Toward unsupervised human activity and gesture recognition in videos - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Vers une reconnaissance des activités humaines non supervisées et des gestes dans les vidéos
The main goal of this thesis is to propose a complete framework for automatic discovery, modeling and recognition of human activities in videos. In order to model and recognize activities in long-term videos, we propose a framework that combines global and local perceptual information from the scene and accordingly constructs hierarchical activity models. In the first variation of the framework, a supervised classifier based on Fisher vector is trained and the predicted semantic labels are embedded in the constructed hierarchical models. In the second variation, to have a completely unsupervised framework, rather than embedding the semantic labels, the trained visual codebooks are stored in the models. Finally, we evaluate the proposed frameworks on two realistic Activities of Daily Living datasets recorded from patients in a hospital environment. Furthermore, to model fine motions of human body, we propose four different gesture recognition frameworks where each framework accepts one or combination of different data modalities as input. We evaluate the developed frameworks in the context of medical diagnostic test namely Praxis. Praxis test is a gesture-based diagnostic test, which has been accepted as a diagnostically indicative of cortical pathologies such as Alzheimer’s disease. We suggest a new challenge in gesture recognition, which is to obtain an objective opinion about correct and incorrect performances of very similar gestures. The experiments show effectiveness of our deep learning based approach in gesture recognition and performance assessment tasks.
L’objectif principal de cette thèse est de proposer un framework complet pour une découverte, modélisation et reconnaissance automatiques des activités humaines dans les vidéos. Afin de modéliser et de reconnaître des activités dans des vidéos à long terme, nous proposons aussi un framework qui combine des informations perceptuelles globales et locales issues de la scène, et qui construit, en conséquence, des modèles d’activités hiérarchiques. Dans la première catégorie du framework, un classificateur supervisé basé sur le vecteur de Fisher est formé et les étiquettes sémantiques prédites sont intégrées dans les modèles hiérarchiques construits. Dans la seconde catégorie, pour avoir un framework complètement non supervisé, plutôt que d’incorporer les étiquettes sémantiques, les codes visuels formés sont stockés dans les modèles. Nous évaluons les frameworks sur deux ensembles de données réalistes sur les activités de la vie quotidienne enregistrées auprés des patients dans un environnement hospitalier. Pour modéliser des mouvements fins du corps humain, nous proposons quatre différents frameworks de reconnaissance de gestes où chaque framework accepte une ou une combinaison de différentes modalités de données en entrée. Nous évaluons les frameworks développés dans le contexte du test de diagnostic médical, appelé Praxis. Nous proposons un nouveau défi dans la reconnaissance gestuelle qui consiste à obtenir une opinion objective sur les performances correctes et incorrectes de gestes très similaires. Les expériences montrent l’efficacité de notre approche basée sur l’apprentissage en profondeur dans la reconnaissance des gestes et les tâches d’évaluation de la performance.
2018AZUR4246.pdf (14.37 Mo) Télécharger le fichier
tel-01947341 , version 1 (06-12-2018)
tel-01947341 , version 2 (26-02-2019)
  • HAL Id : tel-01947341 , version 2
Farhood Negin. Toward unsupervised human activity and gesture recognition in videos. Computer Vision and Pattern Recognition [cs.CV]. Université Côte d'Azur, 2018. English. ⟨NNT : 2018AZUR4246⟩. ⟨tel-01947341v2⟩
615 Consultations
251 Téléchargements
