Contribution à l'analyse CEM globale de structures et de circuits. Application aux antennes Vivaldi en présence d'un système non linéaire pour la récupération d'énergie : une approche FDTD - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Contribution to the global EMC analysis of structures and circuits : application to Vivaldi antennas integrated with a nonlinear system for Energy Harvesting : FDTD approach
Electronic systems are integrated into most objects that we use every day, also in different key sectors such as, automotive, railway, spacial, defense and consumer electronics... Conventional feeding techniques remain difficult to envisage in certain applications because they are limited in their autonomy energy, and they require periodic replacements and their recycling is expensive. In this mind, the wireless power transfer is a very interesting solution, less expensive and aesthetic. This solution needs to pick up the RF power transmitted through the free space by a Rectenna and convert it to a DC voltage, to feed one or several wireless devices or to increase the operating life of batteries.The high operating frequencies makes the microwave circuits faster. Frequency analysis can’t answer a number of questions in these circuits. The introduction of the temporal analysis becomes necessary to solve and answer all the problems encountered. In fact, we are interested in two complementary approaches:• Signal integrity, which represents the malfunction of the circuits due to the distortion of the signals• ElectroMagnetic Compatibility, which is the result of the congestion of the electronic components in the circuits.• The first approach is based on component models and can perfectly predict signal quality during placement and routing of electronic boards. On the other hand, it will be difficult to highlight the causes of the abnormal behavior of the circuit. The second approach, is complementary of the first one, which is the analysis by the electromagnetic compatibility, who will allow to cover the causes of the problems such as cross talk, radiation and defined the susceptibility of this systems to work correctly.The working method adopted in this thesis consists in first identifying the various problems. Then propose solutions via existing calculation codes (FDTD, FEM, MoM ...) who can be developed or via the software such as Spice, Matlab, EMPro, ADS …Key words: Wireless power transfer, UWB systems, numerical methods, Rectenna systems, RF/DC converter, EMC analysis.
Les systèmes électroniques sont au cœur de notre vie quotidienne, ils sont intégrés dans la plupart des objets que nous utilisons chaque jour, et dans des secteurs clés comme l’aéronautique, l’automobile, le spatial, l’électronique grand public... Les techniques d’alimentation classiques (pile ou batterie) restent difficiles à envisager dans certaines applications car, elles sont limitées en autonomie, elles nécessitent des remplacements périodiques et leur recyclage est coûteux. Afin de détourner ces contraintes, le concept de la transmission d’énergie sans fil se présente comme une alternative aux systèmes d’alimentation classiques. La récupération d'énergie électromagnétique a beaucoup attiré l'attention puisque la puissance RF est largement diffusée à partir de nombreuses ressources électromagnétiques fiables. De plus, les circuits électroniques et notamment microondes deviennent de plus en plus rapides à cause des fréquences de travail de plus en plus élevées. L’analyse fréquentielle seule ne peut répondre à un certain nombre d’interrogations dans ces circuits. Une analyse purement temporelle devient nécessaire pour résoudre et répondre à toutes les problématiques. Parmi les problèmes posés dans les circuits microondes, on s’intéresse à deux approches totalement complémentaires:• L’Intégrité du Signal qui représente le dysfonctionnement des circuits du à la distorsion des signaux. • La Compatibilité ElectroMagnétique qui est le résultat de l’encombrement des composants électroniques dans les circuits. La première approche se base sur les modèles de composants et peut prédire parfaitement la qualité des signaux pendant le placement et le routage des cartes électroniques. En revanche, il sera très difficile de mettre en évidence les causes du comportement anormal du circuit en question. La deuxième approche complémentaire de la première, et qui est l’analyse par la compatibilité électromagnétique permettra de couvrir les causes du problème tels que diaphonie (Cross Talk), rayonnement et susceptibilité des systèmes dans le but de corriger le circuit pour qu’il fonctionne correctement.La méthode de travail adoptée dans cette thèse consiste dans un premier temps à identifier les différents problèmes. Ensuite proposer des solutions via des codes de calcul existants (FDTD, FEM, MoM…) et qu’on pourra développer (2D) ou bien via des logiciels adaptés tels que Spice, Matlab, EMPro, ADS…..etc.
2018-ALAOUI-ABDALLAOUI-ISMAIL-VO.pdf (5.55 Mo) Télécharger le fichier
tel-01878778 , version 1 (21-09-2018)
  • HAL Id : tel-01878778 , version 1
Ismail Alaoui Abdallaoui. Contribution à l'analyse CEM globale de structures et de circuits. Application aux antennes Vivaldi en présence d'un système non linéaire pour la récupération d'énergie : une approche FDTD. Micro et nanotechnologies/Microélectronique. Normandie Université, 2018. Français. ⟨NNT : 2018NORMC213⟩. ⟨tel-01878778⟩
289 Consultations
360 Téléchargements
