Importance of the conservation policies for facilitate community adjustment to climate warming of the Mediterranean wintering waterbirds
Importance des politiques de conservation pour faciliter l'ajustement des communautés d'oiseaux d'eau hivernants au réchauffement climatique en Méditerranée
Human activities seriously threaten biodiversity. In terms of global changes, overexploitation of populations and habitat destruction/degradation are at the top of the list of factors responsible for biodiversity loss. Climate change is increasing in magnitude and adding additional pressure on species. In response to the increase in global temperatures, communities are changing as a result of the shift in the geographical distribution of species towards the poles. But the accumulation of anthropogenic pressures is likely to produce interaction effects that limit community adjustment to global warming. In this critical context, conservation biology aims to reconcile human activities with biodiversity conservation. In this thesis I have investigate how the accumulation of anthropogenic pressures can limit the adjustment of communities to global warming and to identify solutions that could be put in place to facilitate their adaptation to this warming. I have used the wintering waterbird species in the countries of the Mediterranean basin as a model for my study. These iconic species benefit from an international census to monitor their populations in response to hunting and the degradation of the wetlands on which they depend. The Mediterranean is a highly anthropized region where the use of natural resources exerts significant pressures on wetlands and their biodiversity. In response, countries have different strategies to protect these ecosystems, making this region an interesting experimental plan to measure the impact in global changes on species assemblage based on conservation measures implemented. By studying the response of communities to global warming under a gradient of habitat loss/degradation, I show that community adjustment is reduced or even prevented by wetland degradation. The Ramsar Convention aims to protect wetlands and their biodiversity by maintaining a rational use of natural resources. In assessing the effect of this convention, I show that its effectiveness in conserving bird populations depends on the implementation of other protection tools, but that its role is crucial in countries where environmental legislation is weak. Finally, I assess the capacity of international conventions to facilitate community adjustment to global warming by reducing population pressures. I compared the communities' response between countries that have ratified the Bern Convention, those that have started its strictly regulatory application under the Birds Directive (European Union) and those that have not ratified these conventions. The result is clear, the more precise and strictly regulatory the regulations, the more communities and strictly protected species adjust to the increase in temperatures.In conclusion, human activities are a threat to biodiversity, but conservation measures, by reducing pressures on populations, facilitate their adaptation to climate change. Waterbird conservation requires international collaboration and the establishment of strictly regulatory laws to protect wetlands and species, while ensuring sustainable use of resources.
Les activités humaines menacent gravement la biodiversité. Sous le terme de changements globaux, la sur-exploitation des populations et la destruction/dégradation des habitats arrivent en tête de liste des facteurs responsables de l’érosion de la biodiversité. Le changement climatique gagne en magnitude et ajoute une pression supplémentaire sur les espèces. En réponse à l’augmentation des températures du globe, les communautés se réorganisent suite au déplacement de la distribution géographique des espèces vers les pôles. Mais l’accumulation des pressions anthropiques est susceptible de produire des effets d’interaction limitant l’ajustement des communautés au réchauffement climatique. Dans ce contexte critique, la biologie de la conservation a pour but de concilier les activités humaines avec la conservation de la biodiversité. Dans cette thèse j’ai cherché à comprendre comment l’accumulation des pressions anthropiques peut limiter l’ajustement des communautés au réchauffement climatique et à identifier les solutions qui pourraient être mises en place pour faciliter leur adaptation à ce réchauffement. J’ai pris pour modèle d’étude les espèces d’oiseaux d’eau hivernants dans les pays du bassin méditerranéen. Ces espèces emblématiques bénéficient d’un dénombrement international destiné à suivre leurs populations en réponse aux prélèvements par la chasse et à la dégradation des zones humides dont elles dépendent. La Méditerranée est une région fortement anthropisée où l’utilisation des ressources naturelles exerce d’importantes pressions sur les zones humides et leur biodiversité. En réponse, les pays ont différentes stratégies pour protéger ces écosystèmes, ce qui fait de cette région un plan expérimental intéressant pour mesurer l’impact dans changements globaux sur l’assemblage des espèces en fonction des mesures de conservation mises en oeuvre. En étudiant la réponse des communautés au réchauffement climatique sous un gradient de perte/dégradation d’habitat, je montre que l’ajustement des communautés est réduit, voire empêché, par la dégradation des zones humides. La Convention Ramsar vise justement à protéger les zones humides et leur biodiversité en maintenant une exploitation raisonnée des ressources naturelles. En évaluant l’effet de cette convention, je montre que son efficacité à conserver les populations d’oiseaux est dépendante de l’implémentation d’autres outils de protection, mais que son rôle est crucial dans les pays où la législation environnementale est faible. Enfin, j’évalue la capacité des conventions internationales à faciliter l’ajustement des communautés au réchauffement climatique grâce à la réduction des pressions qui s’exercent sur les populations. J’ai comparé la réponse des communautés entre les pays ayant ratifié la Convention de Berne, ceux ayant engagé son application strictement réglementaire sous la Directive Oiseaux (Union Européenne) et ceux n’ayant pas ratifié ces conventions. Le résultat est clair, plus la réglementation est précise et strictement réglementaire, plus les communautés et les espèces strictement protégées s’ajustent à l’augmentation des températures.En conclusion, les activités humaines sont une menace pour la biodiversité, mais les mesures de conservation, en réduisant les pressions sur les populations facilitent leur adaptation au changement climatique. La conservation des oiseaux d’eau nécessite une collaboration internationale et l’établissement de lois strictement réglementaires protégeant les zones humides et les espèces, tout en assurant une utilisation durable des ressources.
Biodiversité et Ecologie
