Handbook of mathematical functions. T. 55, pp.17-74, 1966. ,
Random matrix eigenvalue problems in structural dynamics, International Journal for Numerical Methods in Engineering, vol.11, issue.3, pp.562-591, 2007. ,
DOI : 10.1007/978-94-011-2430-0_1
Generic element formulation for modelling bolted lap joints, Mechanical Systems and Signal Processing 21.5, pp.2318-2334, 2007. ,
DOI : 10.1016/j.ymssp.2006.10.006
Efficient Computation of Eigenvector Sensitivities for Structural Dynamics, AIAA Journal, vol.3511, pp.1760-1766, 1997. ,
Handbook on dynamics of jointed structures. Rapp. tech. Sandia National Laboratories (cf, pp.20-41, 2009. ,
Computation of mixed partial derivatives of eigenvalues and eigenvectors by simultaneous iteration, Communications in Numerical Methods in Engineering, vol.23, issue.9, pp.641-649, 1999. ,
DOI : 10.1145/279232.279234
Calcul de sensibilité en dynamique, pp.95-96, 2009. ,
High Modal Density, Curve Veering, Localization: A Different Perspective On The Structural Response, Journal of Sound and Vibration, vol.161, issue.2, pp.358-363, 1993. ,
DOI : 10.1006/jsvi.1993.1078
The Damping of Structural Vibration by Controlled Interfacial Slip in Joints, Journal of Vibration Acoustics Stress and Reliability in Design, vol.105, issue.3, pp.369-373, 1983. ,
DOI : 10.1115/1.3269115
The damping of structural vibration by rotational slip in joints, Journal of Sound and Vibration, vol.53, issue.3, pp.333-340, 1977. ,
DOI : 10.1016/0022-460X(77)90418-7
Iterative methods for design sensitivity analysis, AIAA Journal, vol.97, issue.11, pp.1413-1415, 1988. ,
DOI : 10.2514/3.9793
Active washer for smart mechanical linkage, VIII ECCOMAS Thematic Conference on Smart Structures and Materials (cf, p.124, 2017. ,
Modeling of joints for the dynamic analysis of truss structures, DC : School of Engineering et Applied Science, vol.40, pp.33-36, 1987. ,
The encyclopedia of physics. T. p 498, p.62, 1990. ,
Stratégie de calcul de structures en présence de paramètres incertains. LMT (Cachan) Laboratoire de mécanique et technologie (cf, p.38, 2003. ,
A computational strategy for the random response of assemblies of structures, International Journal of Solids and Structures, vol.41, issue.22-23, pp.22-23, 2004. ,
DOI : 10.1016/j.ijsolstr.2004.05.003
ANALYSIS OF STRUCTURES WITH STOCHASTIC INTERFACES IN THE MEDIUM-FREQUENCY RANGE, Journal of Computational Acoustics, vol.10, issue.04, pp.711-729, 2005. ,
DOI : 10.1016/S0045-7825(03)00352-9
Modeling the dynamics of mechanical joints, Mechanical Systems and Signal Processing 25, pp.2801-2826, 2011. ,
DOI : 10.1016/j.ymssp.2011.01.010
Identification of non-linear joint parameters by using frequency response residuals, International Conference on Noise and Vibration Engineering, pp.3121-3140, 2004. ,
Contrôle vibratoire des structures assemblées, Thèse de doct. Cotutelle entre l'Ecole Nationale des Inénieurs de Sfax et l'Ecole Centrale Paris (cf, pp.50-153, 2017. ,
Forced vibration of mechanical systems with hysteresis, Abstract of proceedings of the fourth conference on nonlinear oscillations, p.30, 1967. ,
The Mechanics of Jointed Structures. Recent Research and Open Challenges for Developing Predictive Models for Structural Dynamics, p.20, 2017. ,
Prédiction par essais virtuels de l'amortissement dans les structures spatiales, Thèse de doct., 1 vol. (117 p.) (Cf, pp.33-158, 2009. ,
An Alternating Frequency/Time Domain Method for Calculating the Steady-State Response of Nonlinear Dynamic Systems, Journal of Applied Mechanics, vol.56, issue.1, pp.149-154, 1989. ,
DOI : 10.1115/1.3176036
URL : https://hal.archives-ouvertes.fr/hal-01333697
A new model for control of systems with friction, IEEE Transactions on Automatic Control, vol.40, issue.3, pp.419-425, 1995. ,
DOI : 10.1109/9.376053
Design sensitivity analysis for repeated eigenvalues in structural design, AIAA Journal, vol.26, issue.12, pp.2347-2350, 1993. ,
DOI : 10.2514/3.48905
Experiments and numerical simulations of nonlinear vibration responses of an assembly with friction joints ??? Application on a test structure named ???Harmony???, Mechanical Systems and Signal Processing 70-71, pp.1097-1116, 2016. ,
DOI : 10.1016/j.ymssp.2015.08.024
The eigenvalue problem for structural systems with statistical properties, AIAA Journal, vol.74, pp.642-648, 1969. ,
Identification of nonlinear structural elements by force-state mapping, AIAA Journal, vol.241, issue.33, pp.155-162, 1986. ,
Force-state mapping identification of nonlinear joints, AIAA Journal, vol.9, issue.2, pp.1003-1010, 1987. ,
DOI : 10.2514/3.9213
Estimating the energy dissipated in a bolted spacecraft at resonance, Computers & Structures, vol.84, issue.5-6, pp.5-6, 2006. ,
DOI : 10.1016/j.compstruc.2005.09.024
A solid friction model, p.29, 1968. ,
DOI : 10.21236/ADA041920
Eigenvector derivatives with repeated eigenvalues, AIAA Journal, vol.27, issue.4, pp.486-491, 1989. ,
DOI : 10.2514/3.7211
Propagation d'incertitudes à travers des modèles dynamiques d'assemblages de structures mécaniques, Thèse de doct. École Normale Supérieure de Cachan (cf, pp.38-41, 2016. ,
Nonlinear vibrations of a mechanical system with non-regular nonlinearities and uncertainties, Communications in Nonlinear Science and Numerical Simulation, vol.18, issue.11, pp.3250-3270, 2013. ,
DOI : 10.1016/j.cnsns.2013.03.005
URL : https://hal.archives-ouvertes.fr/hal-00831862
On the quantification of eigenvalue curve veering : a veering index, Journal of applied mechanics 78, pp.41007-41008, 2011. ,
Placement and dimension optimization of shunted piezoelectric patches for vibration reduction, Journal of Sound and Vibration, vol.331, issue.14, pp.3286-3303, 2012. ,
DOI : 10.1016/j.jsv.2012.03.002
Nonlinear system identification of frictional effects in a beam with a bolted joint connection, Mechanical Systems and Signal Processing 39.1-2, pp.245-264, 2013. ,
DOI : 10.1016/j.ymssp.2013.03.003
Energy dissipation through joints: theory and experiments, Computers & Structures, vol.75, issue.4, pp.347-359, 2000. ,
DOI : 10.1016/S0045-7949(99)00096-6
Modal testing -Theory and practice. T. ch 3, Mechanical engineering research studies (cf, pp.158-168, 1984. ,
Dynamic Response Analysis of Structures with Nonlinear Components Imperial college of science, technology et medecine, Thèse de doct, pp.34-40, 1998. ,
Damping and Vibration of Beams With Various Types of Frictional Support Conditions, Journal of Vibration and Acoustics, vol.1143, pp.289-296, 1992. ,
Identification and modeling of jointed structures for dynamic analysis, pp.27-28, 2014. ,
URL : https://hal.archives-ouvertes.fr/tel-01081475
Rates of change of eigenvalues and eigenvectors., AIAA Journal, vol.2, issue.12, pp.2426-2429, 1968. ,
DOI : 10.2514/3.4587
The Derivatives of Repeated Eigenvalues and Their Associated Eigenvectors, Journal of Vibration and Acoustics, vol.31, issue.3, pp.390-397, 1996. ,
DOI : 10.1115/1.2888195
Calculation of second and higher order eigenvector derivatives, Journal of Guidance, Control, and Dynamics, vol.18, issue.4, pp.919-921, 1995. ,
DOI : 10.2514/3.21170
Modeling and simulation strategy of aeronautical assemblies in an uncertain context " . Theses. École normale supérieure de Cachan -ENS Cachan (cf, p.41, 2011. ,
URL : https://hal.archives-ouvertes.fr/tel-00675741
Nonlinear dynamics of structures assembled by bolted joints, Acta Mechanica, vol.32, issue.1-4, pp.169-181, 1997. ,
DOI : 10.1007/BF01177306
Active Damping of Space Structures by Contact Pressure Control in Joints???, Mechanics of Structures and Machines 26, pp.81-100, 1998. ,
DOI : 10.1007/978-3-642-50995-7_16
FRICTION CONTROL FOR VIBRATION SUPPRESSION, Mechanical Systems and Signal Processing 14, pp.139-150, 2000. ,
DOI : 10.1006/mssp.1999.1285
The Role of Friction in Mechanical Joints, Applied Mechanics Reviews, vol.54, issue.2, pp.93-106, 2001. ,
DOI : 10.1115/1.3097294
Modal properties of a space-frame with localized system uncertainties, 8th ASCE Specialty Conference of Probabilistic Mechanics and Structural Reliability, p.41, 2000. ,
Eigenvalue analysis of a random frame, pp.341-380, 2002. ,
Polynomial Chaos in Stochastic Finite Elements, Journal of Applied Mechanics, vol.57, issue.1, pp.197-202, 1990. ,
DOI : 10.1115/1.2888303
Stochastic Finite Elements : A Spectral Approach, p.39, 2003. ,
DOI : 10.1007/978-1-4612-3094-6
Caractérisation robuste du comportement vibratoire d'une structure en présence de paramètres incertains, Actes du 22ème Congrès Français de Mécanique, CFM 2015, p.156, 2015. ,
Réduction de Modèle Stochastique pour la caractérisation robuste du comportement vibratoire des structures assemblées, Actes du 13ème Colloque National en Calcul des Structures, pp.2017-156, 2017. ,
A simplified method for random vibration analysis of structures with random parameters, Journal of Physics : Conference Series 744.1, pp.12174-156, 2016. ,
DOI : 10.1088/1742-6596/744/1/012174
Stochastic buckling of a joined wing, Stochastic Dynamics Conference, p.40, 2003. ,
Analysis of slip damping with reference to turbine blade vibration, Journal of Applied Mechanics, vol.23, pp.421-448, 1956. ,
Modélisation et calcul des assemblages vissés. Généralités " . In : Techniques de l'ingénieur Assemblages et fixations mécaniques base documentaire : TIB177DUO.ref. article : bm5560 (cf, p.49, 2007. ,
Experimental identification of nonlinear dynamic properties of built-up structures, Journal of Sound and Vibration, vol.327, issue.1-2, pp.183-196, 2009. ,
DOI : 10.1016/j.jsv.2009.06.008
URL : https://hal.archives-ouvertes.fr/hal-00441023
The fundamentals of modal testing : application note 243-3. Application note : Hewlett-Packard Company, pp.55-56, 1986. ,
Derivatives of eigenvectors of locally modified structures, International Journal for Numerical Methods in Engineering, vol.6, issue.11, pp.1769-1773, 1977. ,
DOI : 10.1002/nme.1620111110
Uncertainties and dynamic problems of bolted joints and other fasteners, Journal of Sound and Vibration, vol.279, issue.3-5, pp.3-5, 2005. ,
DOI : 10.1016/j.jsv.2003.11.064
A Distributed-Element Model for Hysteresis and Its Steady-State Dynamic Response, Journal of Applied Mechanics, vol.33, issue.4, pp.393-900, 1966. ,
DOI : 10.1115/1.3625199
Identification of nonlinear bolted lap-joint parameters by force-state mapping, International Journal of Solids and Structures, vol.44, issue.25-26, pp.25-26, 2007. ,
DOI : 10.1016/j.ijsolstr.2007.06.003
Exact nth derivatives of eigenvalues and eigenvectors, Journal of Guidance, Control, and Dynamics, vol.13, issue.2, pp.136-144, 1994. ,
DOI : 10.1002/nme.1620280704
Caractérisation robuste de liaisons amortissantes avec dispositifs piézoélectriques pour la réduction de vibrations de structures, Theses. Conservatoire national des arts et metiers -CNAM (cf, pp.41-137, 2013. ,
Non-linear joint parameter identification by applying the force-state mapping technique in the frequency domain, Mechanical Systems and Signal Processing 8.5, pp.519-529, 1994. ,
DOI : 10.1006/mssp.1994.1037
Lack of knowledge in structural model validation, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.37-40, pp.4697-4710, 0195. ,
DOI : 10.1016/j.cma.2005.10.017
Natural frequency and mode shape sensitivites of damped systems : Part I, Distinct natural frequencies, In : Journal of Sound and Vibration, vol.2233, pp.399-412, 1999. ,
An efficient algebraic method for the computation of natural frequency and mode shape sensitivities???Part I. Distinct natural frequencies, Computers & Structures, vol.62, issue.3, pp.429-435, 1997. ,
DOI : 10.1016/S0045-7949(96)00206-4
Dynamic Characterization of the Joints in a Beam Structure by Using Spectral Element Method, Shock and Vibration 8.6 (cf, pp.35-40, 2001. ,
DOI : 10.1155/2001/254020
A practical algorithm for the efficient computation of eigenvector sensitivities, Computer Methods in Applied Mechanics and Engineering, vol.130, issue.3-4, pp.3-4, 1996. ,
DOI : 10.1016/0045-7825(95)00929-9
The damped dynamic vibration absorbers: revisited and new result, Journal of Sound and Vibration, vol.284, issue.3-5, pp.284-1181, 2005. ,
DOI : 10.1016/j.jsv.2004.08.002
Shape design sensitivity analysis of eigenvalues using ???exact??? numerical differentiation of finite element matrices, Structural optimization 8.1, pp.52-59, 1994. ,
DOI : 10.1007/BF01742934
Statistics of Energy Flows in Spring-Coupled One-Dimensional Subsystems, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.346, issue.1681, pp.525-542, 1681. ,
DOI : 10.1098/rsta.1994.0034
Développement et évaluation de l'hypothèse de stabilité modal pour la variabilité du comportement vibratoire des structures minces modélisées par élélements finis, Thèse de doct, p.84, 2008. ,
Eigenspannungen und verfestigung beim messing, Proceedings of the 2nd International Congress of Applied Mechanics, pp.332-335, 1926. ,
Sensitivity analysis and optimization of thin laminated structures with a nonsmooth eigenvalue based criterion, Structural optimization 14, pp.219-224, 1997. ,
DOI : 10.1007/978-3-642-83051-8_2
Segment-to-segment contact elements for modelling joint interfaces in finite element analysis, Mechanical Systems and Signal Processing 21, pp.724-734, 2007. ,
DOI : 10.1016/j.ymssp.2005.10.006
Measurement of Bolt Pre-load in Torqued Composite Joints, Strain, vol.32, issue.3, pp.109-112, 2005. ,
DOI : 10.1111/j.1475-1305.2005.00201.x
Instantaneous Energy Dissipation Rate in a Lap Joint???Uniform Clamping Pressure, Journal of Applied Mechanics, vol.35, issue.1, pp.123-128, 1968. ,
DOI : 10.1115/1.3601124
A stochastic Iwan-type model for joint behavior variability modeling, Journal of Sound and Vibration, vol.349, issue.43, pp.289-298, 2015. ,
DOI : 10.1016/j.jsv.2015.03.032
Calculation of eigenvector derivatives for structures with repeated eigenvalues, AIAA Journal, vol.267, pp.867-871, 1988. ,
Compliance of Elastic Bodies in Contact, Journal of Applied Mechanics, vol.16, pp.259-268, 1949. ,
DOI : 10.1007/978-1-4613-8865-4_24
An approximate solution scheme for the algebraic random eigenvalue problem, Journal of Sound and Vibration, vol.260, issue.1, pp.45-65, 2003. ,
DOI : 10.1016/S0022-460X(02)00899-4
Study of the effect of bolt diameter and washer on damping in layered and jointed structures, Journal of Sound and Vibration, vol.290, issue.3-5, pp.3-5, 2006. ,
DOI : 10.1016/j.jsv.2005.05.027
Simplified calculation of eigenvector derivatives, AIAA Journal, vol.149, pp.1201-1205, 1976. ,
Machinery's Handbook. Sous la dir. de H. H. Ryffel, 2016. ,
Efficient computation of mode-shape derivatives for large dynamic systems, AIAA Journal, vol.2510, pp.1386-1390, 1987. ,
Simplified models of bolted joints under harmonic loading, Computers & Structures, vol.84, issue.1-2, pp.25-33, 2005. ,
DOI : 10.1016/j.compstruc.2005.09.007
Sensitivity Analysis and optimization of Multiple eigenvaues in structural design problems, Structural optimization 8.4, pp.207-227, 1994. ,
Evaluation of the Bolt Axial Force in High Strength Bolted Joints by Using Strain Gauges, p.50, 2011. ,
Parallel solution methods for stochastic finite element analysis using Monte Carlo simulation, Computer Methods in Applied Mechanics and Engineering, vol.168, issue.1-4, pp.305-320, 1999. ,
DOI : 10.1016/S0045-7825(98)00147-9
Comments on curve veering in eigenvalue problems, Journal of Sound and Vibration, vol.106, issue.3, pp.451-463, 1986. ,
DOI : 10.1016/0022-460X(86)90191-4
Dissipation de l'énergie mécanique dans les assemblages : effet du frottement en sollicitation dynamique, Thèse de doct, pp.25-47, 2012. ,
Dynamic Damping in Joints: Multiscale Model Taking into Account Defects in a Nominally Plane Surface, International Journal of Applied Mechanics, vol.331, issue.1, pp.1650097-157, 2016. ,
DOI : 10.1006/jsvi.1996.0572
URL : https://hal.archives-ouvertes.fr/hal-01589621
Derivatives of eigenvalues and eigenvectors in non-self-adjoint systems., AIAA Journal, vol.98, issue.2, pp.250-251, 1973. ,
DOI : 10.2514/3.50271
Identification of Properties of Nonlinear Joints Using Dynamic Test Data, Journal of Vibration and Acoustics, vol.172, issue.2, pp.324-330, 1998. ,
DOI : 10.1115/1.2893834
Influence of Misfit Mechanisms on Jointed Structure Response, tech. Sandia National Laboratories (SNL-NM), Albuquerque, NM (United States) (cf, p.62, 2007. ,
Derivatives of eigenvalues and eigenvectors, AIAA Journal, vol.3, issue.2, pp.943-944, 1970. ,
DOI : 10.2514/3.5008
Modélisation vibro-acoustique de structures sandwich munies de matériaux viscoélastiques, Thèse de doct. Conservatoire National des Arts et Métiers (cf, p.59, 2013. ,
Uncertainty Assessment of Large Finite Element Systems, Lecture Notes in Applied and Computational Mechanics. T. 24, pp.59-61, 2005. ,
An initial overview of Iwan modeling for mechanical Joints, pp.30-31, 2001. ,
DOI : 10.2172/780307
Relationships among certain joint constitutive models. SAND2001-0811,Unlimited Release. Sandia National Laboratories (cf, pp.30-40, 2004. ,
DOI : 10.2172/919196
URL : https://www.osti.gov/servlets/purl/919196
A four-parameter Iwan model for lap-type joints, Proposed for publication in Journal of Applied Mechanics. (Cf, pp.26-33, 2003. ,
Random Eigenvalue Problems in Structural Analysis, AIAA Journal, vol.104, pp.456-462, 1972. ,
A three parameter constitutive model for a joint which exhibits a power law relationship between energy loss and relative displacement, Proceeding of the Shock and Vibration Symposium. Destin, FL. (cf, pp.30-40, 2001. ,
Stochastic modeling of uncertainties in computational structural dynamics -Recent theoretical advances, In : Journal of Sound and Vibration, vol.33210, issue.124, pp.2379-2395, 2013. ,
Stochastic Models of Uncertainties in Computational Mechanics, p.125, 2012. ,
DOI : 10.1061/9780784412237
URL : https://hal.archives-ouvertes.fr/hal-00749201
Simulation of dynamics of beam structures with bolted joints using adjusted Iwan beam elements, Journal of Sound and Vibration, vol.273, issue.1-2, pp.1-2, 2004. ,
DOI : 10.1016/S0022-460X(03)00499-1
Effect of Pressure Distribution on Energy Dissipation in a Mechanical Lap Joint, AIAA Journal, vol.23, issue.2, pp.420-425, 2005. ,
DOI : 10.1115/1.3607751
Stochastic Finite Element Methods and Reliability : A State-of-the-Art Report, 2000. ,
Performance of piezoelectric shunts for vibration reduction, Smart Materials and Structures 21.1, pp.15008-15032, 2012. ,
DOI : 10.1088/0964-1726/21/1/015008
URL : https://hal.archives-ouvertes.fr/hal-01082925
The status of engineering knowledge concerning the damping of builtup structures, Journal of Sound and Vibration, vol.261, issue.136, pp.141-154, 1973. ,
A friction viscoplasticity without a yield surface, Archive Mech, vol.234, pp.517-551, 1970. ,
A case study to quantify prediction bounds caused by model-form uncertainty of a portal frame, Mechanical Systems and Signal Processing 50-51, pp.11-26, 2015. ,
DOI : 10.1016/j.ymssp.2014.05.001
Modal approaches for the stochastic finite element analysis of structures with material and geometric uncertainties, Computer Methods in Applied Mechanics and Engineering, vol.192, issue.33-34, pp.3705-3729, 2003. ,
DOI : 10.1016/S0045-7825(03)00371-2
Method of random vibration of hysteretic systems, Journal of the Engineering Mechanics Division 102, pp.249-263, 1976. ,
The Homogeneous Chaos, American Journal of Mathematics, vol.60, issue.4, pp.897-936, 1938. ,
DOI : 10.2307/2371268
Modeling uncertainty in flow simulations via generalized polynomial chaos, Journal of Computational Physics, vol.1871, pp.137-167, 2003. ,
Fuzzy sets as a basis for a theory of possibility " . In : Fuzzy Sets and Systems 100, pp.9-34, 1999. ,
A review of robust optimal design and its application in dynamics, Computers & structures 83, pp.315-326, 2005. ,
DOI : 10.1016/j.compstruc.2004.10.007
