Analyse interculturelle de la valeur de santé chez les adolescents atteints d'asthme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Cross-cultural analysis of health value among adolescents with asthma
This thesis aims to help better understand the role of values, attitudes and coping strategies in health behaviors alongside with anxiety/depression symptoms among Russian and French adolescents with asthma. Mediation analysis was employed to study the associations between values (health value, value of exciting life) and health behaviors (preventive and risk behaviors) through affective (explicit and implicit) and cognitive (explicit) attitudes among adolescents suffering from asthma and healthy adolescents (N = 200). Mediation analysis has also been used to reveal the associations between values and anxiety/depression symptoms through coping strategies. Qualitative study based on anthropological research methodology were applied to study the phenomenology of asthma and health among Russian and French adolescents (N = 20). The study confirmed that values are associated with health behaviors through affective and cognitive attitudes. In valuing health or exciting life, adolescents use coping strategies specific to asthma which influence the symptoms of anxiety and depression. Inclusion of the above values in educational programs makes it possible to promote healthy behaviors and ameliorate the quality of life among adolescents with asthma.
Cette thèse a pour objectif de contribuer à la compréhension de rôle des valeurs, des attitudes et des stratégies de coping dans le comportement lié à la santé et les symptômes de l'anxiété et de la dépression des adolescents russes et français atteints d'asthme. L'analyse de médiation a étudié les associations entre les valeurs (la valeur de santé, la valeur de la vie excitante) et le comportement (le comportement préventif et le comportement à risque) à travers les facteurs médiateurs : les attitudes affectives (explicites et implicites), cognitives (explicites) chez les adolescents atteints d'asthme et en bonne santé (N = 200). L'analyse de médiation a aussi étudié les associations entre les valeurs et les symptômes de l'anxiété et de la dépression à travers les stratégies de coping. L'étude qualitative, basée sur une méthodologie de recherche anthropologique, a exploré la phénoménologie de l'asthme et de la santé chez les adolescents russes et français (N = 20). Les valeurs sont associées avec le comportement lié à la santé à travers les attitudes affectives et cognitives. En valorisant la santé ou la vie excitante, les adolescents utilisent des stratégies de coping spécifique à l'asthme qui influent sur les symptômes de l'anxiété et de la dépression. En incluant les valeurs dans les programmes éducatifs il est possible de favoriser le comportement préventif et améliorer la qualité de vie chez les adolescents atteints d'asthme.
va_Iosifyan_Marina.pdf (1.86 Mo) Télécharger le fichier
tel-01876750 , version 1 (18-09-2018)
  • HAL Id : tel-01876750 , version 1
Marina Iosifyan. Analyse interculturelle de la valeur de santé chez les adolescents atteints d'asthme. Psychologie et comportements. Université Sorbonne Paris Cité, 2015. Français. ⟨NNT : 2015USPCB223⟩. ⟨tel-01876750⟩
166 Consultations
138 Téléchargements
