Mechanistic and structural basis for tuning myosin activity
Bases mécanistiques et structurales de la régulation de l'activité des myosines
Molecular motors are essential agents of force production in the cells: they convert the chemical energy released by the hydrolysis of ATP into mechanical work. This thesis focuses on myosins, a family of molecular motors responsible for actin-based motility. Myosin VI is unique among all of the myosin superfamily members in that it moves in the opposite direction of all other known myosins. Previous work revealed myosin VI tail ability to fold back, constituting a potential auto-inhibited state that prevents motor activity. Several myosin VI partners, binding to the C-terminal tail of the myosin, have been identified and shown to recruit the motor for different functions. In the first chapter of this thesis, the mechanism allowing the regulation of myosin VI activity has been studied using biochemical and biophysical analysis (SAXS, light scattering, microscopy, binding assays and mutagenesis). GIPC1, the most studied myosin VI partners, promotes myosin dimerization and activation. During my PhD, I have been also involved in two other projects, in line with my thesis project, that have led to the publication of four articles. Two shorter chapters are therefore devoted to these projects. The second chapter of my thesis explores myosin VII activity regulation by its cellular partners. Finally, the third chapter is devoted to the allosteric regulation of myosins activity by small molecules.
Les moteurs moléculaires sont des protéines capables de produire une force : elles transforment l'énergie chimique de l'hydrolyse de l'ATP en énergie mécanique. Cette thèse se focalise sur l'étude d'une famille de moteurs moléculaires, les myosines, qui se déplacent le long des filaments d'actine et assurent d'importantes fonctions cellulaires.La myosine VI est une myosine très particulière car elle est la seule à se déplacer vers l'extrémité négative des filaments d'actine. Elle est produite dans la cellule sous forme auto-inhibée, inactive. Dans la cellule, son activité est également régulée par plusieurs protéines interagissant avec la queue C-terminale de la myosine VI. Ces protéines, présentes à des endroits précis de la cellule, recrutent la myosine VI et dictent l'action qu'elle doit effectuer. Des analyses de SAXS, de dispersion de la lumière, de microscopie, d'interaction et de mutagénèse ont permis de mieux comprendre le mécanisme régulant l'adoption de l'état auto-inhibé, ainsi que son activation par le calcium. L'interaction avec différents partenaires a été caractérisée. GIPC1, le partenaire le plus étudié, promeut de façon indirecte la dimérisation et l'activation de la myosine VI.Pendant ma thèse, j'ai également été impliqué dans deux autres projets qui s'inscrivent dans la logique du projet de thèse et qui ont mené à la publication de quatre articles. Deux chapitres, plus brefs, sont donc dédiés à ces projets. Le deuxième chapitre porte sur la régulation de l'activité de la myosine VII par ses partenaires cellulaires. Finalement, le troisième chapitre est dédié à l'étude de la modification allostérique de l'activité des myosines par des petites molécules.
