Correlation model selection for interactive video communication, 2017 IEEE International Conference on Image Processing (ICIP), pp.2184-2188, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01590627
A Geometry-aware Framework for Compressing 3D Mesh Textures, 2019 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.4015-4019, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02010328
Evaluation Framework for 360-Degree Visual Content Compression with User View-Dependent Transmission, 2019 IEEE International Conference on Image Processing (ICIP), pp.3756-3760, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02202794
A geometry-aware compression of 3D mesh texture with random access, 2019 Picture Coding Symposium (PCS), 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02380798
Journal Papers in preparation N. Mahmoudian Bidgoli, T. Maugey and A. Roumy, 2019 Picture Coding Symposium (PCS), 2019. ,
Model selection for interactive coding ,
Codage d'atlas de textures avec prédiction guidée par la topologie des maillages, Colloque Gretsi (Symposium of the French Research group on signal and image processing, 2019. ,
Compression de contenus 360°et transmission adaptée à la navigation de l'utilisateur, Colloque Gretsi (Symposium of the French Research group on signal and image processing ,
, Navigation graph of a multiview video for free-viewpoint television system
, The navigation graph of an interactive system
, Overall scheme of an interactive coder
, Encoding graph for the tile-based approach
, Encoding graph for the exhaustive storage approach
, Compound conditional source coding
, Achievable rates for each interactive compression scheme
Saturation maps for the equirectangular and cube map representations, p.28 ,
, Viewport requested from a 360 ? visual content
, An example of user's navigation around the 3D model
, Processing pipeline of compressing an interactive medium
, The geometrical interpretation corresponding to BD, p.40
360 ? images used to illustrate the proposed evaluation framework, p.43 ,
, Color-coded heatmaps of the frequency of pixels observed in the user navigation simulated by the proposed probabilistic model
curves of interactive compression using tile-based approach, p.46 ,
, Iso distortion values for interactive compression of images using tile-based approach, p.47
, In interactive 2D image modalities, a user observes a set of pixels which corresponds to a request of a set of blocks
, 2 Navigation graph for interactive 2D image modalities
, Tile-based approach for compression of interactive 2D image modalities and the corresponding encoding graph G enc
Examples of different allowed block scanning in the proposed method, p.54 ,
Proposed lossy coding scheme of an image block X as a function of its predictions Y 1, p.57 ,
, An example of the proposed scanning of the blocks for interactive compression of 360 ? images based on Algorithm 2
, The other four images used in our experiments to evaluate interactive coder for 360 ? images, p.65
Accumulated transmission per request at iso-distortion PSNR 37dB, p.66 ,
, Usefulness of the observed pixels per request for transmission of 360 ? images using proposed interactive coder
, Comparison of storage and transmission performance for requests of length 10 using the proposed interactive coder
, Uniform sampling of the sphere
72 4.10 Partitioning of the sphere into S-blocks of 8x8 pixels ,
, Proposed scanning order of the spherical order for the case when S-blocks are 2x2 and sphere is pixelized into 192 pixels
RD curves of the proposed spherical coder against the baselines, p.76 ,
Retrieving the neighborhood information using the mesh topology, p.78 ,
, Block prediction of a boundary block using the proposed geometry-aware compression scheme
An example of access blocks localization for texture maps of 3D model, p.81 ,
, 18 RD curves of the proposed geometry aware compression algorithm against two configurations of the anchor on 3 diffusion maps
, 3D models used for experiments of interactive compression
, Transmission rate evolution over the user's navigation for the 3D model Ewer at PSNR 38dB
, Different source coding schemes based on the availability of SI source at encoder and decoder
, 2 The proposed code optimization block diagram
Excess rate under mismatched decoding metric Q XY (x, y) = Q X|Y (x|y)P Y (y) as a function of D KL (P XY ||Q X|Y P Y ) for the symmetric channel from Y to X, p.106 ,
Excess rate under mismatched decoding metric Q XY (x, y) = Q X|Y (x|y)P Y (y) as a function of D KL (P XY ||Q X|Y P Y ) for the non-symmetric channel from Y to X, p.107 ,
, 108 5.6 Excess rate estimation using the doping technique under decoding metric Q XY (x, y) = Q X|Y (x|y)P Y (y) as a function of D KL (P XY ||Q X|Y P Y ) for the non-symmetric channel from Y to X, Percentage of error between KL divergence and estimated excess rate with respect to the SW rate of the designed code (r Q )
, Processing pipeline for interactive communication
, Notations and definitions used for problem formulation of compression for interactive communication
2 Characteristics of different 2D representations in 360 ? contents, p.28 ,
, Performance of different interactive coding schemes
, Average BD measures for illustration of the proposed evaluation framework, p.45
, BD measures (in percent) averaged over all users relative to the no tiling approach (T. 1x1), p.69
, Weighted BD for requests of length 10 averaged over all users relative to the no tiling approach (T. 1x1)
, BD-rate gain of the proposed method with respect to the the rhombic dodecahedron approach proposed in [35]
, Performance comparison of the the proposed Geometry-Aware algorithm, p.83
, Weighted BD averaged over all users relative to whole atlas approach
, 60 2 Algorithm for decoding order when m(?) is equirectangular projection, p.64
, IEEE Transactions on Circuits and Systems for Video Technology, pp.1-1, 2019.
« One Scan Connected Component Labeling Technique, 2007 IEEE International Conference on Signal Processing and Communications, pp.1283-1286, 2007. ,
, Capturing the World at Street Level, vol.43, issue.6, pp.32-38, 2010.
, Extrinsic information transfer functions: model and erasure channel properties, vol.50, pp.2657-2673, 2004.
, AHG8: Truncated Square Pyramid Projection (TSP) For 360 Video, 4th meeting report JVET-D0071, Chengdu: Joint Video Exploration Team (JVET) of ITU-T SG 16 WP 3 and ISO/IEC JTC 1/SC 29/WG 11, 2016.
, Space-Optimized Texture Maps, vol.21, pp.411-420, 2002.
« Rendering from Compressed Textures, Proceedings of the 23rd Annual Conference on Computer Graphics and Interactive Techniques, SIGGRAPH '96, pp.373-378, 1996. ,
« Calculation of average PSNR differences between RD-curves, p.33, 2001. ,
Bringing pixels front and center in VR video, 2017. ,
« Universal data compression with LDPC codes, TURBOCODING 2003, 3rd International Symposium on Turbo Codes and Related Topics, 2003. ,
, On the Duality Between Slepian-Wolf Coding and Channel Coding Under Mismatched Decoding, vol.55, pp.4006-4018, 2009.
, On the Codebook-Level Duality Between Slepian-Woif Coding and Channel Coding, pp.84-93, 2007.
« Recent advances in omnidirectional video coding for virtual reality: Projection and evaluation, Signal Processing, vol.146, pp.165-1684, 2018. ,
« Interactive Streaming of Stored Multiview Video Using Redundant Frame Structures, IEEE Transactions on Image Processing, vol.20, issue.3, pp.744-761, 2011. ,
« Distributed source coding techniques for interactive multiview video streaming, 2009 Picture Coding Symposium, pp.1-4, 2009. ,
« Compression algorithms for flexible video decoding, Visual Communications and Image Processing (VCIP'08), vol.6822, 2008. ,
, White Paper Document ID: 1551296909190103, Cisco, Cisco Visual Networking Index: Forecast and Trends, 2017.
Enable the next generation of interactive video streaming, 2018. ,
URL : https://hal.archives-ouvertes.fr/tel-02011760
« 360-Degree Video Head Movement Dataset, Proceedings of the 8th ACM on Multimedia Systems Conference, MMSys'17, pp.199-204, 2017. ,
« Viewport-adaptive navigable 360-degree video delivery, 2017 IEEE International Conference on Communications (ICC), pp.1-7, 2017. ,
Elements of information theory, second Edition, 2006. ,
, Foundations and Trends® in Communications and Information Theory, vol.1, pp.1567-2190, 2004.
« Adaptive Slepian-Wolf Decoding Based on Expectation Propagation, IEEE Communications Letters, vol.16, issue.2, pp.252-255, 2012. ,
« Rate-distortion optimized merge frame using piecewise constant functions, 2013 IEEE International Conference on Image Processing, pp.1787-1791, 2013. ,
« Deformable block-based motion estimation in omnidirectional image sequences, 2017 IEEE 19th International Workshop on Multimedia Signal Processing (MMSP), pp.1-6, 2017. ,
Introduction to the Geometry of Complex Numbers, p.9780486158044, 2013. ,
« Compound conditional source coding, Slepian-Wolf list decoding, and applications to media coding, 2007 IEEE International Symposium on Information Theory, pp.1511-1515, 2007. ,
« Rate-Distortion Performance of Sequential Massive Random Access to Gaussian Sources with Memory, pp.406-406, 2018. ,
« Transmission and Storage Rates for Sequential Massive Random Access », working paper or preprint, 2018. ,
« Rate-storage regions for Extractable Source Coding with side information, pp.1874-4907, 2019. ,
« Interactive Data Compression, 25th Annual Symposium on-Foundations of Computer Science, pp.100-108, 1984. ,
Based Lossless Compression of Nonstationary Binary Sources Using Sliding-Window Belief Propagation, IEEE Transactions on Communications, vol.60, issue.11, pp.3161-3166, 2012. ,
« Correlation parameter estimation for LDPC-based slepian-wolf coding, IEEE Communications Letters, vol.13, issue.1, pp.37-39, 2009. ,
, Advances in Multiresolution for Geometric Modelling, pp.157-186, 2005.
« The Rhombic Dodecahedron Map: An Efficient Scheme for Encoding Panoramic Video, IEEE Transactions on Multimedia, vol.11, issue.4, pp.634-644, 2009. ,
« Mismatched decoding revisited: general alphabets, channels with memory, and the wide-band limit, IEEE Transactions on Information Theory, vol.46, pp.2315-2328, 2000. ,
Virtual Tour Statistics You Need to Know in 2019, 2019. ,
A Framework for High-Resolution Discretization and Fast Analysis of Data Distributed on the Sphere, The Astrophysical Journal, vol.622, issue.2, pp.759-771, 2005. ,
, 2016 IEEE International Symposium on Multimedia (ISM), pp.107-110, 2016.
, Incense Burner from Iran 3D Model, 2016.
« A Survey of Interaction Techniques for Interactive 3D ,
, Eurographics 2013 -State of the Art Reports, 2013.
« The SP-and SI-frames design for H.264/AVC, IEEE Transactions on Circuits and Systems for Video Technology, vol.13, pp.637-644, 2003. ,
, ACM Trans. Graph, vol.35, issue.6, pp.1-230, 2016.
Next-generation video encoding techniques for 360 video and VR, 2016. ,
, IEEE Transactions on Circuits and Systems for Video Technology, vol.22, pp.1792-1801, 2012.
, « Information Combining, vol.3, pp.227-330, 2006.
, Fethiye tombs, Turquie 3D Model, 2016.
Real Time Translation of 3D Mesh Data to Immersive Virtual Reality Environments, ASME 2016 International Design Engineering Technical Conferences and Computers and Information in Engineering Conference, vol.1, pp.1-02, 2016. ,
« Compression of binary sources with side information at the decoder using LDPC codes, IEEE Communications Letters, vol.6, pp.440-442, 2002. ,
Compression of progressive oriented meshes accessible randomly, Shape Modeling International (SMI) Conference, vol.37, pp.743-752, 2013. ,
, 3D Mesh Compression: Survey, Comparisons, and Emerging Trends, vol.47, p.41, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01174418
« Context-based adaptive binary arithmetic coding in the H.264/AVC video compression standard, IEEE Transactions on Circuits and Systems for Video Technology, vol.13, pp.620-636, 2003. ,
« Navigation Domain Representation For Interactive Multiview Imaging, IEEE Transactions on Image Processing, vol.22, pp.3459-3472, 2013. ,
« Data-driven progressive compression of colored 3D mesh, 2015 IEEE International Conference on Image Processing (ICIP), pp.2490-2494, 2015. ,
, On information rates for mismatched decoders, vol.40, pp.1953-1967, 1994.
« Two-view geometry of omnidirectional cameras, 2004. ,
, « Redundant frame structure using M-frame for interactive light field streaming, pp.1369-1373, 2016.
« Data compression and transmission aspects of panoramic videos, IEEE Transactions on Circuits and Systems for Video Technology, vol.15, pp.82-95, 2005. ,
, Google art and culture
Efficient spherical convolutional neural network with HEALPix sampling for cosmological applications, Astronomy and Computing, vol.27, pp.130-146, 2019. ,
, Elementary Differential Geometry, pp.229-246, 2001.
« Optimizing 360 Video Delivery over Cellular Networks, Proceedings of the 5th Workshop on All Things Cellular: Operations, Applications and Challenges, ATC '16, pp.1-6, 2016. ,
2420-0, Collection of usage scenarios and current statuses of advanced immersive audio-visual systems, tech. rep., International Telecommunication Union (ITU), 2018. ,
« Design of capacity-approaching irregular low-density parity-check codes, IEEE Transactions on Information Theory, vol.47, issue.2, pp.619-637, 2001. ,
« The capacity of low-density parity-check codes under message-passing decoding, IEEE Transactions on Information Theory, vol.47, issue.2, pp.599-618, 2001. ,
Universal Prior for Integers and Estimation by Minimum Description Length, The Annals of Statistics, vol.11, pp.416-431, 1983. ,
« Rate Distortion Optimized Graph Partitioning for Omnidirectional Image Coding, 26th European Signal Processing Conference (EUSIPCO), pp.897-901, 2018. ,
« Navigation-aware adaptive streaming strategies for omnidirectional video, 2017 IEEE 19th International Workshop on Multimedia Signal Processing (MMSP), pp.1-6, 2017. ,
« Design methods for irregular repeat-accumulate codes, IEEE Transactions on Information Theory, vol.50, pp.1711-1727, 2004. ,
Universal lossless coding with random user access: The cost of interactivity, 2015 IEEE International Conference on Image Processing (ICIP), pp.1870-1874, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01208128
, Channel Codes: Classical and Modern, p.9780521848688, 2009.
« Design of irregular LDPC codes for BIAWGN channels with SNR mismatch, IEEE Transactions on Communications, vol.57, issue.1, pp.6-11, 2009. ,
« Performance of Belief Propagation for Decoding LDPC Codes in the Presence of Channel Estimation Error, IEEE Transactions on Communications, vol.55, issue.1, pp.83-89, 2007. ,
« On the design of low-density parity-check codes within 0.0045 dB of the Shannon limit, IEEE Communications Letters, vol.5, issue.2, pp.58-60, 2001. ,
Introduction to Data Compression, Third Edition (Morgan Kaufmann Series in Multimedia Information and Systems), vol.5, p.12620862, 2018. ,
Fabregas, « Mismatched Decoding: Error Exponents, Second-Order Rates and Saddlepoint Approximations, IEEE Transactions on Information Theory, vol.60, issue.5, pp.2647-2666, 2014. ,
« Source coding with side information at several decoders, IEEE Transactions on Information Theory, vol.23, pp.179-182, 1977. ,
« A mathematical theory of communication, The Bell System Technical Journal, vol.27, issue.3, pp.379-423, 1948. ,
Computer Vision, 1st, p.130307963, 2001. ,
« The emerging field of signal processing on graphs: Extending high-dimensional data analysis to networks and other irregular domains, IEEE Signal Processing Magazine, vol.30, issue.3, pp.83-98, 2013. ,
« Texture Images are not Regular Images:How to Leverage Geometry Information?, IEEE MMTC Review-Letter, vol.10, issue.2, p.3, 2019. ,
« Noiseless coding of correlated information sources, IEEE Transactions on Information Theory, vol.19, pp.471-480, 1973. ,
, Ewer with Birds, Snakes, and Humans
, The 3D Program
Flattening the Earth: Two Thousand Years of Map Projections, p.9780226767475, 1993. ,
, Overview of the High Efficiency Video Coding (HEVC) Standard », in: IEEE Transactions on Circuits and Systems for Video Technology, vol.22, pp.1649-1668, 2012.
, LDPC code design for asynchronous Slepian-Wolf coding, vol.58, pp.511-520, 2010.
, « Image Alignment and Stitching: A Tutorial, vol.2, pp.1-104, 2006.
« Adaptive 360-degree video streaming using layered video coding, 2017 IEEE Virtual Reality (VR), pp.347-348, 2017. ,
Free-viewpoint Television, Signal Processing, vol.27, pp.923-5965, 2012. ,
, Convergence behavior of iteratively decoded parallel concatenated codes, vol.49, pp.1727-1737, 2001.
« Design of low-density parity-check codes for modulation and detection, IEEE Transactions on Communications, vol.52, pp.670-678, 2004. ,
, The power of media-rich map listings, 2015.
« Low bit-rate compression of omnidirectional images, 2009 Picture Coding Symposium, pp.1-4, 2009. ,
, Maximum Likelihood BSC Parameter Estimation for the Slepian-Wolf Problem, vol.15, pp.232-234, 2011.
URL : https://hal.archives-ouvertes.fr/inria-00628996
« On the performance of objective metrics for omnidirectional visual content, 2017 Ninth International Conference on Quality of Multimedia Experience (QoMEX), pp.1-6, 2017. ,
« Rate-adaptive codes for distributed source coding, Special Section: Distributed Source Coding, vol.86, pp.3123-3130, 2006. ,
« Projective texture atlas construction for 3D photography, The Visual Computer, vol.23, pp.621-629, 2007. ,
« Motion Compensated Prediction for Translational Camera Motion in Spherical Video Coding, 2018 IEEE 20th International Workshop on Multimedia Signal Processing (MMSP), pp.1-4, 2018. ,
Rotational motion model for temporal prediction in 360 video coding, 2017 IEEE 19th International Workshop on Multimedia Signal Processing (MMSP), pp.1-6, 2017. ,
, The JPEG still picture compression standard, vol.38, pp.xviii-xxxiv, 1992.
, 53rd Annual Allerton Conference on Communication, Control, and Computing (Allerton), pp.147-152, 2015.
, « Analyzing Symbol and Bit Plane-Based LDPC in Distributed Video Coding, vol.2, 2007.
High Efficiency Video Coding: Coding Tools and Specification, Signals and Communication Technology, p.9783662442753, 2014. ,
« Recent results in the Shannon theory, IEEE Transactions on Information Theory, vol.20, issue.1, pp.2-10, 1974. ,
« Recognizing scene viewpoint using panoramic place representation, 2012 IEEE Conference on Computer Vision and Pattern Recognition, pp.2695-2702, 2012. ,
« Patch-based compression for Time-Varying Meshes, 2010 IEEE International Conference on Image Processing, pp.3433-3436, 2010. ,
« A High-Realistic Texture Mapping Algorithm Based on Image Sequences, 26th International Conference on Geoinformatics, pp.1-8, 2018. ,
« Optimized Rate-Adaptive Protograph-Based LDPC Codes for Source Coding With Side Information, IEEE Transactions on Communications, vol.67, issue.6, pp.3879-3889, 2019. ,
« A Framework to Evaluate Omnidirectional Video Coding Schemes, 2015 IEEE International Symposium on Mixed and Augmented Reality, pp.31-36, 2015. ,
, Proceedings of the 3rd International Workshop on Immersive Media Experiences, ImmersiveME '15, pp.1-6, 2015.
« Virtual reality content streaming: Viewportdependent projection and tile-based techniques, 2017 IEEE International Conference on Image Processing (ICIP), pp.1432-1436, 2017. ,
« HEVC-compliant Tile-based Streaming of Panoramic Video for Virtual Reality Applications, Proceedings of the 24th ACM International Conference on Multimedia, MM '16, pp.601-605, 2016. ,
