NMR Spectroscopy, from Strategies commonly used in Clinic to future Techniques
Spectroscopie RMN, des stratégies couramment utilisées en clinique vers les techniques de demain.
Parkinson's disease is a neurodegenerative disorder characterized by motor troubles such as akinesia, rigidity and tremor. The loss of dopaminergic neurons from the nigro-striatal pathway will lead to biochemical changes in the putamen. Especially, works on electrophysiology, micro dialysis and magnetic resonance spectroscopy (MRS) suggests hyperactivity of the glutamatergic cortico-striatal pathway associated with glial microenvironment changes. These observations suggest a modification of the glutamate-glutamine cycle occurring between neurons and astrocytes in response to neuronal loss.In this thesis, two approaches have been developed in order to follow by MRS the metabolic changes occuring in Parkinson's disease. In particular, we want to follow the changes in glutamate-glutamine cycle inside the putamen.in a first study, a a 1H MRS approach was used to assess the metabolic changes inside the putamen of Parkinson's disease without or under dopaminergic treatment. In this study, changes in N-acetylaspartate, creatine and myo-inositol were observed in Parkinsonian patients, but no change in glutamatergic metabolism was observed. This could be due to the lack of sensitivity of the technique to differentiate glutamate and glutamine pools.Thus, we chose to use a new 13C carbon MRS approach in order to follow dynamically in vivo the glutamate-glutamine cycle inside the brain: dynamic nuclear polarization (DNP). Thanks to the high sensitivity of this technique, it is now possible to follow metabolic pathways in vivo in real time. The implementation of DNP was assessed under a control group of animals. This technique offers a new promising tool for the analysis of this flow under pathologic conditions.To conclude, the MRS strategies for clinical diagnostic strategies remain, at present, poorly sensitive for the study of glutamate-glutamine cycle in vivo in humans. The development of DNP opens the door to a new approach for real-time monitoring of this cerebral metabolism Even if DNP is mainly used in preclinical studies at present, the development of new clinical systems could lead to its emergence as a new diagnostic strategy in clinical imaging.
La maladie de Parkinson est une maladie neurodégénérative du système cerveau central conduisant à l'apparition des troubles moteurs caractéristiques de la maladie : akinésie, rigidité et tremblement de repos. La perte des neurones dopaminergiques de la voie nigro-striée va conduire à des modifications biochimiques au niveau du putamen. Notamment, les travaux réalisés en électrophysiologie, microdialyse et spectroscopie par résonance magnétique (SRM) suggèrent une hyperactivité de la voie glutamatergique cortico-striatale associée à un changement du microenvironnement glial au niveau du putamen. Ces observations conduisent à penser à une adaptation du cycle glutamate-glutamine ayant lieu entre les neurones et les astrocytes en réponse à la perte neuronale. Ainsi, dans ce travail de thèse, deux approches ont été développées afin de suivre par SRM les changement métaboliques impliqués dans la pathologie parkinsonienne, notamment les variations des concentrations en glutamate et glutamine dans le putamen. Une première approche de la quantification des métabolites cérébraux par spectroscopie du 1H, technique couramment utilisée en clinique, a été utilisée pour suivre l'évolution des métabolites d'intérêt chez des patients parkinsoniens à jeun ou suite à la prise d'un traitement dopaminergique. Si cette étude a révélé des changements de concentration en N-acetylaspartate, créatine et myoinositol chez les patiens parkinsoniens, aucun changement du métabolisme glutamatergique n'a pu être observé par cette technique, peut-être à cause d'un manque de sensibilité de la technique pour discriminer les pools de glutamate et de glutamine. De ce fait, une nouvelle approche de SRM du Carbone 13C a été développée pour le suivi du cycle glutamate-glutamine in vivo, c'est la polarisation dynamique nucléaire (PDN). Grâce à la haute sensibilité de cette technique, il est désormais possible de suivre des voies métaboliques in vivo en temps réel. La mise en place et l'optimisation de la PDN pour le suivi du cycle glutamate-glutamine a été un des objectifs au cours de ce projet de thèse. Validée sur un groupe d'animaux contrôle, cette technique offre un avenir prometteur pour l'analyse de ce flux dans les pathologies neurodégénératives. En conclusion, les stratégies diagnostiques en clinique par SRM du 1H restent, à l'heure actuelle, peu sensibles pour l'étude des modifications du cycle glutamate-glutamine in vivo chez l'homme. Les développements technologiques réalisés au cours de ce travail de thèse notamment avec la PDN du 13C laissent entrevoir une nouvelle approche pour le suivi en temps réel de ce métabolisme cérébral. Si la PDN est principalement utilisée dans des études précliniques, la disponibilité de nouveaux systèmes cliniques pourrait permettre son avènement en tant que nouvelle stratégie de diagnostic en imagerie clinique.
