Metabolic changes during brain activation : study by nuclear magnetic resonance spectroscopy of proton and carbon 13
Modifications métaboliques lors de l'activation cérébrale : suivi par spectroscopie de résonance magnétique nucléaire du proton et du carbone 13
Lactate has been considered as a waste metabolite for many years. However, this vision has been reconsidered recently, with the appearance of the notion of aerobic glycolysis and lactate shuttles in different cell types (muscle, brain, and sperm). Concerning the brain, in vitro, ex vivo and in vivo studies carried out over the last 20 years have shown, on the one hand, that astrocytes produce lactate and, on the other hand, that lactate can be an energetic substrate for the central nervous system (CNS), and more particularly neurons. This lactate shuttle between astrocyte and neuron was first proposed in 1994 by Pellerin and Magistretti (called ANLS, for astrocyte-neuron lactate shuttle). Despite many studies since then, the existence of a net transfer of lactate between astrocytes and neurons has still not been demonstrated in vivo. In this regard, visualization of lactate production in vivo in the activated brain is essential. The role of lactate transporters, MCTs (Monocarboxylate Transporters), in detecting this signal is also a key issue. The objective of this thesis was to develop in vivo NMR spectroscopy located in the somato-sensory cortex of rats under brain activation conditions. First, experiments were carried out to develop the neural stimulation protocol and to obtain a sufficient signal-to-noise ratio to be able to quantify lactate. Once the protocol was established on control rats, the study was performed on genetically modified rats and down-regulated for MCT, either neuronal or astrocytic. The aim was to determine whether this key partner of the ANLS has an influence on lactate fluctuations during brain activation. In addition to in vivo proton spectroscopy and functional MRI, carbon-13 NMR studies were performed ex vivo. The major result of this thesis shows that in the absence of the neuronal lactate transporter, not only is the increase in lactate lost during brain stimulation but the BOLD signal on the fMRI is also lost. This result suggests, for the first time, that neural activity is highly dependent on the lactate transporter.
Le lactate est considéré comme un métabolite déchet depuis de très nombreuses années. Cependant, cette vision semble revisitée depuis quelques temps, avec l'apparition de la notion de glycolyse aérobie et de navettes lactate dans différents types cellulaires (muscle, cerveau et sperme). Concernant le cerveau, des études in vitro, ex vivo et in vivo réalisées ces 20 dernières années ont montré, d'une part, que les astrocytes produisent du lactate et d’autre part que le lactate pouvait être un substrat énergétique pour le système nerveux central (SNC), et plus particulièrement les neurones. Cette notion de navette lactate entre astrocyte et neurone a été proposée pour la première fois en 1994 par Pellerin et Magistretti (ANLS, pour astrocyte-neuron lactate shuttle). Malgré de nombreuses recherches depuis, l'existence d'un transfert net de lactate entre les astrocytes et les neurones n'a toujours pas pu être démontrée in vivo. Dans cet optique, la visualisation de la production de lactate in vivo dans le cerveau activé est essentielle. Le rôle des transporteurs au lactate, MCTs (Monocarboxylate Transporters), dans la détection de ce signal est également un point capital. L’objectif de cette thèse a été de développer la spectroscopie de RMN in vivo localisée dans le cortex somato-sensoriel du rat en condition d’activation cérébrale. Dans un premier temps, un travail de développement a été effectué afin de mettre au point le protocole de stimulation neuronale et d’obtenir un rapport signal sur bruit suffisant pour pouvoir quantifier de façon fiable le lactate. Une fois le protocole établi sur des rats contrôles, l’étude a été réalisée sur des rats modifiés génétiquement et réprimés pour le MCT, soit neuronal, soit astrocytaire. Le but était de déterminer si ce partenaire clef de l’ANLS avait une influence sur les fluctuations de lactate lors de l'activation cérébrale. En plus de la spectroscopie proton in vivo et de l’IRM fonctionnelle, des études de RMN du carbone-13 ont été réalisées ex vivo. Le résultat majeur de cette thèse montre qu’en l’absence du transporteur de lactate neuronal, non seulement on perd l’augmentation de lactate lors de la stimulation cérébrale mais on perd également le signal BOLD sur l’IRMf. Ce résultat suggère, et ce pour la première fois, que l’activité neuronale est fortement dépendante du transporteur au lactate.
