.1287/trsc.1120.0445
The truck dispatching problem, Management science, vol.6, issue.1, pp.80-91, 1959. ,
Decomposition principle for linear programs, Operations research, vol.8, issue.1, pp.101-111, 1960. ,
Local search in constraint programming: Application to the vehicle routing problem, Proc. CP- 97 Workshop Indust. Constraint-Directed Scheduling, pp.1-15, 1997. ,
The tricriterion shortest path problem with at least two bottleneck objective functions, European Journal of Operational Research, vol.198, issue.2, pp.387-391, 2009. ,
Time-dependent route planning. Robust and online large-scale optimization, pp.207-230, 2009. ,
Speeding up Martins??? algorithm for multiple objective shortest path problems, 4OR, vol.16, issue.4, pp.323-348, 2013. ,
DOI : 10.1145/115234.115368
Column generation, 2006. ,
DOI : 10.1007/b135457
Tabu search, generalized kpath inequalities, and partial elementarity for the vehicle routing problem with time windows, 2006. ,
The vehicle routing problem with time windows Vehicle routing: Problems, methods, and applications, pp.119-159, 2014. ,
A New Optimization Algorithm for the Vehicle Routing Problem with Time Windows, Operations Research, vol.40, issue.2, pp.342-354, 1992. ,
DOI : 10.1287/opre.40.2.342
Time constrained routing and scheduling. Handbooks in operations research and management science, pp.35-139, 1995. ,
A note on two problems in connexion with graphs. Numerische mathematik, pp.269-271, 1959. ,
Time dependent vehicle routing problem with a multi ant colony system, European journal of operational research, vol.185, issue.3, pp.1174-1191, 2008. ,
Arc routing: theory, solutions and applications, 2012. ,
DOI : 10.1007/978-1-4615-4495-1
Stabilized column generation, Discrete Mathematics, vol.194, issue.1-3, pp.229-237, 1999. ,
DOI : 10.1016/S0012-365X(98)00213-1
A Road Timetable to aid vehicle routing and scheduling, Computers & Operations Research, vol.33, issue.12, pp.3508-3519, 2006. ,
DOI : 10.1016/j.cor.2005.03.029
Data-driven approaches for emissions-minimized paths in urban areas, Computers & Operations Research, vol.67, pp.34-47, 2016. ,
DOI : 10.1016/j.cor.2015.08.013
Vehicle routing to minimize time-dependent emissions in urban areas, European Journal of Operational Research, vol.251, issue.2, pp.478-494, 2016. ,
DOI : 10.1016/j.ejor.2015.11.034
A survey and annotated bibliography of multiobjective combinatorial optimization Arif Volkan Vural, and Arnold Reisman. The vehicle routing problem: A taxonomic review, OR-Spektrum Computers & Industrial Engineering, vol.22, issue.574, pp.425-4601472, 2000. ,
A tutorial on column generation and branch-and-price for vehicle routing problems, 4OR, vol.34, issue.1, pp.407-424, 2010. ,
DOI : 10.1007/BF01585555
URL : https://hal.archives-ouvertes.fr/emse-00505959
An exact algorithm for the elementary shortest path problem with resource constraints: Application to some vehicle routing problems, Networks, vol.35, issue.3, pp.216-229, 2004. ,
DOI : 10.1002/net.20033
Vehicle routing. Handbooks in operations research and management science, pp.1-33, 1995. ,
A cutting plane procedure for the travelling salesman problem on road networks, European Journal of Operational Research, vol.21, issue.3, pp.307-317, 1985. ,
DOI : 10.1016/0377-2217(85)90151-1
Time-Varying Travel Times in Vehicle Routing, Transportation Science, vol.38, issue.2, pp.160-173, 2004. ,
DOI : 10.1287/trsc.1030.0062
Algorithm 97: shortest path, Communications of the ACM, vol.5, issue.6, p.345, 1962. ,
Robust Branch-and-Cut-and-Price for the Capacitated Vehicle Routing Problem, Mathematical Programming, vol.44, issue.3, pp.491-511, 2006. ,
DOI : 10.1287/ijoc.7.1.1
Martins' algorithm revisited for multi-objective shortest path problems with a MaxMin cost function, 4OR, vol.4, issue.1, pp.47-59, 2006. ,
DOI : 10.1007/s10288-005-0074-x
URL : https://hal.archives-ouvertes.fr/hal-00462028
Vehicle routing problems with alternative paths: An application to on-demand transportation, European Journal of Operational Research, vol.204, issue.1, pp.62-75, 2010. ,
DOI : 10.1016/j.ejor.2009.10.002
URL : https://hal.archives-ouvertes.fr/hal-00109003
Time-dependent routing problems: A review, Computers & Operations Research, vol.64, pp.189-197, 2015. ,
DOI : 10.1016/j.cor.2015.06.001
A Tabu Search Heuristic for the Vehicle Routing Problem, Management Science, vol.40, issue.10, pp.1276-1290, 1994. ,
DOI : 10.1287/mnsc.40.10.1276
An ant colony optimization algorithm for the bi-objective shortest path problem, Applied Soft Computing, vol.10, issue.4, pp.1237-1246, 2010. ,
DOI : 10.1016/j.asoc.2009.09.014
The vehicle routing problem: latest advances and new challenges, 2008. ,
DOI : 10.1007/978-0-387-77778-8
Label Correcting Methods to Solve Multicriteria Shortest Path Problems, Journal of Optimization Theory and Applications, vol.20, issue.3, pp.589-613, 2001. ,
DOI : 10.1287/mnsc.20.5.814
Bicriterion Path Problems, Multiple criteria decision making theory and application, pp.109-127, 1980. ,
DOI : 10.1007/978-3-642-48782-8_9
A formal basis for the heuristic determination of minimum cost paths, IEEE transactions on Systems Science and Cybernetics, vol.4, issue.2, pp.100-107, 1968. ,
The transport geography of logistics and freight distribution, Journal of Transport Geography, vol.12, issue.3, pp.171-184, 2004. ,
DOI : 10.1016/j.jtrangeo.2003.12.004
Bi-level GA and GIS for Multi-objective TSP Route Planning, Transportation Planning and Technology, vol.6, issue.2, pp.105-124, 2006. ,
DOI : 10.1137/0801031
Time-dependent vehicle routing problem with path flexibility, Transportation Research Part B: Methodological, vol.95, pp.169-195, 2017. ,
DOI : 10.1016/j.trb.2016.10.013
A computational comparison of some bicriterion shortest path algorithms, Journal of the Chinese Institute of Industrial Engineers, vol.13, issue.2, pp.121-125, 1996. ,
Vehicle dispatching with time-dependent travel times, European Journal of Operational Research, vol.144, issue.2, pp.379-396, 2003. ,
DOI : 10.1016/S0377-2217(02)00147-9
Shortest Path Problems with Resource Constraints, Column Generation, vol.6730, pp.33-65, 2005. ,
DOI : 10.1007/0-387-25486-2_2
??? 3, INFORMS Journal on Computing, vol.18, issue.3, pp.391-406, 2006. ,
DOI : 10.1287/ijoc.1040.0117
Analysis of travel times and co2 emissions in time-dependent vehicle routing [77] Mads Jepsen, Bjørn Petersen, Simon Spoorendonk, and David Pisinger. A non-robust branch-and-cut-and-price algorithm for the vehicle routing problem with time windows, Oper. Res. Forthcoming, vol.21, issue.6, pp.1060-1074, 2006. ,
Formulations and exact algorithms for the vehicle routing problem with time windows, Computers & Operations Research, vol.35, issue.7, pp.2307-2330, 2008. ,
DOI : 10.1016/j.cor.2006.11.006
Lagrangian duality applied to the vehicle routing problem with time windows, Computers & Operations Research, vol.33, issue.5, pp.1464-1487, 2006. ,
DOI : 10.1016/j.cor.2004.11.002
Fastest paths in time-dependent networks for intelligent vehicle-highway systems application, Journal of Intelligent Transportation Systems, vol.1, issue.1, pp.1-11, 1993. ,
Stochastic vehicle routing with random travel times, Transportation Science, vol.37, issue.1, pp.69-82, 2003. ,
Seung Il Moon, and Choong Seon Hong. Finding realistic shortest path in road networks with lane changing and turn restriction, Network Operations and Management Symposium (APNOMS), 2016 18th Asia- Pacific, pp.1-4, 2016. ,
2-Path Cuts for the Vehicle Routing Problem with Time Windows, Transportation Science, vol.33, issue.1, pp.101-116, 1999. ,
DOI : 10.1287/trsc.33.1.101
Vehicle routing under time-dependent travel times: the impact of congestion avoidance, Computers & operations research, vol.39, issue.5, pp.910-918, 2012. ,
A tabu search heuristic for the heterogeneous vehicle routing problem on a multigraph, Transportation Research Part E: Logistics and Transportation Review, vol.86, pp.32-52, 2016. ,
A Vehicle Routing Problem Solution Considering Alternative Stop Points, Procedia - Social and Behavioral Sciences, vol.138, pp.584-591, 2014. ,
DOI : 10.1016/j.sbspro.2014.07.242
Fifty Years of Vehicle Routing, Transportation Science, vol.43, issue.4, pp.408-416, 2009. ,
DOI : 10.1287/trsc.1090.0301
The Vehicle Routing Problem with Stochastic Travel Times, Transportation Science, vol.26, issue.3, pp.161-170, 1992. ,
DOI : 10.1287/trsc.26.3.161
Pricing routines for vehicle routing with time windows on road networks, Computers & Operations Research, vol.51, pp.331-337, 2014. ,
Compact formulations of the steiner traveling salesman problem and related problems, European Journal of Operational Research, vol.228, issue.1, pp.83-92, 2013. ,
Exploiting sparsity in pricing routines for the capacitated arc routing problem, Computers & Operations Research, vol.36, issue.7, pp.2320-2327, 2009. ,
A Hybrid Link-Node Approach for Finding Shortest Paths in Road Networks with Turn Restrictions, Transactions in GIS, vol.198, issue.6, pp.915-929, 2015. ,
DOI : 10.1016/j.ejor.2008.08.018
Vehicle routing problems with time windows and stochastic travel and service times: Models and algorithm, International Journal of Production Economics, vol.125, issue.1, pp.137-145, 2010. ,
DOI : 10.1016/j.ijpe.2010.01.013
Reachability cuts for the vehicle routing problem with time windows, European Journal of Operational Research, vol.175, issue.1, pp.210-223, 2006. ,
DOI : 10.1016/j.ejor.2005.04.022
An algorithm for ranking paths that may contain cycles, European Journal of Operational Research, vol.18, issue.1, pp.123-130, 1984. ,
DOI : 10.1016/0377-2217(84)90269-8
On a multicriteria shortest path problem, European Journal of Operational Research, vol.16, issue.2, pp.236-245, 1984. ,
DOI : 10.1016/0377-2217(84)90077-8
Deviation algorithms for ranking shortest paths, International Journal of Foundations of Computer Science, vol.10, issue.03, pp.247-261, 1999. ,
The labeling algorithm for the multiobjective shortest path problem, 1999. ,
A parametric approach to solving bicriterion shortest path problems, European Journal of Operational Research, vol.53, issue.1, pp.81-92, 1991. ,
DOI : 10.1016/0377-2217(91)90094-C
On the cardinality of the Pareto set in bicriteria shortest path problems, Annals of Operations Research, vol.35, issue.1, pp.269-286, 2006. ,
DOI : 10.1007/s002910000046
Shortest-path and minimum-delay algorithms in networks with time-dependent edge-length, Journal of the ACM, vol.37, issue.3, pp.607-625, 1990. ,
DOI : 10.1145/79147.214078
A fundamental problem in vehicle routing, Networks, vol.21, issue.1, pp.35-64, 1974. ,
DOI : 10.1002/net.3230040105
Labeling methods for the general case of the multi-objective shortest path problem?a computational study, Computational Intelligence and Decision Making, pp.489-502, 2013. ,
Evolutionary algorithms for the multiobjective shortest path problem, World Academy of Science, Engineering and Technology International Journal of Mathematical, Computational, Physical, Electrical and Computer Engineering, vol.1, issue.1, pp.7-12, 2007. ,
50th Anniversary Invited Article???Goods Distribution with Electric Vehicles: Review and Research Perspectives, Transportation Science, vol.50, issue.1, pp.3-22, 2016. ,
DOI : 10.1287/trsc.2015.0646
A general heuristic for vehicle routing problems, Computers & Operations Research, vol.34, issue.8, pp.2403-2435, 2007. ,
DOI : 10.1016/j.cor.2005.09.012
A simple and effective evolutionary algorithm for the vehicle routing problem, Computers & Operations Research, vol.31, issue.12, pp.1985-2002, 2004. ,
DOI : 10.1016/S0305-0548(03)00158-8
Finding least fuel emission paths in a network with time-varying speeds, Networks, vol.154, issue.1, pp.96-106, 2014. ,
DOI : 10.1016/j.dam.2006.04.009
Fuel emissions optimization in vehicle routing problems with time-varying speeds, European Journal of Operational Research, vol.248, issue.3, pp.840-848, 2016. ,
DOI : 10.1016/j.ejor.2015.09.009
Speed-up of labelling algorithms for biobjective shortest path problems, Proceedings of the 45th annual conference of the ORSNZ, pp.313-322, 2010. ,
A comparison of solution strategies for biobjective shortest path problems, Computers & Operations Research, vol.36, issue.4, pp.1299-1331, 2009. ,
DOI : 10.1016/j.cor.2008.02.002
URL : https://hal.archives-ouvertes.fr/hal-00466664
The Edge Set Cost of the Vehicle Routing Problem with Time Windows, Transportation Science, vol.50, issue.2, pp.694-707, 2015. ,
DOI : 10.1287/trsc.2015.0620
Symmetry helps: Bounded bi-directional dynamic programming for the elementary shortest path problem with resource constraints, Discrete Optimization, vol.3, issue.3, pp.255-273, 2006. ,
DOI : 10.1016/j.disopt.2006.05.007
New dynamic programming algorithms for the resource constrained elementary shortest path problem, Networks, vol.3, issue.3, pp.155-170, 2008. ,
DOI : 10.1002/net.20212
The geography of transport systems, Routledge, 2009. ,
Branch and Cut and Price for the Pickup and Delivery Problem with Time Windows, Transportation Science, vol.43, issue.3, pp.267-286, 2009. ,
DOI : 10.1287/trsc.1090.0272
An Adaptive Large Neighborhood Search Heuristic for the Pickup and Delivery Problem with Time Windows, Transportation Science, vol.40, issue.4, pp.455-472, 2006. ,
DOI : 10.1287/trsc.1050.0135
Interior point stabilization for column generation, Operations Research Letters, vol.35, issue.5, pp.660-668, 2007. ,
DOI : 10.1016/j.orl.2006.11.004
URL : https://hal.archives-ouvertes.fr/hal-01311478
Tiger road networks for 9th dimacs implementation challenge?shortest path, 2005. ,
Some Considerations about Computational Complexity for Multi Objective Combinatorial Problems, Recent advances and historical development of vector optimization, pp.222-232, 1987. ,
DOI : 10.1007/978-3-642-46618-2_15
A time dependent pollution routing problem in multi-graph, International Journal of Engineering-Transactions B: Applications, vol.30, issue.2, p.234, 2017. ,
A time-dependent vehicle routing problem in multigraph with FIFO property, Journal of Manufacturing Systems, vol.35, issue.35, pp.37-45, 2015. ,
DOI : 10.1016/j.jmsy.2014.11.016
A new local search algorithm providing high quality solutions to vehicle routing problems. APES Group, 1997. ,
A classification of bicriterion shortest path (bsp) algorithms, Asia Pacific Journal of Operational Research, vol.17, issue.2, pp.199-212, 2000. ,
Algorithms for the vehicle routing and scheduling problems with time window constraints, Operations research, vol.35, issue.2, pp.254-265, 1987. ,
Multiobjective a, Journal of the ACM (JACM), vol.38, issue.4, pp.775-814, 1991. ,
Vehicle routing: problems, methods, and applications, 2014. ,
DOI : 10.1137/1.9781611973594
Models, relaxations and exact approaches for the capacitated vehicle routing problem, Discrete Applied Mathematics, vol.123, issue.1-3, pp.487-512, 2002. ,
DOI : 10.1016/S0166-218X(01)00351-1
Multiobjective optimization: Improved fptas for shortest paths and non-linear objectives with applications. Theory of Computing Systems, pp.162-186, 2009. ,
A multicriteria Pareto-optimal path algorithm, European Journal of Operational Research, vol.62, issue.2, pp.203-209, 1992. ,
DOI : 10.1016/0377-2217(92)90248-8
Heuristics for multi-attribute vehicle routing problems: A survey and synthesis, European Journal of Operational Research, vol.231, issue.1, pp.1-21, 2013. ,
DOI : 10.1016/j.ejor.2013.02.053
Two-stage particle swarm optimization algorithm for the time dependent alternative vehicle routing problem, Journal of Applied & Computational Mathematics, vol.3, issue.4, pp.1-9, 2014. ,
Finding a minimum cost path between a pair of nodes in a time-varying road network with a congestion charge, European Journal of Operational Research, vol.236, issue.3, pp.915-923, 2014. ,
DOI : 10.1016/j.ejor.2013.10.044
Minimum cost VRP with time-dependent speed data and congestion charge, Computers & Operations Research, vol.56, pp.41-50, 2015. ,
DOI : 10.1016/j.cor.2014.10.007
Modeling costs of turns in route planning, GeoInformatica, vol.6, issue.4, pp.345-361, 2002. ,
DOI : 10.1023/A:1020853410145
A decision support system for integrated hazardous materials routing and emergency response decisions. Transportation Research Part C: Emerging Technologies, pp.684-703, 2008. ,
