. Bibliographie-[albert, Proteasomes tether to two distinct sites at the nuclear pore complex, Proc. Natl. Acad. Sci, vol.114, p.201716305, 2017.
P. Baldi, Autoencoders, unsupervised learning, and deep architectures, In Work. Unsupervised Transf. Learn, pp.37-50, 2012.
[. Bartesaghi, Classification and 3D averaging with missing wedge correction in biological electron tomography, J. Struct. Biol, vol.162, issue.3, pp.436-50, 2008.
. Bäuerlein, Situ Architecture and Cellular Interactions of PolyQ Inclusions, vol.171, pp.179-187, 2017.
[. Beck, Visual proteomics of the human pathogen Leptospira interrogans, Nat. Methods, vol.6, issue.11, pp.817-823, 2009.
[. Best, Localization of protein complexes by pattern recognition, Methods Cell Biol, issue.79, pp.615-638, 2007.
M. ;. Beucher, S. Beucher, and F. Meyer, The morphological approach to segmentation : the watershed transformation, Math. Morphol. Image Process, pp.433-481, 1993.
J. Bierkens, Non-reversible Metropolis-Hastings, Stat. Comput, vol.26, issue.6, pp.1213-1228, 2015.
DOI : 10.1007/s11222-015-9598-x
URL : https://doi.org/10.1007/s11222-015-9598-x
R. Breyer, L. A. Breyer, and G. O. Roberts, From metropolis to diffusions : Gibbs states and optimal scaling, Stoch. Process. their Appl, vol.90, issue.2, pp.181-206, 2000.
DOI : 10.1016/s0304-4149(00)00041-7
URL : https://doi.org/10.1016/s0304-4149(00)00041-7
J. A. Briggs, Structural biology in situ-the potential of subtomogram averaging, Curr. Opin. Struct. Biol, vol.23, issue.2, pp.261-267, 2013.
G. Brooks, S. P. Brooks, and A. Gelman, General methods for monitoring convergence of iterative simulations, J. Comput. Graph. Stat, vol.7, issue.4, pp.434-455, 1998.
. Buades, A non-local algorithm for image denoising, Comput. Vis. Pattern Recognit, vol.2, pp.60-65, 2005.
[. Buchholz, Cryo-Care : contentaware image restoration for cryo-transmission electron microscopy data, arXiv Prepr, pp.1-5, 2018.
[. Burger, Image denoising : can plain neural networks compete with BM3D ?, SIAM J. Imaging Sci, vol.7, issue.3, pp.1484-1502, 2012.
DOI : 10.1109/cvpr.2012.6247952
URL : http://www.is.tuebingen.mpg.de/fileadmin/user_upload/files/publications/2012/CVPR-2012-Burger.pdf
[. Charbonnier, Deterministic edge-preserving regularization in computed imaging, IEEE Trans. Image Process, vol.6, issue.2, pp.298-311, 1997.
. Chatterjee, P. Milanfar-;-chatterjee, and P. Milanfar, Patch-based near-optimal image denoising, IEEE Trans. Image Process, vol.21, issue.4, pp.1635-1649, 2012.
DOI : 10.1109/tip.2011.2172799
URL : http://www.cse.ucsc.edu/%7Emilanfar/publications/journal/plow_tip.pdf
[. Che, Improved deep learning based macromolecules structure classification from electron cryo tomograms, Mach. Vis. Appl, pp.1227-1236, 2018.
[. Chen, Convolutional neural networks for automated annotation of cellular cryo-electron tomograms, Nat. Methods, 2017.
[. Chen, Automatic particle picking and multi-class classification in cryo-electron tomograms, In Int. Symp. Biomed. Imaging, pp.838-841, 2014.
[. Chen, Detection and identification of macromolecular complexes in cryo-electron tomograms using support vector machines, IEEE Int. Symp. Biomed. Imaging, vol.1, pp.1373-1376, 2012.
URL : https://hal.archives-ouvertes.fr/hal-01692295
[. Chen, , 2014.
, Autofocused 3D Classification of Cryoelectron Subtomograms, Structure, pp.1528-1537
[. Chen, Fast and accurate reference-free alignment of subtomograms, J. Struct. Biol, vol.182, issue.3, pp.235-280, 2013.
F. Chollet, Deep learning with Python, 2017.
J. Chung and H. M. Kim, The Nobel prize in chemistry 2017 : highresolution cryo-electron microscopy, Appl. Microsc, vol.47, issue.4, pp.218-222, 2017.
[. Comaniciu, Mean Shift : a robust approach toward feature space analysis, IEEE Trans. Pattern Anal. Mach. Intell, vol.24, pp.603-619, 2002.
DOI : 10.1109/34.1000236
[. Creswell, Generative Adversarial Networks : An Overview. arXiv Prepr, pp.1-14, 2017.
DOI : 10.1109/msp.2017.2765202
URL : http://arxiv.org/pdf/1710.07035
G. Cybenko, Approximation by superpositions of a sigmoidal function, Math. Control. Signals Syst, vol.2, issue.4, pp.303-314, 1989.
[. Dabov, Image denoising by sparse 3D transform-domain collaborative filtering, IEEE Trans. Image Process, vol.16, issue.8, pp.145-149, 2007.
N. Dalal and B. Triggs, Histograms of oriented gradients for human detection, In IEEE Comput. Soc. Conf. Comput. Vis. Pattern Recognit, vol.1, pp.886-893, 2005.
URL : https://hal.archives-ouvertes.fr/inria-00548512
. Darbon, Fast nonlocal filtering applied to electron cryomicroscopy, IEEE Int. Symp. Biomed. Imaging From Nano to Macro, pp.1331-1334, 2008.
DOI : 10.1109/isbi.2008.4541250
[. Deledalle, Iterative weighted maximum likelihood denoising with probabilistic patch-based weights, IEEE Trans. Image Process, vol.18, issue.12, pp.2661-2672, 2009.
DOI : 10.1109/tip.2009.2029593
URL : https://hal.archives-ouvertes.fr/ujm-00431266
[. Deledalle, Non-local methods with shape-adaptive patches (NLM-SAP), J. Math. Imaging Vis, vol.43, issue.2, pp.103-120, 2012.
DOI : 10.1007/s10851-011-0294-y
URL : https://hal.archives-ouvertes.fr/hal-00536723
. Deng, ImageNet : a large-scale hierarchical image database, Conf. Comput. Vis. Pattern Recognit, pp.248-255, 2009.
[. Duda, Backpropagation Algorithm (Sec. 6.3). In Pattern Classif, pp.288-295, 2000.
[. Duval, A bias-variance approach for the nonlocal means, SIAM J. Imaging Sci, vol.4, issue.2, pp.760-788, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00947885
M. Elad and M. Aharon, Image denoising via sparse and redundant representations over learned dictionaries, In IEEE Trans. Image Process, vol.15, pp.3736-3745, 2006.
DOI : 10.1109/tip.2006.881969
J. Fernandez, Computational methods for electron tomography, Micron, vol.43, issue.10, pp.1010-1030, 2012.
L. ;. Fernandez, J. J. Fernandez, and S. Li, An improved algorithm for anisotropic nonlinear diffusion for denoising cryo-tomograms, J. Struct. Biol, vol.144, pp.152-161, 2003.
J. R. Fienup and . Förster, Phase retrieval algorithms : a comparison, Visual Proteomics. Methods Enzymol, vol.21, issue.C, pp.215-243, 1982.
DOI : 10.1364/ao.21.002758
F. Förster and R. Hegerl, Structure determination In Situ by averaging of tomograms, In Cell. Electron Microsc, vol.79, pp.741-767, 2007.
[. Förster, Classification of cryo-electron sub-tomograms using constrained correlation, J. Struct. Biol, vol.161, issue.3, pp.276-286, 2008.
A. S. Frangakis and R. Hegerl, Noise reduction in electron tomographic reconstructions using nonlinear anisotropic diffusion, J. Struct. Biol, vol.135, pp.239-250, 2001.
DOI : 10.1006/jsbi.2001.4406
Q. Frikel, J. Frikel, and E. T. Quinto, Characterization and reduction of artifacts in limited angle tomography, Inverse Probl, vol.29, issue.12, 2013.
[. Gatys, A neural algorithm of artistic style. arXiv Prepr, pp.1-16, 2015.
A. Gelman and D. B. Rubbin, Inference from iterative simulation using multiple sequences, Stat. Sci, vol.7, issue.4, pp.457-511, 1992.
DOI : 10.1214/ss/1177011136
URL : https://doi.org/10.1214/ss/1177011136
R. ;. Geman, D. Geman, and G. Reynolds, Constrained restoration and the recovery of discontinuities, IEEE Trans. Pattern Anal. Mach. Intell, vol.14, issue.3, pp.367-383, 1992.
[. Gilavert, Efficient Gaussian sampling for solving large-scale inverse problems using MCMC, IEEE Trans. Signal Process, vol.63, pp.70-80, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01059414
P. Gilbert-;-gilbert, Iterative methods for the three-dimensional reconstruction of an object from projections, J. Theor. Biol, vol.36, issue.1, pp.105-117, 1972.
[. Gilks, Markov Chain Monte Carlo in Practice : Interdisciplinary Statistics, 1995.
[. Girolami, Riemann manifold Langevin and Hamiltonian Monte Carlo, J. R. Stat. Soc. Ser. B, vol.73, issue.2, pp.123-214, 2011.
DOI : 10.1111/j.1467-9868.2010.00765.x
I. Goodfellow and . Goodfellow, Basic Algorithms (Sec. 8.3), NIPS 2016 tutorial : Generative adversarial networks. arXiv, pp.294-300, 2016.
[. Goodfellow, Convolutional Networks (Sec. 9.2). In Deep Learn, p.335, 2016.
[. Goodfellow, Generative Adversarial Nets, Adv. Neural Inf. Process. Syst, pp.1-9, 2014.
[. Goodfellow, Qualitatively characterizing neural network optimization problems, In Int. Conf. Learn. Represent, pp.1-20, 2015.
[. Grezl, Probabilistic and bottleneck features for LVCSR of meetings, IEEE Int. Conf. Acoust. Speech Signal Process, pp.757-760, 2007.
R. Gribonval-;-gribonval, Should penalized least squares regression be interpreted as maximum a posteriori estimation ?, IEEE Trans. Signal Process, vol.59, pp.2405-2410, 2011.
URL : https://hal.archives-ouvertes.fr/inria-00486840
A. Griewank, Who invented the reverse mode of differentiation ?, Doc. Math. · Extra, pp.389-400, 2012.
[. Guesdon, Single versus dual-axis cryo-electron tomography of microtubules assembled in vitro : limits and perspectives, J. Struct. Biol, vol.181, issue.2, pp.169-78, 2013.
URL : https://hal.archives-ouvertes.fr/inserm-00831759
F. Guichard and F. Malgouyres, Total variation based interpolation, Eur. Signal Process. Conf., volume, vol.3, pp.1741-1744, 1998.
[. Guo, situ structure of neuronal C9ORF72 poly-GA aggregates reveals proteasome recruitment, vol.172, pp.696-705, 2018.
W. K. Hastings, , 1970.
, Monte Carlo sampling methods using Markov chains and their applications, Biometrika, vol.57, pp.97-109
G. ;. He, H. He, and E. A. Garcia, Learning from imbalanced data, IEEE Trans, 2009.
, Knowl. Data Eng, vol.21, issue.9, pp.1263-1284
R. Henderson, Avoiding the pitfalls of single particle cryo-electron microscopy : Einstein from noise, Proc. Natl. Acad. Sci, vol.110, pp.18037-18041, 2013.
. Heymann, J. B. Belnap-;-heymann, and D. M. Belnap, Bsoft : Image processing and molecular modeling for electron microscopy, J. Struct. Biol, vol.157, issue.1, pp.3-18, 2007.
DOI : 10.1016/j.jsb.2006.06.006
[. Hinton, Deep neural networks for acoustic modeling in speech recognition, IEEE Signal Process. Mag, vol.29, issue.6, pp.82-97, 2012.
[. Holden, Adaptive independent MetropolisHastings, Ann. Appl. Probab, vol.19, issue.1, pp.395-413, 2009.
[. Hrabe, PyTom : A python-based toolbox for localization of macromolecules in cryo-electron tomograms and subtomogram analysis, J. Struct. Biol, vol.178, issue.2, pp.177-188, 2012.
. Isola, Image-to-Image Translation with Conditional Adversarial Networks, 2017.
[. Jin, CT-realistic lung nodule simulation from 3D conditional generative adversarial networks for robust lung segmentation, In Med. Image Comput. Comput. Interv, pp.732-740, 2018.
[. Jin, Nonlocal means and optimal weights for noise removal, SIAM J. Imaging Sci, vol.10, issue.4, pp.1878-1920, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01575918
B. Julesz, Visual pattern discrimination, IRE Trans. Inf. Theory, vol.8, issue.2, pp.84-92, 1962.
DOI : 10.1109/tit.1962.1057698
[. Katkovnik, From local kernel to nonlocal multiple-model image denoising, Int. J. Comput. Vis, vol.86, issue.1, pp.1-32, 2010.
DOI : 10.1007/s11263-009-0272-7
URL : http://www.cs.tut.fi/~foi/papers/KFKA-LocalNonLocalDenoising-IJCV-Preprint2009.pdf
K. Kawaguchi-;-kawaguchi, Deep learning without poor local minima, Conf. Neural Inf. Process. Syst, pp.1-9, 2016.
[. Kazerouni, Bayesian denoising : from MAP to MMSE using consistent cycle spinning, IEEE Signal Process. Lett, pp.249-252, 2013.
DOI : 10.1109/lsp.2013.2242061
URL : http://bigwww.epfl.ch/publications/kazerouni1301.pdf
C. Kervrann, PEWA : Patch-based exponentially weighted aggregation for image denoising, Adv. Neural Inf. Process. Syst, vol.27, pp.1-9, 2014.
URL : https://hal.archives-ouvertes.fr/hal-01103358
. Kervrann, Conditional random fields for tubulin-microtubule segmentation in cryo-electron tomography, In IEEE Trans. Image Process, pp.2080-2084, 2014.
DOI : 10.1109/icip.2014.7025417
URL : https://hal.archives-ouvertes.fr/hal-01103330
C. Kervrann and J. Boulanger, Optimal spatial adaptation for patch-based image denoising, In IEEE Trans. Image Process, vol.15, pp.2866-2878, 2006.
DOI : 10.1109/tip.2006.877529
URL : http://www.irisa.fr/vista/Papers/2006_ip_kervrann.pdf
. Kervrann, C. Boulanger-;-kervrann, and J. Boulanger, Bayesian non-local means filter, image redundancy and adaptive dictionaries for noise removal, In Scale Sp. Var. Methods Comput. Vis, pp.520-532, 2007.
DOI : 10.1007/978-3-540-72823-8_45
URL : https://hal.archives-ouvertes.fr/hal-00645444
. Kervrann, C. Boulanger-;-kervrann, and J. Boulanger, Local adaptivity to variable smoothness for exemplar-based image regularization and representation, Int. J. Comput. Vis, vol.79, issue.1, pp.45-69, 2008.
DOI : 10.1007/s11263-007-0096-2
. Kervrann, Approximate bayesian computation, stochastic algorithms and non-local means for complex noise models, IEEE Int. Conf. Image Process, pp.2834-2838, 2014.
DOI : 10.1109/icip.2014.7025573
URL : https://hal.archives-ouvertes.fr/hal-01103322
. Keskar, , 2016.
, On Large-Batch Training for Deep Learning : Generalization Gap and Sharp Minima. arXiv Prepr, pp.1-16
[. Kindermann, Deblurring and denoising of images by nonlocal functionals, Multiscale Model. Simul, vol.4, issue.4, pp.1091-1115, 2005.
B. Kingma, D. P. Kingma, and J. L. Ba, Adam : a method for stochastic optimization, 2014.
[. Ková?ik, A simple Fourier filter for suppression of the missing wedge ray artefacts in single-axis electron tomographic reconstructions, J. Struct. Biol, vol.186, issue.1, pp.141-52, 2014.
[. Kreme, Phase reconstruction for timefrequency inpainting, Int. Conf. Latent Var. Anal. Signal Sep, pp.417-426, 2018.
URL : https://hal.archives-ouvertes.fr/hal-01865467
[. Krizhevsky, ImageNet classification with deep convolutional neural networks, Conf. Neural Inf. Process. Syst, pp.1-9, 2012.
DOI : 10.1145/3065386
URL : http://dl.acm.org/ft_gateway.cfm?id=3065386&type=pdf
[. Kucukelbir, Quantifying the local resolution of cryo-EM density maps, Nat. Methods, vol.11, issue.1, pp.63-65, 2014.
[. Lauze, Simultaneous reconstruction and segmentation of CT scans with shadowed data, Int. Conf. Scale Sp. Var. Methods Comput. Vis, pp.308-319, 2017.
URL : https://hal.archives-ouvertes.fr/hal-02118564
[. Leary, Compressed sensing electron tomography, Ultramicroscopy, vol.131, pp.70-91, 2013.
[. Lebrun, A nonlocal Bayesian image denoising algorithm, SIAM J. Imaging Sci, vol.6, issue.3, pp.1665-1688, 2013.
[. Lecun, Deep learning, Nature, vol.521, pp.436-444, 2015.
[. Lecun, Backpropagation applied to handwritten zip code recognition, Neural Comput, vol.1, pp.541-551, 1989.
[. Lecun, Convolutional networks and applications in vision, IEEE Int. Symp. Circuits Syst, pp.253-256, 2010.
[. Lee, Convolutional deep belief networks for scalable unsupervised learning of hierarchical representations, In Int. Conf. Mach. Learn, pp.1-8, 2009.
[. Li, , 2017.
, Tversky loss function for image segmentation using 3D fully convolutional deep networks, In Int. Work. Mach. Learn. Med. Imaging, vol.2, pp.379-387
. Liang, Advanced Markov Chain Monte Carlo Methods : Learning from Past Samples, 2010.
. Lin, Network in network. arXiv Prepr, pp.1-10, 2013.
URL : https://hal.archives-ouvertes.fr/hal-01950552
[. Long, Fully convolutional networks for semantic segmentation, Conf. Comput. Vis. Pattern Recognit, pp.3431-3440, 2014.
[. Lou, Image recovery via nonlocal operators, J. Sci. Comput, vol.42, issue.2, pp.185-197, 2010.
DOI : 10.1007/s10915-009-9320-2
URL : https://link.springer.com/content/pdf/10.1007%2Fs10915-009-9320-2.pdf
C. Louchet and L. Moisan, Total variation denoising using posterior expectation, Eur. Signal Process. Conf, vol.5, pp.1-5, 2008.
URL : https://hal.archives-ouvertes.fr/hal-00258849
C. Louchet and L. Moisan, Total variation as a local filter, SIAM J. Imaging Sci, vol.4, issue.3, pp.651-694, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00457763
C. Louchet and L. Moisan, Posterior expectation of the total variation model : properties and experiments, SIAM J. Imaging Sci, vol.6, issue.4, pp.2640-2684, 2013.
URL : https://hal.archives-ouvertes.fr/hal-00764175
D. G. Lowe-;-lowe, Distinctive image features from scale invariant keypoints, Int. J. Comput. Vis, vol.60, pp.91-11020042, 2004.
[. Lu?i?, Cryo-electron tomography : The challenge of doing structural biology in situ, J. Cell Biol, vol.202, issue.3, pp.407-419, 2013.
[. Maggioni, Nonlocal transform-domain filter for volumetric data denoising and reconstruction, IEEE Trans. Image Process, vol.22, issue.1, pp.119-133, 2013.
DOI : 10.1109/tip.2012.2210725
[. Mahamid, Visualizing the molecular sociology at the HeLa cell nuclear periphery, Science, vol.351, issue.6276, pp.969-972, 2016.
[. Mahapatra, Efficient active learning for image classification and segmentation using a sample selection and conditional generative adversarial network, In Med. Image Comput. Comput. Interv, vol.1, pp.580-588, 2018.
, Non-local sparse models for image restoration, IEEE Int. Conf. Comput. Vis, pp.2272-2279, 2009.
S. Mallat, Understanding deep convolutional networks, Philos. Trans. R. Soc. London A Math. Phys. Eng. Sci, vol.374, 2016.
DOI : 10.1098/rsta.2015.0203
URL : http://rsta.royalsocietypublishing.org/content/374/2065/20150203.full.pdf
[. Marnissi, , 2018.
, An auxiliary variable method for Markov chain Monte Carlo algorithms in high dimension, Entropy, p.20
. Martinez-sanchez, Robust membrane detection based on tensor voting for electron tomography, J. Struct. Biol, vol.186, issue.1, pp.49-61, 2014.
[. Mayer, What makes good synthetic training data for learning disparity and optical flow estimation ? arXiv Prepr, 2018.
P. Mcculloch, W. S. Mcculloch, and W. Pitts, A logical calculus of the ideas immanent in nervous activity, Bull. Math. Biophys, vol.5, issue.4, pp.115-133, 1943.
[. Metropolis, Equation of State Calculations, J. Chem. Phys, vol.21, issue.6, pp.1087-1092, 1953.
[. Miao, Equally sloped tomography with oversampling reconstruction, Phys. Rev. B, vol.72, issue.5, pp.3-6, 2005.
DOI : 10.1103/physrevb.72.052103
P. Milanfar, A tour of modern image filtering, IEEE Signal Process. Mag, vol.30, issue.1, pp.106-128, 2013.
[. Milletari, V-Net : fully convolutional neural networks for volumetric medical image segmentation. arXiv Prepr, pp.1-11, 2016.
O. Mirza, M. Mirza, and S. Osindero, Conditional generative adversarial nets. arXiv Prepr, pp.1-7, 2014.
T. Mitchell-;-mitchell, Machine Learning, 1997.
L. Moisan-;-moisan, Periodic plus smooth image decomposition, J. Math. Imaging Vis, vol.39, issue.2, pp.161-179, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00388020
L. C. Moisan, Extrapolation de spectre et variation totale pondérée, 18e Colloq. sur le Trait. du Signal des Images, pp.892-895, 2001.
[. Moreno, TomoEED : fast edge-enhancing denoising of tomographic volumes, Bioinformatics, vol.34, issue.21, pp.3776-3778, 2018.
[. Naylor, Segmentation of Nuclei in Histopathology Images by deep regression of the distance map, IEEE Trans. Med. Imaging, issue.3, pp.1-18, 2018.
URL : https://hal.archives-ouvertes.fr/hal-01984033
R. M. Neal, Improving asymptotic variance of MCMC estimators : non-reversible chains are bbetter, 2004.
[. Ortiz, , 2006.
, Mapping 70S ribosomes in intact cells by cryoelectron tomography and pattern recognition, J. Struct. Biol, vol.156, issue.2, pp.334-375
[. Ouyang, Deep learning massively accelerates super-resolution localization microscopy, Nat. Biotechnol, vol.36, pp.460-468, 2018.
DOI : 10.1038/nbt.4106
URL : https://hal.archives-ouvertes.fr/pasteur-02074397
[. Paavolainen, Compensation of missing wedge effects with sequential statistical reconstruction in electron tomography, PLoS One, vol.9, issue.10, pp.1-23, 2014.
G. Papandreou and A. L. Yuille, Gaussian sampling by local perturbations, Adv. Neural Inf. Process. Syst, vol.23, pp.1-9, 2010.
[. Patrini, Making deep neural networks robust to label noise : a loss correction approach, 2017.
[. Pei, Simulating cryo electron tomograms of crowded cell cytoplasm for assessment of automated particle picking, BMC Bioinformatics, vol.17, issue.1, pp.1-13, 2016.
[. Pettersen, UCSF Chimera -A visualization system for exploratory research and analysis, J. Comput. Chem, vol.25, issue.13, pp.1605-1612, 2004.
[. Pfeffer, Dissecting the molecular organization of the translocon-associated protein complex, Nat. Commun, vol.8, p.14516, 2017.
[. Pizarro, Generalised nonlocal image smoothing, Int. J. Comput. Vis, vol.90, issue.1, pp.62-87, 2010.
DOI : 10.1007/s11263-010-0337-7
URL : http://www.math.uni-sb.de/service/preprints/preprint248.pdf
. Protter, Closed-Form MMSE estimation for signal denoising under sparse representation modeling over a unitary dictionary, IEEE Trans. Signal Process, vol.58, issue.7, pp.3471-3484, 2010.
URL : https://hal.archives-ouvertes.fr/inria-00577220
M. Radermacher, Weighted back-projection methods, In Frank J. Electron Tomogr, pp.245-273, 1992.
DOI : 10.1007/978-1-4757-2163-8_5
[. Radford, Unsupervised representation learning with deep convolutional generative adversarial networks. arXiv Prepr, pp.1-16, 2015.
J. Radon, On the determination of functions from their integral values along certain manifolds, IEEE Trans. Med. Imaging, vol.5, issue.4, pp.170-176, 1986.
M. Robbins, H. Robbins, and S. Monro, A stochastic approximation method, Ann. Math. Stat, vol.22, issue.3, pp.400-407, 1951.
C. Robert, C. P. Robert, and G. Casella, , 2004.
, Monte Carlo statistical methods. Springer
. Roberts, Weak convergence and optimal scaling of random walk Metropolis algorithms, Ann. Appl. Probab, vol.7, issue.1, pp.110-120, 1997.
. Roberts, G. O. Roberts, and J. S. Rosenthal, Optimal scaling for various Metropolis-Hastings algorithms, Stat. Sci, vol.16, issue.4, pp.351-367, 2001.
[. Rolnick, Deep learning is robust to massive label noise, 2017.
[. Ronneberger, U-Net : Convolutional networks for biomedical image segmentation, In Int. Conf. Med. Image Comput. Comput. Assist. Interv, vol.9351, pp.234-241, 2015.
F. Rosenblatt, An overview of gradient descent optimization algorithms, arXiv Prepr, pp.1-14, 1957.
. Rudin, Nonlinear total variation based noise removal algorithms, Phys. D, vol.60, pp.259-268, 1992.
DOI : 10.1016/0167-2789(92)90242-f
[. Rumelhart, Learning representations by back-propagating errors, Nature, vol.323, pp.533-536, 1986.
DOI : 10.1038/323533a0
S. H. Scheres, RELION : Implementation of a Bayesian approach to cryo-EM structure determination, J. Struct. Biol, vol.180, issue.3, pp.519-530, 2012.
. Scheres, Averaging of electron subtomograms and random conical tilt reconstructions through likelihood optimization, Structure, vol.17, issue.12, pp.1563-72, 2009.
[. Sentosun, Artifact reduction based on sinogram interpolation for the 3D reconstruction of nanoparticles using electron tomography, Part. Part. Syst. Charact, vol.1700287, pp.1-8, 2017.
[. Shaikh, SPIDER image processing for single-particle reconstruction of biological macromolecules from electron micrographs, Nat. Protoc, vol.3, issue.12, pp.1941-1974, 2008.
[. Shatsky, A method for the alignment of heterogeneous macromolecules from electron microscopy, J. Struct. Biol, vol.166, issue.1, pp.67-78, 2009.
Z. Simonyan, K. Simonyan, and A. Zisserman, Very deep convolutional networks for large-scale image recognition, In Int. Conf. Learn. Represent, pp.1-14, 2015.
. Springenberg, Striving for simplicity : the all convolutional net, In Int. Conf. Learn. Represent. Work, pp.1-14, 2015.
[. Stölken, Maximum likelihood based classification of electron tomographic data, J. Struct. Biol, vol.173, pp.77-85, 2011.
[. Sudre, Generalised dice overlap as a deep learning loss function for highly unbalanced segmentations, In Int. Work. Deep Learn. Med. Image Anal, vol.10553, pp.240-248, 2017.
[. Sutour, Adaptive regularization of the NL-means : application to image and video denoising, IEEE Trans. Image Process, vol.23, issue.8, pp.3506-3521, 2014.
URL : https://hal.archives-ouvertes.fr/hal-00988752
[. Szegedy, Deep neural networks for object detection, Conf. Neural Inf. Process. Syst, pp.1-9, 2013.
[. Szegedy, Rethinking the Inception Architecture for Computer Vision, 2015.
[. Tajbakhsh, Convolutional neural networks for medical image analysis : full training or fine tuning ?, IEEE Trans. Med. Imaging, vol.35, issue.5, pp.1299-1312, 2016.
[. Tang, EMAN2 : An extensible image processing suite for electron microscopy, J. Struct. Biol, vol.157, pp.38-46, 2007.
D. Ville, D. Kocher-;-van-de-ville, and M. Kocher, SURE-based non-local means, IEEE Signal Process. Lett, vol.16, issue.11, pp.973-976, 2009.
. Der-maaten, L. Hinton-;-van-der-maaten, and G. Hinton, Visualizing data using t-SNE, J. Mach. Learn. Res, vol.9, pp.2579-2605, 2008.
M. Van-heel and M. Schatz, Fourier shell correlation threshold criteria, J. Struct. Biol, vol.151, pp.250-262, 2005.
[. Vendeville, An inventory of the bacterial macromolecular components and their spatial organization, FEMS Microbiol. Rev, vol.35, issue.2, pp.395-414, 2011.
. Voss, DoG Picker and TiltPicker : software tools to facilitate particle selection in single particle electron microscopy, J. Struct. Biol, vol.166, issue.2, pp.205-213, 2009.
[. Walz, , 1997.
, Electron tomography of single ice-embedded macromolecules : Three-dimensional alignment and classification, J. Struct. Biol, vol.120, issue.3, pp.387-395
. Wan, W. Briggs-;-wan, and J. A. Briggs, Cryo-Electron Tomography and Subtomogram Averaging, vol.579, 2016.
DOI : 10.1016/bs.mie.2016.04.014
[. Wang, , 2016.
, DeepPicker : A deep learning approach for fully automated particle picking in cryo-EM, J. Struct. Biol, vol.195, issue.3, pp.325-336
. Wang, Y. Wang, and J. Morel, SURE guided Gaussian mixture image denoising, SIAM J. Imaging Sci, vol.6, issue.2, pp.999-1034, 2013.
DOI : 10.1137/120901131
URL : https://hal.archives-ouvertes.fr/hal-00785334
Y. Wei, D. Wei, and C. Yin, An optimized locally adaptive non-local means denoising filter for cryo-electron microscopy data, J. Struct. Biol, vol.172, issue.3, pp.211-219, 2010.
DOI : 10.1016/j.jsb.2010.06.021
P. J. Werbos, Beyond regression : new tools for prediction and analysis in the behavioral sciences, 1975.
[. Wong, 3D segmentation with exponential logarithmic loss for highly unbalanced object sizes, In Med. Image Comput. Comput. Interv, pp.612-619, 2018.
DOI : 10.1007/978-3-030-00931-1_70
URL : http://arxiv.org/pdf/1809.00076
[. Xu, Template-free detection of macromolecular complexes in cryo electron tomograms, Bioinformatics, vol.27, pp.69-76, 2011.
[. Xu, High-throughput subtomogram alignment and classification by Fourier space constrained fast volumetric matching, J. Struct. Biol, vol.178, issue.2, pp.152-164, 2012.
DOI : 10.1016/j.jsb.2012.02.014
URL : http://europepmc.org/articles/pmc3821800?pdf=render
[. Xu, Deep learning-based subdivision approach for large scale macromolecules structure recovery from electron cryo tomograms, Bioinformatics, vol.33, issue.14, pp.13-22, 2017.
DOI : 10.1093/bioinformatics/btx230
URL : https://academic.oup.com/bioinformatics/article-pdf/33/14/i13/25205909/btx230.pdf
[. Xu, De novo visual proteomics in single cells through pattern mining, 2016.
[. Yan, MBIR : A cryo-ET 3D reconstruction method that effectively minimizes missing wedge artifacts and restores missing information, J. Struct. Biol, vol.206, issue.2, pp.183-192, 2019.
[. Yosinski, How transferable are features in deep neural networks ?, Adv. Neural Inf. Process. Syst, vol.27, 2014.
Y. , K. Yu, F. Koltun, and V. , Multi-Scale Context Aggregation by Dilated Convolutions, Int. Conf. Learn. Represent, 2016.
Z. Yu and A. S. Frangakis, Classification of electron sub-tomograms with neural networks and its application to template-matching, J. Struct. Biol, vol.174, issue.3, pp.494-504, 2011.
[. Zeng, A convolutional autoencoder approach for mining features in cellular electron cryo-tomograms and weakly supervised coarse segmentation, J. Struct. Biol, vol.202, issue.2, pp.150-160, 2018.
[. Zhou, Feature decomposition based saliency detection in electron cryo-tomograms, 2018.
DOI : 10.1109/bibm.2018.8621363
URL : http://arxiv.org/pdf/1801.10562
. Zoran, D. Weiss-;-zoran, and Y. Weiss, From learning models of natural image patches to whole image restoration, IEEE Int. Conf. Comput. Vis, pp.479-486, 2011.
