Mathématiques discrètes appliquées à la cryptographie symétrique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
In this thesis, we study the security of symmetric cryptographic primitives. These systems are based on transformations relying on mathematical objects that can be represented in multiple ways. We then exploit different induced structures to highlight new vulnerabilities. By exploiting various representations, we cryptanalyzed some schemes submitted to the CAESAR competition, and also some dedicated and generic stream ciphers. We exhibited design criteria for lightweight block ciphers in view of the NIST standardization process and in the case of stream ciphers we defined new cryptographic criteria more relevant than the usual ones. More precisely, we study the security of lightweight block ciphers with respect to the recent invariant attacks, and we show how to avoid them with an appropriate choice of the linear layer and the round constants. We propose a new cryptanalysis of the filtered registers, by decomposing elements in the multiplicative subgroups of the finite field with 2^n elements. The analysis of the FLIP cipher, but also of the Goldreich pseudo-random generator, revealed weaknesses that are exploitable in ``guess and determine'' attacks. This leads to new criteria on the Boolean functions used in this context. Finally, we cryptanalyze a weaker version of the authenticated encryption scheme Ketje using several techniques, in order to refine the security evaluation of this cipher.
Dans cette thèse, nous étudions la sécurité de primitives cryptographiques. Ces systèmes sont fondés sur des transformations utilisant des objets mathématiques représentés de multiples manières. Nous utilisons alors certaines structures inhérentes à leurs composantes, et jusqu'alors non prises en compte, pour mettre en évidence de nouvelles vulnérabilités. Par l'exploitation de diverses représentations, nous avons ainsi cryptanalysé des chiffrements authentifiés de la compétition CAESAR, des chiffrements à flot spécifiques et des constructions génériques. Nous avons donné des critères de conception en vue de la standardisation par le NIST de chiffrements à bas coût. Dans le cas des chiffrements à flot, nous avons défini de nouveaux critères cryptographiques plus pertinents que les critères usuels. Plus précisément, nous analysons la sécurité des chiffrements par bloc légers au regard des récentes attaques par invariant, et nous montrons comment les éviter par un choix approprié de la couche linéaire de diffusion et des constantes de tour. Nous proposons une nouvelle cryptanalyse des registres filtrés, grâce à la décomposition des éléments dans les sous-groupes multiplicatifs du corps fini à 2^n éléments. L'analyse du chiffrement FLIP, mais aussi du générateur pseudo-aléatoire de Goldreich a mis en évidence des faiblesses exploitables dans des attaques de type ``supposer et déterminer'', qui nécessitent la prise en compte de nouveaux critères sur les fonctions booléennes utilisées dans ce contexte. Enfin, nous cryptanalysons une version simplifiée du chiffrement authentifié Ketje en utilisant plusieurs techniques, permettant ainsi d'affiner l'évaluation de sa sécurité.
2019SORUS092.pdf (2.31 Mo) Télécharger le fichier
tel-01944827 , version 1 (04-12-2018)
tel-01944827 , version 2 (10-10-2019)
  • HAL Id : tel-01944827 , version 2
Yann Rotella. Mathématiques discrètes appliquées à la cryptographie symétrique. Cryptographie et sécurité [cs.CR]. Sorbonne Université, 2018. Français. ⟨NNT : 2018SORUS092⟩. ⟨tel-01944827v2⟩
805 Consultations
2305 Téléchargements
