Time Series Classification Algorithms with Applications in Remote Sensing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Classification de séries temporelles avec applications en télédétection
Time Series Classification (TSC) has received an important amount of interest over the past years due to many real-life applications. In this PhD, we create new algorithms for TSC, with a particular emphasis on Remote Sensing (RS) time series data. We first propose the Dense Bag-of-Temporal-SIFT-Words (D-BoTSW) method that uses dense local features based on SIFT features for 1D data. Extensive experiments exhibit that D-BoTSW significantly outperforms nearly all compared standalone baseline classifiers. Then, we propose an enhancement of the Learning Time Series Shapelets (LTS) algorithm called Adversarially-Built Shapelets (ABS) based on the introduction of adversarial time series during the learning process. Adversarial time series provide an additional regularization benefit for the shapelets and experiments show a performance improvementbetween the baseline and our proposed framework. Due to the lack of available RS time series datasets,we also present and experiment on two remote sensing time series datasets called TiSeLaCand Brazilian-Amazon
La classification de séries temporelles a suscité beaucoup d’intérêt au cours des dernières années en raison de ces nombreuses applications. Nous commençons par proposer la méthode Dense Bag-of-Temporal-SIFT-Words (D-BoTSW) qui utilise des descripteurs locaux basés sur la méthode SIFT, adaptés pour les données en une dimension et extraits à intervalles réguliers. Des expériences approfondies montrent que notre méthode D-BoTSW surpassent de façon significative presque tous les classificateurs de référence comparés. Ensuite, nous proposons un nouvel algorithmebasé sur l’algorithme Learning Time Series Shapelets (LTS) que nous appelons Adversarially- Built Shapelets (ABS). Cette méthode est basée sur l’introduction d’exemples adversaires dans le processus d’apprentissage de LTS et elle permet de générer des shapelets plus robustes. Des expériences montrent une amélioration significative de la performance entre l’algorithme de base et notre proposition. En raison du manque de jeux de données labelisés, formatés et disponibles enligne, nous utilisons deux jeux de données appelés TiSeLaC et Brazilian-Amazon.
2018theseBaillyA.pdf (6.31 Mo) Télécharger le fichier
tel-02139897 , version 1 (26-05-2019)
  • HAL Id : tel-02139897 , version 1
Adeline Bailly. Time Series Classification Algorithms with Applications in Remote Sensing. General Mathematics [math.GM]. Université Rennes 2, 2018. English. ⟨NNT : 2018REN20021⟩. ⟨tel-02139897⟩
648 Consultations
1108 Téléchargements
