Développement de nouvelles approches d’édition du génome à l’aide de nucléases artificielles (TALENs et CRISPR/Cas9) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
New genome editing approaches development using artificial nucleases (TALEN and CRISPR/Cas9)
Genome editing relies on the ability of artificial nucleases (TALEN or CRISPR/Cas9 system) to induce double strand break into a precise and unique sequence in a whole genome and on the different DNA repair system. The two major DNA repair systems are NHEJ (Non Homologous End Joining) and HR (Homologous Recombination). NHEJ consists on DNA end direct ligation. This system can lead to deletion or insertion at the cut site. These mutations, when induced in an exon, can induce reading frame change and gene inactivation (Knock out). HR consists on the use of sister chromatid to copy lost information in order to complete the double strand break. If an exogenous DNA with homologies with the targeted DNA is inserted with artificial nucleases, it can be used as a template and can permit to introduce any transgene at the cut site (Knock In). In this work, different strategies were used to optimize genome editing. By fusing Nter part of CtIP to Cas9, the KI rate of an exogenous DNA is increased and by fusing Trex2 exonuclease to Cas9, the mutation rate induced is also increased. These two approaches can be widely used to improve genome editing strategies.
L’édition du génome repose sur la création de cassures double brin à un endroit précis du génome à l’aide de nucléases artificielles (ZFN, TALEN, CRISPR/Cas9) et sur les différents systèmes de réparation que la cellule va mettre en place pour réparer ces dommages. Les deux systèmes de réparation principaux sont le NHEJ (Non Homologous End Joining) et la RH (Recombinaison Homologue). Le NHEJ consiste en une ligation directe des extrémités de la coupure pouvant induire de petites insertions ou délétions avant la ligation. Ces mutations, si elles sont introduites dans un exon, vont modifier le cadre de lecture et pouvoir inactiver le gène cible (Knock Out). La RH permet la réparation de la cassure en recopiant les informations présentes sur la chromatide soeur. Si un ADN exogène comportant des homologies avec la séquence à réparer est inséré avec les nucléases artificielles, la cellule peut le prendre comme matrice de réparation, il est ainsi possible d’insérer n’importe quelle mutation ou transgène de manière précise (Knock In). Ici, différentes stratégies ont été développées pour optimiser ces approches d’édition du génome. Le couplage du domaine Nter de la protéine CtIP à la nucléase Cas9 permet d’augmenter le taux d’insertion par homologie d’un transgène au site de coupure. Le couplage de l’exonucléase Trex2 à la nucléase Cas9 nickase permet quant à lui d’augmenter le taux de mutation après coupure. Ces nouvelles approches peuvent être largement utilisées et permettent de faciliter l’édition du génome.
2016EPHE3106.pdf (23.11 Mo) Télécharger le fichier
tel-02105233 , version 1 (20-04-2019)
  • HAL Id : tel-02105233 , version 1
Marine Charpentier. Développement de nouvelles approches d’édition du génome à l’aide de nucléases artificielles (TALENs et CRISPR/Cas9). Génétique. École pratique des hautes études - EPHE PARIS, 2016. Français. ⟨NNT : 2016EPHE3106⟩. ⟨tel-02105233⟩
618 Consultations
110 Téléchargements
