Compression for interactive communication of visual contents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Compression pour la communication interactive de contenus visuels
Interactive images and videos have received increasing attention due to the interesting features they provide. With these contents, users can navigate within the content and explore the scene from the viewpoint they desire. The characteristics of these media make their compression very challenging. On the one hand, the data is captured in high resolution (very large) to experience a real sense of immersion. On the other hand, the user requests a small portion of the content during navigation. This requires two characteristics: efficient compression of data by exploiting redundancies within the content (to lower the storage cost), and random access ability to extract part of the compressed stream requested by the user (to lower the transmission rate). Classical compression schemes can not handle random accessibility because they use a fixed pre-defined order of sources to capture redundancies. The purpose of this thesis is to provide new tools for interactive compression schemes of images. For that, as the first contribution, we propose an evaluation framework by which we can compare different image/video interactive compression schemes. Moreover, former theoretical studies show that random accessibility can be achieved using incremental codes with the same transmission cost as non-interactive schemes and with reasonable storage overhead. Our second contribution is to build a generic coding scheme that can deal with various interactive media. Using this generic coder, we then propose compression tools for 360-degree images and 3D model texture maps with random access ability to extract the requested part. We also propose new representations for these modalities. Finally, we study the effect of model selection on the compression rates of these interactive coders.
Les images et vidéos interactives ont récemment vu croître leur popularité. En effet, avec ce type de contenu, les utilisateurs peuvent naviguer dans la scène et changer librement de point de vue. Les caractéristiques de ces supports posent de nouveaux défis pour la compression. D'une part, les données sont capturées en très haute résolution pour obtenir un réel sentiment d'immersion. D'autre part, seule une petite partie du contenu est visualisée par l'utilisateur lors de sa navigation. Cela induit deux caractéristiques : une compression efficace des données en exploitant les redondances au sein du contenu (pour réduire les coûts de stockage) et une compression avec accès aléatoire pour extraire la partie du flux compressé demandée par l'utilisateur (pour réduire le débit de transmission). Les schémas classiques de compression ne peuvent gérer de manière optimale l’accès aléatoire, car ils utilisent un ordre de traitement des données fixe et prédéfini qui ne peut s'adapter à la navigation de l'utilisateur. Le but de cette thèse est de fournir de nouveaux outils pour les schémas interactifs de compression d’images. Pour cela, comme première contribution, nous proposons un cadre d’évaluation permettant de comparer différents schémas interactifs de compression d'image / vidéo. En outre, des études théoriques antérieures ont montré que l’accès aléatoire peut être obtenu à l’aide de codes incrémentaux présentant le même coût de transmission que les schémas non interactifs au prix d'une faible augmentation du coût de stockage. Notre deuxième contribution consiste à créer un schéma de codage générique pouvant s'appliquer à divers supports interactifs. À l'aide de ce codeur générique, nous proposons ensuite des outils de compression pour deux modalités d'images interactives : les images omnidirectionnelles (360 degrés) et les cartes de texture de modèle 3D. Nous proposons également de nouvelles représentations de ces modalités. Enfin, nous étudions l’effet de la sélection du modèle sur les taux de compression de ces codeurs interactifs.
main.pdf (62.49 Mo) Télécharger le fichier
tel-02410190 , version 1 (13-12-2019)
tel-02410190 , version 2 (23-03-2020)
  • HAL Id : tel-02410190 , version 1
Navid Mahmoudian Bidgoli. Compression for interactive communication of visual contents. Signal and Image Processing. Université de Rennes 1, 2019. English. ⟨NNT : ⟩. ⟨tel-02410190v1⟩
195 Consultations
21 Téléchargements
