Démographie et réponses adaptatives des populations végétales aux changements environnementaux - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Demography and adaptive responses of plant populations to environmental changes
Mediterranean region is a biodiversity hot-spot with a high endemism rate and is classified among the areas most sensitive to climate change. Deep understanding of demography and evolution following these changes is a necessity for species conservation. During this thesis, two rare Mediterranean plant species have been studied, Centaurea corymbosa and Brassica insularis, using recent mathematical models to analyse long term demographic datasets (22 and 18 years). In the first part of this thesis, matrix projection models have been used to analyse spatio-temporal variation in population growth rate in C. corymbosa. Major climatic parameters that impact population growth rate and survival, flowering and fecundity have been identified. A population viability analysis has been performed under various climatic scenarios. In a second part, an analysis of the population ability of C. corymbosa to response to these climatic changes has been performed using integral projection models. Temporal variation of life-history traits showed that the realized flowering strategy varied with climatic conditions following the same direction than the optimal flowering strategy. It can thus be concluded that the studied populations can adapt to climatic changes. Finally, capture-recapture models have been applied on the Brassica insularis dataset to analyse the effect of plant detectability on demographic parameter estimations. Survival probabilities obtained with the classical approach are lower than the ones estimated using the CR models. However, the parameters estimated using both methods are highly correlated, except for one population where individual identification is problematic. Results of this thesis are linked to some considerations in conservation biology of plants, particularly in link to their ability to respond to climatic changes.
La région méditerranéenne, hot-spot de biodiversité avec un fort taux d'endémisme, est classée parmi les zones les plus touchées par le changement climatique. La conservation des espèces nécessite de comprendre finement leur démographie face à ces changements, mais aussi leur capacité à s’adapter à ces nouvelles conditions. Au cours de cette thèse, deux espèces végétales rares méditerranéennes ont été étudiées, Centaurea corymbosa et Brassica insularis, en utilisant des modèles mathématiques récents pour analyser des suivis démographiques de long-terme (22 ans et 18 ans). Dans la première partie de cette thèse, des modèles de projection matriciels ont été construits afin d’analyser la variation spatio-temporelle des taux d’accroissement des populations de C. corymbosa. Cela a permis d'identifier les facteurs climatiques clefs qui impactent les taux d’accroissement des populations, et plus finement, les paramètres de survie, de floraison et de fécondité. Une analyse de viabilité des populations a été réalisée sous différents scénarios climatiques. Dans un second temps, une analyse de la capacité des populations de C. corymbosa à répondre à ces changements climatiques a été effectuée avec un modèle de projection intégral. Les changements des traits d’histoire de vie au cours du temps ont montré que la stratégie de floraison observée répond aux variations climatiques en suivant la même direction que la stratégie optimale. Ceci montre que les populations sont capables de s’adapter au changement climatique. Enfin, des modèles de capture-recapture (CR) ont été construits afin de déterminer l’influence de la faible détectabilité des individus sur l’estimation des paramètres démographiques chez B. insularis. Les probabilités de survie estimées par l’approche classique sont inférieures à celles estimées par les modèles CR. Les paramètres estimés par les deux approches sont en général très corrélés, à l'exception d'une population montrant des problèmes d'identification des individus. L'ensemble de cette thèse est replacé dans le cadre de la biologie de la conservation des espèces végétales, notamment en suggérant de prendre en compte leur capacité de réponse au changement climatique.
2018_HADJOU_BELAID_archivage.pdf (5.23 Mo) Télécharger le fichier
tel-01954646 , version 1 (13-12-2018)
  • HAL Id : tel-01954646 , version 1
Asma Hadjou Belaid. Démographie et réponses adaptatives des populations végétales aux changements environnementaux. Biologie végétale. Université Montpellier, 2018. Français. ⟨NNT : 2018MONTG034⟩. ⟨tel-01954646⟩
157 Consultations
602 Téléchargements
