Degradation of dioxins or benzo[a]pyrene by a tripartite approach : chemical oxydation/biological oxidation by saprotrophic telluric fungi / starch functionalities with surfactant properties
Dégradation des dioxines ou du benz[a]pyrène par une approche tripartite : oxydation chimique / oxydation biologique par des champignons telluriques saprotrophes / amidon difonctionnalisé aux propriétés surfactantes
This thesis work deals with the development of bioremediation techniques for contaminated soils by Persistent Organic Pollutants (POPs) such as : Polycyclic Aromatic Hydrocarbons and dioxins (PCDD/F). The degradation of POPs has two main obstacles to efficient biological treatments by fungi : the low bioavailability of POPs and the difficulty of initiating the oxydation of molecules as stable as others. To overcome these technological barriers, we propose to couple a mild chemical oxidation to biological oxidation by saprotrophic telluric fungi and to use starch to improve the spatial proximity between the pollutant and oxidizing reagents. The first part of this study is to functionalize native potato starch by 1,4-butane sultone and 2-octenyl-1-succinic anhydride according to different synthesis conditions. In comparison with native starch, one of the processed products, P9*, has very interesting surfactant properties for our study. Indeed, P9* increases starch apparent aqueous solubility by a factor of 65 (22.60 g.L⁻¹) and stimulates 33-fold benzo[a]pyrene (BaP) aqueous solubilization. For the second part, the use of a simplified study system where the fungus is cultivated in mineral medium under axenic conditions allowed us to determine the best parameters (fungal strainsn type and dose of chemical oxydant) for the development of a POPs degradation method in the laboratory. Comparative studies of BaP degradation are therefore carried out in vitro by different processes of chemical (Fenton's reagent) and/or biologial oxidation. The coupling of the two processes leads to a BaP degradation of 40.0%. Moreover, the BaP encapsulation by starch nanospheres P9* allows a pollutant degradation of 94.6% by the Fenton reagent. Two fungal strains (Penicillium brasilianum and Funsarium solani) are then used for the degradation lab experiment in historically PCDD/F contaminated soil microcosms. the inoculation of the endogene strain P.brasilianum in presence of cardboard chips as a bulking agent led to a decrease in PCDD/F toxicity of 40.5% after only two months of incubation compared to the controm soil. This PhD work draws new perspectives for remediation techniques of contaminated soils by POPs that are cost-effective and environmentally friendly.
Ce travail de thèse est axé sur l'élaboration de techniques de bioremédiation des sols contaminés par les Polluants Organiques Persistants (POP) en particulier sur deux familles de polluants : les Hydrocarbures Aromatiques Polycyliques et les dioxines (PCDD/F). La dégradation des POP présente deux obstacles majeurs à l'efficacité des traitements biologiques par voie fongique : la faible biodisponibilité des POP et la difficulté d'amorcer l'oxydation de molécules aussi stables chimiquement. Afin de lever ces verrous technologiques, nous proposons de coupler une oxydation chimique douce à l'oxydation biologique par les champignons telluriques saprotrophes et d'utiliser l'amidon pour améliorer la proximité spatiale entre le polluant et les réactifs d'oxydation. La première partie de ce travail de thèse consiste à fonctionnaliser de l'amidon de pomme de terre par la 1,4-butane sultone et l'anhydride 2-octén-1-ylsuccinique selon différentes conditions de synthèses. En comparaison avec l'amidon natif, un des produits obtenus, P9*, possède des propriétés surfactantes très intéressantes pour notre étude. En effet, P9* augmente la solubilité aqueuse de l'amidon par un facteur de 35 (22,60 g.L⁻¹) et stimulent 33 fois la solubilisation aqueuse du benzo[a]pyrène (BaP). Pour la seconde partie, l'utilisation d'un système d'étude simplifié où le champignon est cultivé en milieu minéral en conditions axéniques nous a permis de déterminer les paramètres (souche fongique, type et dose d'oxydant chimique) optimaux pour l'élaboration d'une méthode de dégradation des POP au laboratoire. Des études comparatives de dégradation du BaP sont donc réalisées in vitro par différents processus d'oxydation chimique (réaction de Fenton) et/ou biologique. Le couplage des deux procédés conduit à une dégradation du PaP de 40,0%. De plus, l'encapsulation du BaP par les nanosphères d'amidon P9* permet une dégradation du polluant de 64,6% par le réactif de Fenton. Deux souches fongiques (Penicillium brasilianum et Fusarium solani) sont ensuite utilisées pour des essais de dégradation conduits au laboratoire en microcosmes de sols historiquement contaminés par les PCDD/F. L'inoculation de la souche endogène P. brasilianum en présence de copeaux de carton comme agent structurant a conduit à une diminution de la toxicité des PCDD/F de 40,5% après seulement 2 mois d'incubation par rapport au sol témoin. Ce travail de thèse ouvre ainsi de nouvelles perspectives de techniques de remédiation des sols pollués par les POP à faible coût économique et respectueuses de l'environnement.
