Fibre reinforced cement-based (FRC) composites after over 40 years of development in building and civil engineering, Composite structures, vol.86, pp.3-9, 2008. ,
Modeling of physical properties of composite materials, International Journal of Solids and Structures, vol.37, pp.411-422, 2000. ,
A descriptor-based design methodology for developing heterogeneous microstructural materials system, Journal of Mechanical Design, vol.136, p.51007, 2014. ,
Homogenization of random heterogeneous media with inclusions of arbitrary shape modeled by XFEM, Computational Mechanics, vol.54, pp.1221-1235, 2014. ,
Multiscale modeling of concrete. Archives of Computational, Methods in Engineering, vol.18, pp.341-393, 2011. ,
Strong coupling methods in multi-phase and multi-scale modeling of inelastic behavior of heterogeneous structures, Computer Methods in Applied Mechanics and Engineering, vol.192, pp.3089-3107, 2003. ,
An approach to micro-macro modeling of heterogeneous materials, Computational Mechanics, vol.27, pp.37-48, 2001. ,
Multi-scale modelling of heterogeneous structures with inelastic constitutive behavior: Part II-software coupling implementation aspects, Engineering computations, vol.26, issue.2, pp.6-28, 2009. ,
Multi-scale based fracture and damage analysis of steel fiber reinforced concrete, Engineering Failure Analysis, vol.35, pp.253-261, 2013. ,
Microplane model M4 for concrete. I: Formulation with work-conjugate deviatoric stress, Journal of Engineering Mechanics, vol.126, pp.944-953, 2000. ,
Damage models for concrete. Handbook of materials behavior models, vol.2, pp.500-512, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-01572309
Fracture simulations of concrete using lattice models: computational aspects, Engineering fracture mechanics, vol.57, pp.319-332, 1997. ,
Lattice element models and their peculiarities, Archives of Computational Methods in Engineering, pp.1-32, 2017. ,
Microscale and mesoscale discrete models for dynamic fracture of structures built of brittle material, Computers & Structures, vol.81, pp.1255-1265, 2003. ,
A comparative study between discrete and continuum models to simulate concrete fracture, Engineering Fracture Mechanics, vol.75, pp.117-127, 2008. ,
A modified method of incompatible modes, Communications in applied numerical methods, vol.7, pp.187-194, 1991. ,
Failure analysis of reinforced concrete frames by beam finite element that combines damage, plasticity and embedded discontinuity, Engineering structures, vol.75, pp.507-527, 2014. ,
Dynamics framework for 2D anisotropic continuum-discrete damage model for progressive localized failure of massive structures, Computers & Structures, vol.183, pp.14-26, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01997373
Embedded discontinuity finite element method for modeling of localized failure in heterogeneous materials with structured mesh: an alternative to extended finite element method, Computational Mechanics, vol.40, pp.149-155, 2007. ,
Meso-scale analysis of FRC using a two-step homogenization approach, Computers & Structures, vol.89, pp.921-929, 2011. ,
Irregular lattice model for quasistatic crack propagation, Physical Review B, vol.71, p.94106, 2005. ,
A partition of unity finite element method for obtaining elastic properties of continua with embedded thin fibres, International Journal for Numerical Methods in Engineering, vol.84, pp.708-732, 2010. ,
The partition of unity method, International Journal for Numerical Methods in Engineering, vol.40, pp.727-758, 1997. ,
A partition of unity finite element method for simulating non-linear debonding and matrix failure in thin fibre composites, International Journal for Numerical Methods in Engineering, vol.86, pp.453-476, 2011. ,
The extended/generalized finite element method: an overview of the method and its applications, International Journal for Numerical Methods in Engineering, vol.84, pp.253-304, 2010. ,
Stochastic multiscale characterization of short-fiber reinforced composites, Technische Mechanik, vol.36, pp.13-31, 2016. ,
XFEM modeling of short microfiber reinforced composites with cohesive interfaces, Finite Elements in Analysis and Design, vol.106, pp.16-31, 2015. ,
Three-dimensional modeling of short fiber-reinforced composites with extended finite-element method, Journal of Engineering Mechanics, vol.142, p.4016087, 2016. ,
Modelling of reinforced-concrete structures providing crack-spacing based on X-FEM, ED-FEM and novel operator split solution procedure, International Journal for Numerical Methods in Engineering, vol.83, pp.452-481, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-02002872
Prediction of crack pattern distribution in reinforced concrete by coupling a strong discontinuity model of concrete cracking and a bond-slip of reinforcement model, Engineering Computations, vol.22, issue.6, pp.558-582, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-02002560
The dynamics of the onset of frictional slip, Science, vol.330, pp.211-214, 2010. ,
Linear elastic fracture mechanics predicts the propagation distance of frictional slip, Tribology letters, vol.57, p.23, 2015. ,
A multiscale model for reinforced concrete with macroscopic variation of reinforcement slip, Computational Mechanics, pp.1-20, 2018. ,
A computational study of interfacial debonding damage in fibrous composite materials, Computational Materials Science, vol.12, pp.39-56, 1998. ,
Models of fiber debonding and pullout in brittle composites with friction, Mechanics of materials, vol.9, pp.139-163, 1990. ,
Critical discussion of the single-fibre pull-out test: does it measure adhesion?, Composites science and technology, vol.57, pp.1689-1706, 1998. ,
Identification of parameters of concrete damage plasticity constitutive model, Foundations of civil and environmental engineering, vol.6, pp.53-69, 2005. ,
Parameter identification in a probabilistic setting, Engineering Structures, vol.50, pp.179-196, 2013. ,
Novel anisotropic continuum-discrete damage model capable of representing localized failure of massive structures: Part I: theoretical formulation and numerical implementation, Engineering Computations, vol.26, issue.2, pp.100-127, 2009. ,
Nonlinear analysis of a fiber-reinforced beam (Nelinearni prora?un gredice armirane vlaknima), 2016. ,
Modelling Stochastic Fibrous Materials with Mathematica®, 2008. ,
Similarity of structures based on matrix similarity, Tehnicki vjesnik/Technical Gazette, vol.24, p.1, 2017. ,
FEAP -Finite Element Analysis Program, 2014. ,
, Mathematica, wolfram language and system, documentation center, 2015.
Mathcad 14, electronic documentation: Mathcad user's guide, 2007. ,
Gmsh: a three-dimensional finite element mesh generator with built-in pre-and post-processing facilities, 2008. ,
Combined hardening and softening constitutive model of plasticity: precursor to shear slip line failure, Computational Mechanics, vol.31, pp.88-100, 2003. ,
Anisotropic constitutive model of plasticity capable of accounting for details of meso-structure of two-phase composite material, Computers & Structures, vol.90, pp.153-162, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00643621
Material model for load rate sensitivity, Coupled Systems Mechanics, vol.7, pp.141-162, 2018. ,
The effect of material density on load rate sensitivity in nonlinear viscoelastic material models, Archive of Applied Mechanics, vol.8, 2018. ,
Novel anisotropic continuum-discrete damage model capable of representing localized failure of massive structures: Part ii: identification from tests under heterogeneous stress field, Engineering Computations, vol.26, issue.2, pp.128-144, 2009. ,
Method of incompatible modesoverview and application, Gra?evinar, vol.70, pp.19-29, 2018. ,
The Finite Element Method: Its Basis and Fundamentals, 2005. ,
Modéles continus et discrets pour les problémes de localisation et de rupture fragile et/ou ductile, 2003. ,
Meso scale model for fiber-reinforced-concrete: Microplane based approach, Computers and Concrete, vol.17, p.375, 2017. ,
Discrete bond element for 3D finite element analysis of reinforced concrete structures, Proceedings of the 3rd International Symposium: Bond in Concrete-from research to standards, p.4, 2002. ,
Non-linear three dimensional finite elements for composite concrete structures, Latin American Journal of Solids and Structures, vol.14, pp.398-421, 2017. ,
Kinematics of layered reinforced-concrete planar beam finite elements with embedded transversal cracking, International journal of solids and structures, vol.51, pp.74-92, 2014. ,
Incremental displacement algorithms for nonlinear problems, International Journal for Numerical Methods in Engineering, vol.14, pp.1262-1267, 1979. ,
A path-following method for elasto-plastic solids and structures based on control of plastic dissipation and plastic work, Finite Elements in Analysis and Design, vol.123, pp.1-8, 2017. ,
Modelling fibers in fiber-reinforced composites, 3rd International Conference on Multiscale Computational Methods for Solids and Fluids, 2017. ,
Simulation of single fiber pullout response with account of fiber morphology. Cement and Concrete Composites, vol.48, pp.42-52, 2014. ,
Multi-scale representation of plastic deformation in fiber-reinforced materials: application to reinforced concrete, Latin American Journal of Solids and Structures, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01997355
Nonlinear solid mechanics: theoretical formulations and finite element solution methods, 2009. ,
Analysis of steel fibers pull-out. experimental study, Construction and Building Materials, vol.100, pp.183-193, 2015. ,
The Levenberg-Marquardt method for nonlinear least squares curvefitting problems, 2017. ,
Determination of homogeneity of steel fibres in concrete specimens using computational tomography (Ispitivanje homogenosti raspodjele vlakana u mikroarmiranom betonu primjenom ra?unalne tomografije), 2016. ,
Continuous damage fiber bundle model for strongly disordered materials, Physical Review E, vol.77, p.46102, 2008. ,
Location-scale distributions -linear estimation and probability plotting using matlab, 2010. ,
Inverse model for pullout determination of steel fibers, Coupled Systems Mechanics, vol.7, issue.2, pp.197-209, 2018. ,
, Crack in a fiber-reinforced concrete specimen at the end of a three-point bending test, with fibers bridging the notch
, softening (red): (a) stress-strain diagram for the bulk material (elasticity + hardening phase + elastic unloading); (b) tractionseparation cohesive law at the discontinuity (softening phase); (c) microcracks (blue) and macro-crack (red) in a specimen, Crack development in concrete -three phases of material behavior: elasticity (black), hardening (blue)
12 2.3 Standard shape functions and incompatible shape function with its derivative for a truss bar ,
13 2.5 Example of the incompatible shape function M for for a CST element when the discontinuity passes through the middle of the element: (a) 3D view; (b) front view ,
, 21 2.7 Traction at the discontinuity vs. crack opening (displacement jump): (a) normal direction; (b) tangential direction, Fracture energy G f represented by the grey area under the softening part of the response
, Six specimens containing a fiber: three with 1/4 embedded length, and three with 1/2 embedded length
31 2.10 Different embedded lengths for the fiber: l fe 7.5 mm (one quarter of the fiber length), and l fe 15 mm (one half of the fiber length), Single-fiber pull-out tests: (a) specimen with embedded fiber; (b) experimental setup, p.31 ,
, Results for the single-fiber pull-out tests: (a) specimens with 1/4 embedded length; (b) specimens with 1/2 embedded length
, Results of single-fiber pull-out tests with different embedded lengths, p.32
, Fiber at the end of the analysis, where the straightening of the hook is visible on the pull-out side
33 2.15 Linear bond-slip law for the complete pull-out of the fiber, p.36 ,
, Exponential bond-slip law for the complete pull-out of the fiber, p.36
, Non-conforming mesh: (a) a randomly oriented fiber in the domain; (b) degrees of freedom of a fully enriched element
, 42 3.3 Two phases of the composite behavior: (a) uncracked state; (b) cracked state. 42 3.4 Comparison of total computational time for a monolithic and partitioned approach
, Algorithm flow-chart for the multi-scale framework
Geometry of the reinforced concrete specimen in 2D, p.52 ,
, Finite element mesh with enriched elements shown in grey, p.53
, Force-displacement diagram for the tension test on a reinforced concrete specimen
, 54 3.10 Bond stress: (a) distribution of ? bs along the reinforcement bar (values at Gauss points); (b) evolution of ? bs in time for all enriched elements, Distribution of slip ? bs along the reinforcement bar at the end of the analysis (nodal values), p.54
, Plastic slip: (a) distribution of ? bs,p along the reinforcement bar at the end of the analysis (values at Gauss points); (b) evolution of ? bs,p in time for the enriched elements that have entered the plastic phase, p.55
, Crack opening in concrete: (a) distribution of ? c along the reinforcement bar at the end of the analysis (values at Gauss points); (b) evolution of ? c in time for the cracked element in the middle of the specimen, p.56
, Comparison of the evolution in time of ? c and ? bs : the crack opening in concrete in the middle of the element is nearly equal to the sum of the absolute values of slip in the left and right node of the same element, p.56
, Linear elastic analysis for the domain with a medium fiber (l f 2 mm): (a) Finite element mesh with enriched elements shown in black ; (b) Contour plot of displacements in x-direction at the end of the analysis, p.58
, Force-displacement diagram for the linear elastic behavior of the matrix material, for different fiber lengths
59 3.18 Damage analysis for the domain with a medium fiber (l f 2 mm): (a) finite element mesh with enriched elements shown in black and weakened elements shown in grey; (b) contour plot of displacements in x-direction at the end of the analysis, where the cracks are shown with red lines, p.60 ,
, Force-displacement curves for the damage case for different fiber lengths, p.60
, Slip distribution along the fiber for different fiber lengths, p.61
, Force-displacement curve with and without bond-slip for the medium fiber, p.61
, Stress distribution in concrete in x-direction: (a) with bond-slip; (b) without bond-slip
, Influence of the choice of the fixed node: (a) on the global level (forcedisplacement diagram); (b) on the local level of the fiber (slip distribution), p.62
, Bond stress vs. bond strain for different values of the parameter ? bs, p.63
, Bond stress along the fiber for different values of the tangent modulus ? bs, vol.63
, Bond stress and fiber stress along the fiber at the end of the analysis for the example with medium fiber and ? bs 200
, Evolution of bond stress in time for three elements on the left, p.64
, Position of the weak zone in the specimen (a) completely on the left -element 1; (b) in the middle-left -element 3; (c) in the middle-right -element 6; (d) completely on the right -element 8
, Force-displacement diagrams for different crack locations, p.65
66 3.31 Mesh refinement study for three different meshes (128, 512 and 2048 elements): (a) force-displacement diagrams; (b) slip distribution along the fiber; (c) bond stress along the fiber; (d) convergence: bond stress at the left end of the fiber plotted against the number of elements in the mesh, Slip along the fiber for different crack locations, p.66 ,
, The fiber bridging the notch
, Three-point bending test [41]: (a) specimen; (b) experimental setup, p.68
, Results of the three point bending test [41]: load-displacement curve for three specimens
69 3.36 Mesh and boundary conditions for the modeled specimen, where the notch is represented with grey elements, and the enriched elements containing fiber are shown in black ,
, Results of the numerical simulation for the three-point bending test, p.70
, 71 3.39 Numerical simulation of the three-point bending test -distribution along the fiber at the end of the analysis: (a) slip; (b) bond stress, Three point bending test with a fiber bridging the notch, p.71
, A truss with a damaged bar (shown in green)
, Displacements of the truss bar, with measurement points shown with red dots, p.77
, Beam with measurement points shown in red
, Upper diagonals (yellow) and lower diagonals (green) in a truss structure, p.80
, Error minimization for different combinations of diagonal stiffness, p.81
, Poisson distribution with mean ¯ x 3
, Distribution of n 1000 fibers inside a square domain: (a) fiber midpoints; (b) whole fibers
, Square domain with fibers: (a) subdivision of square in zones; (b) number of points in each zone
, Sample with n 10000 points, and 2500 zones
, Plot of variance vs. mean in logarithmic scale for different zone sizes, p.85
, Plot of variance of number of points vs. zone size
86 4.16 Distribution of fibers in a concrete specimen of dimensions 40x10x10 cm: (a) fiber midpoints; (b) whole fibers, Distribution of fibers in 3D: (a) fiber midpoints; (b) whole fibers, vol.87 ,
X-ray image of a fiber-reinforced concrete specimen [68], p.88 ,
, Sorted fiber lengths and their subdivision in bins
, Comparison of the Gauss distribution (blue) and a histogram obtained from order statistics (red), for 50 bins
Length based model: (a) individual constitutive behavior for three fibers; (b) force-displacement diagram obtained from the contribution of all the fibers' responses ,
, Stiffness based model: (a) individual constitutive behavior for three fibers; (b) force-displacement diagram obtained from the contribution of all the fibers' responses
, Results of the parameter identification procedure, for different values of the damage threshold
, (a) different stiffness variance; (b) different force damage threshold; (c) different stiffness mean
