Etude de Vulcanodinium rugosum (Dinoflagellé producteur de pinnatoxines) se développant dans la lagune méditerranéennede l’Ingril. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
A study on Vulcanodinium rugosum (dinoflagellate producing pinnatoxins) growing in Ingril a french mediterranean lagoon
Harmful and / or toxic phytoplankton blooms impact for a long time marine ecosystems worldwide. These massive developments have an adverse effect on ecosystems and their exploitation. The lagoons of the region Languedoc-Roussillon are affected for decades. In addition to recurring health risks from Dinophysis (DSP toxins) and Alexandrium (PSP toxins), Vulcanodinium rugosum was identified in 2011 in the lagoon Ingril. This new species product pinnatoxins (neurotoxins). Through this thesis work, the biology of this new species (life cycle, growth condition, toxin production), its shellfish contamination capacity and geographic distribution in neighboring lagoons were studied on cultures in the laboratory and via environmental monitoring.The results of this study have demonstrated its thermophilic and euryhaline features (optimum salinity and temperature of 25°C and 40 respectively) and its growth ranges between 20 and 30°C. Its ability to grow on an organic nitrogen source (urea) has been showed in vitro. Its expansion in other lagoons of Languedoc-Roussillon, was confirmed by the contamination of the mussels by the pinnatoxin G. The survival of this organism in the digestive tract of mussels and oysters proves that the transfer of shellfish is potentially a source of contamination of new ecosystems not yet affected by this toxic species.The life cycle of V. rugosum has not been fully described because the resistance cyst has not been formally identified. Temporary cysts appear as very important stages to be considered because of their ability to divide and their strong presence on macrophytes. These temporary forms of resistance may be a significant source of contamination of shellfish in the lagoon of the Ingril even when the vegetative cells of V. rugosum are weakly present in the water column. Because of the low densities of V. rugosum in situ and the difficulty of its identification on morphological criteria, the monitoring within the REPHY protocol remains difficult. Thus the use of passive sampling systems (Spatt) made with resins which adsorb toxins dissolved in water would make possible the early detection of toxins associated with these emerging benthic species. This study highlights the growth of an emerging thermophilic species that might with others and thanks to climate change provide important health and economic problems in vulnerable lagoon ecosystems of the Mediterranean.
Les efflorescences phytoplanctoniques nuisibles et/ou toxiques impactent depuis très longtemps les écosystèmes marins du monde entier. Ces développements massifs ont un effet néfaste sur les écosystèmes et leur exploitation. Les lagunes du Languedoc-Roussillon sont touchées depuis plusieurs décennies. En plus des risques sanitaires récurrents dus aux genres Dinophysis (toxines DSP) et Alexandrium (toxines PSP), Vulcanodinium rugosum a été identifiée en 2011 dans la lagune d’Ingril. Cette nouvelle espèce est productrice de pinnatoxines (neurotoxines). A travers ces travaux de thèse, la biologie de cette nouvelle espèce (cycle de vie, condition de croissance, production de toxines), ses capacités de contamination des mollusques et sa distribution géographique dans les lagunes limitrophes ont été étudiées sur des cultures au laboratoire et via des suivis environnementaux.Les résultats de cette étude ont mis en évidence le caractère thermophile et euryhalin de cette microalgue (croissance optimale à 25°C et à une salinité de 40 ) avec des plages de croissance comprises entre 20 et 30°C. Sa capacité à croître sur une source azotée organique (urée) a été observée in vitro. Son expansion à des lagunes du Languedoc-Roussillon autre que l’étang d’Ingril, a été confirmée par la mise en évidence de la contamination des moules par la pinnatoxine G. La survie de ce dinoflagellé dans le tractus digestif des moules et des huîtres prouve que le transfert de coquillages est une source de contamination potentielle des écosystèmes non impactés par cette espèce toxique.Le cycle de vie de V. rugosum n’a pu être élucidé que partiellement, le kyste de résistance n’ayant pas été identifié formellement. Les kystes temporaires apparaissent comme des stades très importants à prendre en considération en raison de leur capacité à se diviser et de leur forte présence sur les macrophytes. Ces formes temporaires de résistance peuvent constituer une source de contamination non négligeable des mollusques dans la lagune de l’Ingril même lorsque les cellules végétatives de V. rugosum sont peu présentes dans la colonne d’eau. En raison des faibles densités de V. rugosum in situ et la difficulté de son identification sur des critères morphologique, sa surveillance dans le cadre du REPHY demeure difficile. Ainsi l’utilisation de systèmes d’échantillonnage passifs (SPATT) constitués de résines qui adsorbent les toxines dissoutes dans l’eau permettrait la détection précoce des toxines associées à ces espèces benthiques émergentes. Cette étude met en évidence la prolifération d’une espèce émergente thermophile qui pourrait avec d’autres et à la faveur de changements climatiques constituer des problèmes sanitaires et économiques importants dans les écosystèmes lagunaires vulnérables de la Méditerranée.
43432_ABADIE_2015_archivage_cor.pdf (5.57 Mo) Télécharger le fichier
tel-02025673 , version 1 (19-02-2019)
  • HAL Id : tel-02025673 , version 1
Eric Abadie. Etude de Vulcanodinium rugosum (Dinoflagellé producteur de pinnatoxines) se développant dans la lagune méditerranéennede l’Ingril.. Ecologie, Environnement. Université Montpellier, 2015. Français. ⟨NNT : 2015MONTS188⟩. ⟨tel-02025673⟩
204 Consultations
459 Téléchargements
