, Call for Evidence on Free-Viewpoint Television: Super-Multiview and Free Navigation
, ISO/IEC JTC1/SC29/WG11 MPEG2015/N15348, 2015.
3. , 132. Speech and video telephony terminal acoustic test specification, 2017.
A. Albanese, J. Blomer, J. Edmonds, M. Luby, and M. Sudan, Priority encoding transmission, IEEE Transactions on Information Theory, vol.42, issue.6, pp.1737-1744, 1996.
A. Barron and T. Cover, Minimum complexity density estimation, IEEE Transactions on Information Theory, vol.37, issue.4, p.10341054, 1991.
A. Barron, J. Rissanen, and B. Yu, The minimum description length principle in coding and modeling, IEEE Transactions on Information Theory, vol.44, issue.6, pp.2743-2760, 1998.
C. Berrou, A. Glavieux, and P. Thitimajshima, Near Shannon limit error-correcting coding and decoding: Turbo-codes, IEEE International Conference on Communications, (ICC), pp.1064-1070, 1993.
N. Bertin and A. Roumy, New generation of audiovisual sensors and the challenge of dimensionality (nouvelle génération de capteurs audiovisuels : les défis de dimensionalités), Data Science Symposium, 2015.
M. Bevilacqua, A. Roumy, C. Guillemot, and M. Morel, Low-Complexity Single-Image Super-Resolution based on Nonnegative Neighbor Embedding, BMVC (British Machine Vision Conference), 2012.
URL : https://hal.archives-ouvertes.fr/hal-00747054
, Neighbor embedding based single-image super-resolution using SemiNonnegative Matrix Factorization, ICASSP ( IEEE International Conference on Acoustics, Speech, and Signal Processing, 2012.
, Compact and coherent dictionary construction for example-based super-resolution, IEEE International Conference on Acoustics, Speech, and Signal Processing, 2013.
&. , Nonnegative dictionary learning for sparse image representations, IEEE International Conference on Image Processing (ICIP), 2013.
, Super-resolution using Neighbor Embedding of Back-projection residuals, 18th International Conference on Digital Signal Processing (DSP), 2013.
, Video super-resolution via sparse combinations of key-frame patches in a compression context, 30th Picture Coding Symposium (PCS), 2013.
, Single-image super-resolution via linear mapping of interpolated selfexamples, IEEE Transactions on Image Processing, vol.23, pp.5334-5347, 2014.
V. Bottreau, M. Benetiere, B. Felts, and B. Pesquet-popescu, A fully scalable 3d subband video codec, Proceedings 2001 International Conference on Image Processing, 2001.
A. Bouabdallah and J. Lacan, Dependency-aware unequal erasure protection codes, Journal of Zhejiang University-Science A, vol.7, 2006.
S. Boucheron and M. R. Salamatian, About priority encoding transmission, IEEE Transactions on Information Theory, vol.46, issue.2, pp.699-705, 2000.
K. Bouchireb and P. Duhamel, Transmission Schemes for Scalable Video Streaming in a Multicast Environment, 2008 International Wireless Communications and Mobile Computing Conference, pp.419-424, 2008.
S. Chaabouni, N. Sellami, and A. Roumy, Lower bounds on the performance of the MAP equalizer with a priori over MIMO systems, Proc.of ISSPA, International Symposium on Signal Processing and its Applications, 2007.
URL : https://hal.archives-ouvertes.fr/inria-00504521
, The Impact of a priori information on the MAP equalizer performance with M-PSK modulation, Proc.of 15th European Signal Processing conference, 2007.
J. Chen, D. He, and A. Jagmohan, On the duality between Slepian-Wolf coding and channel coding under mismatched decoding, IEEE Transactions on Information Theory, vol.55, issue.9, pp.4006-4018, 2009.
G. Coluccia, E. Magli, A. Roumy, and V. Toto-zarasoa, Lossy compression of distributed sparse sources: a practical scheme, European Signal Processing Conference (EUSIPCO), 2011.
URL : https://hal.archives-ouvertes.fr/inria-00629001
G. Coluccia, A. Roumy, and E. Magli, Exact Performance Analysis of the Oracle Receiver for Compressed Sensing Reconstruction, ICASSP ( IEEE International Conference on Acoustics, Speech, and Signal Processing, 2014.
URL : https://hal.archives-ouvertes.fr/hal-00996695
, Operational Rate-Distortion Performance of Single-source and Distributed Compressed Sensing, IEEE Transactions on Communications, 2014.
, Mismatched sparse denoiser requires overestimating the support length, ICASSP ( IEEE International Conference on Acoustics, Speech, and Signal Processing, 2017.
T. Cover and J. Thomas, Elements of information theory, second Edition, 2006.
I. Csiszar and P. Shields, Information theory and statistics: A tutorial, Foundations and Trends in Communications and Information Theory, vol.1, issue.4, pp.417-528, 2004.
S. C. Draper and E. Martinian, Compound conditional source coding, Slepian-Wolf list decoding, and applications to media coding, IEEE International Symposium on Information Theory, 2007.
P. Duhamel and M. Kieffer, Joint Source-Channel Decoding: A Cross-Layer Perspective with Applications in Video Broadcasting over Mobile and Wireless Networks, 2010.
URL : https://hal.archives-ouvertes.fr/hal-00444983
T. Dumas, A. Roumy, and C. Guillemot, Shallow sparse Autoencoders versus sparse coding algorithms for image compression, IEEE International Conference on Multimedia and Expo (ICME), 2016.
URL : https://hal.archives-ouvertes.fr/hal-01377907
, Image compression with stochastic Winner-Take-All Autoencoder, ICASSP ( IEEE International Conference on Acoustics, Speech, and Signal Processing, 2017.
, Autoencoder based Image compression: can the learning be quantization independent, ICASSP ( IEEE International Conference on Acoustics, Speech, and Signal Processing, 2018.
E. Dupraz, T. Maugey, A. Roumy, and M. Kieffer, Transmission and Storage Rates for Sequential Massive Random Access, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01799016
E. Dupraz, A. Roumy, and M. Kieffer, Source Coding with Side Information at the Decoder: Models with Uncertainty, Performance Bounds, and Practical Coding Schemes, International Symposium on Information Theory and its Applications, 2012.
URL : https://hal.archives-ouvertes.fr/hal-00727780
, Codage de Sources avec Information Adjacente et Connaissance Imparfaite de la CorrélationCorrélation : leprobì eme des cadrans, pp.1-4, 2013.
, Codage Distribué dans des Réseaux de Capteurs avec Connaissance Incertaine des Corrélations, vol.37, pp.1-4, 2013.
, Practical Coding Scheme for Universal Source Coding with Side Information at the Decoder, Proceedings of the Data Compression Conference, vol.38, pp.1-11, 2013.
, Universal Wyner-Ziv Coding for Gaussian Sources, Proceedings of the International Conference on Acoustics, Speech, and Signal Processing, pp.1-4, 2013.
, Source Coding with Side Information at the Decoder and Uncertain Knowledge of the Correlation, IEEE Transactions on Communications, vol.62, issue.1, pp.269-279, 2014.
S. Foucart and H. Rauhut, A Mathematical Introduction to Compressive Sensing. Birkhäuser Basel, 2013.
A. E. Gamal and Y. Kim, Network Information Theory, 2012.
E. Gassiat, Codage universel et identification d'ordre par sélection de modèles, 2014.
R. M. Gray and D. L. Neuhoff, Quantization, IEEE Transactions on Information Theory, vol.44, issue.6, pp.2325-2383, 1998.
P. D. Grunwald, The Minimum Description Length Principle, 2007.
T. Han, Information-spectrum methods in information theory, 2003.
T. Han and K. Kobayashi, Mathematics of Information and Coding, ser. Translations of Mathematical Monographs, vol.203, 2002.
C. Herzet, V. Toto-zarasoa, and A. Roumy, Error-resilient non-asymmetric SlepianWolf coding, IEEE Intl. Conf. on Communications, ICC, 2009.
URL : https://hal.archives-ouvertes.fr/inria-00504555
I. and I. Jtc1, Joint Scalable Video Model JSVM-8.6, 2007.
I. H. Kacem, N. Sellami, A. Roumy, and I. Fijalkow, Training sequence length optimization for a turbo-detector using decision-directed channel estimation, Research Letters in Communications, 2008.
URL : https://hal.archives-ouvertes.fr/inria-00504249
J. C. Kieffer, A unified approach to weak universal source coding, IEEE Transactions on Information Theory, vol.24, pp.674-682, 1978.
J. Kovacevic and M. Vetterli, Wavelets and Subband Coding, ser. Prentice-Hall signal processing series, 1995.
M. Luby, L. Vicisano, J. Gemmell, L. Rizzo, M. Handley et al., The Use of Forward Error Correction (FEC) in Reliable Multicast, IETF Std. RFC, vol.3453, 2002.
N. Majed, S. Ragot, X. Lagrange, and A. Blanc, Delay and quality metrics in Voice over LTE (VoLTE) networks: An end-terminal perspective, ICNC 2017 : International Conference on Computing, Networking and Communications : Communications QoS and System Modeling, pp.643-648, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01574769
D. Marpe, H. Schwarz, and T. Wiegand, Context-Based Adaptive Binary Arithmetic Coding in the H.264/AVC Video Compression Standard, IEEE Trans. Circuits and Systems for Video Technology, vol.13, issue.7, p.620636, 2003.
N. Merhav, G. Kaplan, A. Lapidoth, and S. S. Shitz, On information rates for mismatched decoders, IEEE Transactions on Information Theory, vol.40, issue.6, pp.1953-1967, 1994.
N. Moreau, Tools for Signal Compression, 2011.
P. Pad and M. Unser, Optimality of operator-like wavelets for representing sparse ar(1) processes, IEEE Transactions on Signal Processing, vol.63, issue.18, pp.4827-4837, 2015.
S. Paul, K. K. Sabnani, J. C. Lin, and S. Bhattacharyya, Reliable multicast transport protocol (RMTP), IEEE Journal on Selected Areas in Communications, vol.15, issue.3, pp.407-421, 1997.
B. Pesquet-popescu and V. Bottreau, Three-dimensional lifting schemes for motion compensated video compression, Proceedings 2001 International Conference on Signal Processing, 2001.
P. Piantanida, G. Matz, and P. Duhamel, Outage behavior of discrete memoryless channels under channel estimation errors, IEEE Transactions on Information Theory, vol.55, issue.9, pp.4221-4239, 2009.
URL : https://hal.archives-ouvertes.fr/hal-00425665
J. Postel, Transmission Control Protocol, IETF Std. RFC 0793, 1981.
J. Proakis and M. Salehi, Digital Communications, 2008.
G. Reeves and M. Gastpar, Approximate Sparsity Pattern Recovery: InformationTheoretic Lower Bounds, IEEE Trans. on Information Theory, vol.59, issue.6, pp.3451-3465, 2013.
J. Rissanen, Modeling By Shortest Data Description, Automatica, vol.14, pp.465-471, 1978.
, Universal coding, information, prediction and estimation, IEEE Transactions on Information Theory, vol.30, pp.629-636, 1984.
V. Roca, A. Roumy, and B. Sayadi, The Generalized Object Encoding (GOE) Approach for the Forward Erasure Correction (FEC) Protection of Objects and its Application to Reed-Solomon Codes over GF(2 8 ), IETF RMT Working Group, 2012.
URL : https://hal.archives-ouvertes.fr/hal-00748862
, The Need for Extended Forward Erasure Correction (FEC) Schemes: Problem Position, The Generalized Object Encoding (GOE) LDPC-Staircase FEC Scheme, vol.69, 2012.
J. C. Rolon, E. Mendonca, and P. Salembier, Generalized lifting with adaptive local pdf estimation for image coding, 2009 Picture Coding Symposium, 2009.
J. C. Rolon, A. Ortega, and P. Salembier, Modeling of contours in wavelet domain for generalized lifting image compression, 2009 IEEE International Conference on Acoustics, Speech and Signal Processing, 2009.
J. C. Rolon and P. Salembier, generalized lifting for sparse image representation and coding, 2007 Picture Coding Symposium, 2007.
J. C. Rolon, P. Salembier, and X. Alameda, image compression with generalized lifting and partial knowledge of the signal pdf, 15th IEEE International Conference on Image Processing, 2008.
A. Roumy, An Information theoretical problem in interactive Multi-View Video services, IEEE Communications Society Multimedia Communications Technical Committee (ComSoc MMTC) E-Letter, vol.11, pp.11-16, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01394864
A. Roumy, K. Lajnef, and C. Guillemot, Rate-adaptive turbo-syndrome scheme for Slepian-Wolf Coding, 41st Asilomar Conference on Signals, Systems and Computers, 2007.
URL : https://hal.archives-ouvertes.fr/inria-00504581
A. Roumy and T. Maugey, Universal lossless coding with random user access: the cost of interactivity, Proceedings IEEE International Conference on Image Processing, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01208128
, Universal lossless coding with random user access: the cost of interactivity, IEEE International Conference on Image Processing (ICIP), 2015, Among 10% best papers
A. Roumy, V. Roca, and B. Sayadi, Memory Consumption Analysis for the GOE and PET Unequal Erasure Protection Schemes, IEEE International Conference on Communications, 2012.
URL : https://hal.archives-ouvertes.fr/hal-00668826
A. Roumy, V. Roca, B. Sayadi, and R. Imad, Unequal erasure protection and object bundle protection with the generalized object encoding approach, 2011.
URL : https://hal.archives-ouvertes.fr/inria-00612583
P. Schelkens, Y. Andreopoulos, J. Barbarien, T. Clerckx, and F. Verdicchio, A comparative study of scalable video coding schemes utilizing wavelet technology, Proc. SPIE Photonics East Wavelet Applications in Industrial Processing, 2003.
N. Sellami, A. Roumy, and I. Fijalkow, Performance analysis of the MAP equalizer within an iterative receiver including a channel estimator, IEEE Vehicular Technology Conference, VTC'F04, 2004.
, The impact of both a priori information and channel estimation errors on the MAP equalizer performance, IEEE Trans. on Signal Processing, pp.2716-2724, 2006.
, A proof of convergence of the MAP turbo-detector to the AWGN case, IEEE Trans. on Signal Processing, vol.56, issue.4, pp.2716-2724, 2008.
N. Sellami, M. Siala, A. Roumy, and I. Kammoun, Generalized MAP: sequence detection for non ideal frequency selective channel knowledge, Proc.of ICASSP, IEEE Int. Conference on Acoustics, Speech and Signal Processing, 2007.
URL : https://hal.archives-ouvertes.fr/inria-00504583
, MAP sequence equalization for imperfect frequency selective channel knowledge, European Transactions on Telecommunications, vol.85, issue.2, pp.121-130, 2010.
S. Shalev-shwartz and S. Ben-david, Understanding Machine Learning: From Theory to Algorithms, 2014.
C. E. Shannon, A mathematical theory of communication, Part I, Part II, Bell Syst. Tech. J, vol.27, pp.623-656, 1948.
P. Shields and B. Weiss, Universal redundancy rates for the class of b-processes do not exist, IEEE Transactions on Information Theory, vol.41, issue.2, pp.508-512, 1995.
P. C. Shields, Universal redundancy rates do not exist, IEEE Transactions on Information Theory, vol.39, issue.2, pp.520-524, 1993.
D. Slepian and J. Wolf, Noiseless coding of correlated information sources, IEEE Transactions on Information Theory, vol.19, issue.4, pp.471-480, 1973.
J. Sole and P. Salembier, Generalized lifting prediction optimization applied to lossless image compression, IEEE Signal Processing Letters, vol.14, issue.10, pp.695-698, 2007.
V. Stankovic, A. D. Liveris, Z. Xiong, and C. Georghiades, On code design for the Slepian-Wolf problem and lossless multiterminal networks, IEEE Transactions on Information Theory, vol.52, issue.4, pp.1495-1507, 2006.
K. Suehring, B. Li, K. Sharman, V. Seregin, A. Tourapis et al., JCT-VC AHG report: HEVC HM, SCM, SHM and HDRTools software development and software technical evaluation (AHG3). Doc. JCTVC-AD0003, 2018.
C. Tillier and B. Pesquet-popescu, 3-band, 3-tap temporal lifting for scalable video coding, Proceedings 2003 International Conference on Image Processing, vol.3, 2003.
V. Toto-zarasoa, E. Magli, A. Roumy, and G. Olmo, On Distributed Arithmetic Codes and Syndrome Based Turbo Codes for Slepian-Wolf Coding of Non Uniform Sources, European Conf. on Signal Processing, 2009.
URL : https://hal.archives-ouvertes.fr/inria-00504605
V. Toto-zarasoa, A. Roumy, and C. Guillemot, Rate-adaptive codes for the entire Slepian-Wolf region and arbitrarily correlated sources, IEEE Intl. Conference on Acoustic, Speech and Signal Processing, 2008.
URL : https://hal.archives-ouvertes.fr/inria-00504588
, Hidden Markov model for Distributed Video Coding, International Conference on Image Processing (ICIP), 2010.
, Non-asymmetric Slepian-Wolf coding of non-uniform Bernoulli sources, International Symposium on Turbo Codes (ISTC), 2010.
, Non-uniform source modeling for Distributed Video Coding, European Signal Processing Conference (EUSIPCO), 2010.
V. Toto-zarasoa, A. Roumy, C. Guillemot, and C. Herzet, Robust and Fast Non Asymmetric Distributed Source Coding Using Turbo Codes on the Syndrome Trellis, IEEE Intl. Conf. on Acoustic, Speech and Signal Processing, 2009.
URL : https://hal.archives-ouvertes.fr/inria-00504589
V. Toto-zarasoa, A. Roumy, and C. Guillemot, Maximum Likelihood BSC parameter estimation for the Slepian-Wolf problem, IEEE Communications Letters, vol.15, issue.2, pp.232-234, 2011.
URL : https://hal.archives-ouvertes.fr/inria-00628996
, Source modeling for Distributed Video Coding, IEEE Trans. on Circuits and Systems for Video Technology, vol.22, issue.2, 2012.
J. A. Tropp and A. C. Gilbert, Signal recovery from random measurements via Orthogonal Matching Pursuit, IEEE Trans. on Information Theory, vol.53, issue.12, pp.4655-4666, 2007.
A. Tulino, G. Caire, S. Verdú, and S. Shamai, Support Recovery with sparsely sampled free random matrices, IEEE Trans. on Information Theory, vol.59, issue.7, pp.4243-4271, 2013.
D. Vukobratovic and V. Stankovic, Unequal error protection random linear coding strategies for erasure channels, IEEE Transactions on Communications, vol.60, issue.5, pp.1243-1252, 2012.
M. Watson, A. Begen, and V. Roca, Forward Error Correction (FEC) Framework, IETF Std. RFC 6363, 2011.
M. Wien, H. Schwarz, and T. Oelbaum, Performance Analysis of SVC, IEEE Transactions on Circuits and Systems for Video Technology, vol.17, pp.1194-1203, 2007.
J. Ziv and A. Lempel, A universal algorithm for sequential data compression, IEEE Transactions on Information Theory, vol.23, pp.337-343, 1977.
, Compression of individual sequences by variable rate coding, IEEE Transactions on Information Theory, vol.24, pp.530-536, 1978.
