On error bounds of finite difference approximations to partial differential equations-temporal behaviour and rate of convergence, Journal of Scientific Computing, vol.15, issue.1, pp.79-116, 2000. ,
Computations of shortwaves in shallow water, Coast. Eng. Proc, pp.414-433, 1978. ,
An immersed boundary method using unstructured anisotropic mesh adaptation combined with level-sets and penalization techniques, J. Comput. Phys, vol.257, pp.83-101, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00786853
Large time existence for 3d water-waves and asymptotics, Invent. math, vol.171, pp.485-541, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00128402
Discrete duality finite volume schemes for leray-lions type elliptic problems on general 2d meshes, Num. Meth. for PDEs, vol.23, pp.145-195, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00005779
A penalization method to take into account obstacles in incompressible flows, Numer. Math, vol.81, issue.4, pp.497-520, 1999. ,
Sur les conditions hydrodynamiques au voisinage d'une interface milieu fluidemilieux poreux : application la convection naturelle, C.R. Acad. Sci. Paris II, vol.299, pp.1-4, 1984. ,
, , 2009.
Smoothing properties of implicit finite difference methods for a diffusion equation in maximum norm, SIAM J. Numer. Anal, vol.47, pp.2476-2495, 2009. ,
Uniform error estimates for navier-stokes flow with an exact moving boundary using the immersed interface method, SIAM J. Numer. Anal, vol.53, pp.2097-2111, 2015. ,
On the accuracy of finite difference methods for elliptic problems with interfaces, Commun. Appl. Math. Comput. Sci, vol.1, pp.91-119, 2006. ,
A second-order projection method for the incompressible Navier-Stokes equations, J. Comput. Phys, vol.85, issue.2, pp.257-283, 1989. ,
A computational fluid mechanics solution to the Monge-Kantorovich mass transfer problem, Numerische Matematik, vol.84, pp.375-393, 2000. ,
The Numerical Modelling of Nonlinear Stellar Pulsations, Problems and Prospects, chapter Smooth Particle Hydrodynamics : A Review, NATO ASIS Series, pp.269-287, 1989. ,
h-box methods for the approximation of hyperbolic conservation laws on irregular grids, SIAM J. on Numer. Analysis, vol.41, issue.3, pp.893-918, 2004. ,
An adaptive cartesian mesh algorithm for the euler equations in arbitrary geometries, 1989. ,
Stable boundary conditions for cartesian grid calculations, Computing systems in Engineering, vol.1, issue.2-4, pp.305-311, 1990. ,
Drag and drop simulations : from images to full 3d simulations, proc. of the eigth international conference on computational fluid dynamics, 2014. ,
An accurate cartesian method for incompressible flows with moving boundaries, Communications in Computational Physics, vol.15, issue.5, p.5, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00906897
A sharp cartesian method for the simulation of air-water interface, proc. of the eigth international conference on computational fluid dynamics, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01024657
Enablers for high order level set methods in fluid mechanics, Int. J. Numer. Meth. Fluids, vol.79, pp.654-675, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01097185
A sharp cartesian method for incompressible flows with large density ratios, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01331234
Artificial boundary conditions for the linearized benjamin-bonamahony equation, Numer. Math, vol.139, pp.281-314, 2018. ,
Discrete transparent boundary conditions for the mixed kdv-bbm equation, J. Comput. Phys, vol.345, pp.484-509, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01373388
A decomposed immersed interface method for variable coefficient elliptic equations with non-smooth and discontinuous solutions, J. Comput. Phys, vol.197, pp.364-386, 2004. ,
The exact order of convergence for finite difference approximations to ordinary boundary value problems, Math. Comput, vol.33, pp.1213-1228, 1979. ,
A second-order cut-cell method for the numerical simulation of 2d flows past obstacles, Computers and Fluids, vol.65, pp.80-91, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00570049
Numerical solution of the monge-kantorovich problem by density lift-up continuation, ESAIM : M2AN, vol.49, pp.1577-1592, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01250636
A continuum method for modeling surface tension, J. Comput. Phys, vol.100, issue.2, pp.335-354, 1992. ,
On the formulation of finite difference analogues of the dirichlet problem for poisson's equation, Numer. Math, vol.4, pp.313-327, 1962. ,
Convergence estimates for essentially positive type discrete dirichlet problems, Mathematics of Computation, vol.23, pp.695-709, 1969. ,
Generalized local maximum principles for finite-difference operators, Math. Comput, vol.27, pp.685-718, 1973. ,
Interior estimates for second-order elliptic differential (or finite-difference) equations via the maximum principle, Israel Journal of Mathematics, vol.7, pp.95-121, 1973. ,
Polar factorization and monotone rearrangement of vector-valued functions, Communication in Pure and Applied Mathematics, vol.64, pp.375-417, 1991. ,
Computational modeling of solid tumor growth : the avascular stage, SIAM J. Sci. Comput, vol.32, pp.2321-2344, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00148610
Numerical studies on the effect of electric pulses on an egg-shaped cell with a spherical nucleus, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00477495
Particle-mesh hydrodynamics and astrophysics simulation, International Journal of Modern Physics C, vol.18, pp.610-618, 2007. ,
The ls-stag method : A new immersed boundary/level-set method for the computation of incompressible viscous flows in complex moving geometries with good conservation properties, J. Comput. Phys, vol.229, pp.1043-1076, 2010. ,
Numerical solution of the Navier-Stokes equations, Math. Comp, vol.22, pp.745-762, 1968. ,
Discrete maximum principle for finite-difference operators, Aequationes Mathematica, vol.4, pp.338-352, 1970. ,
Discrete variational green functions, Numer. Math, vol.16, pp.115-128, 1970. ,
A parallel second order cartesian method for elliptic interface problems, Commun. Comput. Phys, vol.12, pp.1562-1587, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00577874
A supra-convergent finite difference scheme for the variable coefficient poisson equation on non-graded grids, J. Comput. Phys, vol.218, pp.123-140, 2006. ,
An accuracy assessment of cartesian mesh approaches for the euler equations, J. Comput. Phys, vol.117, pp.121-131, 1995. ,
A cartesian grid embedded boundary method for hyperbolic conservation laws, J. Comput. Phys, vol.211, issue.1, pp.347-366, 2006. ,
A vortex level set method for the two-way coupling of an incompressible fluid with colliding rigid bodies, J. Comput. Phys, vol.227, pp.9121-9137, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00297673
High order semi-lagrangian particles for transport equations : numerical analysis and implementation issues, ESAIM : Math. Modell. Numer. Anal, vol.48, pp.1029-1060, 2014. ,
Vortex methods, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-01063292
TVD remeshing schemes for particle methods, C. R. Acad. Sci. Paris, Ser. I, vol.347, pp.1367-1372, 2009. ,
Particle methods revisited : a class of high-order finite-difference schemes, C. R. Acad. Sci. Paris, Ser. I, vol.343, pp.51-56, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00354751
Développement d'un code de calcul pour la simulation d'écoulements de fluides non miscibles : application à la désintégration assistée d'un jet liquide par un courant gazeux, 2007. ,
A 3d discrete duality finite volume method for nonlinear elliptic equation, SIAM J. Sci. Comput, vol.33, pp.1739-1764, 2011. ,
A comparison of spectral and vortex methods in three-dimensional incompressible flow, ESAIM : Math. Modell. Numer. Anal, vol.34, pp.1123-1149, 2000. ,
Modified interpolation kernels for treating diffusion and remeshing in vortex methods, J. Comput. Phys, vol.213, pp.239-263, 2006. ,
Ghost-cell method for analysis of inviscid three dimensionnal flows on cartesian grids, Computers and Fluids, vol.36, pp.1513-1528, 2007. ,
Modelling electroporation in a single cell. I. Effects of field strength and rest potential, Biophysical Journal, vol.77, pp.1213-1224, 1999. ,
A spectrally refined interface approach for simulating multiphase flows, J. Comput. Phys, vol.228, pp.1658-1677, 2009. ,
A parallel fast sweeping method for the eikonal equation, J. Comput. Phys, vol.237, pp.46-55, 2013. ,
A finite volume method for the laplace equation on almost arbitrary two-dimensional grids, ESAIM : Math. Model. Numer. Anal, vol.39, pp.1203-1249, 2005. ,
Failure of the discrete maximum principle for an elliptic finite element problem, Math. Comput, vol.74, pp.1-23, 2005. ,
Second-order accurate computation of curvatures in a level set framework using novel high-order reinitialization schemes, J. Sci. Comput, vol.35, pp.114-131, 2008. ,
Second-order accurate computation of curvatures in a level set framework using novel high-order reinitialization schemes, J. Sci. Comput, vol.35, issue.2-3, pp.114-131, 2008. ,
The particle-in-cell method for hydrodynamics calculations, 1956. ,
Coupling an eulerian fluid calculation to a lagrangian solid calculation with the ghost fluid method, J. Comput. Phys, vol.175, pp.200-224, 2002. ,
A non-oscillatory eulerian approach to interfaces in multimaterial flows (the ghost fluid method), J. Comput. Phys, vol.152, pp.457-492, 1999. ,
On the supraconvergence of elliptic finite difference schemes, Applied Num. Math, vol.28, pp.275-292, 1998. ,
On the nonlinear behaviour of boussinesq type models : Amplitude-velocity vs amplitude-flux forms, Coastal Engineering, vol.99, pp.109-123, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01140635
A high order boundary treatment for cartesian grid methods, J. Comput. Phys, vol.140, pp.259-277, 1998. ,
Particle-wall collisions in a viscous fluid, Journal of Fluid Mechanics, vol.433, pp.329-346, 2001. ,
On stability condition for bifluid flows with surface tension : Application to microfluidics, J. Comput. Phys, vol.227, pp.6140-6164, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00274569
A level set based sharp interface method for the multiphase incompressible navierâ ? A ¸ Sstokes equations with phase change, J. Comput. Phys, vol.222, pp.536-555, 2007. ,
A fourth order accurate discretization for the laplace and heat equations on arbitrary domains, with applications to the stefan problem, J. Comput. Phys, vol.202, pp.577-601, 2005. ,
Smoothed particle hydrodynamics : theory and application to non-spherical stars, Mon. Not. R. Astr. Soc, vol.181, pp.375-389, 1977. ,
A simple second order cartesian scheme for compressible euler flows, J. Comput. Phys, vol.231, pp.7780-7794, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00701277
A simple second order cartesian scheme for compressible flows, Springer Proceedings in Mathematics, vol.4, pp.543-551, 2011. ,
An hamiltonian interface sph formulation for multi-fluid and free-surface flows, J. Comput. Phys, vol.228, pp.8380-8393, 2009. ,
The convergence rate for difference approximations to general initial boundary value problems, SIAM Journal of Numerical Analysis, vol.18, pp.179-190, 1981. ,
A discontinuous Galerkin method for elliptic interface problems with application to electroporation, Comm. Numer. Methods Engrg, vol.25, issue.10, pp.991-1008, 2009. ,
Fluid force acting on a particle falling toward a wall, JSME International Journal Series B, vol.44, issue.4, pp.520-525, 2001. ,
Numerical calculation of time-dependent viscous incompressible flow of fluid with free surface, Phys. Fluids, vol.8, pp.2182-2189, 1965. ,
Hydrodynamic problems involving large fluid distorsion, J. Assoc. Comp. Mach, vol.4, pp.137-142, 1957. ,
The influence of density ratio on the primary atomization of a turbulent jet in crossflow, Proc. Combust. Inst, vol.33, pp.2079-2088, 2011. ,
Volume of fluid (vof) method for the dynamics of free boundarie, J. Comput. Phys, vol.39, issue.1, pp.201-225, 1981. ,
A conservative interface method for compressible flows, J. Comput. Phys, vol.219, pp.553-578, 2006. ,
Convergence analysis of the immersed interface method, IMA J. Numer. Anal, vol.19, pp.583-608, 1999. ,
A coupling interface method for elliptic interface problems, J. Comput. Phys, vol.225, pp.2138-2174, 2007. ,
A shallow water approximation for water waves, J. Math. Kyoto Univ, vol.49, pp.13-55, 2009. ,
Hyperbolic free boundary problems and applications to wave-structure interactions ,
URL : https://hal.archives-ouvertes.fr/hal-01818940
Electrical modeling of the influence of medium conductivity on electroporation, Physical Chemistry Chemical Physics, vol.12, issue.34, pp.10055-10064, 2010. ,
Modelling the dynamics of a sphere approaching and bouncing on a wall in a viscous fluid, Journal of Fluid Mechanics, vol.747, pp.422-446, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00980559
Weighted ENO schemes for Hamilton-Jacobi equations, SIAM J. Sci. Comput, vol.21, issue.6, pp.2126-2143, 2000. ,
A cartesian grid embedded boundary method for poisson's equation on irregular domains, J. Comput. Phys, vol.147, pp.60-85, 1998. ,
Oblique particle-wall collisions in a liquid, Journal of Fluid Mechanics, vol.510, pp.71-93, 2004. ,
A boundary condition capturing method for multiphase incompressible flow, Journal of Scientific Computing, vol.15, issue.3, pp.323-360, 2000. ,
Classical electropermeabilization modeling at the cell scale, J. Math. Biol, vol.68, pp.235-265, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00712683
Dispersive models of ocean waves propagation : Numerical issues and modelling, 2018. ,
URL : https://hal.archives-ouvertes.fr/tel-01939447
An immersed boundary finite volume method for simulations of flow in complex geometries, J. Comput. Phys, vol.171, pp.132-150, 2001. ,
Inviscid axisymmetrization of an elliptical vortex, J. Comput. Phys, vol.138, pp.821-857, 1997. ,
Hybrid spectral particle method for the turbulent transport of a passive scalar, J. Comp. Phys, vol.260, pp.127-142, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00935487
Methode d'interface immergee pour la simulation directe de l'atomisation primaire, 2017. ,
Local lubrication model for spherical particles within an incompressible navier-stokes flow, Phys. Rev. E, vol.97, p.33313, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01585066
The Water Waves Problem : Mathematical Analysis and Asymptotics, Mathematical Surveys and Monographs, vol.188, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01101991
Generating boundary conditions for a Boussinesq system ,
URL : https://hal.archives-ouvertes.fr/hal-01982925
Convergence des méthodes particulaires renormalisées pour les systèmes de Friedrichs, C. R. Acad. Sci. Paris, Ser I, vol.349, pp.465-470, 2005. ,
Renormalized meshfree schemes II : convergence for scalar conservation laws, SIAM J. Numer. Anal, vol.46, pp.1935-1964, 2008. ,
Towards the ultimate conservative difference scheme i. the quest of monotonicity, Lecture notes in Physics, vol.18, p.163, 1972. ,
A second-order cartesian method for the simulation of electropermeabilization cell models, J. Comput. Phys, vol.292, pp.114-140, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01158377
The immersed interface method for elliptic equations with discontinuous coefficients and singular sources, SIAM Numerical Analysis, vol.31, issue.4, pp.1019-1044, 1994. ,
Boundary value problems for quasilinear hyperbolic systems, Duke University Mathematics ser, vol.5, 1985. ,
URL : https://hal.archives-ouvertes.fr/inria-00076486
Accurate solution and grandient computation for elliptic interface problems with variable coefficients, SIAM J. Numer. Anal, vol.55, pp.570-597, 2017. ,
Superconvergence of solution derivatives for the Shortley-Weller difference approximation to Poisson's equation with singularities on polygonal domains, Applied Num. Math, vol.58, pp.689-704, 2008. ,
Superconvergence of solution derivatives for the Shortley-Weller difference approximation of Poisson's equation. part i : smoothness problems, J. Comp. Applied Math, vol.151, pp.307-333, 2003. ,
A fast iterative algorithm for elliptic interface problems, SIAM J. Numer. Anal, vol.35, pp.230-254, 1998. ,
Maximum principle preserving schemes for interface problems with discontinuous coefficients, SIAM J. Sci. Comput, vol.23, pp.339-361, 2001. ,
A boundary condition capturing method for poisson's equation on irregular domains, J. Comput. Phys, vol.160, pp.151-178, 2000. ,
A boundary capturing method for poisson's equation on irregular domains, J. Comput. Phys, vol.160, pp.151-178, 2000. ,
Convergence of the ghost fluid method for elliptic equations with interfaces, Math. Comput, vol.72, pp.1731-1746, 2003. ,
Numerical solution of the monge-ampere equation by a newton's algorithm, C. R. Acad. Sci. Paris, Ser. I, vol.340, pp.319-324, 2005. ,
Simulating water and smoke with an octree data structure, ACM transactions on graphics, vol.23, pp.457-462, 2004. ,
Enablers for high-order level set methods in fluid mechanics, Int. J. Numer. Meth. Fluids, vol.79, pp.654-675, 2015. ,
Accurate, non-oscillatory, remeshing schemes for particle methods, J. Comput. Phys, vol.231, issue.1, pp.152-172, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00588848
Numerical viscosity and the entropy condition, Comm. Pure Appl. Math, vol.32, pp.797-838, 1979. ,
Theoretical and Numerical Study of Shallow Water Models. Applications to Nearshore Hydrodynamics, 2005. ,
An experimental study of the collapse of liquid columns on a rigid horizontal plane, Philos. Trans. R. Soc. London, Ser. A, vol.244, pp.312-324, 1952. ,
Superconvergence of the Shortley-Weller approximation for Dirichlet problems, J. Comp. Applied Math, vol.116, pp.263-273, 2000. ,
Direct numerical simulations of three-dimensional flows past obstacles with a vortex penalization method, Computers and Fluids, vol.183, pp.331-347, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01855265
A versatile sharp interface immersed boundary method for incompressible flows with complex boundaries, J. Comput. Phys, vol.227, pp.4825-4852, 2008. ,
Why particle methods work, SIAM J. Sci. Stat. Comput, vol.3, issue.4, pp.422-433, 1982. ,
Smoothed particle hydrodynamics, Annu. Rev. Astron. Astrophys, vol.30, pp.543-574, 1992. ,
Convergence of SPH methods for scalar nonlinear conservation laws, SIAM J. Numer. Anal, vol.37, issue.3, pp.863-887, 2000. ,
Level Set Methods and Dynamic Implicit Surfaces, 2003. ,
Fronts propagating with curvature-dependent speed : algorithms based on Hamilton-Jacobi formulations, J. Comput. Phys, vol.79, issue.1, pp.12-49, 1988. ,
Collision model for fully-resolved simulations of flows laden with finite-size particles, Physical Review E, vol.92, issue.5, p.10, 2015. ,
Bouncing motion of spherical particles in fluids, Physics of Fluids, vol.14, issue.2, pp.643-652, 2002. ,
Optimal transport with proximal splitting, SIAM on Journal on Imaging Sciences, vol.7, pp.212-238, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00918460
An adaptive cartesian grid method for unsteady compressible flows in irregular regions, J. Comput. Phys, vol.120, pp.278-304, 1995. ,
The fluid dynamics of heart valves : experimental, theoretical and computational methods, Annu. Rev. Fluid Mech, vol.14, pp.235-259, 1981. ,
The one-dimensional shallow water equations with transparent boundary conditions, Mathematical Methods in the Applied Sciences, vol.36, pp.1979-1994, 2013. ,
Gerris : a tree-based adaptive solver for the incompressible euler equations in complex geometries, J. Comput. Phys, vol.190, pp.572-600, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-01445436
A three-dimensional conservative coupling method between an inviscid compressible flow and a moving rigid solid, SIAM J. Sci. Comput, vol.37, pp.884-909, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00974602
Consistent mass and momentum transport for simulating incompressible interfacial flows with large density ratios using the level set method, Computers and Fluids, vol.63, pp.70-81, 2012. ,
A viscosity solutions approach to shape-from-shading, SIAM J. Numer. Anal, vol.29, issue.3, pp.867-884, 1992. ,
A volume-tracking method for computing incompressible multifluid flows with large density variations, Int. J. Numer. Meth. Fluids, vol.28, pp.357-378, 1998. ,
A remark on computing distance functions, J. Comput. Phys, vol.163, issue.1, pp.51-67, 2000. ,
Sparskit a basic tool-kit for sparse matrix computations ,
An efficient numerical algorithm for the l2 optimal transport problem with periodic densities, IMA Journal of Applied Mathematics, 2013. ,
Optimal linfty estimates for the finite element method on irregular meshes, Math. Comput, vol.30, pp.681-697, 1976. ,
Convergence analysis in the maximum norm of the numerical gradient of the shortleyweller method, J. Sci. Comput, vol.74, pp.631-639, 2017. ,
A fast marching level set method for monotonically advancing fronts, Proc. Nat. Acad. Sci. U.S.A, vol.93, issue.4, pp.1591-1595, 1996. ,
A coupled level set and volume of fluid method for computing 3d and axisymmetric incompressible two-phase flows, J. Comput. Phys, vol.162, pp.301-337, 2000. ,
A sharp interface method for incompressible two-phase flows, J. Comput. Phys, vol.221, pp.469-505, 2007. ,
A level-set approach for computing solutions to incompressible two-phase flows, J. Comput. Phys, vol.114, pp.146-159, 1994. ,
Inverse lax-wendroff procedure for numerical boundary conditions of conservation laws, J. Comput. Phys, vol.229, pp.8144-8166, 2010. ,
A level set method for vaporizing two-phase flows, J. Comput. Phys, vol.221, pp.837-853, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00649783
Sur l'approximation de la solution des equations de navier-stokes par la methode des pas fractionnaires ii, Archiv. Rat. Mech. Anal, vol.32, pp.377-385, 1969. ,
Elliptic difference equations and interior regularity, Numer. Math, vol.1, pp.196-210, 1968. ,
Direct numerical simulations of gas-liquid multiphase flows, 2011. ,
Fast sweeping algorithms for a class of Hamilton-Jacobi equations, SIAM J. Numer. Anal, vol.41, issue.2, pp.673-694, 2003. ,
A ghost cell immersed boundary method for flow in complex geometry, J. Comput. Phys, vol.192, pp.593-623, 2003. ,
In pursuit of grid convergence for two-dimensional euler solutions, Journal of Aircraft, vol.47, issue.4, pp.1152-1166, 2010. ,
Discrete maximum principle for higher-order finite elements in 1d, Math. Comput, vol.76, pp.1833-1846, 2007. ,
Topics in optimal transportation, 2003. ,
Optimal Transport, old and new, 2009. ,
Méthode particulaire multi-niveaux pour la dynamique des gaz, application au calcul d'écoulements multifluides, 2006. ,
Convergence of a cartesian method for elliptic problems with immersed interfaces, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01280283
Super-convergence in maximum norm of the gradient for the shortley-weller method, J. Sci. Comput, vol.75, pp.625-637, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01896220
Consistency, accuracy and entropy behaviour of remeshed particle methods, ESAIM : Mathematical Modelling and Numerical Analysis, vol.47, pp.57-81, 2013. ,
The explicit jump immersed interface method : finite difference method for PDEs with piecewise smooth solutions, SIAM J. Numer. Anal, vol.37, issue.3, pp.827-862, 2000. ,
Convergence analysis of the standard central finite difference method for Poisson equation, J Sci Comput, vol.67, pp.602-617, 2016. ,
High order fast sweeping methods for static Hamilton-Jacobi equations, J. Sci. Comput, vol.29, issue.1, pp.25-56, 2006. ,
A fast sweeping method for eikonal equations, Math. Comp, vol.74, issue.250, pp.603-627, 2005. ,
A new high-order immersed interface method for solving elliptic equations with imbedded interface of discontinuity, J. Comput. Phys, vol.225, pp.1066-1099, 2007. ,
High order matched interface and boundary method for elliptic equations with discontinuous coefficients and singular source, J. Comput. Phys, vol.213, pp.1-30, 2006. ,
