, www.alcoa.com, 2018.
, www.boeing.com, 2018.
Analysis and comparative study of factors affecting quality in the hemming of 6016T4AA performed by means of electromagnetic forming and process characterization, J Mater Process Tech, vol.211, pp.916-940, 2011. ,
Aluminum alloy damage evolution for different strain paths -Application to hemming process, Eng Fract Mech, vol.76, pp.1202-1216, 2009. ,
Material parameter identification within an integrated methodology considering anisotropy, hardening and rupture, J Mater Process Technol, vol.220, pp.157-72, 2015. ,
Path independent forming limits in strain and stress spaces, Int J Solids Struct, vol.49, pp.3616-3641, 2012. ,
Analyse des procédés de sertissage de tôles métalliques : aspects expérimentaux et numériques, endommagement des pièces serties, 2009. ,
Experimental investigation and numerical prediction of rupture in bending of metallic sheets, 2013. ,
Influence of a tensile pre-strain on bending of aluminium alloy, Key Eng Mater, pp.1742-1751, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01115649
Prediction of failure in bending of an aluminium sheet alloy, Int J Mech Sci, vol.119, pp.23-35, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-02110743
Review of Drucker's postulate and the issue of plastic stability in metal forming, Int J Plast, vol.22, pp.391-433, 2006. ,
, Formability of Metallic Materials, 2000.
Plane stress yield function for aluminum alloy sheets -part 1 : theory, Int J Plast, vol.19, pp.1297-319, 2003. ,
Linear transfomation-based anisotropic yield functions, Int J Plast, vol.21, pp.1009-1048, 2005. ,
Prediction of six or eight ears in a drawn cup based on a new anisotropic yield function, Int J Plast, vol.22, pp.174-93, 2006. ,
Mémoire sur l'écoulement des corps solides soumis à de fortes pressions, C R Acad Sci, vol.59, p.754, 1864. ,
Mechanik der festen Körper im plastisch deformablen Zustand, Göttin Nachr Math Phys, vol.1, pp.582-92, 1913. ,
A six-component yield function for anisotropic materials, Int J Plast, vol.7, pp.693-712, 1991. ,
A Theory of the Yielding and Plastic Flow of Anisotropic Metals, Math Phys Sci, vol.193, pp.281-97, 1948. ,
, Constitutive Modelling of Anisotropic Sheet Metals Based on a Non-Associated Flow Rule. PhD, 2013.
Plastic behavior and stretchability of sheet metals. Part I: A yield function for orthotropic sheets under plane, stress conditions, vol.5, pp.51-66, 1989. ,
A theory of the plastic distorsion of a polycrystalline aggregate under combined stress, Philos Mag, vol.42, pp.414-441, 1951. ,
Yield function development alloy sheets for aluminum, J Mech Phys Solids, vol.45, pp.1727-63, 1997. ,
Plane stress yield function for aluminum alloy sheets -part II : FE formulation and its implementation, Int J Plast, vol.20, pp.495-522, 2004. ,
Modeling of anisotropic plastic behavior of ferritic stainless steel sheet, Int J Mech Sci, vol.51, pp.718-743, 2009. ,
Experiments and modeling of anisotropic aluminum extrusions under multi-axial loading -Part II: Ductile fracture, Int J Plast, vol.36, pp.34-49, 2012. ,
Evaluation of anisotropic constitutive models : Mixed anisotropic hardening and non-associated flow rule approach, Int J Mech Sci, vol.73, pp.53-68, 2013. ,
Earing predictions for strongly textured aluminum sheets, vol.52, pp.1563-78, 2010. ,
Parameter reduction for the Yld2004-18p yield criterion, Int J Mater Form, vol.3, pp.10-13, 2015. ,
A novel approach for anisotropic hardening modeling. Part I : Theory and its application to finite element analysis of deep drawing, Int J Plast, vol.25, pp.2383-409, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00509789
Development of computational anisotropic hypoelastic-and hyperelastic-based models including nonlinear kinematic hardening, 2015. ,
Effect of compression-tension loading reversal on the strain to fracture of dual phase steel sheets, Int J Plast, vol.72, pp.21-43, 2015. ,
Prediction of anisotropy and hardening for metallic sheets in tension, simple shear and biaxial tension, vol.53, pp.338-385, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00715774
Comparison of the work hardening of metallic sheets in bending-unbending and simple shear, Int J Mech Sci, vol.51, pp.122-152, 2009. ,
A modification of Prager's hardening rule, Q Appl Mech, vol.17, pp.55-65, 1959. ,
Time-independent constitutive theories for cyclic plasticity 1986, vol.2, pp.149-88 ,
A Mathematical representation of the multiaxial Bauschinger effect, Cent Electr Gener Board Report, vol.731, 1966. ,
A finite element formulation based on non-associated plasticity for sheet metal forming, Int J Plast, vol.24, pp.646-87, 2008. ,
Earing prediction in cup drawing based on non-associated flow rule, NUMIFORM '07 Mater Process Des Model Simul Appl Pts I II, pp.685-90, 2007. ,
A non-associated flow rule for sheet metal forming, Int J Plast, vol.18, pp.687-714, 2002. ,
Lüders front propagation in low-carbon steels, J Mech Phys Solids, vol.10, pp.313-347, 1962. ,
Yield point phenomena in metals and alloys, 1970. ,
Underlying material response for Lüders-like instabilities, Int J Plast, vol.47, pp.1-12, 2013. ,
Dislocation theory of yielding and strain ageing in iron, Proc Phys Soc A62, p.40, 1949. ,
Dislocation velocities, dislocation densities and plastic flow in lithium floride crystals, J Appl Phys, vol.30, p.129, 1959. ,
The Portevin-Le Chatelier effect in deformation with constant stress rate, Acta Metall, vol.33, pp.397-407, 1985. ,
Theory of flow localisation due to dynamic strain ageing, Acta Metall, vol.36, pp.3061-3068, 1988. ,
A plasticity model describing yield-point phenomena of steels and its application to FE simulation of temper rolling, Int J Plast, vol.24, pp.1792-818, 2008. ,
Influence of static strain aging on the cleavage fracture of a C -Mn steel, Eng Fract Mech, vol.141, pp.95-110, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01165657
Experimental characterization and numerical modeling of micromechanical damage under different stress states, Mater Des, vol.50, pp.207-229, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01057964
Implementation of a damage evolution law for dualphase steels in Gurson-type models, Mater Des, vol.88, pp.1213-1235, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01273675
Essai sur une application des règles des maximis et minimis à quelques problèmes de statique relatifs à l'architecture, Mem Acad Roy Div Sav, vol.7, pp.343-87, 1776. ,
Abhandlungen aus dem Gebiete der Technischen Mechanik, 1914. ,
Calibration and evaluation of seven fracture models, Int J Mech Sci, vol.47, pp.719-762, 2005. ,
Investigation of the rupture in tension and bending of DP980 steel sheet, Int J Mech Sci, vol.84, pp.171-81, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01115645
Ductility and the workability of metals, J Inst Met, vol.96, 1968. ,
A new method for the prediction of formability in metal sheets, Proc. 7th Bienn. Conf. IDDRG, 1972. ,
Fracture criteria identification using an inverse technique method and blanking experiment, Int J Mech Sci, vol.44, pp.1349-61, 2002. ,
On the ductile enlargement of voids in triaxial stress fields *, J Mech Phys Solids, vol.17, pp.201-218, 1969. ,
A new model of metal plasticity and fracture with pressure and Lode dependence, Int J Plast, vol.24, pp.1071-96, 2008. ,
The effect of pressure on the flow-stress of metals, Acta Metall, vol.32, pp.457-63, 1984. ,
Pressure dependence and dilatancy of plastic flow, Theor Appl Mech, pp.377-86, 1980. ,
A critical reexamination of classical metal plasticity, J Appl Mech, vol.69, pp.63-71, 2002. ,
A criterion for description of anisotropy and yield differential effects in pressure-insensitive metals, Int J Plast, vol.20, pp.2027-2072, 2004. ,
Orthotropic yield criterion for hexagonal closed packed metals, Int J Plast, vol.22, pp.1171-94, 2006. ,
Strain burst phenomena in the necking of a sheet that deforms by nonassociated plastic flow, Model Simul Mater Sci Eng n.d, vol.15, pp.297-311 ,
On the mechanisms of ductile failure in high-strength steels subjected to multi-axial stress-states, J Mech Phys Solids, vol.24, pp.147-69, 1976. ,
Application of extended Mohr-Coulomb criterion to ductile fracture, Int J Fract, vol.161, pp.1-20, 2010. ,
Ductile fracture of aluminum 2024-T351 under proportional and non-proportional multi-axial loading: Bao-Wierzbicki results revisited, Int J Solids Struct, pp.459-74, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01227222
Modeling of shear ductile fracture considering a changeable cut-off value for stress triaxiality, Int J Plast, vol.54, pp.56-80, 2014. ,
On the cut-off value of negative triaxiality for fracture, Eng Fract Mech, vol.72, pp.1049-69, 2005. ,
Anisotropic ductile fracture criterion based on linear transformation, Int J Plast, vol.93, 2017. ,
Fracture in bending -The straining limits of monolithic sheets and machined tailor-made blanks, Mater Des, vol.32, pp.1229-1270, 2011. ,
The shear fracture of dual-phase steel, Int J Plast, vol.27, pp.1658-76, 2011. ,
Numerical failure analysis of a stretch-bending test on dual-phase steel sheets using a phenomenological fracture model, Int J Solids Struct, vol.47, pp.3084-102, 2010. ,
A combined experimental-numerical investigation of ductile fracture in bending of a class of ferritic-martensitic steel, Int J Solids Struct, vol.49, pp.1608-1634, 2012. ,
Numerical modelling of crack propagation : automatic remeshing and comparison of different criteria, Comput Methods Appl Mech Engrg, vol.192, pp.3887-908, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00677710
Analysis of the air-bending test using finite-element simulation: Application to steel sheets, Int J Mech Sci, vol.57, pp.43-53, 2012. ,
Ductile fracture experiments with locally proportional loading histories, Int J Plast, vol.79, pp.328-54, 2016. ,
Deformation analysis of large sized panels in the press shop, pp.315-353, 1977. ,
Comparison of the work-hardening of metallic sheets using tensile and shear strain paths, Int J Plast, vol.25, pp.733-51, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00404007
Simple shear tests : Experimental techniques and characterization of the plastic anisotropy of rolled sheets at large strains, vol.172, pp.96-103, 2006. ,
Characterization of the strain-induced plastic anisotropy of rolled sheets by using sequences of simple shear and uniaxial tensile tests, J Mater Process Technol, vol.174, pp.115-141, 2006. ,
Hydroforming -a method to manufacture light-weight parts, J Mater Process Technol, vol.60, pp.669-76, 1996. ,
Determination of flow stress for sheet metal forming using the viscous pressure bulge (VPB) test, J Mater Process Tech, vol.146, pp.1-7, 2004. ,
Accurate characterization of biaxial stress-strain response of sheet metal from bulge testing, Int J Plast, vol.2016, pp.1-22 ,
The influence of strain-path changes on forming limit diagrams of Al 6111 T4, Int J Mech Sci, vol.36, pp.897-910, 1994. ,
Experimental and theoretical investigations of the forming limit of 5754O aluminum alloy sheet under different combined loading paths, Int J Mech Sci, vol.133, pp.147-66, 2017. ,
Calibration of anisotropic yield criterion with conventional tests or biaxial test, Int J Mech Sci, vol.85, pp.142-51, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01005604
Research note on a simple model for pressure-sensitive strain-hardening materials, Int J Plast, vol.4, pp.265-78, 1988. ,
An evaluation of yield criteria and flow rules for aluminium alloys, Int J Plast, vol.15, pp.191-208, 1999. ,
A pressure-sensitive yield criterion under a non-associated flow rule for sheet metal forming, Int J Plast, vol.20, pp.705-736, 2004. ,
A non-associated constitutive model with mixed isokinematic hardening for finite element simulation of sheet metal forming, Int J Plast, vol.26, pp.288-309, 2010. ,
Evaluation of advanced anisotropic models with mixed hardening for general associated and non-associated flow metal plasticity, Int J Plast, vol.27, pp.1781-802, 2011. ,
Study on Yield Function and Plastic Potential Under Non-Associated Flow for Accurate Earing Prediction in Cup Drawing, Steel Res Int, vol.86, pp.852-60, 2015. ,
Elasto-plastic finite element method based on incremental deformation theory and continuum based shell elements for planar anisotropic sheet materials, Comput Methods Appl Mech Engrg, pp.23-56, 1999. ,
Equivalent Plastic Strain for the Hill's Yield Criterion under General Three-Dimensional Loading, 2013. ,
Influence of ductile damage on the bending behaviour of aluminium alloy thin sheets, Mater Des, vol.32, pp.2049-57, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00715779
, Anisotropy for Metals in Non-Associated Flow Plasticity. PhD, 2015.
Partially coupled anisotropic fracture model for aluminum sheets, Eng Fract Mech, vol.77, pp.1128-52, 2010. ,
Predicting ductile fracture of low carbon steel sheets : Stress-based versus mixed stress / strain-based Mohr -Coulomb model, Int J Solids Struct, vol.50, pp.1055-66, 2013. ,
A new analytical theory for earing generated from anisotropic plasticity, Int J Plast, vol.27, pp.1165-84, 2011. ,
A constitutive model of cyclic plasticity, Int J Plast, vol.16, pp.359-80, 2000. ,
Kinematics of Portevin -Le Chatelier bands in simple shear, Int J Plast, vol.58, pp.66-83, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01099846
Bending of steel tubes with Luders bands, Int J Plast, vol.20, pp.1199-225, 2004. ,
On the effect of Lüders bands on the bending of steel tubes . Part I : Experiments, Int J Solids Struct, vol.48, pp.3275-84, 2011. ,
Thermomechanical characterization of Portevin -Le Châtelier bands in AlMg3 (AA5754) and modeling based on a modified Estrin -McCormick approach, Int J Plast, vol.67, pp.192-216, 2015. ,
The morphology of Portevin-Le Chatelier bands: finite element simulation for Al-Mg-Si, Acta Metall, vol.49, pp.1087-94, 2001. ,
Effect of strain rate on spatio-temporal behavior of Portevin -Le Châtelier bands in a twinning induced plasticity steel, Mech Mater, vol.68, pp.164-75, 2014. ,
Spatio-temporal characteristics of the Portevin -Le Châtelier effect in austenitic steel with twinning induced plasticity, Int J Plast, vol.25, pp.2298-330, 2009. ,
