Précipitation des gels de silice en solution aqueuse sursaturée à forte acidité : mécanismes et mésostructures, application à la filtrabilité des pulpes dans les procédés hydrométallurgiques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Precipitation of silica gel in supersaturated aqueous solutionn with high acidity : mechanisms ans mesostructures, application to filterability of slurries in hydrometallurgical processes
The formation of silica gels in hydrometallurgical processes is very often problematic for the performance of the solid-liquid separation steps, due to clogging of the filters. These steps are carried out downstream of leaching aiming to solubilize the elements of interests, in particular in solutions with strong acidity. Also dissolved during acidic leaching, the silicon then precipitates in the form of silicon oxide and forms gels extremely detrimental to filtration. In collaboration with ERAMET Research, a research center of ERAMET, a french mining group that designs hydrometallurgical processes, we studied the influence of the leaching conditions of a specific ore on the dissolution kinetics of silicon as well as on the mechanisms of precipitation of silica in an acidic solution. We have shown that below a pH value of 2, silica polymerizes to form gels following mechanisms independent of the ionic composition of the solution. Based, on the structural study of the gels, carried out by small angle radiation scattering (SAXS) we proposed a model for the mesotructure, which explain the impact on filtration rates. Subsequently, strategies to modify the mesostructure of the gels by physical or physicochemical approaches were considered. The results have shown the potentialities of these strategies in the short term to improve the filterability of precipitated silica gels in a hydrométallurgical process.
La formation de gels de silice dans les procédés hydrométallurgiques est très souvent problématique pour la performance des étapes de séparation solide-liquide, en raison du colmatage des filtres. Ces étapes interviennent en aval des étapes de lixiviation visant à mettre en solution les éléments d'intérêts, notamment dans des milieux à forte acidité. Egalement mis en solution au cours de ces attaques acides, le silicium précipite alors sous forme d'oxyde de silicium et forme des gels extrêmement préjudiciables à la filtration. Dans le cadre d'une collaboration avec ERAMET Research, centre de recherche d'ERAMET, groupe minier français qui conçoit des procédés hydrométallurgiques, nous avons étudié l'influence des conditions de lixiviation d'un minerai spécifique sur la cinétique de dissolution du silicium ainsi que sur les mécanismes de précipitation de la silice en milieu acide. Nous avons montré qu'en-dessous d'une valeur de pH égale à 2, la silice polymérise pour former des gels suivant des mécanismes indépendants de la composition ionique de la solution. L'étude structurale des gels obtenus, réalisée par diffusion de rayonnement aux petits angles (SAXS) nous a conduit à proposer un modèle pour la mésostructure qui permet de comprendre leur impact sur les vitesses de filtration. Par la suite, des stratégies consistant à modifier la mésostructure des gels par des approches physiques ou physico-chimiques ont été considérées. Les résultats obtenus ont montré la possibilité d'utiliser à court terme ces stratégies pour améliorer la filtrabilité des gels de silice dans un procédé hydrométallurgique.
2017TOU30251b.pdf (7.9 Mo) Télécharger le fichier
tel-01925392 , version 1 (16-11-2018)
  • HAL Id : tel-01925392 , version 1
Christian Manfoumbi. Précipitation des gels de silice en solution aqueuse sursaturée à forte acidité : mécanismes et mésostructures, application à la filtrabilité des pulpes dans les procédés hydrométallurgiques. Génie des procédés. Université Paul Sabatier - Toulouse III, 2017. Français. ⟨NNT : 2017TOU30251⟩. ⟨tel-01925392⟩
161 Consultations
2958 Téléchargements
