Experiment and theory of plasmon coupling physics, wave effects and their study by electron spectroscopies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Expériences et théorie relatives au couplage plasmonique, aux effets ondulatoires et à leur étude par spectroscopie électronique
Hugo Lourenço-Martins
Surface plasmons (SP) are electromagnetic waves propagating at the interface between two media typically a metal and a dielectric. SPs can confine electromagnetic fields in very short volumes (typically one to few nanometers), well below the light diffraction limit. This property has a tremendous number of applications ranging from fundamental physics (e.g. quantum optics) to applications (e.g. cancer therapy). However, the price to pay is that SPs suffer from huge ohmic losses in the metal which leads to very short lifetimes (typically few femtoseconds). Theoretically, this presence of dissipation dramatically hardens the theoretical description of SPs. Another consequence of the sub-wavelength confinement of light associated with SPs is that their observation requires a nanometric resolution - which excludes the use of standard optical techniques. Yet, the scanning transmission electron microscope (STEM) is a particularly suitable tool to study SPs as it employs fast electrons with typical wavelength from 1 to 10 picometers. Thus, the last decade has seen the tremendous development of electron-based spectroscopies applied to nano-optics such as electron energy loss spectroscopy (EELS), cathodoluminescence spectroscopy (CL) or STEM- Hanbury Brown and Twiss interferometry (HBT). In this thesis, I explored different open problems of plasmonics and nano-optics under the scope of electron microscopy and spectroscopies. In chapter 3, I develop a formalism taking into account both the quantum and relativistic nature of EELS experiments using elements of quantum field theory. In chapter 4, I apply the latter formalism to the case of EELS measurements of SPs using electrons with shaped phase. In chapter 5, I give several theoretical and experimental results on coupling experiments involving SPs. Particularly, I demonstrate a counterintuitive type of coupling, the so-called self- hybridization which is a consequence of the non-Hermitian nature of the LSP eigenproblem and draw analogy with open quantum system. Finally, in chapter 6, I discuss the recent result on vibrational EELS in monochromated STEM.
Les plasmons de surface (SP) sont des ondes électromagnétiques se propageant à l'interface entre deux milieux, typiquement un métal et un diélectrique. Les plasmons de surface ont la capacité de confiner le champ électromagnétique dans de très petite région de l’espace, typiquement quelques nanomètres, c’est à dire bien en dessous de la limite de diffraction de la lumière. Une conséquence de ce confinement sub-longueur d’onde de la lumière est que leur observation nécessite une résolution spatiale nanométrique - ce qui exclut l’utilisation de techniques optiques standard. Néanmoins, le microscope électronique en transmission à balayage (STEM) est un outil particulièrement adapté à l'étude des plasmons de surface car il emploie des électrons rapides ayant une longueur d’onde typique comprise entre 1 et 10 picomètres. Ainsi, durant la dernière décennie, les spectroscopies électroniques appliquées à la nano-optique se sont fortement développées, parmi elle comptent : la spectroscopie de perte d'énergie électronique (EELS), la spectroscopie cathodoluminescence (CL) ou l'interférométrie de Hanbury Brown et Twiss (HBT) appliquée à la CL. Dans cette thèse, j’ai exploré différents problèmes ouverts de la plasmonique et de la nano-optique dans le cadre particulier de la microscopie électronique. Dans le chapitre 3, je présente un formalisme prenant en compte à la fois la nature quantique et relativiste des expériences d’EELS en faisant appel notamment à des éléments de théorie quantique des champs. Dans le chapitre 4, nous démontrons que la réalisation d’une expérience d’EELS avec de tels faisceaux permet de mesurer des propriétés jusqu’alors inatteignable à l’échelle du nanomètre telle que la phase des plasmons, leurs chiralité optique voire même leur longueur de cohérence. Dans le chapitre 5, je présente plusieurs résultats théoriques et expérimentaux concernant des expériences de couplage. En particulier, j’étudie le phénomène contre-intuitif d’auto-hybridation qui est une conséquence de la nature non-hermitienne du problème aux valeurs propres associé aux résonances de plasmon et établit une analogie avec les systèmes quantiques ouverts. Enfin, au chapitre 6, je discute des récentes mesures de phonon réalisées dans un STEM grâce au développement de monochromateur électroniques.
69544_LOURENCO_MARTINS_2018_diffusion.pdf (54.42 Mo) Télécharger le fichier
tel-01924457 , version 1 (16-11-2018)
  • HAL Id : tel-01924457 , version 1
Hugo Lourenço-Martins. Experiment and theory of plasmon coupling physics, wave effects and their study by electron spectroscopies. Condensed Matter [cond-mat]. Université Paris Saclay (COmUE), 2018. English. ⟨NNT : 2018SACLS284⟩. ⟨tel-01924457⟩
493 Consultations
165 Téléchargements
