Correction de données de séquençage de troisième génération - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Error correction of third-generation sequencing data
The aims of this thesis are part of the vast problematic of high-throughput sequencing data analysis. More specifically, this thesis deals with long reads from third-generation sequencing technologies. The aspects tackled in this topic mainly focus on error correction, and on its impact on downstream analyses such a de novo assembly. As a first step, one of the objectives of this thesis is to evaluate and compare the quality of the error correction provided by the state-of-the-art tools, whether they employ a hybrid (using complementary short reads) or a self-correction (relying only on the information contained in the long reads sequences) strategy. Such an evaluation allows to easily identify which method is best tailored for a given case, according to the genome complexity, the sequencing depth, or the error rate of the reads. Moreover, developpers can thus identify the limiting factors of the existing methods, in order to guide their work and propose new solutions allowing to overcome these limitations. A new evaluation tool, providing a wide variety of metrics, compared to the only tool previously available, was thus developped. This tool combines a multiple sequence alignment approach and a segmentation strategy, thus allowing to drastically reduce the evaluation runtime. With the help of this tool, we present a benchmark of all the state-of-the-art error correction methods, on various datasets from several organisms, spanning from the A. baylyi bacteria to the human. This benchmark allowed to spot two major limiting factors of the existing tools: the reads displaying error rates above 30%, and the reads reaching more than 50 000 base pairs. The second objective of this thesis is thus the error correction of highly noisy long reads. To this aim, a hybrid error correction tool, combining different strategies from the state-of-the-art, was developped, in order to overcome the limiting factors of existing methods. More precisely, this tool combines a short reads alignmentstrategy to the use of a variable-order de Bruijn graph. This graph is used in order to link the aligned short reads, and thus correct the uncovered regions of the long reads. This method allows to process reads displaying error rates as high as 44%, and scales better to larger genomes, while allowing to reduce the runtime of the error correction, compared to the most efficient state-of-the-art tools.Finally, the third objectif of this thesis is the error correction of extremely long reads. To this aim, aself-correction tool was developed, by combining, once again, different methologies from the state-of-the-art. More precisely, an overlapping strategy, and a two phases error correction process, using multiple sequence alignement and local de Bruijn graphs, are used. In order to allow this method to scale to extremely long reads, the aforementioned segmentation strategy was generalized. This self-correction methods allows to process reads reaching up to 340 000 base pairs, and manages to scale very well to complex organisms such as the human genome.
Les objectifs de cette thèse s’inscrivent dans la large problématique du traitement des données issues de séquenceurs à très haut débit, et plus particulièrement des reads longs, issus de séquenceurs de troisième génération.Les aspects abordés dans cette problématiques se concentrent principalement sur la correction des erreurs de séquençage, et sur l’impact de la correction sur la qualité des analyses sous-jacentes, plus particulièrement sur l’assemblage. Dans un premier temps, l’un des objectifs de cette thèse est de permettre d’évaluer et de comparer la qualité de la correction fournie par les différentes méthodes de correction hybride (utilisant des reads courts en complément) et d’auto-correction (se basant uniquement sur l’information contenue dans les reads longs) de l’état de l’art. Une telle évaluation permet d’identifier aisément quelle méthode de correction est la mieux adaptée à un cas donné, notamment en fonction de la complexité du génome étudié, de la profondeur de séquençage, ou du taux d’erreurs des reads. De plus, les développeurs peuvent ainsi identifier les limitations des méthodes existantes, afin de guider leurs travaux et de proposer de nouvelles solutions visant à pallier ces limitations. Un nouvel outil d’évaluation, proposant de nombreuses métriques supplémentaires par rapport au seul outil disponible jusqu’alors, a ainsi été développé. Cet outil, combinant une approche par alignement multiple à une stratégie de segmentation, permet également une réduction considérable du temps nécessaire à l’évaluation. À l’aide de cet outil, un benchmark de l’ensemble des méthodes de correction disponibles est présenté, sur une large variété de jeux de données, de profondeur de séquençage, de taux d’erreurs et de complexité variable, de la bactérie A. baylyi à l’humain. Ce benchmark a notamment permis d’identifier deux importantes limitations des outils existants : les reads affichant des taux d’erreurs supérieurs à 30%, et les reads de longueur supérieure à 50 000 paires de bases. Le deuxième objectif de cette thèse est alors la correction des reads extrêmement bruités. Pour cela, un outil de correction hybride, combinant différentes approches de l’état de l’art, a été développé afin de surmonter les limitations des méthodes existantes. En particulier, cet outil combine une stratégie d’alignement des reads courts sur les reads longs à l’utilisation d’un graphe de de Bruijn, ayant la particularité d’être d’ordre variable. Le graphe est ainsi utilisé afin de relier les reads alignés, et donc de corriger les régions non couvertes des reads longs. Cette méthode permet ainsi de corriger des reads affichant des taux d’erreurs atteignant jusqu’à 44%, tout en permettant un meilleur passage à l’échelle sur de larges génomes et une diminution du temps de traitement, par rapport aux méthodes de l’état de l’art les plus efficaces. Enfin, le troisième objectif de cette thèse est la correction des reads extrêmement longs. Pour cela, un outil utilisant cette fois une approche par auto-correction a été développé, en combinant, de nouveau, différentes méthodologies de l’état de l’art. Plus précisément, une stratégie de calcul des chevauchements entre les reads, puis une double étape de correction, par alignement multiple puis par utilisation de graphes de de Bruijn locaux, sont utilisées ici. Afin de permettre à cette méthode de passer efficacement à l’échelle sur les reads extrêmement longs, la stratégie de segmentation mentionnée précédemment a été généralisée. Cette méthode d’auto-correction permet ainsi de corriger des reads atteignant jusqu’à 340 000 paires de bases, tout en permettant un excellent passage à l’échelle sur des génomes plus complexes, tels que celui de l’humain.
pierremorisse2.pdf (10.95 Mo) Télécharger le fichier
tel-02320413 , version 1 (18-10-2019)
  • HAL Id : tel-02320413 , version 1
Pierre Morisse. Correction de données de séquençage de troisième génération. Bio-informatique [q-bio.QM]. Normandie Université, 2019. Français. ⟨NNT : 2019NORMR043⟩. ⟨tel-02320413⟩
464 Consultations
1044 Téléchargements
