Déterminisme génétique de la résistance au flétrissement bactérien chez l'aubergine et applications en sélection variétale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Genetic determinism of the resistance in the bacterial withering to the eggplant and the applications in varietal selection
Eggplant cultivation is confronted by the bacterial wilt disease caused by the Ralstonia solanacearum species complex. Breeding resistant cultivars is the most effective strategy to control the disease but is limited by the pathogen’s extensive genetic diversity. A major QTL (ERs1) was previously mapped in a recombinant inbred lines (RIL) population from the cross of susceptible (S) MM738 × resistant (R) AG91-25 lines. ERs1 was originally found to control 3 strains from phylotype I, while being ineffective against the strain PSS4 from the same phylotype. The objectives of this thesis was to (i) clarify the position of ERs1 and define its spectrum of action, (ii) found other QTLs, promptly to control virulent strains on AG91-25 and (iii) introgress some of the QTLs into two S cultivars. For this purpose, the new doubled haploid (DH) populations MM152 (R) × MM738 (S) and EG203 (R) × MM738 (S) were created. The RIL population was phenotyped with 4 additional RSSC strains belonging to phylotypes I, IIA, IIB and III and the DH populations were phenotyped with virulent strains PSS4 and R3598. QTL mapping confirmed the existence of ERs1 (renamed EBWR9), defined its position on chromosome (chr) 9 and validated its specific control of 3 phylotype I strains. EBWR2 and EBWR14, 2 broad-spectrum resistance QTLs, were detected on chr 2 and 5. QTL analysis reveals a polygenic system of resistance in EG203. The transfer of resistance into 2 local cultivars was initiated and allowed the introgression of EBWR9 and EBWR2 QTLs through a backcross scheme. These results offer perspectives to breed broad-spectrum R cultivars.
La culture de l’aubergine est confrontée au flétrissement bactérien, maladie causée par le complexe d’espèces Ralstonia solanacearum. La résistance variétale est la méthode la plus efficace pour contrôler cette maladie. Un QTL majeur (ERs1) a précédemment été cartographié dans une population de lignées recombinantes (RIL) issue du croisement aubergine sensible (S) MM738 × aubergine résistante (R) AG91-25. Initialement, ERs1 a été détecté avec 3 souches du phylotype I, alors qu’il est contourné par la souche PSS4 de ce même phylotype. Les objectifs de cette thèse étaient (i) de préciser la position d’ERs1 et de définir son spectre d’action, (ii) d’identifier d’autres QTLs contrôlant les souches virulentes sur AG91-25, et (iii) d’introgresser certains de ces QTLs dans des cultivars S. Pour cela, 2 populations d'haploïdes doublés (HD), MM152 (R) × MM738 (S) et EG203 (R) × MM738 (S), ont été créées. La population RIL a été phénotypée avec 4 souches supplémentaires appartenant aux phylotypes I, IIA, IIB et III, tandis que les populations HD l’ont été avec les souches virulentes PSS4 et R3598. Les analyses de cartographie génétique ont confirmé l’existence d’ERs1 (renommé EBWR9), défini sa position sur le chromosome (chr) 9 et validé son contrôle spécifique de 3 souches du phylotype I. EBWR2 et EBWR14, 2 autres QTLs à large spectre, ont été détectés sur les chr 2 et 5. Les analyses QTL ont mis en évidence un système de résistance de type polygénique chez EG203. Le transfert de la résistance dans 2 cultivars locaux a été initié et a permis l’introgression d’EBWR9 et d’EBWR2. Ces résultats ouvrent des perspectives quant à la création de variétés à large spectre de résistance.
2017lare0010_SSalgon.pdf (35.5 Mo) Télécharger le fichier
tel-01798810 , version 1 (24-05-2018)
  • HAL Id : tel-01798810 , version 1
Sylvia Salgon. Déterminisme génétique de la résistance au flétrissement bactérien chez l'aubergine et applications en sélection variétale. Sciences agricoles. Université de la Réunion, 2017. Français. ⟨NNT : 2017LARE0010⟩. ⟨tel-01798810⟩
569 Consultations
261 Téléchargements
