, we have 1/2 derivative to spare. Moreover, using the relation between the M i 's, we can always place all (3/2)+ derivatives on the term containing v, thus we can sum by using Cauchy-Schwarz to
, R defined above is continuous and nondecreasing, and furthermore Bibliographie
Loss of regularity for supercritical nonlinear Schrödinger equations, Mathematische Annalen, vol.343, issue.2, pp.397-420, 2009. ,
On the transverse instability of solitary waves in the Kadomtsev-Petviashvili equation, Physics Letters A, vol.226, issue.3, pp.187-192, 1997. ,
The Stability of Solitary Waves, Proceedings of the Royal Society of London A : Mathematical, Physical and Engineering Sciences, vol.328, pp.153-183, 1573. ,
On the Ill-Posedness of the IVP for the Generalized Korteweg-De Vries and Nonlinear Schrödinger Equations, Journal of the London Mathematical Society, vol.53, issue.3, pp.551-559, 1996. ,
Fourier transform restriction phenomena for certain lattice subsets and applications to nonlinear evolution equations, Geometric and Functional Analysis, vol.3, issue.3, pp.209-262, 1993. ,
On the Cauchy problem for the Kadomstev-Petviashvili equation, Geometric and Functional Analysis, vol.3, issue.4, pp.315-341, 1993. ,
The Initial-Value Problem for the Korteweg-De Vries Equation, Philosophical Transactions of the Royal Society of London A : Mathematical, Physical and Engineering Sciences, vol.278, pp.555-601, 1287. ,
Asymptotics, frequency modulation, and low regularity ill-posedness for canonical defocusing equations, American journal of mathematics, vol.125, issue.6, pp.1235-1293, 2003. ,
Solitary waves of generalized KadomtsevPetviashvili equations, vol.14, pp.211-236, 1997. ,
Low regularity for the fifth order Kadomtsev-Petviashvili-I type equation, Journal of Differential Equations, 2017. ,
Le problème de Cauchy pour des EDP semi-linéaires périodiques en variables d'espace, Séminaire Bourbaki, pp.163-187, 1996. ,
Non-Existence of Solutions for the Periodic Cubic NLS below L 2 . International Mathematics Research Notices, 2016. ,
Uniform wellposedness and inviscid limit for the Benjamin-Ono-Burgers equation, Advances in Mathematics, vol.228, issue.2, pp.647-677, 2011. ,
Stability theory of solitary waves in the presence of symmetry, I, Journal of Functional Analysis, vol.74, issue.1, pp.160-197, 1987. ,
Well-Posedness for the Kadomtsev-Petviashvili II Equation and Generalisations, Transactions of the American Mathematical Society, vol.360, issue.12, pp.6555-6572, 2008. ,
Well-posedness and scattering for the KP-II equation in a critical space, vol.26, pp.917-941, 2009. ,
Local and Global Wellposedness of Periodic KP-I Equations, pp.181-212, 2007. ,
Global well-posedness of the KP-I initialvalue problem in the energy space, Inventiones mathematicae, vol.173, issue.2, pp.265-304, 2008. ,
Local and global cauchy problems for the Kadomtsev-Petviashvili (KP-II) equation in Sobolev spaces of negative indices, Communications in Partial Differential Equations, vol.26, pp.1027-1054, 2001. ,
Local solution for the Kadomtsev-Petviashvili equation with periodic conditions. manuscripta mathematica, vol.75, pp.383-393, 1992. ,
Local Solution for the Kadomtsev-Petviashvili Equation in R 2, Journal of Mathematical Analysis and Applications, vol.196, issue.2, pp.566-587, 1995. ,
On equations of KP-type, Proceedings of the Royal Society of Edinburgh : Section A Mathematics, vol.128, pp.725-743, 1998. ,
On the local and global well-posedness theory for the KP-I equation. Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.21, pp.827-838, 2004. ,
On the Stability of Solitary Waves in Weakly Dispersing Media, Soviet Physics Doklady, p.15, 1970. ,
Commutator estimates and the Euler and NavierStokes equations, Communications on Pure and Applied Mathematics, vol.41, issue.7, pp.891-907, 1988. ,
Well-posedness for the fifth-order KdV equation in the energy space, Trans. Amer. Math. Soc, vol.367, issue.4, pp.2551-2612, 2015. ,
Well-Posedness of the Initial Value Problem for the Korteweg-de Vries Equation, Journal of the American Mathematical Society, vol.4, issue.2, pp.323-347, 1991. ,
The Cauchy problem for the Korteweg-de Vries equation in Sobolev spaces of negative indices, Duke Math. J, vol.71, issue.1, pp.1-21, 1993. ,
Well-posedness and scattering results for the generalized Korteweg-De Vries equation via the contraction principle, Communications on Pure and Applied Mathematics, vol.46, issue.4, pp.527-620, 1993. ,
A bilinear estimate with applications to the KdV equation, Journal of the American Mathematical Society, vol.9, issue.2, pp.573-603, 1996. ,
On the ill-posedness of some canonical dispersive equations, Duke Math. J, vol.106, issue.3, pp.617-633, 2001. ,
On the local well-posedness of the Benjamin-Ono equation in H s (R), International Mathematics Research Notices, issue.26, pp.1449-1464, 2003. ,
Nonlinear wave interactions for the BenjaminOno equation, International Mathematics Research Notices, issue.30, pp.1833-1847, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00019959
Global wellposedness of KdV in H ?1 (T, R), Duke Math. J, vol.135, issue.2, pp.327-360, 2006. ,
On finite energy solutions of the KP-I equation, Mathematische Zeitschrift, vol.258, issue.1, pp.55-68, 2008. ,
The Water Waves Problem : Mathematical Analysis and Asymptotics, Mathematical Surveys and Monographs, vol.188, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01101991
Perte de régularité pour les équations d'ondes sur-critiques, Bull. Soc. Math. Fr, vol.133, issue.1, pp.145-157, 2005. ,
Nondegeneracy, Morse Index and Orbital Stability of the Lump Solution to the KP-I Equation, 2017. ,
Well-posedness of the fifth order Kadomtsev-Petviashvili I equation in anisotropic Sobolev spaces with nonnegative indices, Journal de Mathématiques Pures et Appliquées, vol.90, issue.4, pp.338-352, 2008. ,
Global well-posedness in the energy space for the Benjamin-Ono equation on the circle, Mathematische Annalen, vol.337, issue.2, pp.353-383, 2007. ,
Global well-posedness for the KP-I equation, Mathematische Annalen, vol.324, issue.2, pp.255-275, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00104398
Well-posedness and illposedness results for the Kadomtsev-Petviashvili-I equation, Duke Math. J, vol.115, issue.2, pp.353-384, 2002. ,
Global well-posedness for the KP-II equation on the background of a non-localized solution. Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.28, pp.653-676, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01270936
Stability of the line soliton of the KP-II equation under periodic transverse perturbations, Mathematische Annalen, vol.352, issue.3, pp.659-690, 2012. ,
On the Cauchy problem for the periodic fifth-order KP-I equation, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01761459
Global well-posedness of partially periodic kp-i equation in the energy space and application. Annales de l'Institut Henri Poincaré C, Analyse non linéaire, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01761457
Nonlinear microlocal analysis of semilinear hyperbolic systems in one space dimension, Duke Math. J, vol.49, issue.2, pp.397-475, 1982. ,
Stability and instability of the KdV solitary wave under the KP-I flow, Communications in Mathematical Physics, vol.313, issue.1, pp.155-173, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00707829
, Remarks on the Generalized Kadomtsev-Petviashvili Equations. Indiana University Mathematics Journal, vol.42, issue.3, pp.1011-1026, 1993.
The cauchy problem for higher-order KP equations, Journal of Differential Equations, vol.153, issue.1, pp.196-222, 1999. ,
The Cauchy problem for the fifth order KP equations, Journal de Mathématiques Pures et Appliquées, vol.79, issue.4, pp.307-338, 2000. ,
On Periodic KP-I Type Equations, Communications in Mathematical Physics, vol.221, pp.451-476, 2001. ,
Multilinear Weighted Convolution of <tex-math>L 2 </tex-math> Functions, and Applications to Nonlinear Dispersive Equations, American Journal of Mathematics, vol.123, issue.5, pp.839-908, 2001. ,
Nonlinear dispersive equations : local and global analysis. Number 106, 2006. ,
On a generalized Kadomtsev-Petviashvili equation, Contemporary Mathematics, vol.200, pp.193-210, 1996. ,
L 2 -Solutions for Nonlinear Schrödinger Equations and Nonlinear Groups, Funkcialaj Ekvacioj, vol.30, pp.115-125, 1987. ,
On the local regularity of the KadomtsevPetviashvili-II equation, International Mathematics Research Notices, issue.2, pp.77-114, 2001. ,
, Ill-posedness issues for nonlinear dispersive equations. ArXiv Mathematics e-prints, 2004.
URL : https://hal.archives-ouvertes.fr/hal-00108211
Local solutions of the Kadomtsev-Petviashvili equation, J. Fac. Sci. Univ. Tokyo Sect. IA Math, vol.36, issue.2, pp.193-209, 1989. ,
Stability of the line soliton of the Kadomtsev-Petviashvili-I equation with the critical traveling speed, 2017. ,
Local well-posedness of KP-I initial value problem on torus in the Besov space, Communications in Partial Differential Equations, pp.1-26, 2015. ,
