New synthetic routes to fluoroalkylselenylated compounds
Nouvelles voies d’accès aux composés fluoroalkylséléniés
Nowadays, organofluorine compounds are widely used, with applications in all fields of life sciences (pharmaceuticals and agrochemicals) as well as materials. This growing interest is due to the unique properties induced by fluorinated motifs. In this context, the association of fluorine with heteroatoms such as chalcogens allows its properties of interest (lipophilicity, conformation, metabolic stability) to be modulated. The development of OCF3, SCF3 and their derivatives has significantly expanded during the past two decades. Despite its promising properties, the selenylated analog SeCF3 has been less studied. Indeed, selenium is well known to be more toxic. Thus, only few methodologies were reported in the literature. However, selenium is an essential trace element for humans and it is well studied in medicinal chemistry for its anti-oxidant properties. This manuscript is devoted to the direct introduction of the fluoroalkylselenylated moiety SeRF onto organic substrates through two generations of reagents: fluoroalkylselenyl chlorides, ClSeRF and fluoroalkyltolueneselenosulfonates, TsSeRF. On the one hand, the former was involved in various electrophilic reactions. On the other hand, the design and the synthesis of the latter allowed challenging transformations to be achieved. Moreover, depending on the conditions, TsSeRF derivatives appeared to be highly versatile since the fluorinated motif can be introduced as electrophile, radical or nucleophile. This unique behavior can be a useful synthetic tool in organofluorine chemistry. TsSeRF reagents are already well established in modern strategies for the introduction of fluoroalkylselenylated moieties. Nevertheless, efforts are still needed to shed some light on the toxicity of the SeRF-containing molecules. Such improvements will pave the way for future applications of this chemistry.
De nos jours, les composés fluorés sont de plus en plus présents dans notre quotidien et gagnent tous les domaines d’application des sciences de la vie (industries pharmaceutique et agrochimique) mais également dans les matériaux. Cet engouement croissant s’explique de part les caractéristiques uniques que confèrent les motifs fluorés lorsqu’ils sont introduits sur une molécule. En outre, l’association du fluor avec des hétéroatomes, et notamment les chalcogènes, a permis d’apporter de nouvelles propriétés d’intérêt (lipophilie, conformation, stabilité métabolique). Ces deux dernières décennies ont vu la croissance exponentielle des développements autour des motifs OCF3, SCF3 et de leurs dérivés. Bien moins étudié que ses analogues, le groupement SeCF3 n’a pas connu le même essor en dépit des propriétés prometteuses. En effet, communément craint à cause de sa plus grande toxicité, peu de méthodes d’introduction de ce motif ont été décrites. Le sélénium est pourtant un oligoélément essentiel chez l’Homme et est particulièrement étudié en médecine pour ses propriétés anti-oxydantes. Ce manuscrit est dédié à l’introduction directe du groupement fluoroalkylsélénium SeRF sur divers substrats organiques à travers deux générations de réactifs et de leurs dérivés : les chlorures de fluoroalkylsélénium ClSeRF et les fluoroalkyltoluènesélénosulfonates TsSeRF. Si le premier a été impliqué dans dans diverses réactions électrophiles, l’émergence du second a permis de franchir les obstacles synthétiques rencontrés. De plus, en fonction des conditions opératoires, les réactifs TsSeRF peuvent introduire le motif fluoroalkylsélénié de manière électrophile, radicalaire ou nucléophilie. Cette versatilité s’avère être un outil synthétique de choix pour cette chimie. L’apport de ce réactif a contribué aux récents développements autour du motif SeCF3. Cependant, des efforts restent à fournir notamment afin d’apporter des données quant à la toxicité de ce motif lorsqu’il est introduit sur un composé organique. Celles ci ouvriraient alors le champ vers de potentielles applications
Chimie organique
