Keyboard Acoustic Emanations, 2004 IEEE Symposium on Security and Privacy, pp.3-11, 2004. ,
DOI : 10.1109/secpri.2004.1301311
SipHash : A Fast ShortInput PRF, pp.489-508 ,
DOI : 10.1007/978-3-642-34931-7_28
URL : http://cr.yp.to/siphash/siphash-20120918.pdf
Exhaustive search for small dimension recursive MDS diffusion layers for block ciphers and hash functions, Proceedings of the 2013 IEEE International Symposium on Information Theory, pp.1551-1555, 2013. ,
DOI : 10.1109/isit.2013.6620487
URL : https://hal.archives-ouvertes.fr/hal-00823082
Origins of cryptology : The Arab contributions, Cryptologia 16, vol.2, pp.97-126, 1992. ,
Block Ciphers-Focus on the Linear Layer (feat. PRIDE)". In : CRYPTO 2014, Part I. Sous la dir, LNCS, pp.57-76, 2014. ,
DOI : 10.1007/978-3-662-44371-2_4
Ciphers for MPC and FHE, EUROCRYPT 2015, Part I. Sous la dir. d'Elisabeth Oswald et Marc Fischlin. T. 9056, pp.430-454, 2015. ,
DOI : 10.1007/978-3-662-46800-5_17
Strict Evaluation of the Maximum Average of Differential Probability and the Maximum Average of Linear Probability, IEICE TRANSACTIONS on Fundamentals of Electronics, pp.2-8, 1997. ,
Midori : A Block Cipher for Low Energy, ASIACRYPT 2015, Part II. Sous la dir. de Tetsu Iwata et Jung Hee Cheon. T. 9453, pp.411-436, 2015. ,
DOI : 10.1007/978-3-662-48800-3_17
Whirlwind : a new cryptographic hash function, Designs, Codes and Cryptography, vol.56, pp.1573-7586, 2010. ,
DOI : 10.1007/s10623-010-9391-y
AtomicAES : A Compact Implementation of the AES Encryption/Decryption Core, INDOCRYPT 2016. Sous la dir. d'Orr Dunkelman et Somitra Kumar Sanadhya. T. 10095, pp.173-190, 2016. ,
MAC Reforgeability, FSE 2009. Sous la dir. d'Orr Dunkelman. T. 5665, pp.345-362, 2009. ,
DOI : 10.1007/978-3-642-03317-9_21
URL : https://link.springer.com/content/pdf/10.1007%2F978-3-642-03317-9_21.pdf
Keying Hash Functions for Message Authentication, pp.1-15, 1996. ,
DOI : 10.1007/3-540-68697-5_1
URL : https://link.springer.com/content/pdf/10.1007%2F3-540-68697-5_1.pdf
The MICKEY Stream Ciphers, New Stream Cipher Designs-The eSTREAM Finalists, pp.978-981, 2008. ,
DOI : 10.1007/978-3-540-68351-3_15
On Almost Perfect Nonlinear Permutations, EUROCRYPT'93. Sous la dir. de Tor Helleseth. T. 765, pp.65-76, 1994. ,
DOI : 10.1007/3-540-48285-7_7
URL : https://link.springer.com/content/pdf/10.1007%2F3-540-48285-7_7.pdf
Bryan Weeks et Louis Wingers. The SIMON and SPECK Families of Lightweight Block Ciphers, Cryptology ePrint Archive, 2013. ,
The SKINNY Family of Block Ciphers and Its Low-Latency Variant MANTIS, CRYPTO 2016, Part II. Sous la dir. de Matthew Robshaw et Jonathan Katz. T. 9815, pp.123-153, 2016. ,
DOI : 10.1007/978-3-662-53008-5_5
Matt Robshaw et Yannick Seurin, p.113, 2009. ,
Victor Lomné et Thomas Peyrin. Implementing Lightweight Block Ciphers on x86 Architectures, Cryptology ePrint Archive, 2013. ,
On Almost Perfect Nonlinear Functions Over F n 2, IEEE Trans. Information Theory, vol.52, issue.9, pp.4160-4170, 2006. ,
Sosemanuk, a Fast Software-Oriented Stream Cipher, New Stream Cipher Designs-The eSTREAM Finalists. Sous la dir, pp.978-981, 2008. ,
DOI : 10.1007/978-3-540-68351-3_9
URL : https://hal.archives-ouvertes.fr/hal-00328825
Stronger Security Bounds for Wegman-Carter-Shoup Authenticators, pp.164-180, 2005. ,
, The Poly1305-AES Message-Authentication Code". In : FSE 2005. Sous la dir. d'Henri Gilbert et Helena Handschuh. T. 3557, pp.32-49, 2005.
The Salsa20 Family of Stream Ciphers, New Stream Cipher Designs-The eSTREAM Finalists, pp.978-981, 2008. ,
A tool for obtaining tighter security analyses of pseudorandom function based constructions, with applications to PRP to PRF conversion. Cryptology ePrint Archive, 1999. ,
A Toolbox for Cryptanalysis : Linear and Affine Equivalence Algorithms, EUROCRYPT 2003. Sous la dir. d'Eli Biham. T. 2656, pp.33-50, 2003. ,
DOI : 10.1007/3-540-39200-9_3
URL : https://link.springer.com/content/pdf/10.1007%2F3-540-39200-9_3.pdf
Lightweight Multiplication in GFp2 n q with Applications to MDS Matrices, CRYPTO 2016, Part I. Sous la dir. de Matthew Robshaw et Jonathan Katz. T. 9814, pp.625-653, 2016. ,
DOI : 10.1007/978-3-662-53018-4_23
On the classification of APN functions up to dimension five, Des. Codes Cryptography, vol.49, pp.273-288, 2008. ,
UMAC : Fast and Secure Message Authentication, CRYPTO'99. Sous la dir. de Michael J. Wiener. T. 1666, pp.216-233, 1999. ,
DOI : 10.1007/3-540-48405-1_14
URL : https://link.springer.com/content/pdf/10.1007%2F3-540-48405-1_14.pdf
Message authentication codes, 2000. ,
Logic Minimization Techniques with Applications to Cryptology, Journal of Cryptology, vol.26, pp.280-312 ,
DOI : 10.1007/s00145-012-9124-7
Links between Truncated Differential and Multidimensional Linear Properties of Block Ciphers and Underlying Attack Complexities, EUROCRYPT 2014. Sous la dir. de Phong Q. Nguyen et Elisabeth Oswald. T. 8441, pp.165-182, 2014. ,
DOI : 10.1007/978-3-642-55220-5_10
URL : https://link.springer.com/content/pdf/10.1007%2F978-3-642-55220-5_10.pdf
PRESENT : An Ultra-Lightweight Block Cipher, CHES 2007. Sous la dir. de Pascal Paillier et Ingrid Verbauwhede. T. 4727, pp.450-466, 2007. ,
DOI : 10.1007/978-3-540-74735-2_31
URL : https://link.springer.com/content/pdf/10.1007%2F978-3-540-74735-2_31.pdf
PRINCE-A Low-Latency Block Cipher for Pervasive Computing Applications-Extended Abstract, ASIACRYPT 2012. Sous la dir. de Xiaoyun Wang et Kazue Sako. T. 7658. LNCS. Springer, Heidelberg, pp.208-225 ,
DOI : 10.1007/978-3-642-34961-4_14
URL : https://link.springer.com/content/pdf/10.1007%2F978-3-642-34961-4_14.pdf
Strong 8-bit Sboxes with Efficient Masking in Hardware, CHES 2016. Sous la dir. de Benedikt Gierlichs et Axel Y. Poschmann. T. 9813, pp.171-193, 2016. ,
DOI : 10.1007/978-3-662-53140-2_9
A New Combinational Logic Minimization Technique with Applications to Cryptology, SEA. T. 6049. Lecture Notes in Computer Science, pp.178-189, 2010. ,
DOI : 10.1007/978-3-642-13193-6_16
URL : https://eprint.iacr.org/2009/191.pdf
The Whirlpool hashing function, First open NESSIE Workshop, p.14, 2000. ,
CBC MACs for Arbitrary-Length Messages : The Three-Key Constructions, CRYPTO 2000. Sous la dir. de Mihir Bellare. T. 1880, pp.197-215, 2000. ,
A Block-Cipher Mode of Operation for Parallelizable Message Authentication, EUROCRYPT 2002. Sous la dir. de Lars R. Knudsen. T. 2332, pp.384-397, 2002. ,
Determining the Nonlinearity of a New Family of APN Functions, Applied Algebra, Algebraic Algorithms and Error-Correcting Codes-AAECC-17. T. 4851, pp.72-79, 2007. ,
An APN permutation in dimension six, Finite Fields : Theory and ApplicationsFQ9. T. 518. Contemporary Mathematics, pp.33-42, 2010. ,
On the solution of algebraic equations over finite fields, Inform. Contr, vol.12, pp.553-564, 1967. ,
Differential Cryptanalysis of DES-like Cryptosystems, pp.2-21, 1991. ,
Differential Fault Analysis of Secret Key Cryptosystems, pp.513-525, 1997. ,
The Rabbit Stream Cipher, New Stream Cipher Designs-The eSTREAM Finalists, pp.978-981, 2008. ,
Weight distributions of the cosets of the (32, 6) Reed-Muller code, IEEE Transactions on Information Theory, vol.18, pp.203-207, 1972. ,
Propagation Characteristics and Correlation-Immunity of Highly Nonlinear Boolean Functions, EUROCRYPT 2000. Sous la dir. de Bart Preneel. T. 1807, pp.507-522, 2000. ,
On cryptographic properties of the cosets of R(1, m), IEEE Trans. Information Theory, vol.47, pp.1494-1513, 2001. ,
Stream Ciphers : A Practical Solution for Efficient Homomorphic-Ciphertext Compression, FSE 2016. Sous la dir. de Thomas Peyrin. T. 9783, pp.313-333, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01280479
Analysis and design of secret-key ciphers". Habilitation à diriger des recherches, 2006. ,
URL : https://hal.archives-ouvertes.fr/tel-00095980
Chap. Boolean functions for cryptography and error correcting codes, Boolean Models and Methods in Mathematics, Computer Science, and Engineering, pp.257-397, 2010. ,
Binary m-sequences with three-valued crosscorrelation : A proof of Welch's conjecture, IEEE Trans. Information Theory, vol.46, pp.4-9, 2000. ,
Codes, Bent Functions and Permutations Suitable For DES-like Cryptosystems, Des. Codes Cryptography, vol.15, pp.125-156, 1998. ,
Some new three-valued crosscorrelation functions for binary m-sequences, IEEE Trans. Information Theory, vol.42, pp.1238-1240, 1996. ,
Construction of Lightweight S-Boxes Using Feistel and MISTY Structures, SAC 2015. Sous la dir. d'Orr Dunkelman et Liam Keliher. T. 9566, pp.373-393, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01205187
A Generalisation of Dillon's APN Permutation With the Best Known Differential and Nonlinear Properties for All Fields of Size 2 4k+2, IEEE Trans. Information Theory, vol.63, pp.7575-7591, 2017. ,
Towards Sound Approaches to Counteract Power-Analysis Attacks, CRYPTO'99. Sous la dir. de Michael J. Wiener. T. 1666, pp.398-412, 1999. ,
Batch Fully Homomorphic Encryption over the Integers, EUROCRYPT 2013. Sous la dir. de Thomas Johansson et Phong Q. Nguyen. T. 7881, pp.315-335, 2013. ,
New Constructions of MACs from (Tweakable) Block Ciphers, IACR Trans. Symm. Cryptol, pp.2519-173, 2017. ,
Boolean functions with restricted input and their robustness ; application to the FLIP cipher, IACR Trans. Symm. Cryptol, vol.2017, pp.2519-173, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01633506
Sous la dir, New Stream Cipher Designs-The eSTREAM Finalists, pp.978-981, 2008. ,
Attacks Against Filter Generators Exploiting Monomial Mappings, FSE 2016. Sous la dir. de Thomas Peyrin. T. 9783, pp.78-98, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01401009
EWCDM : An Efficient, BeyondBirthday Secure, Nonce-Misuse Resistant MAC, CRYPTO 2016, Part I. Sous la dir. de Matthew Robshaw et Jonathan Katz. T. 9814, pp.121-149, 2016. ,
DOI : 10.1007/978-3-662-53018-4_5
, Links Between Differential and Linear Cryptanalysis". In : EUROCRYPT'94. Sous la dir. d'Alfredo De Santis. T. 950, pp.356-365, 1995.
DOI : 10.1007/bfb0053450
URL : https://link.springer.com/content/pdf/10.1007%2FBFb0053450.pdf
Universal classes of hash functions, Proceedings of the ninth annual ACM symposium on Theory of computing, pp.106-112, 1977. ,
DOI : 10.1016/0022-0000(79)90044-8
URL : https://doi.org/10.1016/0022-0000(79)90044-8
, Nessie proposal : NOEKEON". In : First Open NESSIE Workshop, 2000.
Single Key Variant of PMAC_Plus, IACR Trans. Symm. Cryptol, vol.4, pp.2519-173, 2017. ,
, NBS FIPS PUB, vol.46, 1977.
New Directions in Cryptography, IEEE Transactions on Information Theory, vol.22, pp.644-654, 1976. ,
Privacy and authentication : An introduction to cryptography, Proceedings of the IEEE, vol.67, pp.397-427, 1979. ,
Homomorphic AES Evaluation using NTRU, IACR Cryptology ePrint Archive, p.39, 2014. ,
Information-theoretic Indistinguishability via the Chi-squared Method. Cryptology ePrint Archive, 2017. ,
Polynomial hash functions are reliable, Automata, Languages and Programming. Sous la dir. de W. Kuich, pp.235-246, 1992. ,
A Note on Two Problems in Connexion with Graphs, Numerische Mathematik, vol.1, pp.269-271, 1959. ,
Felics-fair evaluation of lightweight cryptographic systems, NIST Workshop on Lightweight Cryptography. T. 128, 2015. ,
Lightweight MACs from Universal Hash Functions, En soumission, 2018. ,
MDS Matrices with Lightweight Circuits, IACR Transactions on Symmetric Cryptology, vol.2, pp.2519-173, 2018. ,
Cryptanalysis of the FLIP Family of Stream Ciphers, CRYPTO 2016, Part I. Sous la dir. de Matthew Robshaw et Jonathan Katz. T. 9814, pp.457-475, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01404145
Almost Perfect Nonlinear Power Functions on GF(2 n ) : A New Case for n Divisible by 5, Finite Fields and Applications. Sous la dir. de Dieter Jungnickel et Harald Niederreiter, pp.978-981, 2001. ,
One-to-One Highly Nonlinear Power Functions on GF(2 n ), In : Appl. Algebra Eng. Commun. Comput, vol.9, pp.139-152, 1998. ,
Almost Perfect Nonlinear Power Functions on GF(2n) : The Niho Case, Inf. Comput, vol.151, pp.57-72, 1999. ,
DOI : 10.1006/inco.1998.2764
URL : https://doi.org/10.1006/inco.1998.2764
, Bibliographie, vol.201
Almost Perfect Nonlinear Power Functions on GF(2 n ) : The Welch Case, IEEE Trans. Information Theory, vol.45, pp.1271-1275, 1999. ,
Toward Practical Homomorphic Evaluation of Block Ciphers Using Prince, Financial Cryptography and Data Security-FC 2014 Workshops, BITCOIN and WAHC, pp.208-220, 2014. ,
The Wide Trail Design Strategy, 8th IMA International Conference on Cryptography and Coding. Sous la dir. de Bahram Honary. T. 2260, pp.222-238, 2001. ,
The Design of Rijndael : AES-The Advanced Encryption Standard. Information Security and Cryptography, pp.3-540, 2002. ,
Message verification and transmission error detection by block chaining. US Patent 4,074, p.66, 1978. ,
SNOW-a new stream cipher, PROCEEDINGS OF FIRST OPEN NESSIE WORKSHOP, 2000. ,
Differentially 4-Uniform Permutations with the Best Known Nonlinearity from Butterflies, IACR Trans. Symm. Cryptol. 2017, vol.2, pp.2519-173, 2017. ,
, NIST FIPS PUB, vol.113, 1985.
A Statistical Attack of the FEAL-8 Cryptosystem, pp.22-33, 1991. ,
Codes which detect deception, Bell Labs Technical Journal, vol.53, pp.405-424, 1974. ,
KLEIN : A New Family of Lightweight Block Ciphers, RFID. Security and Privacy-7th International Workshop, pp.1-18, 2011. ,
Maximal recursive sequences with 3-valued recursive crosscorrelation functions, Corresp.)" In : IEEE Trans. Information Theory, vol.14, pp.154-156, 1968. ,
The PHOTON Family of Lightweight Hash Functions, CRYPTO 2011. Sous la dir. de Phillip Rogaway. T. 6841, pp.222-239, 2011. ,
, SCREAM & iSCREAM Side-Channel Resistant Authenticated Encryption with Masking". In : CAESAR competition, 2014.
URL : https://hal.archives-ouvertes.fr/hal-01093512
LS-Designs : Bitslice Encryption for Efficient Masked Software Implementations, FSE 2014. Sous la dir. de Carlos Cid et Christian Rechberger. T. 8540, pp.18-37, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01093491
The LED Block Cipher, CHES 2011. Sous la dir. de Bart Preneel et Tsuyoshi Takagi. T. 6917, pp.326-341, 2011. ,
Almost perfect nonlinear trinomials and hexanomials, Finite Fields and Their Applications, vol.33, pp.258-282, 2015. ,
The Grain Family of Stream Ciphers, New Stream Cipher DesignsThe eSTREAM Finalists, pp.978-981, 2008. ,
DOI : 10.1007/978-3-540-68351-3_14
A Formal Basis for the Heuristic Determination of Minimum Cost Paths, IEEE Trans. Systems Science and Cybernetics, vol.4, pp.100-107, 1968. ,
Key-Recovery Attacks on Universal Hash Function Based MAC Algorithms, CRYPTO 2008. Sous la dir ,
DOI : 10.1007/978-3-540-85174-5_9
URL : https://link.springer.com/content/pdf/10.1007%2F978-3-540-85174-5_9.pdf
, LNCS. Springer, pp.144-161, 2008.
Exploiting Multiples of the Connection Polynomial in Word-Oriented Stream Ciphers, ASIACRYPT 2000. Sous la dir. de Tatsuaki Okamoto. T. 1976, pp.303-316, 2000. ,
A Proof of the Welch and Niho Conjectures on Cross-Correlations of Binary m-Sequences, Finite Fields and Their Applications, vol.7, pp.1071-5797, 2001. ,
OMAC : One-Key CBC MAC, FSE 2003. Sous la dir. de Thomas Johansson. T. 2887, pp.129-153, 2003. ,
Private Circuits : Securing Hardware against Probing Attacks, CRYPTO 2003. Sous la dir. de Dan Boneh. T. 2729, pp.463-481, 2003. ,
ZMAC : A Fast Tweakable Block Cipher Mode for Highly Secure Message Authentication, CRYPTO 2017, Part III. Sous la dir. de Jonathan Katz et Hovav Shacham. T. 10403, pp.34-65, 2017. ,
New Blockcipher Modes of Operation with Beyond the Birthday Bound Security, pp.310-327, 2006. ,
Optimizing Implementations of Lightweight Building Blocks, IACR Trans. Symm. Cryptol, vol.4, pp.2519-173, 2017. ,
The Codebreakers : The comprehensive history of secret communication from ancient times to the internet, 1996. ,
Exercice de style". working paper or preprint, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01263735
The Weight Enumerators for Several Clauses of Subcodes of the 2nd Order Binary Reed-Muller Codes, Information and Control, vol.18, pp.369-394, 1971. ,
A. Kerckhoffs, la cryptographie militaire, In : Journal des sciences militaires, vol.9, p.203, 1883. ,
FOAM : Searching for Hardware-Optimal SPN Structures and Components with a Fair Comparison, CHES 2014. Sous la dir. de Lejla Batina et Matthew Robshaw. T. 8731, pp.433-450, 2014. ,
Differential Power Analysis, pp.388-397, 1999. ,
PRINTcipher : A Block Cipher for IC-Printing, CHES 2010. Sous la dir. de Stefan Mangard et François-Xavier Standaert. T. 6225, pp.16-32, 2010. ,
The Art of Computer Programming, Seminumerical Algorithms, vol.II, p.201038021, 1969. ,
Timing Attacks on Implementations of Diffie-Hellman, RSA, DSS, and Other Systems, pp.104-113, 1996. ,
Shorter Linear Straight-Line Programs for MDS Matrices, IACR Trans. Symm. Cryptol, vol.4, pp.2519-173, 2017. ,
Exact maximum expected differential and linear probability for two-round Advanced Encryption Standard, IET Information Security, vol.1, issue.2, pp.53-57, 2007. ,
On inverses of APN exponents, IEEE International Symposium on Information Theory-ISIT 2012, pp.1207-1211, 2012. ,
, International Symposium on Coding Theory and Applications-EUROCODE '90. Sous la dir. de Gérard D. Cohen et Pascale Charpin. T. 514, pp.51-59, 1990.
A Cryptanalysis of PRINTcipher : The Invariant Subspace Attack, CRYPTO 2011. Sous la dir. de Phillip Rogaway. T. 6841, pp.206-221, 2011. ,
On the Generalization of Butterfly Structure, IACR Trans. Symm. Cryptol. 2018, vol.1, pp.2519-173, 2018. ,
A Revised Version of Crypton-Crypton V1.0, FSE'99. Sous la dir. de Lars R. Knudsen. T. 1636, pp.31-45, 1999. ,
Private Computation on Encrypted Genomic Data, Progress in CryptologyLATINCRYPT 2014-Third International Conference on Cryptology and Information Security in Latin America, pp.3-27, 2014. ,
A Proposal for a New Block Encryption Standard, EUROCRYPT'90. Sous la dir. d'Ivan Damgård. T. 473, pp.389-404, 1991. ,
A Comparison of the Homomorphic Encryption Schemes FV and YASHE, AFRICACRYPT 14. Sous la dir ,
URL : https://hal.archives-ouvertes.fr/hal-01006484
Cryptanalysis of KLEIN, FSE 2014. Sous la dir. de Carlos Cid et Christian Rechberger. T. 8540, pp.451-470, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00931699
, Rudolf Lidl et Harald Niederreiter. Finite fields, 1983.
Clocked Adversaries for Hashing, Algorithmica 9, vol.3, pp.239-252, 1993. ,
On the Classification of 4 Bit SBoxes, Arithmetic of Finite Fields, First International Workshop, WAIFI, pp.159-176, 2007. ,
On the Classification of 4 Bit SBoxes, Arithmetic of Finite Fields-WAIFI. T. 4547, pp.159-176, 2007. ,
Tweakable Block Ciphers, CRYPTO 2002. Sous la dir. de Moti Yung. T. 2442, pp.31-46, 2002. ,
Lightweight MDS Generalized Circulant Matrices, FSE 2016. Sous la dir. de Thomas Peyrin. T. 9783, pp.101-120, 2016. ,
Constructing S-boxes for Lightweight Cryptography with Feistel Structure, CHES 2014. Sous la dir. de Lejla Batina et Matthew Robshaw. T. 8731, pp.127-146, 2014. ,
On the Construction of Lightweight Circulant Involutory MDS Matrices, FSE 2016. Sous la dir. de Thomas Peyrin. T. 9783, pp.121-139, 2016. ,
The weights of the orthogonals of the extended quadratic binary Goppa codes, IEEE Trans. Information Theory, vol.36, pp.686-692, 1990. ,
New Structure of Block Ciphers with Provable Security against Differential and Linear Cryptanalysis, Fast Software Encryption-FSE'96. T. 1039, vol.isbn, pp.3-540, 2008. ,
Linear Cryptanalysis Method for DES Cipher, EUROCRYPT'93. Sous la dir. de Tor Helleseth. T. 765, pp.386-397, 1994. ,
The First Experimental Cryptanalysis of the Data Encryption Standard, CRYPTO'94. Sous la dir. d'Yvo Desmedt. T. 839, pp.1-11, 1994. ,
, New Block Encryption Algorithm MISTY". In : FSE'97. Sous la dir. d'Eli Biham. T. 1267, pp.54-68, 1997.
, Bibliographie 205
Encrypted Davies-Meyer and Its Dual : Towards Optimal Security Using Mirror Theory, CRYPTO 2017, Part III. Sous la dir. de Jonathan Katz et Hovav Shacham. T. 10403, pp.556-583, 2017. ,
Chaskey : An Efficient MAC Algorithm for 32-bit Microcontrollers, SAC 2014. Sous la dir. d'Antoine Joux et Amr M. Youssef. T. 8781, pp.306-323, 2014. ,
The Theory of Error Correcting Codes, 1977. ,
On permutation polynomials over finite fields, International Journal of Mathematics and Mathematical Sciences, vol.10, issue.3, pp.535-543, 1987. ,
Fast Correlation Attacks on Certain Stream Ciphers, J. Cryptology, vol.1, issue.3, pp.159-176, 1989. ,
Provably Secure MACs from Differentially-Uniform Permutations and AES-Based Implementations, pp.226-241, 2006. ,
The Security and Performance of the Galois/Counter Mode (GCM) of Operation, INDOCRYPT 2004. Sous la dir. d'Anne Canteaut et Kapalee Viswanathan. T. 3348, pp.343-355, 2004. ,
Towards Stream Ciphers for Efficient FHE with Low-Noise Ciphertexts, EUROCRYPT 2016, Part I. Sous la dir. de Marc Fischlin et Jean-Sébastien Coron. T. 9665, pp.311-343, 2016. ,
Provable Security Against a Differential Attack, J. Cryptology, vol.8, pp.27-37, 1995. ,
ChaCha20 and Poly1305 for IETF Protocols. RFC 7539 (Informational), 2015. ,
Can homomorphic encryption be practical ?, In : Proceedings of the 3rd ACM Cloud Computing Security Workshop, pp.113-124, 2011. ,
Perfect Nonlinear S-Boxes, EUROCRYPT'91. Sous la dir. de Donald W. Davies. T. 547, pp.378-386, 1991. ,
Perfect nonlinear S-boxes, Advances in CryptologyEUROCRYPT'91. T. 547. LNCS, pp.378-385, 1991. ,
Differentially Uniform Mappings for Cryptography, EUROCRYPT'93. Sous la dir. de Tor Helleseth. T. 765, pp.55-64, 1994. ,
Generalized Feistel Networks, ASIACRYPT'96. Sous la dir. de Kwangjo Kim et Tsutomu Matsumoto. T. 1163, pp.91-104, 1996. ,
Speeding up Serpent, AES Candidate Conference, pp.317-329, 2002. ,
Optimized arithmetic for Reed-Solomon encoders, Proceedings of IEEE International Symposium on Information Theory, p.250, 1997. ,
A Proof of Security in O(2n) for the Xor of Two Random Permutations, ICITS. T. 5155. Lecture Notes in Computer Science, pp.232-248, 2008. ,
Security in Op2 n q for the Xor of Two Random PermutationsProof with the standard H technique, Cryptology ePrint Archive, 2013. ,
On Weak Keys and Forgery Attacks Against Polynomial-Based MAC Schemes, FSE 2013. Sous la dir. de Shiho Moriai. T. 8424, pp.287-304, 2014. ,
Cryptanalysis of a Theorem : Decomposing the Only Known Solution to the Big APN Problem, CRYPTO 2016, Part II. Sous la dir. de Matthew Robshaw et Jonathan Katz. T. 9815, pp.93-122, 2016. ,
MDx-MAC and Building Fast MACs from Hash Functions, CRYPTO'95. Sous la dir. de Don Coppersmith. T. 963, pp.1-14, 1995. ,
Constructing Differentially 4-Uniform Permutations Over F 2 2k via the Switching Method, IEEE Trans. Information Theory, vol.59, pp.4675-4686, 2013. ,
Robshaw et Olivier Billet, éds. New Stream Cipher Designs-The eSTREAM Finalists. T. 4986. Lecture Notes in Computer Science, pp.978-981, 2008. ,
Bucket Hashing and Its Application to Fast Message Authentication, Journal of Cryptology, vol.12, pp.91-115, 1999. ,
On "Bent" Functions, J. Comb. Theory, Ser. A, vol.20, issue.3, pp.300-305, 1976. ,
Cryptographic Analysis of All 4 ? 4-Bit SBoxes, SAC 2011. Sous la dir. d'Ali Miri et Serge Vaudenay. T. 7118, pp.118-133, 2012. ,
Recursive Diffusion Layers for Block Ciphers and Hash Functions, FSE 2012. Sous la dir. d'Anne Canteaut. T. 7549, pp.385-401, 2012. ,
A Compact Rijndael Hardware Architecture with S-Box Optimization, ASIACRYPT 2001. Sous la dir. de Colin Boyd. T. 2248, pp.239-254, 2001. ,
Communication theory of secrecy systems, Bell Systems Technical Journal, vol.28, pp.656-715, 1949. ,
, Bibliographie, vol.207
On Fast and Provably Secure Message Authentication Based on Universal Hashing, pp.313-328, 1996. ,
DOI : 10.1007/3-540-68697-5_24
URL : https://link.springer.com/content/pdf/10.1007%2F3-540-68697-5_24.pdf
Efficient Computation of Minimal Polynomials in Algebraic Extensions of Finite Fields, Proceedings of the 1999 International Symposium on Symbolic and Algebraic Computation, ISSAC '99, pp.53-58, 1999. ,
Determinants of block matrices, The Mathematical Gazette, vol.84, pp.460-467, 2000. ,
Lightweight MDS Involution Matrices, FSE 2015. Sous la dir. de Gregor Leander. T. 9054, pp.471-493, 2015. ,
Lightweight Diffusion Layer : Importance of Toeplitz Matrices, In : IACR Trans. Symm. Cryptol. 2016, vol.1, pp.2519-173, 2016. ,
Universal Hashing and Authentication Codes, CRYPTO'91. Sous la dir. de Joan Feigenbaum. T. 576, pp.74-85, 1992. ,
DOI : 10.1007/3-540-46766-1_5
URL : https://link.springer.com/content/pdf/10.1007%2F3-540-46766-1_5.pdf
A Known Plaintext Attack of FEAL-4 and FEAL-6, CRYPTO'91. Sous la dir. de Joan Feigenbaum. T. 576, pp.172-181, 1992. ,
DOI : 10.1007/3-540-46766-1_12
URL : https://link.springer.com/content/pdf/10.1007%2F3-540-46766-1_12.pdf
Differentially 4-uniform bijections by permuting the inverse function, Des. Codes Cryptography, vol.77, pp.117-141, 2015. ,
DOI : 10.1007/s10623-014-9992-y
URL : http://eprint.iacr.org/2013/639.pdf
Enhanced criteria on differential uniformity and nonlinearity of cryptographically significant functions, Cryptography and Communications, vol.8, pp.291-311, 2016. ,
Finding Optimal Bitsliced Implementations of 4x4-bit S-Boxes, SKEW 2011 Symmetric Key Encryption Workshop, pp.16-17, 2011. ,
New Hash Functions and Their Use in Authentication and Set Equality, Journal of Computer and System Sciences, vol.22, pp.265-279, 1981. ,
The Stream Cipher HC-128, New Stream Cipher Designs-The eSTREAM Finalists, pp.978-981, 2008. ,
DOI : 10.1007/978-3-540-68351-3_4
Recursive Diffusion Layers for (Lightweight) Block Ciphers and Hash Functions, SAC 2012. Sous la dir. de Lars R. Knudsen et Huapeng Wu. T. 7707, pp.355-371, 2013. ,
DOI : 10.1007/978-3-642-35999-6_23
LBlock : A Lightweight Block Cipher, ACNS 11. Sous la dir. de Javier Lopez et Gene Tsudik. T. 6715, pp.327-344, 2011. ,
DOI : 10.1007/978-3-642-21554-4_19
URL : https://eprint.iacr.org/2011/345.pdf
The Sum of CBC MACs Is a Secure PRF, CT-RSA 2010. Sous la dir. de Josef Pieprzyk. T. 5985, pp.366-381, 2010. ,
A New Variant of PMAC : Beyond the Birthday Bound, CRYPTO 2011. Sous la dir. de Phillip Rogaway. T. 6841, pp.596-609, 2011. ,
3kf9 : Enhancing 3GPP-MAC beyond the Birthday Bound, ASIACRYPT 2012. Sous la dir. de Xiaoyun Wang et Kazue Sako. T. 7658, pp.296-312 ,
DOI : 10.1007/978-3-642-34961-4_19
URL : https://link.springer.com/content/pdf/10.1007%2F978-3-642-34961-4_19.pdf
Designing Optimal Implementations of Linear Layers (Full Version), 2016. ,
Constructing new differentially 4uniform permutations from the inverse function, Finite Fields and Their Applications, vol.25, pp.64-78, 2014. ,
DOI : 10.1016/j.ffa.2013.08.003
Analysis and Design of Symmetric Encryption Algorithms, 2007. ,
