Topological Floquet states, artificial gauge fields in strongly correlated quantum fluids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
États de Floquet topologiques, champs de jauge artificiels dans des fluides quantiques fortement corrélés
In this thesis we study the topological aspects of condensed matter physics, that received a revolutionary development in the last decades. Topological states of matter are protected against perturbations and disorder, making them very promising in the context of quantum information. The interplay between topology and interactions in such systems is however far from being well understood, while the experimental realization is challenging. Thus, in this work we investigate analytically such strongly correlated states of matter and explore new protocols to probe experimentally their properties. In order to do this, we use various analytical and numerical techniques. First, we analyze the properties of an interacting bosonic version of the celebrated Haldane model – the model for the quantum anomalous Hall effect. We propose its quantum circuit implementation based on the application of periodic time-dependent perturbations – Floquet engineering. Continuing these ideas, we study the interacting bosonic version of the Kane-Mele model – the first model of a topological insulator. This model has a very rich phase diagram with an emergence of an effective frustrated magnetic model and a variety of symmetry broken spin states in the strongly interacting regime. Ultra-cold atoms or quantum circuits implementation of both Haldane and Kane-Mele bosonic models would allow for experimental probes of the exotic states we observed. Second, in order to deepen the perspectives of quantum circuit simulations of topological phases we analyze the strong coupling limit of the Su-Schrieffer-Heeger model and we test new experimental probes of its topology associated with the Zak phase. We also work on the out-of-equilibrium protocols to study bulk spectral properties of quantum systems and quantum phase transitions using a purification scheme which could be implemented both numerically and experimentally.
Dans cette thèse nous abordons des aspects topologiques de la matière condensée. Les états topologiques sont insensibles à un large spectre des perturbations externes et au désordre – une propriété indispensable dans le domaine d'information quantique. L’effet des interactions dans des systèmes topologiques est pourtant loin d’être bien maîtrisé à ce jour. Dans ce travail, nous étudions la corrélation entre la description topologique et l'effet des interactions. Afin d'accomplir notre but, nous utilisons des méthodes analytiques et numériques. Nous nous intéressons aussi à des sondes expérimentales qui peuvent être utilisées pour vérifier nos prédictions théoriques. Tout d’abord, nous étudions la version bosonique en interactions du modèle de Haldane – le modèle célèbre qui décrit l’effet Hall anomal. Nous proposons son implémentation expérimentale dans des circuits quantiques, basée sur l’application de perturbation périodique dépendantes du temps – méthodologie qui s’appelle l’ingénierie de Floquet. En poursuivant ces idées, nous étudions la version bosonique du modèle de Kane-Mele d’un isolant topologique. Ce modèle possède un diagramme de phase très riche. En particulier, lorsque les interactions sont fortes, nous observons l’apparition d’un modèle de magnétisme frustrée présentant une variété d'états exotiques. La mise en œuvre de ces modèles dans des réseaux d'atomes ultra-froids ou des circuits quantiques permettra de sonder expérimentalement les propriétés exotiques que nous avons observées. Ensuite, nous abordons d’une manière plus détaillée la réalisation expérimentale des modèles topologiques dans des circuits quantiques, en considérant le cas particulier du modèle de Su-Schrieffer-Heeger en couplage fort. Nous testons aussi des nouvelles sondes qui peuvent être utilisées afin de mesurer la phase de Zak et en déduire la topologie du système. Finalement, nous nous intéressons aux sondes hors d’équilibre et des méthodes pour tester les propriétés spectrales de systèmes quantiques, en utilisant l’approche de purification, pertinent pour le numérique et les expériences.
76949_PLEKHANOV_2018_archivage.pdf (9.19 Mo) Télécharger le fichier
tel-01874629 , version 1 (14-09-2018)
  • HAL Id : tel-01874629 , version 1
Kirill Plekhanov. Topological Floquet states, artificial gauge fields in strongly correlated quantum fluids. Condensed Matter [cond-mat]. Université Paris-Saclay, 2018. English. ⟨NNT : 2018SACLS264⟩. ⟨tel-01874629⟩
586 Consultations
680 Téléchargements
