Contribution à la commande d'un onduleur multiniveaux, destinée aux énergies renouvelables, en vue de réduire le déséquilibre dans les réseaux électriques. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Contribution to the control of a multilevel inverter, intended for renewable energies, in order to reduce the imbalance in electrical networks
The work in this research thesis presents a contribution to voltage regulation in electrical networks. By considering adequate active and reactive powers injection into the grid, voltage control and load balancing are provided. These powers are generated from a grid connected renewable energy conversion system : a special attention was paid to the Wind Energy ConversionSystem (WECS) based on Doubly-Fed Induction Generator (DFIG).The typical control strategy for WECS is the maximum power coefficient tracking method. However, this method limits desirable ancillary power services, such as the participation of wind turbines in voltage regulation in the power grid. Therefore, a new method that derives the optimal power coefficient enhancing the participation of WTS in voltage regulation in the network (reactive and unbalanced power compensation), has been developed. The multilevel NPC (Neutral Point Clamped) converter, used for grid interface connection of renewable energy sources systems, has been studied. A predictive control method for the three-level NPC converter, capable of simultaneously compensating the problems of : DC link capacitors voltage balancing, load balancing and power factor correction in the power system, has been proposed. Then, the application of this predictive control was extended to simultaneously achieve multiple objectives: load balancing with power factor correction in the network, DC link capacitors voltage balancing, switching losses minimization and common mode voltage reduction. The switching losses minimization was obtained by proposing a new strategy which consists on exploiting the manufacturer datasheets that gives the evolution of the switching loss energy in function of the circulating current. The experimental curves of the datasheet are expressed in a mathematical model implemented in the predictive control. Simulation and experimental results are presented to evaluate the performance of the proposed method.
Le travail de cette thèse apporte une contribution aux méthodes de réglage de la tension dans les réseaux électriques. Il s’agit de fournir au réseau la puissance active et surtout la puissance réactive nécessaire pour réguler la tension et aboutir à un système équilibré vue du côté source. Ces puissances sont extraites d’une source d’energie renouvelable : une attention particulière a été portée à l’énergie éolienne raccordée au réseau à travers la Machine Asynchrone à Double Alimentation (MADA) pilotée par des convertisseurs statiques. Le système de contrôle le plus répandu des éoliennes est basé principalement sur la technique d’extraction du maximum de puissance. Cependant, cette technique limite la mise en oeuvre deservices auxiliaires, telle que la participation des éoliennes au réglage de la tension dans le réseau électrique. Pour cela, une nouvelle méthode d’extraction du coefficient de puissance optimal, permettant d’améliorer la participation de la MADA à la régulation de la tension dans le réseau (compensation de la puissance réactive et du déséquilibre), a été développée. Le convertisseur multiniveaux à structure NPC (Neutral Point Clamped) raccordant l’énergie renouvelable au réseau a été étudié. La commande prédictive assurant simulatnément l’amélioration du facteur de puissance, l’équilibrage du réseau électrique et du bus continu du convertisseur NPC a été proposée. Ensuite, l’application de cette commande prédictive a été elargie en lui attribuant plusieurs objectifs : amélioration du facteur de puissance avec équilibrage du réseau, équilibrage du bus continu, minimisation des pertes par commutation et réduction de la tension de mode commun. La minimisation des pertes a été obtenue en proposant une nouvelle stratégie qui consiste à exploiter les datasheets constructeurs donnant l’évolution de l’énergie dissipée durant la commutation en fonction du courant. Ces courbes expérimentales ont été transformées en modèlesmathématiques implémentés dans la commande prédictive. Les résultats de simulation et expérimentaux sont présentés pour évaluer les performances de la méthode proposée.
riachylea2.pdf (7.78 Mo) Télécharger le fichier
tel-01958589 , version 1 (18-12-2018)
  • HAL Id : tel-01958589 , version 1
Léa Riachy. Contribution à la commande d'un onduleur multiniveaux, destinée aux énergies renouvelables, en vue de réduire le déséquilibre dans les réseaux électriques.. Energie électrique. Normandie Université, 2017. Français. ⟨NNT : 2017NORMR076⟩. ⟨tel-01958589⟩
718 Consultations
1071 Téléchargements
