Modelling magnetized accretion columns of young stars in the laboratory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Modélisation en laboratoire de la dynamique d'accrétion des étoiles jeunes en milieux magnétisé.
The work that is presented here has been performed in the frame of laboratory astrophysics, which consists in studying in the laboratory physical processes occurring in astrophysical objects. The main advantages in doing so are that the processes can be studied in a controlled way and that their full dynamics can be investigated. Here, we have been taking advantage of high-intensity laser facilities to perform our studies.In this manuscript, will be treated issues that include the interaction of a plasma expanding into vacuum with an ambient magnetic field. The presence of a magnetic field in a variety of astrophysical phenomena makes the inclusion of this component in the laboratory of great interest. We have used for our study a split Helmholtz coil, specifically designed in order to work in a laser environment, that allows for reaching a magnetic field strength up to 30 T.The astrophysical objects on which this study is focused are Young Stellar Objects (YSOs). Several steps of the star formation process are here investigated: (i) the generation of very long range, bright jets, (ii) the accretion dynamic involving, in the standard representation, matter falling down on the star in the shape of magnetically confined columns, and (iii) more exotic accretion channels, as the equatorial accretion that implies propagation of plasma perpendicularly to magnetic field lines.More precisely, in a first chapter, the jet formation dynamic will be discussed. A first part is dedicated to the jet formation mechanism in a poloidal magnetic field (aligned with respect to the main plasma expansion axis). A second part is dealing with the distortion of such jet formation via the interaction of the same expanding plasma with a misaligned magnetic field (i.e. presenting an angle with respect to the plasma expansion axis). Finally, a third part details the propagation of the plasma within a perpendicular magnetic field. This last part allows us to investigate exotic channels of matter accretion onto the stars, consisting of equatorial accretion from the disk to the star, through orthogonal magnetic field lines. The second chapter addresses the topic of the standard accretion dynamic via magnetically confined columns of matter, falling down onto the stellar surface. Using the same experimental setup as in the first chapter, the formed jet (in the case of the perfectly aligned magnetic field) is used to mimic the accretion column, and is launched onto a secondary target that acts as the stellar surface. The shock dynamic at the obstacle location is carefully studied and links with astrophysical accretion observations are built. A plasma cocoon, shaped around the impact region via the interaction with the magnetic field, is found to be similar to the one found in astrophysical simulations. This cocoon is an important element as a potential X-ray absorptive medium in order to explain observed discrepancies, between observed UV/Optical and X-ray emissions emitted from accreting stars.
Le travail présenté dans cette thèse s’inscrit dans le domaine de l'astrophysique de laboratoire, qui consiste à étudier en laboratoire des processus physiques qui se produisent dans des objets astrophysiques. Les principaux avantages ici sont que les processus peuvent être étudiés de manière contrôlée et que leur dynamique complète peut être étudiée. Présentement, nous avons profité des installations laser à haute intensité pour effectuer nos études.Pour cela, dans ce manuscrit, seront traitées les questions liées à l'astrophysique de laboratoire qui impliquent l'interaction d’un plasma en détente dans le vide en présence d’un champ magnétique ambiant. La présence d'un champ magnétique dans une variété de phénomènes astrophysiques rend l’introduction de cette composante magnétique dans le laboratoire nécessaire afin que ces études soient pertinentes. Pour ce faire, en collaboration avec Laboratoire National des Champs Magnétiques Intenses -LNCMI, une bobine Helmholtz, spécialement conçue pour travailler dans un environnement laser a été développée, permettant d'atteindre une force de champ magnétique jusqu'à 30 T.Les objets astrophysiques sur lesquels cette étude est centrée sont les étoiles jeunes ou « Young Stellar Objects » (YSOs). Plusieurs étapes du processus de formation de ces étoiles seront ici étudiées : (i) la génération de jets collimatés à très grande échelle, (ii) la dynamique d'accrétion impliquant, dans la représentation standard, des flux de matière tombant sur la surface de l’étoile sous forme de colonnes magnétiquement confinées, et (iii) des canaux d'accrétion plus exotiques, comme l'accrétion équatoriale qui implique la propagation du plasma perpendiculairement aux lignes de champ magnétique.Plus précisément, dans un premier chapitre, la dynamique de formation des jets sera discutée. Une première partie est dédiée au mécanisme de formation de jet dans un champ magnétique poloïdal (aligné par rapport à l'axe principal d’expansion du plasma). Une seconde partie traite de la distorsion d'une telle formation de jet par l'interaction du même plasma en expansion avec un champ magnétique désaligné (c'est-à-dire présentant un angle par rapport à l'axe d’expansion du plasma). Enfin, une troisième partie détaille la propagation du plasma dans un champ magnétique perpendiculaire. Cette dernière partie nous permet d'étudier des canaux exotiques d'accumulation de matière sur les étoiles, consistant en une accrétion du disque d’accrétion directement vers l'étoile, c’est-à-dire sur le plan équatorial, impliquant une propagation orthogonale aux lignes de champ magnétiques. Le deuxième chapitre aborde le thème de la dynamique d'accrétion par l'intermédiaire de colonnes de matière magnétiquement confinées, tombant sur la surface stellaire. En utilisant la même configuration expérimentale que dans le premier chapitre, le jet formé (dans le cas du champ magnétique parfaitement aligné) est utilisé pour imiter la colonne d'accrétion et est lancé sur une cible secondaire qui agit comme la surface stellaire. La dynamique de choc à l'emplacement de l'obstacle est soigneusement étudiée et des liens avec les observations de phénomènes d’accrétion astrophysique sont construits. Un cocon de plasma, formé autour de la région d'impact via l'interaction avec le champ magnétique, est observé être similaire à celui trouvé dans les simulations astrophysiques. Ce cocon est un élément important en tant que milieu potentiel d'absorption des émissions X. Ce milieu permettrait en effet d'expliquer les écarts observés entre les émissions UV / optiques et les émissions X provenant des étoiles lors des phases d’accrétion.
67975_REVET_2018_archivage.pdf (54.67 Mo) Télécharger le fichier
tel-02100492 , version 1 (16-04-2019)
tel-02100492 , version 2 (30-04-2019)
  • HAL Id : tel-02100492 , version 2
Guilhem Revet. Modelling magnetized accretion columns of young stars in the laboratory. Plasma Physics [physics.plasm-ph]. Université Paris Saclay (COmUE), 2018. English. ⟨NNT : 2018SACLX046⟩. ⟨tel-02100492v2⟩
358 Consultations
106 Téléchargements
