Monitor and act : the role of the territory in the mobilization and implementation of a network for monitoring the quality of Breton rivers (1992-2017)
Surveiller et agir : le rôle du territoire dans la mobilisation et la mise en oeuvre d’un réseau de suivi de la qualité des cours d’eau bretons (1992-2017)
Since the establishment of the first national waterways and rivers quality monitoring in 1971, several types of measures coexist at the drainage basin scale: on the one hand, the monitoring networks supported by the State services; on theother hand, the water quality monitoring of the drainage basin (SQE-BV) provided by decentralized actors. The acquisition of complementary knowledge on water from the field measurement has accompanied the evolution of local practices of water management, in a different way depending on the regions, the basins and sub-basins. Thanks to the regulatory constraint and a State-Region partnership, Breton waterways have been the subject of a highly developed surveillance policy. This approach was motivated in the 1990s because of the urgency to act in front of a greater pollution visibility. This thesis illustrates the regionalised approach by several case studies, including that of the precursor basin of Yvel-Yvet. The whole thesis, based on the study of these local follow-ups and on a temporality of more than twenty years, mobilizes the concept of instrument of public action to explain the stages, the socio-political motivations and the implementation scales of this territorialized policy of regaining water quality.
Depuis la mise en place de la première surveillance de la qualité des cours d’eau et des rivières à l’échelle nationale en 1971, plusieurs types de mesures cohabitent à l’échelle du bassin-versant : les réseaux de surveillance pris en charge par les services de l’Etat, d’une part, les suivis qualité des eaux du bassin-versant (SQE-BV) assurés par des acteurs décentralisés d’autre part. L’acquisition de connaissances complémentaires sur l’eau issues de la mesure sur le terrain a accompagné l’évolution des pratiques locales de gestion de l’eau, de manière contrastée selon les régions, les bassins et sous-bassins. A la faveur de la contrainte réglementaire et d’un attelage partenarial Etat-Région, les cours d’eau bretons ont fait l’objet d’une politique de surveillance très développée. L’urgence d’agir face à une visibilité plus marquée de la pollution a motivé cette démarche dans les années 1990. Cette thèse illustre cette démarche régionalisée par plusieurs études de cas, dont celle du bassin précurseur de l’Yvel-Yvet. L’ensemble de la thèse, appuyée sur l’étude de ces suivis locaux et sur une temporalité de plus de vingt ans, mobilise le concept d’instrument d’action publique pour expliquer les étapes, les ressorts socio-politiques et les échelles de la mise en oeuvre de cette politique territorialisée de reconquête de la qualité des eaux.
