Radio Resource Management in LTE Networks : Load Balancing in Heterogeneous Cellular Networks
Gestion des ressources radio dans les réseaux LTE
High demands on mobile networks provide a fresh opportunity to migrate towardsmulti-tier deployments, denoted as heterogeneous network (HetNet), involving a mix of cell types and radio access technologies working together seamlessly. In this context, network optimisation functionalities such as load balancing have to be properly engineered so that HetNet benefit are fully exploited. This dissertation aims to develop tractable frameworks to model and analyze load balancing dynamics while incorporating the heterogeneous nature of cellular networks. In this context we investigate and analyze a class of load balancingstrategies, namely adaptive handover based load balancing strategies. These latter were firstly studied under the general heading of stochastic networks using independent and homogeneous Poisson point processes based network model. We propose a baseline model to characterize rate coverage and handover signalling in K-tier HetNet with a general maximum power based cell association and adaptive handover strategies. Tiers differ in terms of deployment density and cells characteristics (i.e. transmit power, bandwidth, and path loss exponent). One of the main outcomes is demonstrating the impact of offloading traffic from macro- to small-tier. This impact was studied in terms of rate coverage and HO signalling. Results show that enhancement in rate coverage is penalized by HO signalling overhead. Then appropriate algorithms of LB based adaptive HO are designed and their performance is evaluated by means of extensive system level simulations. These latter are conducted in 3GPP defined scenarios, including representation of mobility procedures in both connectedstate. Simulation results show that the proposed LB algorithms ensure performance enhancement in terms of network throughput, packet loss ratio, fairness and HO signalling.
Face à la croissance exponentielle des réseaux mobiles très haut débit, les opérateurs de téléphonie mobile se sont lancé dans le déploiement des réseaux dits hiérarchiques (HetNet), composés par des sous-réseaux avec des caractéristiques divergentes en termes de type des cellules déployées et des technologies d’accès radio utilisées. Avec ce caractère hétérogène des réseaux cellulaire, l’exploitation de ces derniers devienne de plus en plus compliquée et coûteuse impliquant le déploiement, la configuration et la reconfiguration de stations de base et d’équipements de différentes caractéristiques. Ainsi, l’intégration dans les réseaux HetNet de fonctionnalités d’auto-configuration automatisant et simplifiant l’exploitation des réseaux deviennent une demande forte des opérateurs. Cette thèse a pour objectif l’étude et le développement de solutions de gestion dynamique de l’équilibrage de charges entre les différentes couches composant un même HetNet, pour une expérience utilisateur (QoE) améliorée. Dans ce contexte, une classe des algorithmes d’équilibrage de charges dite ‘équilibrage de charges par adaptation dynamique des paramètres de la procédure de handover’ est étudiée. Pour commencer, nous développons un modèle théorique basé sur des solutions et des outils de la géométrie stochastique et incorporant le caractère hétérogène des réseaux cellulaires. Ensuite nous exploitons ce modèle pour introduire des algorithmes d’adaptation des paramètres de handover basés sur la maximisation de la puissance reçue et du rapport signal/brouillage plus bruit (SINR). Nous exploitons ces résultats pour implémenter et étudier, par simulation à évènements discrets, des algorithmes d’équilibrage de charges dans le contexte des réseaux LTE HetNet auto-organisés basés sur les spécifications 3GPP. Ces travaux soulignent l’importance de l’équilibrage de charges afin de booster les performances des réseaux cellulaires en termes de débit global transmis, perte de paquets de données et utilisation optimisée des ressources radio.
