TensorFlow: Large-scale machine learning on heterogeneous systems, Josh Levenberg, 2015. ,
Re ectance modeling by neural texture synthesis, Proc. SIGGRAPH), vol.35, 2016. ,
Burst image deblurring using permutation invariant convolutional neural networks, e European Conference on Computer Vision (ECCV), 2018. ,
Substance designer, 2019. ,
Substance share, 2019. ,
Distribution-based brdfs, 2007. ,
Practical SVBRDF capture in the frequency domain, vol.32, 2013. ,
Two-shot SVBRDF capture for stationary materials, Proc. SIGGRAPH), vol.34, 2015. ,
e sca ering of electromagnetic waves from rough surfaces, 1987. ,
Learning long-term dependencies with gradient descent is di cult, IEEE Transactions on Neural Networks, vol.5, issue.2, pp.157-166, 1994. ,
Ps-fcn: A exible learning framework for photometric stereo, e European Conference on Computer Vision (ECCV), 2018. ,
Photographic image synthesis with cascaded re nement networks, International Conference on Computer Vision (ICCV, 2017. ,
A re ectance model for computer graphics, ACM Transactions on Graphics, vol.1, issue.1, pp.7-24, 1982. ,
3d-r2n2: A uni ed approach for single and multi-view 3d object reconstruction, IEEE European Conference on Computer Vision (ECCV), pp.628-644, 2016. ,
Single-image svbrdf capture with a rendering-aware deep network, ACM Transactions on Graphics (SIGGRAPH Conference Proceedings), vol.37, issue.128, p.15, 2018. ,
Flexible svbrdf capture with a multi-image deep network, Computer Graphics Forum (Proceedings of the Eurographics Symposium on Rendering), vol.38, 2019. ,
Recognition of surface re ectance properties from a single image under unknown real-world illumination, Proc. IEEE Workshop on Identifying Objects Across Variations in Lighting: Psychophysics and Computation, 2001. ,
Appearance-from-motion: Recovering spatially varying surface reectance under unknown lighting, Proc. SIGGRAPH Asia), vol.34, 2014. ,
ImageNet: A Large-Scale Hierarchical Image Database, CVPR09, 2009. ,
Acquiring the re ectance eld of a human face, Proceedings of the 27th Annual Conference on Computer Graphics and Interactive Techniques, SIGGRAPH '00, pp.145-156, 2000. ,
Guided super-resolution as a learned pixel-to-pixel transformation, IEEE International Conference on Computer Vision (ICCV), 2019. ,
Deep appearance modeling: A survey, Visual Informatics, vol.3, issue.2, pp.59-68, 2019. ,
Appgen: Interactive material modeling from a single image, Proc. SIGGRAPH Asia), vol.30, pp.1-146, 2011. ,
Re ectance and texture of real-world surfaces, ACM Transactions On Graphics (TOG), vol.18, issue.1, pp.1-34, 1999. ,
, Proc. SIGGRAPH), vol.29, 2010.
Real-world illumination and the perception of surface re ectance properties, Journal of Vision, vol.3, issue.5, 2003. ,
e theory and measurement of bidirectional re ectance distribution function (brdf) and bidirectional transmi ance distribution function (btdf), vol.0257, 1981. ,
StyLit: Illumination-guided examplebased stylization of 3d renderings, ACM Transactions on Graphics (proc. SIGGRAPH), vol.35, issue.4, 2016. ,
Example-based synthesis of stylized facial animations, ACM Transactions on Graphics (Proc. SIG-GRAPH), vol.36, issue.4, 2017. ,
Understanding the di culty of training deep feedforward neural networks, Proceedings of the irteenth International Conference on Articial Intelligence and Statistics, vol.9, pp.13-15, 2010. ,
Estimating specular roughness and anisotropy from second order spherical gradient illumination, Computer Graphics Forum, vol.28, issue.4, pp.1161-1170, 2009. ,
, BRDF Representation and Acquisition. Computer Graphics Forum, 2016.
Deep inverse rendering for high-resolution svbrdf estimation from an arbitrary number of images, ACM Trans. Graph, vol.38, issue.4, 2019. ,
Generative adversarial nets, Advances in Neural Information Processing Systems, vol.27, pp.2672-2680, 2014. ,
Linear light source re ectometry, ACM Trans. Graph, vol.22, issue.3, pp.749-758, 2003. ,
Arbitrary style transfer in real-time with adaptive instance normalization, ICCV, 2017. ,
Deep neural networks for acoustic modeling in speech recognition, IEEE Signal Processing Magazine, vol.29, pp.82-97, 2012. ,
Bidirectional texture function compression based on multi-level vector quantization, Computer Graphics Forum, vol.29, issue.1, pp.175-190, 2010. ,
, Image analogies. ACM SIGGRAPH, 2001.
Depth map superresolution by deep multi-scale guidance, European Conference on Computer Vision (ECCV), 2016. ,
A coaxial optical scanner for synchronous acquisition of 3d geometry and surface re ectance, ACM SIGGRAPH 2010 Papers, SIGGRAPH '10, vol.99, pp.1-99, 2010. ,
Bidirectional re ectometry. part i. a high resolution laser bidirectional re ectometer with results on several optical coatings, 1976. ,
Re ectance capture using univariate sampling of brdfs, IEEE International Conference on Computer Vision (ICCV, 2017. ,
Deep residual learning for image recognition, 2016 IEEE Conference on Computer Vision and Pa ern Recognition (CVPR), pp.770-778, 2016. ,
Decomposing single images for layered photo retouching, Computer Graphics Forum (Proc. EGSR), vol.36, issue.4, 2017. ,
Let there be Color!: Joint End-to-end Learning of Global and Local Image Priors for Automatic Image Colorization with Simultaneous Classi cation, ACM Transactions on Graphics (Proc. SIGGRAPH), vol.35, issue.4, 2016. ,
Image-toimage translation with conditional adversarial networks, e IEEE Conference on Computer Vision and Pa ern Recognition (CVPR), 2017. ,
Mitsuba renderer, 2010. ,
Kajiya. e rendering equation, Computer Graphics, pp.143-150, 1986. ,
Progressive growing of GANs for improved quality, stability, and variation, International Conference on Learning Representations (ICLR), 2018. ,
Adam: A method for stochastic optimization, International Conference on Learning Representations (ICLR), 2015. ,
E cient re ectance capture using an autoencoder, Proc. SIGGRAPH), vol.37, 2018. ,
A style-based generator architecture for generative adversarial networks, 2018. ,
Imagenet classication with deep convolutional neural networks, Proceedings of the 25th International Conference on Neural Information Processing Systems, vol.1, pp.1097-1105, 2012. ,
Andreas Mayr, and Sepp Hochreiter. Self-normalizing neural networks, Advances in Neural Information Processing Systems (NIPS), pp.972-981, 2017. ,
Handwri en digit recognition with a back-propagation network, Advances in neural information processing systems, pp.396-404, 1990. ,
Material editing using a physically based rendering network, IEEE International Conference on Computer Vision (ICCV), pp.2261-2269, 2017. ,
Modeling surface appearance from a single photograph using self-augmented convolutional neural networks, Proc. SIGGRAPH), vol.36, 2017. ,
Image-based reconstruction of spatial appearance and geometric detail, ACM Transactions on Graphics, vol.22, issue.2, pp.234-257, 2003. ,
An intriguing failing of convolutional neural networks and the coordconv solution, ACM Transactions on Graphics, vol.38, issue.4, 2018. ,
Re ectance and illumination recovery in the wild, IEEE Transactions on Pa ern Analysis and Machine Intelligence (PAMI), vol.38, pp.129-141, 2016. ,
Materials for masses: SVBRDF acquisition with a single mobile phone image, Proceedings of ECCV, 2018. ,
Learning to reconstruct shape and spatially-varying re ectance from a single image, ACM Transactions on Graphics (Proc. SIG-GRAPH Asia), 2018. ,
A Generalized Surface Appearance Representation for Computer Graphics, 2002. ,
e automated measurement of brdfs and their application to luminaire modeling, Journal of the Illuminating Engineering Society, vol.19, issue.1, pp.87-99, 1990. ,
Transfer of albedo and local depth variation to photo-textures, vol.12, p.2012 ,
A logical calculus of the ideas immanent in nervous activity, e bulletin of mathematical biophysics, vol.5, issue.4, pp.115-133, 1943. ,
Direct intrinsics: Learning albedo-shading decomposition by convolutional regression, IEEE International Conference on Computer Vision (ICCV), 2015. ,
Geometrical considerations and nomenclature for re ectance, 1977. ,
Brdf and geometry capture from extended inhomogeneous samples using ash photography, Computer Graphics Forum (Proc. Eurographics), vol.24, pp.383-391, 2005. ,
Illumination for computer generated pictures, Commun. ACM, vol.18, issue.6, pp.311-317, 1975. ,
Pointnet: Deep learning on point sets for 3d classi cation and segmentation, 2016. ,
Pointnet: Deep learning on point sets for 3d classi cation and segmentation, IEEE Conference on Computer Vision and Pa ern Recognition (CVPR, 2017. ,
Re ectance and natural illumination from single-material specular objects using deep learning, IEEE Transactions on Pa ern Analysis and Machine Intelligence, 2017. ,
Parallel distributed processing: Explorations in the microstructure of cognition, chapter Learning Internal Representations by Error Propagation, vol.1, pp.318-362, 1986. ,
Neural btf compression and interpolation, Computer Graphics Forum (Proceedings of Eurographics), vol.38, 2019. ,
Btf compression via sparse tensor decomposition, Computer Graphics Forum, vol.28, issue.4, pp.1181-1188, 2009. ,
A probabilistic model for information storage and organization in the brain, Psychological Review, pp.65-386, 1958. ,
U-net: Convolutional networks for biomedical image segmentation, Medical Image Computing and Computer-Assisted Intervention (MICCAI), vol.9351, pp.234-241, 2015. ,
Mobile surface re ectometry, Computer Graphics Forum, vol.35, issue.1, 2016. ,
Polarization imaging re ectometry in the wild, Proc. SIGGRAPH, p.2017 ,
Playing for data: Ground truth from computer games, Proc. European Conference on Computer Vision (ECCV), 2016. ,
Pocket re ectometry, Proc. SIGGRAPH), vol.30, 2011. ,
Render for cnn: Viewpoint estimation in images using cnns trained with rendered 3d model views, e IEEE International Conference on Computer Vision (ICCV), 2015. ,
Design and implementation of practical bidirectional texture function measurement devices focusing on the developments at the university of bonn, Sensors, vol.14, issue.5, 2014. ,
Sequence to sequence learning with neural networks ,
, Advances in Neural Information Processing Systems, vol.27, pp.3104-3112, 2014.
eory for o -specular re ection from roughened surfaces *, J. Opt. Soc. Am, vol.57, issue.9, pp.1105-1114, 1967. ,
MoFA: Model-based Deep Convolutional Face Autoencoder for Unsupervised Monocular Reconstruction, IEEE International Conference on Computer Vision (ICCV, 2017. ,
Improved texture networks: Maximizing quality and diversity in feed-forward stylization and texture synthesis, e IEEE Conference on Computer Vision and Pa ern Recognition (CVPR), 2017. ,
Transferring color to greyscale images, ACM Transactions on Graphics (Proc. SIGGRAPH), vol.21, issue.3, 2002. ,
Measuring and modeling anisotropic re ection, 1992. ,
A sparse parametric mixture model for btf compression, editing and rendering, Computer Graphics Forum, vol.30, issue.2, pp.465-473, 2011. ,
Nonlocal neural networks, e IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2018. ,
Material classi cation based on training data synthesized using a btf database, European Conference on Computer Vision (ECCV), pp.156-171, 2014. ,
Microfacet models for refraction through rough surfaces, Proc. of Eurographics Conference on Rendering Techniques (EGSR), 2007. ,
Estimating dual-scale properties of glossy surfaces from step-edge lighting, Proc. SIGGRAPH Asia), vol.30, 2011. ,
Silnet : Single-and multi-view reconstruction by learning from silhoue es, British Machine Vision Conference (BMVC, 2017. ,
Minimal brdf sampling for two-shot near-eld re ectance acquisition, Proc. SIGGRAPH Asia), vol.35, 2016. ,
Deep sets, Advances in Neural Information Processing Systems (NIPS), 2017. ,
Unpaired image-to-image translation using cycle-consistent adversarial networks, Computer Vision (ICCV, 2017. ,
Re ectance sharing: predicting appearance from a sparse set of images of a known shape, IEEE Transactions on Pa ern Analysis and Machine Intelligence, vol.28, issue.8, 2006. ,
Jin, and omas A. Funkhouser. Physically-based rendering for indoor scene understanding using convolutional neural networks, e IEEE Conference on Computer Vision and Pa ern Recognition (CVPR), 2017. ,
Real-time user-guided image colorization with learned deep priors, Proc. SIGGRAPH), vol.9, 2017. ,
