Théorèmes d’existence en temps court du flot de Ricci pour des variétés non-complètes, non-éffondrées, à courbure minorée. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Short-time existence theorems for the Ricci flow of non-complete, non-collapsed manifold with curvature bounded from below.
The Ricci Flow is a partial differential equation governing the evolution of a Riemannian metric depending on a time parameter t on a differential manifold. It was first introduced and studied by R. Hamilton, and eventually led to the solution of the Geometrization conjecture for closed three-dimensional manifolds by G. Perelman in 2001. The classical short-time existence theory for the Ricci Flow, due to Hamilton and Shi, asserts, in any dimension, the existence of a flow starting from any initial metric when the underlying manifold in compact, or for any complete initial metric with a bound on the norm of the curvature tensor otherwise. In the absence of such a bound, though, the conjecture is that starting from dimension 3 one can find such initial data for which there is no solution. In this thesis, we prove short-time existence theorems under hypotheses weaker than a bound on the norm of the curvature tensor. To do this, we introduce a general construction which, for any Riemannian metric g (not necessarily complete) on a manifold M, allows us to produce a solution to the equation of the flow on an open domain D of the space-time M * [0,T] which contains the initial time slice, with g as an initial datum. We proceed to show that under suitable hypotheses on g, one can control the shape of the domain D, so that in particular, D contains a subset of the form M * [0,t] with t>0 if g is complete. By « suitable hypothesis », we mean one of the following. In any case, we assume a lower bound on the volume of balls of radius at most 1, plus a) in dimension 3, a lower bound on the Ricci tensor, b) in dimension n, a lower bound on the so-called « isotropic curvature I » or c) in dimension n, a bound on the norm of the Ricci tensor, as well as a hypothesis which garanties the metric proximity of every ball of radius at most 1 with a ball of the same radius in a metric product between a three-dimensional metric space and a n-3 dimensional Euclidian factor. Moreover, with these existence results come estimates on the existence time and regularization properties of the flow, quantified in term of the hypotheses on the initial data. The possibility to regularize metrics, locally or globally, with such estimates has consequences in terms of the metric spaces obtained as limits, in the Gromov-Hausdorff topology, of sequences of manifolds uniformly satisfying a), b) or c). Indeed, the classical compactness theorems for the Ricci Flow allow for the extraction of a limit flow for any sequence of initial metrics uniformly satisfying the hypotheses and thus possessing a flow for a controlled amount of time. In the case when these metrics approach a singular space in the Gromov-Hausdorff topology, such a limit solution can be interpreted as a flow regularizing the singular limit space, the existence of which puts constraints on the topology of this space.
Le flot de Ricci est une équation aux dérivées partielles qui régit l’évolution d’une métrique riemannienne dépendant d’un paramètre de temps sur une variété différentielle. D’abord introduit et étudié par R. Hamilton, il est à l’origine de la solution de la conjecture de géométrisation des variétés compactes de dimension 3 par G. Perelman en 2001. La théorie classique concernant l’existence en temps court des solutions, due à Hamilton et à Shi, garantit (en dimension quelconque) l’existence d’un flot soit sur une variété compacte, soit lorsque la métrique initiale est complète avec une borne sur la norme du tenseur de courbure. En l’absence de cette borne, on conjecture qu’on peut trouver, à partir de la dimension 3, des données initiales pour lesquelles il n’existe pas de solution. Dans cette thèse, on démontre des théorèmes d’existence en temps court du flot sous des hypothèses plus faibles qu’une borne sur la norme du tenseur de courbure. Pour cela, on introduit une construction générale qui, pour une métrique riemannienne g quelconque sur une variété M, pas nécessairement complète, permet de produire une solution de l’équation du flot sur un domaine ouvert D de l’espace-temps M * [0,T] qui contient la tranche de temps initiale, avec g pour donnée initiale. On montre ensuite que sous des hypothèses adaptées sur la métrique g, on contrôle la forme du domaine D. En particulier, lorsque la métrique g est complète, D contient un ensemble de la forme M * [0,t], avec t>0, ce qui revient à dire qu’il existe un flot au sens classique dont la donnée initiale est g. Les « hypothèses adaptées » qui conduisent à des théorèmes d’existence sont de trois types. Dans tout les cas, on suppose une minoration uniforme du volume des boules de rayon au plus 1, à quoi on ajoute : a) en dimension 3, une minoration du tenseur de Ricci, b) en dimension n, une minoration d’une notion de courbure dite « courbure isotrope I » ou bien c) en dimension n, une borne sur la norme du tenseur de Ricci et une hypothèse qui garantit la proximité au sens métrique des boules de rayon au plus 1 avec une boule de même rayon dans un espace métrique obtenu comme le produit cartésien d’un espace de dimension 3 et d’un facteur euclidien de dimension n-3. De plus, avec ces résultats d’existence viennent des estimations sur les propriétés de régularisation du flot quantifiées en fonction des hypothèses sur la donnée initiale. La possibilité ainsi offerte de régulariser, globalement ou localement, pour un temps et avec des estimations quantifiés, une métrique initiale a des conséquence sur les espaces métriques singuliers obtenus comme limites, pour la distance de Gromov-Hausdorff, de suites de variétés satisfaisant uniformément aux conditions a), b) ou c). En effet, des théorèmes de compacité classiques pour le flot de Ricci permettent d’extraire un flot limite, étant donnée une suite de métriques initiales satisfaisant uniformément à ces hypothèses, et possédant donc toutes un flot pour un temps contrôlé. Lorsque les métriques en question approchent, pour la topologie de Gromov-Hausdorff, un espace singulier, cette solution limite s’interprète comme un flot régularisant l’espace singulier en question, et son existence contraint la topologie de cet espace singulier.
HOCHARD_RAPHAEL_2019.pdf (1.37 Mo) Télécharger le fichier
tel-02092609 , version 1 (08-04-2019)
  • HAL Id : tel-02092609 , version 1
Raphaël Hochard. Théorèmes d’existence en temps court du flot de Ricci pour des variétés non-complètes, non-éffondrées, à courbure minorée.. Géométrie différentielle [math.DG]. Université de Bordeaux, 2019. Français. ⟨NNT : 2019BORD0006⟩. ⟨tel-02092609⟩
449 Consultations
291 Téléchargements
