Households residential decisions : choices and contraints
Décision résidentielle des ménages : entre choix et contraintes
The residential choice depends to a certain number of constraints: whether internal to the household or resulting from market distortion, these constraints change considerably the choices set of the households. The first part of the thesis is about the internal constraints to the household. The resulting work is a continuation of the work realized on the family economy and that of decision-making depending on their mobility. The first constraint presented is about the discrimination on the prices in the housing market. The literature has studied in detail the question of the discrimination in access to the housing highlighting a restricted and tacit access to the immigrant households, but no study has ever considered the highlighting of a potential residential discrimination by prices. In this article, we study the effective rent differences between French natives and immigrants, using the decomposition proposed by Oaxaca & Blinder (1973). We search to explain theses rent differentials by a part attributable to individual choices differences and another due to a discrimination on the housing market based on the data of the 1996 housing survey. Although no discrimination by price has clearly been shown, however some housing characteristics seem more expensive for immigrants. The second part of the thesis presents two constraints intra-households. The first of that is housing occupied by agents before they merge in order to create a household. The literature has deeply studied the residential mobility choices of couples through most of the stages of the life cycle, without including that of the household formation. However, this would allow taking into account the plurality of decision makers inside the household. This chapter offer a collective model of the household formation, measuring the probability that a couple, together, occupies the dwelling occupied by the man single, the one occupied by the woman single, compared to the fact of refuse them both, based on the estimations of a multinomial logit model. We work on the data housing national survey of 2002 which allow us to trace the totality the mobility paths of two agents. We studie the choice of the first household housing in the sense of its initial occupation. The elaboration of the theoretical model, based on a collective type model, where agents realized a negotiation, including the situation where the two may not have to leave the respective homes, in the couple threat points. We propose an enhanced version of the model where we argue that the decision of the collective housing can implied an inefficiency in the futures couple decisions. Although the man housing seems to be a proven choice, wage inequality between men and women, as well as the age difference within the couple tend to significantly influence the couples choice. Then, the housing choice, for a couple, has to take into account the daily travel time between home and workplace. The agents, having a localized job, choose a housing which meets their needs in a region where space occupation is strongly heterogeneous and housing supply is not uniformly distributed. The idea of this article is to measure the impact of agents individual characteristics on the attached decision of the household travel times, as well as how the agents allocated theses movements. The data are these of the French 1999 census of the population, enhanced with communal data and agents travel times. We show that a distinction can be realized between men and women on the attraction to the employment poles and the job stability.
Le choix résidentiel s’articule autour d’un certain nombre de contraintes : qu’elles soient internes au ménage ou résultant de la distorsion du marché, ces contraintes modifient fondamentalement l’ensemble de choix des ménages. La première partie de la thèse porte les contraintes que le ménage subit et qui repose sur une de ses caractéristiques. La littérature a étudié en détail la question de la discrimination à l’accès au logement en mettant en évidence un accès limité et tacite aux ménages immigrés, mais aucune étude ne s’est penché sur la mise en évidence d’une potentielle discrimination résidentielle par les prix. Dans cet article, nous étudions les écarts de loyers effectifs entre les français et les immigrés, à l’aide de la décomposition proposée par Oaxaca & Blinder (1973). Nous cherchons à expliquer ces différentiels de loyers en une part imputable à des différences de choix individuels et en une part relevant d'une discrimination sur le marché du logement sur des données de l’enquête logement de 1996. Bien qu’aucune discrimination par les prix ne soit mise clairement en évidence, certains caractéristiques du logement semblent, toutefois, plus onéreuses pour les immigrés. La seconde partie de cette thèse porte sur sur les contraintes internes au ménage. Le travail de cette première partie s’inscrit dans la continuité des travaux effectués sur l’économie de la famille et celle de la prise de décision concernant leur mobilité. La première contrainte que nous présentons est celle de logements qu’occupent les agents avant de se mettre en ménage. La littérature a étudié en profondeur les choix de mobilité résidentielle des couples à travers la plupart des étapes du cycle de vie, sans se pencher sur celui de la mise en ménage. Cela permettrait pourtant de prendre en compte la pluralité des décideurs au sein du ménage. Ce chapitre présente un modèle collectif de mise en ménage, mesurant la probabilité qu’un couple occupe, ensemble, le logement que l’homme occupe seul, celui que la femme occupe seule, par rapport au fait de les refuser tous deux, basé sur un modèle d’estimation logit multinomal. Nous travaillons sur des données de l’enquête nationale logement de 2002 qui nous permet de retracer l’ensemble des parcours de mobilité des deux agents. Nous nous choix du premier logement du couple au sens de son occupation initiale. L’élaboration du modèle théorique, basé sur un modèle de type collectif, où les agents opèrent une négociation, inclue la situation où les deux agents peuvent ne pas être amenés à quitter leur logement dans les points de menace du couple. Nous proposons un enrichissement du modèle où nous faisons valoir le fait que la décision du logement commun peut impliquer une inefficacité dans les décisions futures du couple. Bien que le logement de l’homme semble un choix avéré, l’inégalité salariale entre les hommes et les femmes, ainsi que la différence d’âge au sein du couple semblent influencer significativement le choix des couples. Ensuite, le choix d’un logement, pour un couple, doit prendre en compte les temps de trajet domicile-travail quotidiens. Les agents, ayant un emploi localisé, choisissent un logement qui répond à leurs besoins dans une région dont l’occupation de l’espace est fortement hétérogène et dont l’offre de logement n’est pas distribuée de façon uniforme. L’idée de l’article est de mesurer l’impact des caractéristiques individuelles des agents sur la décision jointe des temps de trajet du ménage, ainsi que la façon dont les agents se répartissent ces déplacements. Les données sur lesquelles nous travaillons sont celles du recensement de la population de 1999, enrichies de données communales et des temps de trajet des agents. Nous mettons en évidence une distinction des comportements hommes/femmes basée sur l’attraction aux pôles d’emplois et à la stabilité de l’emploi.
