Towards an electrically-injected optical parametric oscillator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Vers un oscillateur paramétrique optique injecté électriquement
The work presented in this thesis deals with the design, fabrication and characterization of sources intended to function as both laser diodes and optical parametric oscillators. These lasers are designed to emit on a higher order mode to allow parametric frequency conversion with fundamental modes of the guide at half frequency. The laser diode and OPO share the same optical cavity; to ensure phase matching and correct nominal structure deviations induced during epitaxial processing, the ridge width is used as a control parameter of the effective indices. The proposed diodes are therefore narrow (3-5 μm) and etched deeply. Consequently, it is potentially interesting to use quantum dots to limit non-radiative recombination on the sidewalls. In the context of this work, we have designed diodes based on this principle for the two GaAs/AlGaAs and InGaAsP/InP systems, which respectively allow to potentially obtain an OPO emission in the vicinity of 2 μm or 3 μm. In the case of InGaAsP/InP, we previously studied the refractive index of InGaAsP alloys in a wavelength range not covered by literature to this day. This data was acquired via effective m-line index measurements of InGaAsP guiding layers epitaxially grown on and lattice-matched to an InP substrate. For optimized laser-OPO structures, simulations show that the OPO threshold should be obtained for an intracavity pump power of a few hundred mW, which is realistic to achieve for state-of-the-art laser diodes. We have studied the electro-optical properties of GaAs/AlGaAs quantum well laser diodes made on the basis of our designs; the observation of the laser effect on the TE2 mode validates the original vertical design of our laser diodes. For the manufacture of narrow-ridge lasers-OPOs, we have developed new manufacturing processes on the Plateforme Technologique Amont (Upstream Technology Platform, CEA - Grenoble), including deep etching (> 10 μm) by ICP-RIE. Finally, we have proposed an alternative diode-OPO concept, comprising distinct laser and OPO cavities coupled by an adiabatic taper
Le travail présenté dans cette thèse porte sur la conception, la fabrication et la caractérisation de sources prévues pour fonctionner à la fois comme diode laser et comme oscillateur paramétrique optique. Ces lasers sont conçus pour émettre sur un mode d’ordre supérieur afin de permettre une conversion de fréquence paramétrique avec les modes fondamentaux du guide à la fréquence moitié. La diode laser et l’OPO partagent la même cavité optique ; pour assurer l’accord de phase et corriger les écarts à la structure nominale induits lors de l’élaboration par épitaxie, la largeur de ruban est utilisée comme paramètre de contrôle des indices efficaces. Les diodes proposées sont donc étroites (3-5 µm) et gravées profondément. En conséquence, il est potentiellement intéressant d’utiliser des boîtes quantiques pour limiter les recombinaisons non radiatives sur les flancs. Dans le cadre de ce travail, nous avons conçu des diodes basées sur ce principe pour les deux systèmes GaAs/AlGaAs et InGaAsP/InP, qui permettent respectivement d’obtenir potentiellement une émission OPO au voisinage de 2 µm ou de 3 µm. Dans le cas de l’InGaAsP/InP, nous avons étudié au préalable l’indice de réfraction des alliages InGaAsP dans une plage de longueur d’onde jusque-là non couverte par la littérature. Ces données ont été acquises via des mesures d’indice efficace (m-lines) de couches guidantes d’InGaAsP épitaxiées en accord de maille sur un substrat d’InP. Pour des structures laser-OPO optimisées, les simulations montrent que le seuil OPO devrait être obtenu pour une puissance de pompe intracavité de quelques centaines de mW, qu’il est réaliste d’atteindre pour des diodes laser à l’état de l’art. Nous avons étudié les propriétés électro-optiques de diodes lasers à puits quantiques GaAs/AlGaAs réalisées sur la base de nos dessins; l’observation de l’effet laser sur le mode TE2 valide le dessin vertical original de nos diodes lasers. En vue de la fabrication de laser-OPO à ruban étroit, nous avons développé des procédés de fabrication nouveaux sur la Plateforme Technologique Amont (CEA – Grenoble), notamment la gravure profonde (>10 µm) par ICP-RIE. Enfin, nous avons proposé un concept alternatif de diode-OPO, comprenant des cavités laser et OPO distinctes couplées par un taper adiabatique
BERNARD_Alice_2_complete_20170710.pdf (21.64 Mo) Télécharger le fichier
tel-02320246 , version 1 (18-10-2019)
  • HAL Id : tel-02320246 , version 1
Alice Bernard. Towards an electrically-injected optical parametric oscillator. Physics [physics]. Université Sorbonne Paris Cité, 2018. English. ⟨NNT : 2018USPCC104⟩. ⟨tel-02320246⟩
168 Consultations
26 Téléchargements
