Tile lowrank approximation of large-scale maximum likelihood estimation on manycore architectures, 2018. ,
Robust memory-aware mappings for parallel multifrontal factorizations, SIAM Journal on Scientific Computing, vol.38, issue.3, pp.256-279, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01334113
Achieving high performance on supercomputers with a sequential task-based programming model, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01618526
Implementing multifrontal sparse solvers for multicore architectures with sequential task flow runtime systems, ACM Transactions on Mathematical Software (TOMS), vol.43, issue.2, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01333645
Parallel algebraic domain decomposition solver for the solution of augmented systems, Advances in Engineering Software, vol.60, pp.23-30, 2013. ,
URL : https://hal.archives-ouvertes.fr/inria-00559133
Tile Low Rank Cholesky Factorization for Climate/Weather Modeling Applications on Manycore Architectures, pp.22-40, 2017. ,
Taskparallel lu factorization of hierarchical matrices using ompss, Parallel and Distributed Processing Symposium Workshops (IPDPSW), 2017 IEEE International, pp.1148-1157, 2017. ,
Improving Multifrontal Methods by Means of Block Low-Rank Representations, SIAM Journal on Scientific Computing, vol.37, issue.3, pp.1451-1474, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01237169
, Encyclopedia of Parallel Computing, pp.1232-1238, 2011.
On the complexity of the block low-rank multifrontal factorization, SIAM Journal on Scientific Computing, vol.39, issue.4, pp.1710-1740, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01672943
Bridging the gap between flat and hierarchical low-rank matrix formats: the multilevel BLR format, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01774642
An approximate minimum degree ordering algorithm, SIAM Journal on Matrix Analysis and Applications, vol.17, issue.4, pp.886-905, 1996. ,
A fast block low-rank dense solver with applications to finite-element matrices, Journal of Computational Physics, vol.304, pp.170-188, 2016. ,
A fast, memory efficient and robust sparse preconditioner based on a multifrontal approach with applications to finiteelement matrices, International Journal for Numerical Methods in Engineering, vol.107, issue.6, pp.520-540, 2016. ,
, , 1992.
A Block Low-Rank Multithreaded Factorization for Dense BEM Operators, SIAM Conference on Parallel Processing for Scientific Computing (SIAM PP 2016), 2016. ,
, The Traveling Salesman Problem: A Computational Study (Princeton Series in Applied Mathematics), 2007.
Maxflow, min-cuts and multisectors of graphs, CSC14: The Sixth SIAM Workshop on Combinatorial Scientific Computing, p.17, 2014. ,
StarPU: a unified platform for task scheduling on heterogeneous multicore architectures. Concurrency and Computation: Practice and Experience, vol.23, pp.187-198, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00384363
Differential greedy for the 0-1 equicut problem, Proceedings of the DIMACS Workshop on Network Design: Connectivity and Facilities Location, pp.3-21, 1997. ,
Hierarchical matrices, 2008. ,
Mesh refinement in direct transcription methods for optimal control, Optimal Control Applications and Methods, vol.19, issue.1, pp.1-21, 1998. ,
, ScaLAPACK users' guide. SIAM, 1997.
Flexible development of dense linear algebra algorithms on massively parallel architectures with dplasma, Parallel and Distributed Processing Workshops and Phd Forum, pp.1432-1441, 2011. ,
Dongarra. Parsec: Exploiting heterogeneity to enhance scalability, Computing in Science & Engineering, vol.15, issue.6, pp.36-45, 2013. ,
Hypergraph partitioning for VLSI CAD: methodology for heuristic development, experimentation and reporting, Proceedings of the 36th annual ACM/IEEE Design Automation Conference, pp.349-354, 1999. ,
An improved recursive graph bipartitioning algorithm for well balanced domain decomposition, 21st IEEE International Conference on High Performance Computing (HiPC), pp.1-10, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01056749
An Efficient Solver for Sparse Linear Systems Based on Rank-Structured Cholesky Factorization, 2015. ,
Algorithmic study and complexity bounds for a nested dissection solver, Numerische Mathematik, vol.55, issue.4, pp.463-476, 1989. ,
Algorithm 887: Cholmod, supernodal sparse cholesky factorization and update/downdate, ACM Transactions on Mathematical Software (TOMS), vol.35, issue.3, p.22, 2008. ,
Worst-case analysis of a new heuristic for the travelling salesman problem, DTIC Document, 1976. ,
On the validity of a front-oriented approach to partitioning large sparse graphs with a connectivity constraint, Numerical Algorithms, vol.12, issue.1, pp.193-214, 1996. ,
The University of Florida sparse matrix collection, ACM Trans. Math. Softw, vol.38, issue.1, 2011. ,
A survey of direct methods for sparse linear systems, Acta Numerica, vol.25, pp.383-566, 2016. ,
A set of level 3 basic linear algebra subprograms, ACM Trans. Math. Softw, vol.16, issue.1, pp.1-17, 1990. ,
Randomized qr with column pivoting, SIAM Journal on Scientific Computing, vol.39, issue.4, pp.263-291, 2017. ,
Direct methods for sparse matrices, 1986. ,
The multifrontal solution of indefinite sparse symmetric linear, ACM Transactions on Mathematical Software (TOMS), vol.9, issue.3, pp.302-325, 1983. ,
The approximation of one matrix by another of lower rank, Psychometrika, vol.1, issue.3, pp.211-218, 1936. ,
Ordonnancement hybride statique-dynamique en algèbre linéaire creuse pour de grands clusters de machines NUMA et multi-coeurs. PhD thesis, LaBRI, 2009. ,
A linear-time heuristic for improving network partitions, Proceedings of the 19th design automation conference, pp.175-181, 1982. ,
A parallel direct/iterative solver based on a Schur complement approach, IEEE 11th International Conference on Computational Science and Engineering, pp.98-105, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00353547
Nested dissection of a regular finite element mesh, SIAM Journal on Numerical Analysis, vol.10, issue.2, pp.345-363, 1973. ,
Sparse Cholesky factorization on a local memory multiprocessor, SIAM Journal on Scientific and Statistical Computing, vol.9, pp.327-340, 1988. ,
Computer Solution of Large Sparse Positive Definite Systems, 1981. ,
On the application of the minimum degree algorithm to finite element systems, SIAM Journal on Numerical Analysis, vol.15, issue.1, pp.90-112, 1978. ,
A robust parallel preconditioner for indefinite systems using hierarchical matrices and randomized sampling, 2017 IEEE International Parallel and Distributed Processing Symposium, pp.897-906, 2017. ,
An Efficient Multicore Implementation of a Novel HSS-Structured Multifrontal Solver Using Randomized Sampling, SIAM Journal on Scientific Computing, vol.38, issue.5, pp.358-384, 2016. ,
Sparse approximations of the Schur complement for parallel algebraic hybrid linear solvers in 3D. Rapport de recherche RR-7237, INRIA, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00542450
A Robust Criterion for the Modified Gram-Schmidt Algorithm with Selective Reorthogonalization, SIAM Journal on Scientific Computing, vol.25, issue.2, pp.417-441, 2003. ,
Performance of H-LU preconditioning for sparse matrices, Computational methods in applied mathematics, vol.8, issue.4, pp.336-349, 2008. ,
Parallel black box H-LU preconditioning for elliptic boundary value problems. Computing and Visualization in Science, vol.11, pp.273-291, 2008. ,
Domain decomposition based H ? lu preconditioning, Numerische Mathematik, vol.112, issue.4, pp.565-600, 2009. ,
A Sparse Matrix Arithmetic Based on H-Matrices. Part I: Introduction to H-Matrices, Computing, vol.62, issue.2, pp.89-108, 1999. ,
, Hierarchical Matrices: Algorithms and Analysis, vol.49, 2015.
Data-sparse Approximation by Adaptive H 2Matrices, Computing, vol.69, issue.1, pp.1-35, 2002. ,
Finding structure with randomness: Probabilistic algorithms for constructing approximate matrix decompositions, SIAM review, vol.53, pp.217-288, 2011. ,
Error Detecting and Error Correcting Codes, Bell System Technical Journal, vol.26, issue.2, pp.147-160, 1950. ,
PaStiX: A High-Performance Parallel Direct Solver for Sparse Symmetric Definite Systems, Parallel Computing, vol.28, issue.2, pp.301-321, 2002. ,
On finding approximate supernodes for an efficient block-ILU (k) factorization, Parallel Computing, vol.34, issue.6-8, pp.345-362, 2008. ,
Hierarchical Interpolative Factorization for Elliptic Operators: Differential Equations, Communications on Pure and Applied Mathematics, vol.8, issue.69, pp.1415-1451, 2016. ,
Kernel methods in machine learning. The annals of statistics, pp.1171-1220, 2008. ,
Design of a multicore sparse Cholesky factorization using dags, SIAM Journal on Scientific Computing, vol.32, issue.6, pp.3627-3649, 2010. ,
Cache efficient bidiagonalization using blas 2.5 operators, ACM Trans. Math. Softw, vol.34, issue.3, p.33, 2008. ,
Lattice h-matrices on distributed-memory systems, 2018 IEEE International Parallel and Distributed Processing Symposium, IPDPS 2018, 2018. ,
DOI : 10.1109/ipdps.2018.00049
Parallel hierarchical matrices with block low-rank representation on distributed memory computer systems, Proceedings of the International Conference on High Performance Computing in Asia-Pacific Region, pp.232-240, 2018. ,
Fast and effective reordering of columns within supernodes using partition refinement, Proceedings of the Seventh SIAM Workshop on Combinatorial Scientific Computing, pp.76-86, 2018. ,
Greedy algorithms for k-way graph partitioning, the 6th international conference on advanced computing, 1998. ,
The Traveling Salesman Problem: A Case Study in Local Optimization, vol.1, pp.215-310, 1997. ,
METIS: A software package for partitioning unstructured graphs, partitioning meshes, and computing fill-reducing orderings of sparse matrices, 1995. ,
A fast and high quality multilevel scheme for partitioning irregular graphs, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.359-392, 1998. ,
H-LU factorization on many-core systems, Computing and Visualization in Science, vol.16, issue.3, pp.105-117, 2013. ,
Handbook of Multi and Many-Core Processing: Architecture, Algorithms, Programming, and Applications, 2014. ,
Scheduling and memory optimizations for sparse direct solver on multi-core/multi-gpu cluster systems, 2015. ,
Designing An Efficient and Scalable Block Low-Rank Direct Solver for Large Scale Clusters, SIAM Conference on Parallel Processing for Scientific Computing (SIAM PP 2016), 2016. ,
Taking advantage of hybrid systems for sparse direct solvers via task-based runtimes, HCW'2014 workshop of IPDPS, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00925017
A multilevel algorithm for partitioning graphs, ACM/IEEE conference on Supercomputing, 1995. ,
A hybridizable discontinuous galerkin method combined to a schwarz algorithm for the solution of 3d time-harmonic maxwell's equation, Journal of Computational Physics, vol.256, pp.563-581, 2014. ,
SuperLU_DIST: A Scalable Distributed-memory Sparse Direct Solver for Unsymmetric Linear Systems, ACM Trans. Math. Softw, vol.29, issue.2, pp.110-140, 2003. ,
Generalized nested dissection, SIAM journal on numerical analysis, vol.16, issue.2, pp.346-358, 1979. ,
A separator theorem for planar graphs, SIAM Journal on Applied Mathematics, vol.36, pp.177-189, 1979. ,
The role of elimination trees in sparse factorization, SIAM Journal on Matrix Analysis and Applications, vol.11, issue.1, pp.134-172, 1990. ,
On finding supernodes for sparse matrix computations, SIAM Journal on Matrix Analysis and Applications, vol.14, issue.1, pp.242-252, 1993. ,
Résolution directe rapide pour les éléments finis de frontière en électromagnétisme et acoustique : H-matrices. parallélisme et applications industrielles, 2014. ,
On the minimum flops problem in the sparse Cholesky factorization, SIAM Journal on Matrix Analysis and Applications, vol.35, issue.1, pp.1-21, 2014. ,
A fast randomized algorithm for computing a hierarchically semiseparable representation of a matrix, SIAM Journal on Matrix Analysis and Applications, vol.32, issue.4, pp.1251-1274, 2011. ,
Blocked rank-revealing qr factorizations: How randomized sampling can be used to avoid single-vector pivoting, 2015. ,
Block Low-Rank multifrontal solvers: complexity, performance, and scalability, 2017. ,
URL : https://hal.archives-ouvertes.fr/tel-01929478
A unified geometric approach to graph separators, Proc. 31st Annual Symposium on Foundations of Computer Science, pp.538-547, 1991. ,
Density graphs and separators, Second Annual ACM-SIAM Symposium on Discrete Algorithms, pp.331-336, 1991. ,
, Concorde TSP solver
Scotch and libScotch 5.1 User's Guide, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00410327
Computing the block triangular form of a sparse matrix, ACM Transactions on Mathematical Software (TOMS), vol.16, issue.4, pp.303-324, 1990. ,
Fast hierarchical solvers for sparse matrices using extended sparsification and low-rank approximation, SIAM Journal on Scientific Computing, vol.39, issue.3, pp.797-830, 2017. ,
Load Balancing for Parallel Coupled Simulations, 2016. ,
URL : https://hal.archives-ouvertes.fr/tel-01518956
Comparison of initial partitioning methods for multilevel direct k-way graph partitioning with fixed vertices. Parallel Computing, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01538600
ShyLU : A hybrid-hybrid solver for multicore platforms, Parallel Distributed Processing Symposium (IPDPS), 2012 IEEE 26th International, pp.631-643, 2012. ,
A study of clustering techniques and hierarchical matrix formats for kernel ridge regression, 2018 IEEE International Parallel and Distributed Processing Symposium Workshops, IPDPS Workshops, pp.883-892, 2018. ,
Adaptive cross approximation of dense matrices, Int. Association Boundary Element Methods Conf., IABEM, pp.28-30, 2002. ,
Algorithmic aspects of vertex elimination in directed graphs, SIAM Journal on Applied Mathematics, vol.34, issue.1, pp.176-197, 1978. ,
An analysis of several heuristics for the traveling salesman problem, SIAM J. Comput, vol.6, issue.3, pp.563-581, 1977. ,
Iterative methods for sparse linear systems, vol.82, 2003. ,
Über die auflösung linearer gleichungen mit unendlich vielen unbekannten, vol.25, pp.53-77, 1908. ,
The HSL Mathematical Software Library. A collection of Fortran codes for large scale scientific computation ,
Controlling the Memory Subscription of Distributed Applications with a Task-Based Runtime System, 21st International Workshop on High-Level Parallel Programming Models and Supportive Environments, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01284004
Scaling the solution of large sparse linear systems using multifrontal methods on hybrid shared-distributed memory architectures, 2014. ,
URL : https://hal.archives-ouvertes.fr/tel-01111259
Compress and eliminate" solver for symmetric positive definite sparse matrices, 2016. ,
Direct solutions of sparse network equations by optimally ordered triangular factorization, Proceedings of the IEEE, vol.55, pp.1801-1809, 1967. ,
A Parallel Geometric Multifrontal Solver Using Hierarchically Semis-Separable Structure, ACM Trans. Math. Softw, vol.42, issue.3, p.21, 2016. ,
Improving multifrontal solvers by means of algebraic block low-rank representations, 2013. ,
URL : https://hal.archives-ouvertes.fr/tel-00934939
Randomized sparse direct solvers, SIAM Journal on Matrix Analysis and Applications, vol.34, issue.1, pp.197-227, 2013. ,
Superfast Multifrontal Method For Large Structured Linear Systems of Equations, SIAM Journal on Matrix Analysis and Applications, vol.31, pp.1382-1411, 2009. ,
Fast parallel randomized qr with column pivoting algorithms for reliable low-rank matrix approximations, 2017 IEEE 24th International Conference on High Performance Computing (HiPC), pp.233-242, 2017. ,
On techniques to improve robustness and scalability of a parallel hybrid linear solver, International Conference on High Performance Computing for Computational Science, pp.421-434, 2010. ,
, Sparse Hierarchical Solvers with Guaranteed Convergence, 2016.
Geometry-oblivious fmm for compressing dense spd matrices, Proceedings of the International Conference for High Performance Computing, Networking, Storage and Analysis, p.53, 2017. ,
Sparse supernodal solver using block low-rank compression: Design, performance and analysis, International Journal of Computational Science and Engineering, vol.27, pp.255-270, 2018. ,
Reordering strategy for blocking optimization in sparse linear solvers, SIAM Journal on Matrix Analysis and Applications, vol.38, issue.1, pp.226-248, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01485507
Sparse Supernodal Solver Using Block Low-Rank Compression, PDSEC'2017 workshop of IPDPS, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01502215
Divide and Conquer Symmetric Tridiagonal Eigensolver for Multicore Architectures, 29th IEEE International Parallel & Distributed Processing Symposium, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01078356
, French conferences with proceedings
Utilisation de la compression Block Low-Rank pour accélérer un solveur direct creux supernodal, Conférence d'informatique en Parallélisme, Architecture et Système (ComPAS'17), 2017. ,
Exploiting Kepler architecture in sparse direct solver with runtime systems, 9th International Workshop on Parallel Matrix Algorithms and Applications (PMAA'2016), 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01421372
Blocking strategy optimizations for sparse direct linear solver on heterogeneous architectures, Sparse Days, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01187881
On the use of H-Matrix Arithmetic in PaStiX: a Preliminary Study, In Workshop on Fast Solvers, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01187882
Exploiting HMatrices in Sparse Direct Solvers, SIAM Conference on Parallel Processing for Scientific Computing, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01251812
On the use of low rank approximations for sparse direct solvers, SIAM Annual Meeting (AN'16), 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01421376
Sparse Supernodal Solver Using Hierarchical Compression, Workshop on Fast Direct Solvers, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01421368
Sparse Supernodal Solver exploiting Low-Rankness Property, Sparse Days, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01585622
Sparse Supernodal Solver Using Hierarchical Compression over Runtime System, SIAM Conference on Computation Science and Engineering (CSE'17), 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01421379
Exploiting Modern Manycore Architecture in Sparse Direct Solver with Runtime Systems, SIAM Conference on Computation Science and Engineering (CSE'17), 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01421383
Impact of blocking strategies for sparse direct solvers on top of generic runtimes, SIAM Conference on Parallel Processing for Scientific Computing, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01251808
Impact of Blocking Strategies for Sparse Direct Solvers on Top of Generic Runtimes, SIAM Conference on Computation Science and Engineering (CSE'17), 2017. ,
, French conferences without proceedings
Sparse supernodal solver with low-rank compression for solving the frequencydomain Maxwell equations discretized by a high order HDG method, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01660653
