Recherche de nouvelles stratégies thérapeutiques pour le traitement de la tularémie : résistances bactériennes chez Francisella tularensis et développement de nouveaux antibiotiques bis-indoliques de synthèse - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Search for new therapeutic strategies for the treatment of tularemia : antibiotic resistances of Francisella tularensis and development of new synthetic bis-indolic antibiotics.
Tularemia is a zoonosis caused by the highly pathogenic bacterium Francisella tularensis. The most virulent subspecies, F. tularensis subsp. tularensis, is found only in North America while the subspecies F. tularensis subsp. holarctica is present in the whole Northern hemisphere. In France, all strains belong to the biovar I of the subspecies holarctica and more specifically to the phylogenetic subclade B.FTNF002-00. Although tularemia is usually not a severe disease in France, many patients suffer from therapeutic failures despite receiving an appropriate treatment. These treatments failures are observed in up to 25% of patients treated with ciprofloxacin or gentamicin, and up to 35% if patients treated with doxycycline. The causes of those therapeutic failures remain poorly elucidated. Analysis of the literature and determination of the susceptibility of 59 French F. tularensis subsp. holarctica strains to 18 antibiotics confirmed that to date, no strain with acquired resistance to any of the first-line antibiotics used for treatment of tularemia have been isolated. The fluoroquinolones (in particular ciprofloxacin and levofloxacin) exhibit the lowest minimal inhibitory concentrations, compared to gentamicin and doxycycline. Data obtained in vitro and in animal models are concordant with human data concerning the efficacy of antibiotics and therapeutic failure rates. Thus, we advocate the use of ciprofloxacin as first-line treatment for mild form of tularemia, and the use of doxycyclin only as a second-line treatment in patients with contraindications to fluoroquinolones. Azithromycin and telithromycin may also be considered as potential therapeutic alternatives for tularemia cases caused by biovar I strains of the susbspecies holarctica, but only for patients with contraindications to first-line antibiotics. Further data in animal models are however required to consolidate our in vitro data. The in vitro selection of fluoroquinolone-resistant strains of F. tularensis has been reported. This suggests that the in vivo selection of such resistant mutants may occur. In vitro, the main fluoroquinolone resistance mutations occur in the gyrA and gyrB genes that encode type II topoisomerases of F. tularensis. We have characterized the functional impact of such mutations in avirulent F. novicida strains, taken as a surrogate of F. tularensis. Supercoiling and DNA cleavage activity of GyrA/GyrB complexes reconstituted in vitro have been determined in the presence of fluoroquinolones. Fluoroquinolone resistance level was the highest in strains with a D87G/D87Y mutation in the GyrA subunit or +P466 mutation in the GyrB subunit. The mutation P43H located outside the GyrA Quinolone-Resistance-Determining-Region (QRDR) confered significant but lower fluoroquinolone resistance. The mutation D487R-∆K488 also outside GyrB QRDR did not cause fluoroquinolone resistance by itself, but increased the resistance level in case of concomitant D87G mutation. No mutation could be identified in vivo in the QRDR of gyrA and gyrB genes amplified from clinical samples collected in patients treated with a fluoroquinolone, although some of them experienced therapeutic failure. Finally, while searching for new antibiotic compounds, we identified new synthetic bis-indolic derivatives with antibacterial activity. Lead compounds were only bacteriostatic against F. tularensis but bactericidal against staphylococci including against multi-drug-resistant Staphylococcus aureus. MIC90 were measured at 2mg/L for F. tularensis and S. aureus strains for the most active compound. However, many developments are still required to improve their solubility in water, decrease their plasma proteins binding and elucidate their original mechanism of action.
La tularémie est une zoonose liée à la bactérie Francisella tularensis, hautement pathogène pour l’homme. La sous espèce la plus virulente, F. tularensis subsp. tularensis, est retrouvée uniquement en Amérique du Nord, alors que la sous-espèce F. tularensis subsp. holarctica est présente dans tout l’hémisphère Nord. En France toutes les souches appartiennent au biovar I de la sous-espèce holarctica et plus précisément au groupe phylogénétique B.FTNF002-00. Bien que rarement grave en France, la tularémie pose le problème de taux d’échecs thérapeutiques élevés, jusqu’à 25% en cas de traitement par ciprofloxacine ou gentamicine, et 35% pour la doxycycline. Les causes de ces échecs ne sont pas bien élucidées à l’heure actuelle. L’analyse de la littérature ainsi que la détermination de la sensibilité de 59 souches françaises de F. tularensis subsp. holarctica à 18 antibiotiques, confirment qu’aucune souche isolée à ce jour ne présente de résistance acquise à ces trois familles d’antibiotiques, qui représentent le traitement de première ligne de la tularémie. Les fluoroquinolones (en particulier la ciprofloxacine et la lévofloxacine) présentent concentrations minimales inhibitrices les plus basses, devant la gentamicine et la doxycycline. Les données disponibles in vitro et en modèle animal étant corrélées aux données humaines en termes d’efficacité et de taux d’échecs thérapeutiques, il semble néanmoins préférable de positionner la ciprofloxacine en première ligne pour le traitement des formes modérées de tularémie et de limiter l’utilisation de la doxycycline aux cas de contre-indication aux fluoroquinolones. L’azithromycine et la télithromycine ont été identifiées comme des alternatives thérapeutiques envisageables en cas d’infection par une souche de biovar I de F. tularensis subsp. holarctica lorsqu’existe une contre-indication aux traitements de première ligne. Des études en modèles animaux restent néanmoins nécessaires pour conforter ces dernières observations. La sélection in vitro de souches résistantes aux fluoroquinolones est possible, ce qui suggère la possibilité d’émergence de mutants résistants in vivo pour expliquer les taux d’échec thérapeutiques. Les principales mutations de résistance aux fluoroquinolones chez F. tularensis sont observées au niveau des gènes gyrA et gyrB codant pour les topoisomérases de type II. L’impact fonctionnel de mutations de résistances aux fluoroquinolones a été caractérisé in vitro chez F. novicida, pris comme modèle de bactérie avirulente proche de F. tularensis. L’activité de superenroulement et de clivage de l’ADN en présence de fluoroquinolones a été déterminée suite à la reconstruction in vitro de complexes GyrA/GyrB fonctionnels. La résistance aux fluoroquinolones était la plus forte en cas de mutation D87G/D87Y pour la sous-unité GyrA ou +P466 pour la sous-unité GyrB. La mutation P43H située en dehors du QRDR de GyrA est à l’origine d’un plus faible niveau de résistance. La mutation D487R-∆K488 en dehors du QRDR de GyrB ne confère pas de résistance intrinsèque mais potentialise l’effet d’une mutation D87G concomitante. En revanche, l’identification de mutations de résistance in vivo au sein des QRDR des gènes gyrA et gyrB chez des patients en situation d’échec thérapeutique traités par une fluoroquinolone est demeurée négative. Enfin, notre recherche a permis d’identifier de nouveaux composés de synthèse de structure bis-indolique possédant des activités antibactériennes. Ces composés sont bactériostatiques vis-à-vis de F. tularensis mais bactéricides vis-à-vis des staphylocoques y compris vis-à-vis de souches multi-résistantes de Staphylococcus aureus avec des CMI90 évaluées à 2mg/L chez F. tularensis et S. aureus pour le composé le plus actif. La faible solubilité de ces composés en milieu aqueux, leur forte liaison aux protéines plasmatiques ainsi que la recherche de leur mécanisme d’action original appellent néanmoins de nombreux développements futurs.
CASPAR_2017_archivage.pdf (12.52 Mo) Télécharger le fichier
tel-02137367 , version 1 (23-05-2019)
  • HAL Id : tel-02137367 , version 1
Yvan Caspar. Recherche de nouvelles stratégies thérapeutiques pour le traitement de la tularémie : résistances bactériennes chez Francisella tularensis et développement de nouveaux antibiotiques bis-indoliques de synthèse. Virologie. Université Grenoble Alpes, 2017. Français. ⟨NNT : 2017GREAV028⟩. ⟨tel-02137367⟩
1398 Consultations
410 Téléchargements
