Discovering multi-relational association rules from ontological knowledge bases to enrich ontologies
Découverte de règles d'association multi-relationnelles à partir de bases de connaissances ontologiques pour l'enrichissement d'ontologies
In the Semantic Web context, OWL ontologies represent explicit domain knowledge based on the conceptualization of domains of interest while the corresponding assertional knowledge is given by RDF data referring to them. In this thesis, based on ideas derived from ILP, we aim at discovering hidden knowledge patterns in the form of multi-relational association rules by exploiting the evidence coming from the assertional data of ontological knowledge bases. Specifically, discovered rules are coded in SWRL to be easily integrated within the ontology, thus enriching its expressive power and augmenting the assertional knowledge that can be derived. Two algorithms applied to populated ontological knowledge bases are proposed for finding rules with a high inductive power: (i) level-wise generated-and-test algorithm and (ii) evolutionary algorithm. We performed experiments on publicly available ontologies, validating the performances of our approach and comparing them with the main state-of-the-art systems. In addition, we carry out a comparison of popular asymmetric metrics, originally proposed for scoring association rules, as building blocks for a fitness function for evolutionary algorithm to select metrics that are suitable with data semantics. In order to improve the system performance, we proposed to build an algorithm to compute metrics instead of querying via SPARQL-DL.
Dans le contexte du Web sémantique, les ontologies OWL représentent des connaissances explicites sur un domaine sur la base d'une conceptualisation des domaines d'intérêt, tandis que la connaissance correspondante sur les individus est donnée par les données RDF qui s'y réfèrent. Dans cette thèse, sur la base d'idées dérivées de l'ILP, nous visons à découvrir des motifs de connaissance cachés sous la forme de règles d'association multi-relationnelles en exploitant l'évidence provenant des assertions contenues dans les bases de connaissances ontologiques. Plus précisément, les règles découvertes sont codées en SWRL pour être facilement intégrées dans l'ontologie, enrichissant ainsi son pouvoir expressif et augmentant les connaissances sur les individus (assertions) qui en peuvent être dérivées. Deux algorithmes appliqués aux bases de connaissances ontologiques peuplées sont proposés pour trouver des règles à forte puissance inductive : (i) un algorithme de génération et test par niveaux et (ii) un algorithme évolutif. Nous avons effectué des expériences sur des ontologies accessibles au public, validant les performances de notre approche et les comparant avec les principaux systèmes de l'état de l'art. En outre, nous effectuons une comparaison des métriques asymétriques les plus répandues, proposées à l'origine pour la notation de règles d'association, comme éléments constitutifs d'une fonction de fitness pour l'algorithme évolutif afin de sélectionner les métriques qui conviennent à la sémantique des données. Afin d'améliorer les performances du système, nous avons proposé de construire un algorithme pour calculer les métriques au lieu d'interroger viaSPARQL-DL.
