Explicit la mort de Fromondin : édition et étude linguistique, littéraire et historique du passage correspondant aux vers 13935 à 14795 du ms. A de Gerbert de Mez d'après les douze mss complets ABCDEJMNPRSV et les trois amputés d'une partie de la fin ILQ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Explicit la mort de Fromondin : edition and linguistic, literary and historical study of the passage corresponding to verses 13935 to 14795 of the Ms. A of Gerbert de Mez from the twelve complete manuscripts ABCDEJMNPRSV and the three amputees of part of the end ILQ
This thesis is attached to a particular part of Gerbert of Metz, last part of the original Loherain cycle, the conclusion of the story (from the flight of Fromondin, the last of the Bordelais, until his death). This edition includes a detailed description and a comparative study of all the manuscripts available for this passage (twelve complete manuscripts: ABCDEJMNPRSV, and three amputees of the late IL1Q), a literary study attempting to analyze the originality of this conclusion with a narrative, stylistic and historical point of view, a linguistic analysis as well as a glossary, an index of proper nouns. The edition of the texts is presented in a semi-synoptic form in order to allow a comparative reading of the different families of manuscripts considered for the conclusion. The interest of this thesis is to propose new elements in the knowledge of the rich manuscript tradition of the Geste des Loherains, as well as in the possible writing of its conclusion (sources and interpretations).
La présente édition s’attache à une partie particulière de la chanson de Gerbert de Metz, dernière partie du cycle original des Loherains, à savoir la conclusion du récit (de la fuite de Fromondin, dernier des Bordelais, jusqu’à sa mort). Cette édition comprend une description détaillée et une étude comparative de tous les manuscrits disponibles pour ce passage (soit douze manuscrits complets : ABCDEJMNPRSV, et trois amputés de la fin IL1Q), une étude littéraire s’attachant à analyser l’originalité de cette conclusion d’un point de vue narratif, stylistique et historique, une analyse linguistique ainsi qu’un glossaire, un index des noms propres. L’édition des textes en elle-même se présente sous une forme semi synoptique afin de permettre une lecture comparative des différentes familles de manuscrits envisagées pour la conclusion. L’intérêt de cette thèse est de proposer de nouveaux éléments dans la connaissance de la riche tradition manuscrite de la Geste des Loherains, ainsi que dans la possible écriture de sa conclusion (sources et interprétations).
Gruber_Gauthier2.pdf (6.04 Mo) Télécharger le fichier
tel-01958177 , version 1 (17-12-2018)
  • HAL Id : tel-01958177 , version 1
Gauthier Grüber. Explicit la mort de Fromondin : édition et étude linguistique, littéraire et historique du passage correspondant aux vers 13935 à 14795 du ms. A de Gerbert de Mez d'après les douze mss complets ABCDEJMNPRSV et les trois amputés d'une partie de la fin ILQ. Littératures. Université de Valenciennes et du Hainaut-Cambresis, 2018. Français. ⟨NNT : 2018VALE0014⟩. ⟨tel-01958177⟩
209 Consultations
529 Téléchargements
