The encoding of olfactory memory traces in the mouse piriform cortex
La formation de traces mnésiques olfactives dans le cortex piriforme de la souris
Olfaction is an evolutionarily old sensory modality that plays key roles in the survival of many species and is densely interwoven with memory and emotions. However, how odor memories are formed and stored in the brain remains largely unknown. To address these questions, we studied the olfactory (piriform) cortex of mice, which is a good candidate for encoding olfactory memory traces. We used c-fos as a marker of neural activity and the cfos-tTA transgenic mouse line (and the fosCreERT2 mouse line to a lesser extent) to selectively express chemogenetic receptors (DREADDs) in piriform neurons that are active during an olfactory fear conditioning task. We found that chemogenetically reactivating these ensembles artificially retrieves the memory while chemogenetically silencing them impairs memory retrieval. Piriform neurons active during olfactory learning thus play a key role in memory retrieval. These results open new horizons in understanding memory trace formation. We decided to explore in a preliminary way how learning shapes piriform network properties. In parallel, using a theoretical framework, we investigated if a model based on dendritic voltage could predict synaptic plasticity. Taken together, these experiments will provide important insights into the mechanisms of odor coding and memory.
Comment les souvenirs olfactifs sont-ils stockés dans notre cerveau? Plusieurs études suggèrent que le cortex olfactif (piriforme) jouerait un rôle important dans la mémoire olfactive. J'ai donc voulu déterminer si cette région du cerveau est impliquée dans le rappel d'un souvenir olfactif. Pour cela, j'ai manipulé l'activité des neurones du cortex piriforme ayant été actifs pendant un apprentissage olfactif aversif, en utilisant cfos comme marqueur d'activation neuronale. Plus précisément, j'ai choisi de travailler avec la lignée de souris transgénique cfos-tTA (et de manière moins développée avec la lignée fosCreERT2) et d'utiliser les récepteurs "DREADDs". J'ai montré que lors du test de mémoire, l'inactivation des neurones du cortex piriforme actifs pendant l'apprentissage rend la souris amnésique. De manière réciproque, la réactivation artificielle de ces neurones récupère le souvenir de l'association odeur-stimulus aversif. Ainsi, une trace mnésique se forme au niveau du cortex piriforme, et plus précisément au niveau des neurones actifs lors de l'apprentissage. Ce résultat ouvre la voie à de nombreux champ d'investigations pour mieux comprendre les mécanismes de la mémoire. J'ai choisi d'explorer de manière préliminaire l'effet de l'apprentissage sur la représentation des odeurs au niveau du cortex piriforme. En parallèle, en utilisant une approche théorique, j'ai étudié si un modèle basé sur les variations de potentiel de membrane dendritique pouvait prédire l'occurrence d'un type de plasticité à une synapse corticale. L'ensemble de ces travaux ont permis d'accroître nos connaissances sur le fonctionnement de la mémoire olfactive.
