Stable recursive algorithm for elastic wave propagation in layered anisotropic media: Stiffness matrix method, The Journal of the Acoustical Society of America, vol.112, issue.3, pp.822-834, 2002. ,
Elastic waves at the surface of separation of two solids, Proc. R. Soc. Lond. A, vol.106, pp.416-428, 1924. ,
Acoustic Filtration in Non-Homogeneous Media, The Journal of the Acoustical Society of America, vol.5, issue.3, pp.202-205, 1934. ,
Filtration of oblique elastic waves in stratified media, The Journal of the Acoustical Society of America, vol.11, issue.2, pp.178-183, 1939. ,
Supersonic Transmission at Oblique Incidence Through a Solid Plate in Water, The Journal of the Acoustical Society of America, vol.16, issue.1, pp.20-25, 1944. ,
Transmission of Elastic Waves through a Stratified Solid Medium, Journal of applied Physics, vol.21, issue.2, pp.89-93, 1950. ,
The dispersion of surface waves on multilayered media, Bulletin of the Seismological Society of America, vol.43, issue.1, pp.17-34, 1953. ,
Transmission of plane waves through layered linear viscoelastic media, The Journal of the Acoustical Society of America, vol.46, issue.3B, pp.649-654, 1969. ,
, Waves in Layered Media, vol.16, 2012.
Transmission and reflection of ultrasonic waves in layered media, The Journal of the Acoustical Society of America, vol.62, issue.5, pp.1102-1109, 1977. ,
Computation of modal solutions in layered, elastic media at high frequencies, Bulletin of the Seismological Society of America, vol.55, issue.2, pp.335-358, 1965. ,
Elastic waves in a multilayered solid due to a dislocation source, Wave Motion, vol.7, issue.5, pp.459-506, 1985. ,
A robust transfer matrix formulation for the ultrasonic response of multilayered absorbing media, The Journal of the Acoustical Society of America, vol.92, issue.1, pp.452-467, 1992. ,
Transmission coefficient of multilayered absorbing anisotropic media. A solution to the numerical limitations of the Thomson-Haskell method, Ultrasonics International, vol.93, pp.431-434, 1993. ,
Delta operator technique to improve the Thomson-Haskell-method stability for propagation in multilayered anisotropic absorbing plates, The Journal of the Acoustical Society of America, vol.95, issue.4, pp.1931-1941, 1994. ,
On a numerical truncation approximation algorithm for transfer matrix method, Journal of the Acoustical Society of America, vol.107, issue.2, pp.1053-1056, 2000. ,
A Comparison of Ultrasonic Wave Reflection/transmission Models from Isotropic Multi-Layered Structures by Transfer-Matrix and Stiffness-Matrix Recursive Algorithms, AIP Conference Proceedings, 2003. ,
A matrix method for elastic wave problems, Bulletin of the Seismological Society of America, vol.54, issue.1, pp.431-438, 1964. ,
Fast programs for layered half-space problems, Bulletin of the Seismological Society of America, vol.57, issue.6, pp.1299-1315, 1967. ,
Surface wave dispersion computations: Knopoff's method, Bulletin of the Seismological Society of America, vol.60, issue.5, pp.1491-1520, 1970. ,
A full wave solution for propagation in multilayered viscoelastic media with application to Gaussian beam reflection at fluid-solid interfaces, The Journal of the Acoustical Society of America, vol.77, issue.3, pp.813-825, 1985. ,
Efficient global matrix approach to the computation of synthetic seismograms, Geophysical Journal of the Royal Astronomical Society, vol.84, issue.2, pp.331-359, 1986. ,
Wave propagation in layered composite laminates under periodic surface loads, Wave Motion, vol.10, issue.3, pp.257-266, 1988. ,
Transmission and reflection from a layered medium in water. Simulations and measurements, 38th Scandinavian Symposium on Physical Acoustics, 2015. ,
Matrix techniques for modeling ultrasonic waves in multilayered media, IEEE Transactions on Ultrasonics, Ferroelectrics, and Frequency Control, vol.42, issue.4, pp.525-542, 1995. ,
Stiffness matrices for layered soils, Bulletin of the Seismological Society of America, vol.71, issue.6, pp.1743-1761, 1981. ,
Seismic waves in a stratified half space, Geophysical Journal International, vol.57, issue.3, pp.557-583, 1979. ,
, Seismic Wave Propagation in Stratified Media, 2009.
Seismic waves in stratified anisotropic media, Geophysical Journal International, vol.78, issue.3, pp.691-710, 1984. ,
Seismic waves in stratified anisotropic media-II. Elastodynamic eigensolutions for some anisotropic systems, Geophysical Journal of the Royal Astronomical Society, vol.91, issue.1, pp.73-101, 1987. ,
Ultrasonic wave interaction with a thin anisotropic layer between two anisotropic solids. II. Second-order asymptotic boundary conditions, The Journal of the Acoustical Society of America, vol.94, issue.6, pp.3405-3420, 1993. ,
Stable reformulation of transfer matrix method for wave propagation in layered anisotropic media, Ultrasonics, vol.39, issue.6, pp.413-424, 2001. ,
Ultrasonic waves in layered anisotropic media: characterization of multidirectional composites, International Journal of Solids and Structures, vol.39, pp.5529-5545, 2002. ,
Biot waves in layered media, Journal of Applied Physics, vol.60, issue.6, pp.1926-1929, 1986. ,
Inhomogeneous Biot waves in layered media, Journal of Applied Physics, vol.66, issue.6, pp.2278-2284, 1989. ,
Acoustic multipole logging in transversely isotropic poroelastic formations, The Journal of the Acoustical Society of America, vol.86, issue.6, pp.2397-2421, 1989. ,
Inhomogeneous plane waves in layered materials including fluid, solid and porous layers, Wave Motion, vol.13, issue.4, pp.329-336, 1991. ,
Waves in stratified anisotropic poroelastic media: a transfer matrix approach, Journal of Sound and Vibration, vol.277, issue.1-2, pp.239-275, 2004. ,
Matrix propagator method for layered porous media: Analytical expressions and stability criteria, Geophysics, vol.69, issue.4, pp.1071-1081, 2004. ,
Dispersion and attenuation of acoustic guided waves in layered fluid-filled porous media, The Journal of the Acoustical Society of America, vol.95, issue.1, pp.91-98, 1994. ,
A general method of modelling sound propagation in layered media, Journal of Sound and Vibration, vol.183, issue.1, pp.129-142, 1995. ,
Propagation of sound in porous media: modelling sound absorbing materials 2e, 2009. ,
Dynamic response of a multi-layered poroelastic medium, Earthquake Engineering & Structural Dynamics, vol.24, issue.5, pp.703-722, 1995. ,
Exact stiffness method for quasi-statics of a multi-layered poroelastic medium, International Journal of Solids and Structures, vol.32, issue.11, pp.1535-1553, 1995. ,
Wave propagation in layered dry, saturated and unsaturated poroelastic media, International Journal of Solids and Structures, vol.35, pp.4753-4778, 1998. ,
Reflection and transmission of plane waves at an interface of water/multilayered porous sediment overlying solid substrate, Ocean Engineering, vol.126, pp.217-231, 2016. ,
Elastic Waves in Solids I: Free and Guided Propagation, 2000. ,
Transient Acoustic Wave Propagation in Porous Media, Modeling and Measurement Methods for Acoustic Waves and for Acoustic Microdevices, pp.127-160, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00868218
Sound absorbing materials, 1949. ,
Theory of Propagation of Elastic waves in a Fluid-Saturated Porous Solid. I. Low-Frequency Range, The Journal of the Acoustical Society of America, vol.28, issue.2, pp.168-178, 1956. ,
URL : https://hal.archives-ouvertes.fr/hal-01368666
Theory of propagation of elastic waves in a fluid-saturated porous solid. II. Higher frequency range, The Journal of the Acoustical Society of America, vol.28, issue.2, pp.179-191, 1956. ,
Acoustical characteristics of porous materials, Physics Reports, vol.82, issue.3, pp.179-227, 1982. ,
Acoustical characteristics of rigid fibrous absorbents and granular materials, he Journal of the Acoustical Society of America, vol.73, issue.3, pp.785-799, 1983. ,
Theory of dynamic permeability and tortuosity in fluid-saturated porous media, Journal of Fluid Mechanics, vol.176, pp.379-402, 1987. ,
Dynamic tortuosity and bulk modulus in air-saturated porous media, Journal of Applied Physics, vol.70, issue.4, pp.1975-1979, 1991. ,
Dynamic compressibility of air in porous structures at audible frequencies, The Journal of the Acoustical Society of America, vol.102, issue.4, 1995. ,
Propagation des ondes acoustiques dans les milieux poreux saturés: application du modèle de Biot à détermination des paramètres de mousses plast iques et de l'os trabéculaire, 2006. ,
Mechanics of Deformation and Acoustic Propagation in Porous Media, Journal of Applied Physics, vol.33, issue.4, pp.1482-1498, 1962. ,
URL : https://hal.archives-ouvertes.fr/hal-01368725
Elastic wave propagation in fluid-saturated porous media, he Journal of the Acoustical Society of America, vol.69, issue.2, pp.416-424, 1981. ,
Seismic reflections from a gas-water contact, Geophysics, vol.48, issue.2, pp.148-162, 1983. ,
Wave fields in real media: Wave propagation in anisotropic, anelastic, porous and electromagnetic media, 2007. ,
Reflection and transmission coefficients of a single layer, The Journal of the Acoustical Society of America, vol.135, issue.6, pp.3151-3162, 2014. ,
Confirmation of Biot's theory, Applied Physics Letters, vol.37, issue.4, pp.382-384, 1980. ,
Reflection and transmission coefficients in fluid-saturated porous media, The Journal of the Acoustical Society of America, vol.91, issue.4, pp.1911-1923, 1992. ,
On the boundary conditions for acoustic waves at a solid-solid or fluid-solid interface, The Journal of the Acoustical Society of America, vol.95, issue.1, pp.40-44, 1994. ,
Reflection and transmission of elastic waves from a fluid-saturated porous solid boundary, The Journal of the Acoustical Society of America, vol.87, issue.6, pp.2349-2358, 1990. ,
Reflection and transmission of plane waves at an interface of water/porous sediment with underlying solid substrate, Ocean Engineering, vol.63, pp.8-16, 2013. ,
Introduction to Fourier optics, 2005. ,
Forward and backward projection of acoustic fields using FFT methods, The Journal of the Acoustical Society of America, vol.71, issue.4, pp.803-812, 1982. ,
Transducer characterization using the angular spectrum method, The Journal of the Acoustical Society of America, vol.85, issue.5, pp.2202-2214, 1989. ,
Prediction of ultrasonic field propagation through layered media using the extended angular spectrum method, Ultrasound in Medicine & Biology, vol.20, issue.7, pp.611-622, 1994. ,
Finite amplitude acoustic propagation modeling using the extended angular spectrum method, The Journal of the Acoustical Society of America, vol.95, issue.5, pp.2399-2408, 1994. ,
