Experimental characterization of water sorption and transport properties of polymer electrolyte membranes for fuel cells - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2012
Caractérisation expérimentales des propriétés de sorption de l'eau et de transport des membranes de piles à combustible
The overall aim of this PhD thesis was to characterize the properties of commercial Nafion N115 and Nafion NRE212 membranes in term of water sorption, transport, and mechanical properties over a wide range of experimental conditions. Because of the high dispersion of the data in the literature, our primary objective was to gather a comprehensive set of experimental measurements and to compare them with published results. Simple and reproducible protocols allowed us to measure the membrane properties over a wide range of experimental conditions and to study the influence of certain parameters on their evolution. For example, the samples were heat-treated at different temperatures and the effect of thermal history on water sorption, transport and mechanical properties was investigated. Nafion membranes were also exposed to moderate temperature (60°C - 80°C) and constant relative humidity (RH = 0.3 to 0.95) for long periods of time, which is known to cause a so-called ?hygrothermal aging? resulting in a decrease in their sorption capacity and proton conductivity. Such effects were observed but they appeared to be reversible and without noticeable consequences in term of fuel cell performance. Our experimental results can be used in studies involving water transport, water management and durability of fuel cells, especially for numerical simulation or modelling. More fundamentally, they can help understanding the thermodynamics of sorption and transport phenomena in PFSA membranes
L'objectif général de cette thèse de doctorat est de caractériser les propriétés de membranes PFSA de type Nafion N115 et Nafion NRE212 en termes de sorption d'eau, de propriétés de transport et de propriétés mécaniques, sur une large gamme de conditions expérimentales. Nous avons réalisé de très nombreuses mesures afin de comparer les résultats avec les données de la littérature, souvent dispersées. Des protocoles simples et reproductibles nous ont permis de mesurer les propriétés des membranes et d'étudier l'influence de certains paramètres sur leur variation. Les échantillons ont par exemple été séchés à différentes températures et nous avons étudié l'effet de ce prétraitement thermique sur la capacité de sorption, les propriétés de transport et les propriétés mécaniques. Les membranes Nafion ont également été exposées à une température modérée (60°C - 80°C) et à une humidité relative constante (RH = 0.3 à 0.95) pendant plusieurs semaines, conditions à l'origine d'un phénomène dit de "vieillissement hygrothermique" qui affecte leur capacité de sorption et leur conductivité protonique. De tels effets ont été observés mais ils se sont révélés réversibles et sans conséquences notables en terme de performances une fois les membranes utilisées en pile à combustible. Nos résultats peuvent être utilisés dans des études impliquant le transport et la gestion de l'eau dans les piles à combustible ainsi que leur durabilité, en particulier pour de la simulation numérique ou de la modélisation. Plus fondamentalement, ils peuvent aider à comprendre la thermodynamique de sorption et les phénomènes de transport dans les membranes PFSA
DDOC_T_2012_0146_MALDONADO_SANCHEZ.pdf (4.04 Mo) Télécharger le fichier
tel-02074195 , version 1 (20-03-2019)
  • HAL Id : tel-02074195 , version 1
Libeth Maldonado Sánchez. Experimental characterization of water sorption and transport properties of polymer electrolyte membranes for fuel cells. Chemical engineering. Université de Lorraine, 2012. English. ⟨NNT : 2012LORR0146⟩. ⟨tel-02074195⟩
116 Consultations
643 Téléchargements
