Approche CRONE multivariable : développement et application à la régulation de bancs d'essais moteur haute dynamique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
CRONE multivariable approach : development and application for high dynamic test-bench control
The work presented in this Thesis is part of the CRONE (robust control with fractional integration order) multivariable methodology development. It deals with the simplification of the robust multivariable control system implementation with application to the control of high dynamic engine test-benches, including those developed by the D2T company. The first chapter introduces different kind of test-benches and gives a general idea about how those systems work while explaining their problems. While the first part of chapter II presents a simple method for test-benches modeling which then allows their simulation, the second part is dedicated to their frequency-domain system identification. The defined identification procedure is applied to a test-bench equipped with a Diesel engine. The third chapter presents the CRONE multivariable methodology and different developments to simplify its use. Reflecting these developments, the developed CRONE multivariable toolbox is used to design a control system for a test-bench consists of two asynchronous motors. The fourth chapter is dedicated to validate the presented work by applying these developments to a high dynamic test-bench with a spark ignition engine. This chapter presents the various software tools developed to simplify the implementation to D2T products of the CRONE full MIMO methodology.
Le travail de cette thèse s'inscrit dans le cadre du développement de la méthodologie CRONE (Commande Robuste d'Ordre Non Entier) multivariable. Il porte plus précisément sur la simplification de sa mise en oeuvre pour la synthèse de régulateurs multivariables robustes, avec une application au contrôle de bancs d'essais moteur haute dynamique, notamment ceux développés par l'entreprise D2T. Le premier chapitre présente les différents types de bancs d'essais, leur fonctionnement et leur problématique. Le deuxième chapitre présente tout d'abord une modélisation physique simple des bancs d'essais qui en permet ensuite leur simulation, puis est dédié à leur identification fréquentielle avec une application à un banc d'essais équipé d'un moteur Diesel. Le troisième chapitre présente la méthodologie CRONE multivariable et différents développements permettant d'en simplifier la mise en oeuvre notamment grâce à l'optimisation d'un nouveau paramètre. Illustrant ces développements, la boite à outils CRONE multivariable qui a été développée est alors utilisée pour la synthèse de la loi de commande d'une maquette de banc d'essais constituée de deux moteurs asynchrones. Finalement, le quatrième chapitre est dédié à la validation des développements présentés par leur application à un banc d'essais haute dynamique équipé d'un moteur Essence. Ce chapitre présente également les différents outils logiciel développés pour faciliter l'intégration de la méthodologie CRONE full MIMO aux produits D2T.
LAMARA_ABDERRAHIM_2015.pdf (7.07 Mo) Télécharger le fichier
tel-01800760 , version 1 (28-05-2018)
  • HAL Id : tel-01800760 , version 1
Abderrahim Lamara. Approche CRONE multivariable : développement et application à la régulation de bancs d'essais moteur haute dynamique. Physique [physics]. Université de Bordeaux, 2015. Français. ⟨NNT : 2015BORD0069⟩. ⟨tel-01800760⟩
235 Consultations
530 Téléchargements
