, The instacart online grocery shopping dataset, 2013.
Improved algorithms for linear stochastic bandits, SDM10: Proceedings of the 2010 SIAM International Conference on Data Mining, vol.24, pp.701-712, 2010. ,
Learning the parameters of determinantal point process kernels, Proceedings of the 31th International Conference on Machine Learning, pp.1224-1232, 2014. ,
Mining association rules between sets of items in large databases, SIGMOD Rec, vol.22, issue.2, pp.207-216, 1993. ,
Thompson sampling for contextual bandits with linear payoffs, Proceedings of the 30th International Conference on Machine Learning, vol.28, pp.127-135, 2013. ,
Thompson sampling for contextual bandits with linear payoffs, Proceedings of the 30th International Conference on International Conference on Machine Learning, vol.28, 2013. ,
Using confidence bounds for exploitation-exploration trade-offs, J. Mach. Learn. Res, vol.3, pp.397-422, 2003. ,
Near-optimal regret bounds for reinforcement learning, Advances in Neural Information Processing Systems, vol.21, pp.89-96, 2009. ,
Logarithmic online regret bounds for undiscounted reinforcement learning, NIPS, pp.49-56, 2006. ,
Alambic : a privacy-preserving recommender system for electronic commerce, Int. J. Inf. Sec, vol.7, issue.5, pp.307-334, 2008. ,
The 'filter bubble' explains why trump won and you didn't see it coming, 2016. ,
Task clustering and gating for bayesian multitask learning, J. Mach. Learn. Res, vol.4, pp.83-99, 2003. ,
Towards time-dependant recommendation based on implicit feedback, Workshop on context-aware recommender systems (CARS-09), 2009. ,
Recsys challenge 2015 and the yoochoose dataset, Proceedings of the 9th ACM Conference on Recommender Systems, RecSys '15, pp.357-358, 2015. ,
The netflix prize, KDD Cup and Workshop in conjunction with KDD, 2007. ,
Temporal differences-based policy iteration and applications in neuro-dynamic programming, Proceedings of the 2007 ACM Conference on Recommender Systems, RecSys '07, pp.9-16, 1996. ,
Tighter low-rank approximation via sampling the leveraged element. CoRR, abs/1410, Proceedings of the Sixteenth International Conference on Machine Learning, vol.3886, pp.49-56, 1999. ,
DOI : 10.1137/1.9781611973730.62
URL : http://arxiv.org/pdf/1410.3886
Empirical analysis of predictive algorithms for collaborative filtering, Proceedings of the Fourteenth Conference on Uncertainty in Artificial Intelligence, UAI'98, pp.43-52, 1998. ,
Using association rules for product assortment decisions: A case study, Knowledge Discovery and Data Mining, pp.254-260, 1999. ,
Dynamic itemset counting and implication rules for market basket data, Proceedings of the 1997 ACM SIGMOD International Conference on Management of Data, SIGMOD '97, pp.255-264, 1997. ,
DOI : 10.1145/253260.253325
Hybrid recommender systems: Survey and experiments, User Modeling and User-Adapted Interaction, vol.12, issue.4, pp.331-370, 2002. ,
Graph regularized nonnegative matrix factorization for data representation, IEEE Trans. Pattern Anal. Mach. Intell, vol.33, issue.8, pp.1548-1560, 2007. ,
A singular value thresholding algorithm for matrix completion, SIAM J. on Optimization, vol.20, issue.4, pp.1956-1982, 2010. ,
Exact matrix completion via convex optimization, 2008. ,
The power of convex relaxation: Near-optimal matrix completion. CoRR, abs/0903.1476. [Canny, 2002] Canny, Proceedings of the 25th Annual International ACM SIGIR Conference on Research and Development in Information Retrieval, SIGIR '02, pp.238-245, 2002. ,
Music Recommendation and Discovery in the Long Tail, 2009. ,
Active matrix completion, Advances in Neural Information Processing Systems, vol.26, pp.81-90, 2013. ,
Data mining for the online retail industry: A case study of rfm model-based customer segmentation using data mining, Journal of Database Marketing & Customer Strategy Management, vol.19, issue.3, pp.197-208, 2012. ,
Improving the diversity of top-n recommendation via determinantal point process. Large Scale Recommendation Systems Workshop, 2017. ,
, Efficient vector representation for documents through corruption, 2017.
Blockbusters and wallflowers: Accurate, diverse, and scalable recommendations with random walks, Proceedings of the 9th ACM Conference on Recommender Systems, RecSys '15, vol.28, pp.163-170, 2005. ,
Orthogonal nonnegative matrix t-factorizations for clustering, Proceedings of the 12th ACM SIGKDD International Conference on Knowledge Discovery and Data Mining, KDD '06, pp.126-135, 2006. ,
Smoothed analysis of condition numbers and complexity implications for linear programming, Math. Program, vol.126, issue.2, pp.315-350, 2011. ,
Differential privacy: A survey of results, Proceedings of the 5th International Conference on Theory and Applications of Models of Computation, TAMC'08, pp.1-19, 2008. ,
Collaborative filtering recommender systems, Found. Trends Hum.-Comput. Interact, vol.4, issue.2, pp.81-173, 2011. ,
Personality-based active learning for collaborative filtering recommender systems, Proceeding of the XIIIth International Conference on AI*IA 2013: Advances in Artificial Intelligence, vol.8249, pp.360-371, 2013. ,
, Efficiently computing private recommendations, 2011 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), vol.6, pp.615-637, 2005.
Matrix Rank Minimization with Applications, 2002. ,
Tucker factorization with missing data with application to low-n-rank tensor completion. Multidimensional Systems and Signal Processing, pp.1-16, 2013. ,
Optimally Sensing a Single Channel Without Prior Information: The Tiling Algorithm and Regret Bounds, IEEE Journal of Selected Topics in Signal Processing, vol.5, issue.1, pp.68-76, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00408867
Diverse personalization with determinantal point process eigenmixtures, 2013. ,
Bayesian low-rank determinantal point processes, Proceedings of the 10th ACM Conference on Recommender Systems, RecSys '16, pp.349-356, 2016. ,
Lowrank factorization of determinantal point processes, Proceedings of the ThirtyFirst AAAI Conference on Artificial Intelligence, pp.1912-1918, 2017. ,
Zonotope hit-and-run for efficient sampling from projection dpps, Proceedings of the 34th International Conference on Machine Learning, pp.1223-1232, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01526577
Discovering diverse and salient threads in document collections, Proceedings of the 2012 Joint Conference on Empirical Methods in Natural Language Processing and Computational Natural Language Learning, vol.12, pp.710-720, 2012. ,
Expectation-maximization for learning determinantal point processes, Advances in Neural Information Processing Systems, vol.27, pp.133-151, 2001. ,
Scalable recommendation with poisson factorization, 2013. ,
, , 2016.
Large-scale bandit recommender system, International Workshop on Machine Learning, Optimization and Big Data, pp.204-215, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01406389
Noisy Matrix Completion Using Alternating Minimization, p.194, 2013. ,
arules-A computational environment for mining association rules and frequent item sets, Journal of Statistical Software, vol.14, issue.15, pp.1-25, 2005. ,
Faster greedy MAP inference for determinantal point processes, International Conference on Machine Learning, 2017. ,
On the provable convergence of alternating minimization for matrix completion. CoRR, abs/1312.0925, Proceedings of the 2014 IEEE 55th Annual Symposium on Foundations of Computer Science, FOCS '14, pp.651-660, 2013. ,
The movielens datasets: History and context, ACM Trans. Interact. Intell. Syst, vol.5, issue.4, p.19, 2015. ,
Ups and downs: Modeling the visual evolution of fashion trends with one-class collaborative filtering. CoRR, abs/1602.01585, Proceedings of the TwentyFifth International Joint Conference on Artificial Intelligence, IJCAI'16, pp.1562-1570, 2016. ,
An algorithmic framework for performing collaborative filtering, Proceedings of the 1999 Conference on Research and Development in Information Retrieval, 1999. ,
An algorithmic framework for performing collaborative filtering, Proceedings of the 22Nd Annual International ACM SIGIR Conference on Research and Development in Information Retrieval, SIGIR '99, pp.230-237, 1999. ,
Parallel recurrent neural network architectures for feature-rich sessionbased recommendations, Proceedings of the SIGCHI Conference on Human Factors in Computing Systems, CHI '95, vol.2, pp.58-64, 1995. ,
Personalized recommendation via cross-domain triadic factorization, Proceedings of the 22Nd International Conference on World Wide Web, WWW '13, pp.595-606, 2013. ,
Collaborative filtering for implicit feedback datasets, Proceedings of the 2008 Eighth IEEE International Conference on Data Mining, ICDM '08, pp.263-272, 2008. ,
Efficient algorithms for collaborative filtering, 2012. ,
Eli pariser: activist whose filter bubble warnings presaged trump and brexit, 2017. ,
Fast exact matrix completion with finite samples. CoRR, abs/1411, p.1087, 2014. ,
Low-rank matrix completion using alternating minimization, Proceedings of the Forty-fifth Annual ACM Symposium on Theory of Computing, STOC '13, pp.665-674, 2013. ,
DOI : 10.1145/2488608.2488693
URL : http://arxiv.org/abs/1212.0467
Near-optimal regret bounds for reinforcement learning, J. Mach. Learn. Res, vol.11, pp.1563-1600, 2010. ,
Nonstochastic best arm identification and hyperparameter optimization, AISTATS, 2016. ,
Just in time recommendations: Modeling the dynamics of boredom in activity streams, Proceedings of the Eighth ACM International Conference on Web Search and Data Mining, WSDM '15, vol.27, pp.199-213, 2012. ,
Matrix completion from noisy entries, J. Mach. Learn. Res, vol.11, pp.2057-2078, 2010. ,
DOI : 10.1109/isit.2009.5205567
URL : http://arxiv.org/pdf/0901.3150
Matrix completion from a few entries, 2009. ,
Tensor decompositions and applications, Ethics of Personalized Information Filtering, vol.51, pp.455-500, 2009. ,
Time-Decaying Bandits for Non-stationary Systems, pp.460-466, 2014. ,
DOI : 10.1007/978-3-319-13129-0_40
Factorization meets the neighborhood: A multifaceted collaborative filtering model, Proceedings of the 14th ACM SIGKDD International Conference on Knowledge Discovery and Data Mining, KDD '08, pp.426-434, 2008. ,
Collaborative filtering with temporal dynamics, Proceedings of the 15th ACM SIGKDD International Conference on Knowledge Discovery and Data Mining, vol.53, pp.447-456, 2009. ,
Matrix factorization techniques for recommender systems, Computer, vol.42, issue.8, pp.30-37, 2009. ,
DOI : 10.1109/mc.2009.263
URL : http://research.yahoo.com/files/ieeecomputer.pdf
Private traits and attributes are predictable from digital records of human behavior, Proceedings of the National Academy of Sciences, vol.110, issue.15, pp.5802-5805, 2013. ,
DOI : 10.1073/pnas.1218772110
URL : http://www.pnas.org/content/110/15/5802.full.pdf
Do You Trust Your Recommendations? An Exploration of Security and Privacy Issues in Recommender Systems, SIAM J. Matrix Anal. Appl, vol.21, issue.4, pp.1253-1278, 2000. ,
Knowledge Transfer in Reinforcement Learning, 2008. ,
, Bayesian multi-task reinforcement learning, Proceedings of the Twenty-Seventh International Conference on Machine Learning (ICML-2010)
Transfer of samples in batch reinforcement learning, Proceedings of the Twenty-Fifth Annual International Conference on Machine Learning (ICML-2008), pp.544-551, 2008. ,
Distributed representations of sentences and documents. CoRR, abs/1405.4053, Journal of Machine Learning Research, pp.1-24, 2014. ,
Classificationbased collaborative filtering using market basket data, Expert Syst. Appl, vol.29, issue.3, pp.700-704, 2005. ,
Can movies and books collaborate?: Cross-domain collaborative filtering for sparsity reduction, Proceedings of the 21st International Jont Conference on Artifical Intelligence, IJCAI'09, pp.2052-2057, 2009. ,
Transfer learning for collaborative filtering via a rating-matrix generative model, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, pp.617-624, 2009. ,
An unbiased, datadriven, offline evaluation method of contextual bandit algorithms, 2010. ,
DOI : 10.1145/1935826.1935878
URL : http://arxiv.org/pdf/1003.5956
A contextual-bandit approach to personalized news article recommendation, Proceedings of the 19th International Conference on World Wide Web, WWW '10, pp.661-670, 2010. ,
DOI : 10.1145/1772690.1772758
A contextual-bandit approach to personalized news article recommendation, pp.661-670, 2010. ,
Unbiased offline evaluation of contextual-bandit-based news article recommendation algorithms, Proceedings of the Fourth ACM International Conference on Web Search and Data Mining, WSDM '11, pp.297-306, 2011. ,
Collaborative filtering bandits, Proceedings of the 39th International ACM SIGIR Conference on Research and Development in Information Retrieval, SIGIR '16, pp.539-548, 2016. ,
DOI : 10.1145/2911451.2911548
URL : http://arxiv.org/pdf/1502.03473
Amazon.com recommendations: Item-to-item collaborative filtering, IEEE Internet Computing, vol.7, issue.1, pp.76-80, 2003. ,
Integrating classification and association rule mining, Proceedings of the Fourth International Conference on Knowledge Discovery and Data Mining, KDD'98, pp.80-86, 1998. ,
, , 2011.
Predicting online performance of news recommender systems through richer evaluation metrics, Proceedings of the 9th ACM Conference on Recommender Systems, RecSys '15, vol.24, pp.179-186, 2015. ,
Fixed-point algorithms for determinantal point processes, 2015. ,
Bandits warm-up cold recommender systems, CoRR, 2014. ,
DOI : 10.1007/978-3-319-27926-8_29
URL : https://hal.archives-ouvertes.fr/hal-01022628
Differentially private recommender systems: Building privacy into the net, Proceedings of the 15th ACM SIGKDD International Conference on Knowledge Discovery and Data Mining, KDD '09, pp.627-636, 2009. ,
Differentially private recommender systems: Building privacy into the netflix prize contenders, Proceedings of the 15th ACM SIGKDD International Conference on Knowledge Discovery and Data Mining (KDD), vol.26, pp.3111-3119, 2009. ,
A fused elastic net logistic regression model for multi-task binary classification, 2013. ,
Talmud: Transfer learning for multiple domains, Proceedings of the 21st ACM International Conference on Information and Knowledge Management, CIKM '12, pp.425-434, 2012. ,
How to break anonymity of the netflix prize dataset, 2006. ,
Exploring the filter bubble: The effect of using recommender systems on content diversity, Proceedings of the 28th International Conference on Machine Learning (ICML-11), ICML '11, pp.809-816, 2011. ,
Regret bounds for restless markov bandits, Theor. Comput. Sci, vol.558, pp.62-76, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00765450
Generalization and exploration via randomized value functions, Proceedings of the 33rd International Conference on International Conference on Machine Learning, vol.48, pp.2377-2386, 2016. ,
A survey on transfer learning, IEEE Trans. on Knowl. and Data Eng, vol.22, issue.10, pp.1345-1359, 2010. ,
Transfer learning in collaborative filtering for sparsity reduction, 2010. ,
The Filter Bubble: What the Internet Is Hiding from You. Penguin Group , The, 2011. ,
Improving regularized singular value decomposition for collaborative filtering, Proc. KDD Cup Workshop at SIGKDD'07, 13th ACM Int. Conf. on Knowledge Discovery and Data Mining, pp.39-42, 2007. ,
Fewer flops at the top: Accuracy, diversity, and regularization in two-class collaborative filtering, Proceedings of the Eleventh ACM Conference on Recommender Systems, RecSys '17, pp.215-223, 2017. ,
The adaptive web. chapter Content-based Recommendation Systems, pp.325-341, 2007. ,
Markov Decision Processes: Discrete Stochastic Dynamic Programming, Proceedings of the 2005 ACM Symposium on Applied Computing, SAC '05, pp.791-795, 1994. ,
A coverage-based approach to recommendation diversity on similarity graph, Proceedings of the 10th ACM Conference on Recommender Systems, RecSys '16, pp.15-22, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01387171
Privacy risks in recommender systems, IEEE Internet Computing, vol.5, issue.6, pp.54-62, 2001. ,
A simpler approach to matrix completion. CoRR, abs/0910.0651, ICDM, pp.995-1000, 2009. ,
Grouplens: An open architecture for collaborative filtering of netnews, Proceedings of the 1994 ACM Conference on Computer Supported Cooperative Work, CSCW '94, pp.175-186, 1994. ,
, , 2010.
, Recommender Systems Handbook
A new convex relaxation for tensor completion, vol.4653, pp.2967-2975, 2013. ,
Bayesian probabilistic matrix factorization using markov chain monte carlo, Proceedings of the 25th International Conference on Machine Learning, ICML '08, pp.880-887, 2008. ,
The adaptive web. chapter Collaborative Filtering Recommender Systems, Proceedings of the 8th ACM Conference on Recommender Systems, RecSys '14, pp.345-348, 2007. ,
An mdpbased recommender system, J. Mach. Learn. Res, vol.6, pp.1265-1295, 2005. ,
Preserving privacy in collaborative filtering through distributed aggregation of offline profiles, Proceedings of the Third ACM Conference on Recommender Systems, RecSys '09, pp.157-164, 2009. ,
Contextual sequence modeling for recommendation with recurrent neural networks. CoRR, abs/1706.07684, Proceedings of the 7th ACM Conference on Recommender Systems, RecSys '13, vol.27, pp.213-220, 2013. ,
A survey of collaborative filtering techniques, Adv. in Artif. Intell, vol.4, pp.2-4, 2009. ,
Batch learning from logged bandit feedback through counterfactual risk minimization, J. Mach. Learn. Res, vol.16, issue.1, pp.1731-1755, 2015. ,
K-anonymity: A model for protecting privacy, Int. J. Uncertain. Fuzziness Knowl.-Based Syst, vol.10, issue.5, pp.557-570, 2002. ,
Tag recommendations based on tensor dimensionality reduction, Proceedings of the 2008 ACM Conference on Recommender Systems, RecSys '08, pp.327-414, 2005. ,
Online Learning of Rested and Restless Bandits, IEEE Transactions on Information Theory, vol.58, issue.8, 2012. ,
Adaptive, personalized diversity for visual discovery, Proceedings of the 10th ACM Conference on Recommender Systems, RecSys '16, pp.35-38, 2016. ,
An accelerated proximal gradient algorithm for nuclear norm regularized linear least squares problems, Pacific Journal of Optimization, 2010. ,
Parafac and missing values, vol.75, pp.163-180, 2005. ,
Feature-based methods for large scale dynamic programming, Machine Learning, vol.22, pp.59-94, 1996. ,
Modelling contextual information in session-aware recommender systems with neural networks, Proceedings of the 10th ACM Conference on Recommender Systems, RecSys '16, pp.273-276, 2016. ,
Improving sales diversity by recommending users to items, Proceedings of the 8th ACM Conference on Recommender Systems, RecSys '14, pp.145-152, 2014. ,
Metaprod2vec-product embeddings using side-information for recommendation, 2016. ,
, , 2001.
, Asymptotic Combinatorics with Applications to Mathematical Physics
Provably correct active sampling algorithms for matrix column subset selection with missing data. CoRR, abs/1505.04343, Tight performance bounds on greedy policies based on imperfect value functions, 1993. ,
Multitask reinforcement learning: A hierarchical bayesian approach, Proceedings of the 24th International Conference on Machine Learning, ICML '07, pp.1015-1022, 2007. ,
Speedup matrix completion with side information: Application to multi-label learning, Advances in Neural Information Processing Systems, vol.26, pp.2301-2309, 2008. ,
, Large-scale parallel collaborative filtering for the netflix prize, Proceedings of the 4th International Conference on Algorithmic Aspects in Information and Management, AAIM '08, pp.337-348
Cascading bandits for large-scale recommendation problems, 2016. ,
