, Stage 1: Iteration 9
, Stage 1: Iteration 18
, Shape of a mockup submarine-shaped scatterer: target vs. computed parameters at different stagnations, noise-free mono-frequency case, vol.17
, To this end, it is necessary to study and exploit as much as possible each frequency with different regularization parameters. This is an ongoing work
Handbook of mathematical functions: with formulas, graphs, and mathematical tables, Courier Corporation, vol.55, 1964. ,
Sobolev spaces, vol.140, 2003. ,
Mumps: a multifrontal massively parallel sparse direct solver, 2013. ,
Conditions de Radiation sur le Bord, 1997. ,
Bayliss-turkel-like radiation conditions on surfaces of arbitrary shape, Journal of Mathematical Analysis and Applications, vol.229, issue.1, pp.184-211, 1999. ,
An interior penalty finite element method with discontinuous elements, SIAM journal on numerical analysis, vol.19, issue.4, pp.742-760, 1982. ,
Unified analysis of discontinuous Galerkin methods for elliptic problems, SIAM journal on numerical analysis, vol.39, issue.5, pp.1749-1779, 2002. ,
Characterization of the Fréchet derivative of the elasto-acoustic field with respect to Lipschitz domains, Journal of Inverse and Ill-Posed Problems, vol.22, issue.1, pp.1-8, 2014. ,
Efficient DG-like formulation equipped with curved boundary edges for solving elasto-acoustic scattering problems, International Journal for Numerical Methods in Engineering, vol.98, issue.10, pp.747-780, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00931852
On the existence and the uniqueness of the solution of a fluid-structure interaction scattering problem, Journal of Mathematical Analysis and applications, vol.412, issue.2, pp.571-588, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00903365
Mathematical Determination of the Fréchet Derivative with Respect to the Domain for a Fluid-Structure Scattering Problem. Case of Polygonal-Shaped Domains, Journal of Mathematical Analysis, pp.1-29, 2017. ,
Saint-Guirons. Two-dimensional approximate local dtn boundary conditions for elliptical-shaped boundaries, International Conference on Theoretical and Computational Acoustics, 2007. ,
Introduction of fréchet and gâteaux derivative, Applied Mathematical Sciences, vol.2, issue.20, pp.975-980, 2008. ,
Acoustic inverse scattering using topological derivative of far-field measurements-based l2 cost functionals, Inverse Problems, vol.29, issue.7, p.75012, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00835030
Apposition of the topological sensitivity and linear sampling approaches to inverse scattering, Wave Motion, vol.50, issue.5, pp.891-908, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00797649
Contributions à la modélisation mathématique et à l'algorithmique parallèle pour l'optimisation d'un propagateur d'ondes élastiques en milieu anisotrope, 2014. ,
On simultaneous identification of the shape and generalized impedance boundary condition in obstacle scattering, SIAM Journal on Scientific Computing, vol.34, issue.3, pp.1824-1848, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00741618
Electromagnetic and acoustic scattering by simple shapes, 1970. ,
Analyse fonctionnelle: théorie et applications, vol.91, 1999. ,
Inverse estimation of viscoelastic material properties for solids immersed in fluids using vibroacoustic techniques, Journal of applied physics, vol.101, issue.2, p.23509, 2007. ,
Inverse viscoelastic material characterization using pod reducedorder modeling in acoustic-structure interaction, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.9, pp.893-903, 2009. ,
2d elastic frequency-domain full-waveform inversion for imaging complex onshore structures, 71st EAGE Conference and Exhibition incorporating SPE EUROPEC, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00415715
Trace theorems on non-smooth boundaries for functional spaces related to Maxwell equations: an overview, Lecture notes in computational science and engineering, vol.28, pp.23-34, 2003. ,
Qualitative methods in inverse scattering theory: An introduction, 2005. ,
The finite element method for elliptic problems, 2002. ,
Recent developments in inverse acoustic scattering theory, Siam Review, vol.42, issue.3, pp.369-414, 2000. ,
A simple method for solving inverse scattering problems in the resonance region, Inverse problems, vol.12, issue.4, p.383, 1996. ,
Inverse acoustic and electromagnetic scattering theory, vol.93, 2012. ,
A simple method using Morozov's discrepancy principle for solving inverse scattering problems, Inverse Problems, vol.13, issue.6, p.1477, 1997. ,
Boundary integral operators on Lipschitz domains: elementary results, SIAM Journal on Mathematical Analysis, vol.19, issue.3, pp.613-626, 1988. ,
Shape derivatives of boundary integral operators in electromagnetic scattering. part I: Shape differentiability of pseudo-homogeneous boundary integral operators. Integral Equations and Operator Theory, vol.72, pp.509-535, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00453948
Boundary value problems for the systems of elastostatics in Lipschitz domains, Duke Math. J, vol.57, issue.3, pp.795-818, 1988. ,
, Lions. Mathematical Analysis and Numerical Methods for Science and Technology, vol.1, 2012.
On the characterization of the Fréchet derivative with respect to a Lipschitz domain of the acoustic scattered field, Journal of mathematical analysis and applications, vol.238, issue.1, pp.259-276, 1999. ,
Finite element solution of two-dimensional acoustic scattering problems using arbitrarily shaped convex artificial boundaries, Journal of Computational Acoustics, vol.8, issue.01, pp.81-99, 2000. ,
Continuous Fréchet differentiability with respect to a Lipschitz domain and a stability estimate for direct acoustic scattering problems, IMA journal of applied mathematics, vol.63, issue.1, pp.51-69, 1999. ,
Time domain topological gradient and time reversal analogy: an inverse method for ultrasonic target detection, Wave motion, vol.42, issue.1, pp.31-52, 2005. ,
Les inéquations en mécanique et en physique. Dunod, 1972. ,
A continuous derivative for real-valued functions, New Computational Paradigms, pp.493-519, 2008. ,
Contribution à l'analyse mathématique et à la résolution numérique d'un problème inverse de scattering élasto-acoustique, 2013. ,
On the solution of three-dimensional inverse obstacle acoustic scattering problems by a regularized Newton method. Inverse problems, vol.18, p.1229, 2002. ,
Numerical Experiments involving Large Scale Optimization Algorithms, Contributions to Seismic Full Waveform Inversion for Time Harmonic Wave Equations: Stability Estimates, 2017. ,
URL : https://hal.archives-ouvertes.fr/tel-01807861
Discontinuous galerkin methods for the helmholtz equation with large wave number, SIAM Journal on Numerical Analysis, vol.47, issue.4, pp.2872-2896, 2009. ,
Dg approximation of coupled navier-stokes and darcy equations by beaver-joseph-saffman interface condition, SIAM Journal on Numerical Analysis, vol.47, issue.3, pp.2052-2089, 2009. ,
Non-reflecting boundary conditions, Journal of computational physics, vol.94, issue.1, pp.1-29, 1991. ,
On nonreflecting boundary conditions, Journal of Computational Physics, vol.122, issue.2, pp.231-243, 1995. ,
Adaptive eigenspace method for inverse scattering problems in the frequency domain, Inverse Problems, vol.33, issue.2, p.25006, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01342694
A FEM-based direct method for material reconstruction inverse problem in soft tissue elastography, Computers & structures, vol.88, issue.23, pp.1459-1468, 2010. ,
Elliptic differential equations. Theory and Numerical Treatment, 1992. ,
Lectures on Cauchy's problem in linear partial differential equations, Courier Corporation, 2014. ,
On the Fréchet derivative for obstacle scattering with an impedance boundary condition, SIAM Journal on Applied Mathematics, vol.65, issue.1, pp.194-208, 2004. ,
The use of the L-curve in the regularization of discrete ill-posed problems, SIAM Journal on Scientific Computing, vol.14, issue.6, pp.1487-1503, 1993. ,
Valeurs propres d'un corps élastique. Comptes rendus de l, Académie des sciences. Série 1, vol.311, issue.13, pp.857-859, 1990. ,
Symmetric interior penalty dg methods for the compressible navier-stokes equations i: Method formulation, 2005. ,
Symmetric interior penalty dg methods for the compressible navier-stokes equations ii: Goal-oriented a posteriori error estimation, 2005. ,
, Fréchet derivatives in inverse obstacle scattering. Inverse problems, vol.11, p.371, 1995.
Iterative methods in inverse obstacle scattering: regularization theory of linear and nonlinear exponentially ill-posed problems, 1999. ,
Weak solutions of fluid-solid interaction problems, Mathematische Nachrichten, vol.218, issue.1, pp.139-163, 2000. ,
Boundary integral equations, vol.164, 2008. ,
An ultra-weak method for acoustic fluid-solid interaction, Journal of Computational and Applied Mathematics, vol.213, issue.1, pp.166-185, 2008. ,
Finite element analysis of acoustic scattering, vol.132, 2006. ,
Shape reconstruction of acoustic obstacles from the modulus of the far field pattern, Inverse Problems and Imaging, vol.1, issue.4, p.609, 2007. ,
Identification of sound-soft 3D obstacles from phaseless data, Inverse Problems and Imaging, vol.4, issue.1, pp.131-149, 2010. ,
Inverse scattering for surface impedance from phase-less far field data, Journal of Computational Physics, vol.230, issue.9, pp.3443-3452, 2011. ,
The Neumann problem on Lipschitz domains, Bulletin of the American Mathematical Society, vol.4, issue.2, pp.203-207, 1981. ,
Low-frequency scattering by a body in lubricated contact, The Quarterly Journal of Mechanics and Applied Mathematics, vol.36, issue.1, pp.111-138, 1983. ,
Sound, structures, and their interaction, vol.225, 1986. ,
, Numerical Methods for Inverse Problems, 2016.
The domain derivative and two applications in inverse scattering theory. Inverse problems, vol.9, p.81, 1993. ,
Characterization of the shape of a scattering obstacle using the spectral data of the far field operator, Inverse problems, vol.14, issue.6, p.1489, 1998. ,
Factorization of the far-field operator for the inhomogeneous medium case and an application in inverse scattering theory, Inverse Problems, vol.15, issue.2, p.413, 1999. ,
An introduction to the mathematical theory of inverse problems, vol.120, 2011. ,
A quasi-Newton method in inverse obstacle scattering, Inverse Problems, vol.10, issue.5, p.1145, 1994. ,
Inverse obstacle scattering with modulus of the far field pattern as data. Inverse problems in medical imaging and nondestructive testing, pp.75-92, 1997. ,
The seismic inverse problem as a sequence of before stack migrations, Conference on Inverse Scattering-Theory and Application, pp.206-220, 1983. ,
Scattering theory, vol.26, 1990. ,
Optimisation de forme d'antennes lentilles intégrées aux ondes millimétriques, 2009. ,
Fluid-solid interaction: acoustic scattering by a smooth elastic obstacle, SIAM Journal on Applied Mathematics, vol.55, issue.4, pp.904-922, 1995. ,
Eigentensors of linear anisotropic elastic materials, The Quarterly Journal of Mechanics and Applied Mathematics, vol.43, issue.1, pp.15-41, 1990. ,
Introduction to functional analysis, 1997. ,
A Newton method for solving the inverse scattering problem for a sound-hard obstacle, Inverse Problems, vol.12, issue.3, p.309, 1996. ,
The adaptive computation of far-field patterns by a posteriori error estimation of linear functionals, SIAM Journal on Numerical Analysis, vol.36, issue.1, pp.251-274, 1998. ,
Diffraction of elastic waves and dynamic stress concentrations, 1971. ,
Absorbing boundary conditions and perfectly matched layers in wave propagation problems, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00799759
Acoustic and electromagnetic equations: integral representations for harmonic problems, vol.144, 2001. ,
Mathematical problems in elasticity and homogenization, vol.26, 1992. ,
Three-dimensional frequency-domain full-waveform inversion with an iterative solver, Geophysics, 2009. ,
Thematic set: Full waveform inversion of a deep water ocean bottom seismometer dataset, First Break, vol.28, issue.4, pp.71-78, 2010. ,
Fréchet differentiability of boundary integral operators in inverse acoustic scattering, Inverse Problems, vol.10, issue.2, p.431, 1994. ,
Domain derivatives in electromagnetic scattering, Mathematical Methods in the Applied sciences, vol.19, issue.15, pp.1157-1175, 1996. ,
Fréchet differentiability of the solution to the acoustic Neumann scattering problem with respect to the domain, Journal of Inverse and Ill-Posed Problems, vol.4, issue.1, pp.67-84, 1996. ,
Bézier and B-spline techniques, 2013. ,
On scatterer reconstruction from far-field data, IEEE Transactions on Antennas and Propagation, vol.24, issue.1, pp.66-70, 1976. ,
Boundary element methods, Boundary Element Methods, pp.183-287, 2010. ,
Principles of functional analysis, vol.2, 1971. ,
The use of Morozov's discrepancy principle for Tikhonov regularization for solving nonlinear ill-posed problems, Computing, vol.51, issue.1, pp.45-60, 1993. ,
Eighty years of Sommerfeld's radiation condition, Historia mathematica, vol.19, issue.4, pp.385-401, 1992. ,
Die Greensche Funktion der Schwingungslgleichung, Jahresbericht der Deutschen Mathematiker-Vereinigung, vol.21, pp.309-352, 1912. ,
Inversion of seismic reflection data in the acoustic approximation, Geophysics, vol.49, issue.8, pp.1259-1266, 1984. ,
Weak elastic anisotropy, Geophysics, vol.51, issue.10, pp.1954-1966, 1986. ,
Solutions of ill-posed problems, vol.14, 1977. ,
Méthodes asymptotiques pour la propagation des ondes dans les milieux comportant des fentes, 2004. ,
Inverse material identification in coupled acoustic-structure interaction using a modified error in constitutive equation functional, Computational mechanics, vol.54, issue.3, pp.645-659, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00977526
Scattering theory for the d'Alembert equation in exterior domains, vol.442, 2006. ,
Acoustical scattering from an elastic sphere in water: Surface wave glory, resonances, and the Sommerfeld-Watson transformation for amplitudes, 1985. ,
Differential calculus in topological linear spaces, vol.374, 2006. ,
