Edge partitioning of large graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Partitionnement de grands graphes
Yifan Li
  • Fonction : Auteur
In this thesis, we mainly focus on a fundamental problem, graph partitioning, in the context of unexpectedly fast growth of data sources, ranging from social networks to internet of things. Particularly, to conquer intractable properties existing in many graphs, e.g. power-law degree distribution, we apply the novel fashion vertex-cut, instead of the traditional edge-cut method, for achieving balanced workload in distributed graph processing. Besides, to reduce the inter-partition communication cost, we present a block-based edge partition method who can efficiently explore the locality underlying graphical structures, to enhance the execution of graph algorithm. With this method, the overhead of both communication and runtime can be decreased greatly, compared to existing approaches. The challenges arising in big graphs also include their high-variety. As we know, most of real life graph applications produce heterogenous datasets, in which the vertices and/or edges are allowed to have different types or labels. A big number of graph mining algorithms are also proposed with much concern for the label attributes. For this reason, our work is extended to multi-layer graphs with taking into account the edges closeness and labels distribution during partitioning process. Its outstanding performance over real-world datasets is demonstrated finally.
Dans cette thèse nous étudions un problème fondamental, le partitionnement de graphe, dans le contexte de la croissance rapide des données, le volume des données continues à augmenter, allant des réseaux sociaux à l'internet des objets. En particulier, afin de vaincre les propriétés intraitables existant dans de nombreuses graphies, par exemple, la distribution des degrés en loi de puissance, nous appliquons un nouveau mode pour coupe de sommet, à la place de la méthode traditionnelle (coupe de bord), ainsi que pour assurer une charge de travail équilibrée et raisonnablement dans le traitement de graphe distribué. En outre, pour réduire le coût de communication inter-partitions, nous proposons une méthode de partition de bord basée sur les blocs, qui peut explorer efficacement les structures graphiques sous-jacentes au niveau local. , afin d'optimiser l'exécution de l'algorithme de graphe. Par cette méthode, le temps d'exécution et des communications généraux peuvent être considérablement réduits par rapport aux approches existantes. Les challenges qui se posent dans les grands graphiques comprennent également leur grande variété. Comme nous le savons, la plupart des applications graphiques au monde réel produisent des ensembles de données hétérogènes, dans lesquels les sommets et / ou les arêtes peuvent avoir des différents types ou des différentes étiquettes. De nombreuses algorithmes de fouille de graphes sont également proposés avec beaucoup d'intérêt pour les attributs d'étiquette. Pour cette raison, notre travail est étendu aux graphes de multicouches en prenant en compte la proximité des arêtes et la distribution des étiquettes lors du processus de partitionnement. En fin de cette thèse, Nous démontré à la ses performances exceptionnelles sur les ensembles de données du monde réel.
2017PA066346.pdf (3.45 Mo) Télécharger le fichier
tel-01956979 , version 1 (17-12-2018)
  • HAL Id : tel-01956979 , version 1
Yifan Li. Edge partitioning of large graphs. Social and Information Networks [cs.SI]. Université Pierre et Marie Curie - Paris VI, 2017. English. ⟨NNT : 2017PA066346⟩. ⟨tel-01956979⟩
273 Consultations
1206 Téléchargements
