The chemical and radioactive properties of the heavy elements, Chemical & Engineering News Archive, vol.23, issue.23, pp.2190-2193, 1945. ,
Chemistry of thorium in aqueous solutions. I. Some organic and inorganic complexes, Journal of the American Chemical Society, vol.72, issue.12, pp.5662-5666, 1950. ,
The hydration of thenoyltrifluoroacetone in benzene solution, Journal of the American Chemical Society, vol.73, issue.4, pp.1806-1808, 1951. ,
Thorium complexes with chloride, fluoride, nitrate, phosphate and sulfate, Journal of the American Chemical Society, vol.73, issue.12, pp.5646-5650, 1951. ,
Chemistry of Thorium in Aqueous Solutions. II. Chloride Complexing as A Function of Ionic Strength, The Journal of Physical Chemistry, vol.56, issue.1, pp.1-5, 1952. ,
Anion-exchange Studies, 1956. ,
U (IV) in hydrochloric acid. Separation of thorium, protactinium and uranium, Journal of the American Chemical Society, vol.78, issue.12, pp.2692-2695 ,
Distribution of neptunium between TBP and some mineral acids, Bulletin of the Chemical Society of Japan, vol.32, issue.7, pp.713-720, 1959. ,
A review of the kinetics of the aqueous oxidation-reduction reactions of uranium, neptunium, And plutonium, Journal of Physical Chemistry, vol.63, issue.3, pp.365-370, 1959. ,
Ultraviolet absorption spectra of some hydroxamic acids and hydroxamic acid derivatives, Journal of Organic Chemistry, vol.24, issue.6, pp.802-804, 1959. ,
Absorption spectra of uranium (iii) and uranium (IV) in DClO4 solution, Journal of Physical Chemistry, vol.64, issue.12, pp.1933-1936, 1960. ,
A summary of TTA extraction coefficients, Journal of Inorganic and Nuclear Chemistry, vol.16, issue.3-4, pp.323-336, 1961. ,
Hydroxamatkomplexe .2. Die Anwendung der pH-Methode, Helvetica Chimica Acta, vol.46, issue.4, p.1400, 1963. ,
, Protactinium. Quarterly Reviews, Chemical Society, vol.17, issue.3, pp.289-341, 1963.
Hydroxamatkomplexe i. Die Stabilitä t der Eisen(iii)-Komplexe einfacher Hydroxamsä uren und des Ferrioxamins b, Helvetica Chimica Acta, vol.46, issue.4, 1963. ,
Studies on protactinium (V) in sulphuric acid solution-I: Centrifugation study, Journal of Inorganic and Nuclear Chemistry, vol.27, issue.2, pp.405-409, 1965. ,
The complexing power of hydroxamic acids and its effect on behaviour of organic extractants in the reprocessing of irradiated fuels-II: The complexes between benzohydroxamic acid and thorium, uranium (IV) and plutonium (IV), Journal of Inorganic and Nuclear Chemistry, vol.28, issue.12, pp.2961-2967, 1966. ,
Formation, hydrolysis, and olation of uranium (IV) chelates, Journal of the American Chemical Society, vol.90, issue.1, pp.32-38, 1968. ,
Adsorption of thorium and its TTA-complexes from aqueous solutions, Acta Chem. Scand, issue.8, p.6, 1969. ,
Solvent extraction studies of the formation of fluoride and sulphate complexes of zirconium (IV), Acta Chem. Scand, issue.2, p.23, 1969. ,
The Chemistry of Plutonium. Gordon and Beach, 1970. ,
Extraction behavior of europium with thenoyltrifluoroacetone (TTA), Radioisotopes, vol.19, issue.1, pp.1-6, 1970. ,
Hydrolyse du plutonium té travalent. Radiochem, Radioanal. Lett, vol.10, pp.27-35, 1972. ,
Comparative solution chemistry, ionic radius, and single ion hydration energy of nobelium, Inorganic Chemistry, vol.13, issue.9, pp.2233-2237, 1974. ,
Investigation of the hydrolytic properties of tetravalent uranium: II. Conditions of formation of mononuclear and polynuclear hydroxo complexesof U(IV), Sov. Radiochem, vol.17, pp.160-164, 1975. ,
Studies of rare-earth metal-complexes of hydroxamic acids, Journal of the Chinese Chemical Society, vol.22, issue.4, pp.317-330, 1975. ,
Revised effective ionic-radii and systematic studies of interatomic distances in halides and chalcogenides, Acta Crystallographica Section A, vol.32, pp.751-767, 1976. ,
Plutonium (IV) and thorium (IV) hydrous polymer chemistry. Oak Ridge National Lab, 1978. ,
Relativistic Quantum Chemistry, Advances in Quantum Chemistry, vol.11, pp.353-409, 1978. ,
Worldwilde Fallout, Transuranic Elements in the Environment Worldwide Fallout, pp.53-82, 1980. ,
Occurrence of hydroxamate siderophore iron chelators in soils, Nature, vol.287, issue.5785, pp.833-834, 1980. ,
The positions of lanthanum (actinium) and lutetium (lawrencium) in the periodic table, Journal of Chemical Education, vol.59, 1982. ,
The determination of the 1st hydrolysis constant of Eu(III) and Am(III), Radiochimica Acta, vol.33, issue.2-3, pp.101-104, 1983. ,
Solution chemistry of the actinides, Radiochimica Acta, vol.32, issue.1-3, pp.43-53, 1983. ,
Summary and comparative aspects of the actinide elements. The chemistry of the actinide elements, 1986. ,
Relativistic effects in structural chemistry, Chemical Reviews, vol.88, issue.3, pp.563-594, 1988. ,
Isomerization and solution structures of desferrioxamine B complexes of aluminum(3+) and gallium(3+), 1989. ,
, Inorganic Chemistry, vol.28, issue.18, pp.3538-3545
Metal-ion recognition in ligands with negatively charged oxygen donor groups -complexation of Fe(iii), Ga(iii), In(iii), Al(iii), and other highly charged metal-ions. Inorganic Chemistry, vol.28, pp.2189-2195, 1989. ,
Symmetry and spectroscopy: an introduction to vibrational and electronic spectroscopy, 1989. ,
Studies of collectors .10. Complexing ability of amino hydroxamic acid ligands with dioxouranium(IV) in aqueous-solution, Bulletin of the Chemical Society of Japan, vol.62, issue.11, pp.3714-3715, 1989. ,
Hydrolysis of actinides and lanthanides: hydrolysis of some trivalent actinide and lanthanide ions studied by extraction with thenoyltrifluoroacetone, Polyhedron, vol.8, issue.16, pp.2071-2076, 1989. ,
, , 1989.
, Electromigration of carrier-free radionuclides, Radiochimica Acta, vol.8, issue.4, pp.187-189
Actinide binding and solubilization by microbial siderophores, Radiochimica Acta, pp.357-363, 1992. ,
Chemical thermodynamics of uranium, 1992. ,
Aqueous chemistry of metal-cations -hydrolysis, condensation and complexation, Structure and Bonding, vol.77, pp.153-206, 1992. ,
Principles and practices of solvent extradction, 1992. ,
, Fundamentals of Radiochemistry, 2018.
Density-functional thermochemistry. III. The role of exact exchange, J. Chem. Phys, vol.98, p.5648, 1993. ,
, UV Spectroscopy: Techniques, instrumentation and data handling, vol.4, 1993.
, Capillary electrophoresis technology, vol.64, 1993.
Practical spectroscopy series. Internal reflection spectroscopy: Theory and Applications, pp.17-52, 1993. ,
Relativistic effects and electronic structure of lanthanide and actinide molecules, Handbook on the physics and chemistry of rare earths", vol.18, pp.29-158, 1994. ,
Siderophores -structure and function of microbial iron transport compounds, Journal of Biological Chemistry, vol.270, issue.45, pp.26723-26726, 1995. ,
Relativistic effects in chemistry. Theoretical and Experimental Chemistry, vol.31, pp.153-168, 1995. ,
Aspects of the permanent storage of uranium tailings, Water Air and Soil Pollution, vol.88, issue.1-2, pp.83-92, 1996. ,
Speciation of uranium in seepage waters of a mine tailing pile studied by time-resolved laser-induced fluorescence spectroscopy (TRLFS), Radiochimica Acta, vol.74, issue.s1, pp.87-92, 1996. ,
Investigation of equilibria in solution. Determination of equilibrium constants with the HYPERQUAD suite of programs, Talanta, vol.43, issue.10, pp.1739-1753, 1996. ,
Stability constants for complexes of the siderophore desferrioxamine B with selected heavy metal cations, 1996. ,
, Inorganica Chimica Acta, vol.244, issue.2, pp.179-184
Hydrophilic actinide complexation studied by solvent extraction radiotracer technique, 1996. ,
Stability of the thorium(IV) complexes of desferrioxamine B (DFO) and three octadentate catecholate or hydroxypyridinonate DFO derivatives: DFOMTA, DFOCAMC, and DFO-1,2-HOPO. Comparative stability of the plutonium(IV) DFOMTA complex, Inorganic Chemistry, vol.29, issue.14, pp.4128-4136, 1996. ,
Solubility, dissociation and complexation with Nd(III) and Th(IV) of oxine, thenoyltrifluoroacetone and 1,10-phenanthroline in 5.0 m NaCl, Talanta, vol.43, issue.12, pp.2073-2081, 1996. ,
Determination of uranium, thorium, plutonium, americium, and curium ultratraces by photon electron rejecting ? liquid scintillation, Analytical Chemistry, vol.69, issue.13, pp.2275-2282, 1997. ,
URL : https://hal.archives-ouvertes.fr/in2p3-00000296
, Compendium of chemical terminology, vol.1669, 1997.
Chemical Hardness, 1997. ,
237Np 239Pu atom ratios in integrated global fallout: a reassessment of the production of 237Np, Journal of Environmental Radioactivity, vol.38, issue.2, pp.133-146, 1998. ,
Oxidation state determination of plutonium aquo ions using X-ray absorption spectroscopy, Polyhedron, vol.17, pp.599-602, 1998. ,
The applications of formo-and aceto-hydroxamic acids in nuclear fuel reprocessing, Journal of Alloys and Compounds, vol.271, pp.534-537, 1998. ,
A critical review on the stability constants of the fluoride complexes of actinides in aqueous solution and their correlation with fundamental properties of the ions, Journal of Radioanalytical and Nuclear Chemistry, vol.240, issue.3, pp.993-1011, 1999. ,
A comparison between the chelating properties of some dihydroxamic acids, desferrioxamine B and acetohydroxamic acid, Polyhedron, vol.18, issue.18, pp.2391-2398, 1999. ,
Migration of plutonium in ground water at the Nevada Test Site, Nature, vol.397, issue.6714, pp.56-59, 1999. ,
, , 1999.
, Structure of the aqua ions and fluoride complexes of uranium(IV) and thorium(IV) in aqueous solution: an EXAFS study, Inorganic Chemistry, vol.38, issue.8, pp.1795-1799
The chemical complexities of plutonium, Los Alamos Science, vol.26, pp.364-381, 2000. ,
Studies on the complexation behavior of thorium(IV). 1. Hydrolysis equilibria, Journal of Solution Chemistry, vol.29, issue.1, pp.63-86, 2000. ,
Comparative hydrolysis behavior of the rare earths and yttrium: the influence of temperature and ionic strength, Polyhedron, vol.19, issue.1, pp.99-107, 2000. ,
Structural characterization of a plutonium (IV) siderophore complex: single-crystal structure of pu-desferrioxamine E, Angewandte Chemie International Edition, vol.39, issue.8, pp.1442-1444, 2000. ,
Metal complexes of salicylhydroxamic acid (H(2)Sha), anthranilic hydroxamic acid and benzohydroxamic acid. Crystal and molecular structure of Cu(phen)(2)(Cl) Cl center dot H(2)Sha, a model for a peroxidase-inhibitor complex, Journal of Inorganic Biochemistry, vol.79, issue.1-4, pp.47-51, 2000. ,
Infrared spectroscopy. Kirk-Othmer encyclopedia of chemical technology, 2000. ,
Neptunium redox speciation, Radiochimica Acta, vol.89, issue.1, pp.17-25, 2001. ,
, Chemical thermodynamics of neptunium and plutonium, vol.4, 2001.
Separation of long-lived radionuclides from high active nuclear waste, Comptes Rendus Physique, vol.3, issue.7-8, pp.797-811, 2002. ,
URL : https://hal.archives-ouvertes.fr/cea-02360108
Solubility of amorphous Th(IV) hydroxide -application of LIBD to determine the solubility product and EXAFS for aqueous speciation, 2002. ,
, Radiochimica Acta, vol.90, issue.9, pp.485-494
XAFS investigation of the structure of aqueous thorium(IV) species, colloids, and solid thorium(IV) oxide/hydroxide, Inorganic Chemistry, vol.41, issue.2, pp.249-258, 2002. ,
Organic mature of colloidal actinides transported in surface water environments, Environmental Science & Technology, vol.36, issue.17, pp.3711-3719, 2002. ,
Acetohydroxamic acid complexes with trivalent f-block metal cations, Journal of Nuclear Science and Technology, vol.39, pp.359-362, 2002. ,
Update on the chemical thermodynamic of uranium, neptunium, plutonium, americium and technetium, 2003. ,
Contribution à l'é tude thermodynamique de l'hydrolyse de, 2003. ,
V) à l'é chelle des traces par la technique d'extraction liquide-liquide avec la thenoyltrifluoroacetone (TTA): caracté risation du partage de la thenoyltrifluoroacetone dans le systè me TTA/H2O/toluè ne/Na+/H+/CIO4-(Doctoral dissertation, vol.11 ,
Solubility and first hydrolysis constants of europium at different ionic strength and 303 K, Journal of Radioanalytical and Nuclear Chemistry, vol.257, issue.2, pp.299-303, 2003. ,
Uranium mill tailings: nuclear waste and natural laboratory for geochemical and radioecological investigations, Journal of Environmental Radioactivity, vol.77, issue.1, pp.1-27, 2004. ,
Study of the interaction between oxovanadium(IV) and hydroxamic acids, Polyhedron, vol.24, issue.7, pp.837-845, 2005. ,
Siderophore?manganese(III) interactions. I. Air-oxidation of manganese(II) promoted by desferrioxamine B. Environmental, Science & Technology, vol.39, issue.16, pp.6037-6044, 2005. ,
Experimental and theoretical vibrational spectroscopy studies of acetohydroxamic acid and desferrioxamine B in aqueous solution: Effects of pH and iron complexation, Geochimica Et Cosmochimica Acta, vol.69, issue.13, pp.3237-3248, 2005. ,
First structural characterization of a protactinium (V) single oxo bond in aqueous media, Inorganic Chemistry, vol.44, issue.25, pp.9542-9546, 2005. ,
URL : https://hal.archives-ouvertes.fr/in2p3-00025340
ATHENA, ARTEMIS, HEPHAESTUS: data analysis for X-ray absorption spectroscopy using IFEFFIT, Journal of Synchrotron Radiation, vol.12, pp.537-541, 2005. ,
, , 2005.
, Thermo-FTIR spectroscopic study of the siderophore ferrioxamine B: Spectral analysis and stereochemical implications of iron chelation, pH, and temperature, Journal of Agricultural and Food Chemistry, vol.53, issue.9, pp.3434-3443
Atlas of Eh-pH diagrams, Geological Survey of Japan Open File report, p.102, 2005. ,
Infrared spectra and structures of the Th(OH)(2) and Th(OH)(4) molecules, Physical Chemistry Chemical Physics, vol.7, issue.22, pp.3834-3838, 2005. ,
IR, Raman and surface-enhanced Raman study of desferrioxamine B and its Fe(III) complex, ferrioxamine B, Journal of Molecular Structure, vol.788, issue.1, pp.1-6, 2006. ,
Determination of the thermodynamic quantities of complexation between Eu(III) and carboxylic acids by microcalorimetry, Radiochimica Acta, vol.94, issue.9, pp.541-547, 2006. ,
Colloid transport of plutonium in the far-field of the Mayak production association, Russia. Science, vol.314, issue.5799, pp.638-641, 2006. ,
Characterization of metal-deferoxamine complexes by continuous variation method: A new approach using capillary zone electrophoresis, Microchemical Journal, vol.82, issue.2, pp.214-219, 2006. ,
Solution coordination chemistry of actinides: Thermodynamics, structure and reaction mechanisms, Coordination Chemistry Reviews, vol.250, issue.7-8, pp.784-815, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00105000
Complexation of Pu(IV) with the natural siderophore desferrioxamine B and the redox properties of Pu(IV)(siderophore) complexes, Inorganic Chemistry, vol.46, issue.3, pp.1018-1026, 2007. ,
Solvent extraction behavior of plutonium (IV) ions in the presence of simple hydroxamic acids, Solvent Extraction and Ion Exchange, vol.25, issue.6, pp.723-745, 2007. ,
Actinide speciation in the environment, Journal of Radioanalytical and Nuclear Chemistry, vol.273, issue.3, pp.695-703, 2007. ,
Complexation of uranium(VI) with aromatic acids in aqueous solution -a comparison of hydroxamic acids and benzoic acid, Radiochimica Acta, vol.95, issue.3, pp.151-157, 2007. ,
Synthesis and characterization of the solid uranium(VI) dioxo-diacetohydroxamate complex. Radiochimica Acta, vol.95, pp.439-450, 2007. ,
U(IV), and Th(IV) sulfato complexes in aqueous solution, EXAFS investigation of U(VI), vol.46, pp.5882-5892, 2007. ,
Equilibrium studies of binary systems involving lanthanide and actinide metal ions and some selected aliphatic and aromatic monohydroxamic acids, Journal of Chemical and Engineering Data, vol.52, issue.5, pp.1571-1579, 2007. ,
Spectrophotometry and luminescence spectroscopy of acetohydroxamate complexes of trivalent lanthanide and actinide ions, Journal of Solution Chemistry, vol.36, issue.6, pp.815-830, 2007. ,
Determination of binding constants by affinity capillary electrophoresis, electrospray ionization mass spectrometry and phasedistribution methods, Trends in Analytical Chemistry, vol.27, issue.9, pp.738-748, 2008. ,
Oxidation-reduction reactions of simple hydroxamic acids and plutonium (IV) ions in nitric acid, Radiochimica Acta, issue.6, pp.333-343, 2008. ,
Structure-based differences between the metal ion selectivity of two siderophores desferrioxamine B (DFB) and desferricoprogen (DFC): Why DFC is much better Pb(II) sequestering agent than DFB?, Journal of Inorganic Biochemistry, vol.102, issue.8, pp.1654-1659, 2008. ,
Lanthanum (La) and actinium (Ac) should remain in the dblock, Journal of Chemical Education, vol.85, issue.11, p.1482, 2008. ,
Chemical Thermodynamics of Thorium, 2008. ,
Hydrolysis constants and complexation of Th(IV) with carboxylates. Radiochimica Acta, vol.96, pp.799-803, 2008. ,
, , 2009.
, ATR-FTIR spectroscopic study of the adsorption of desferrioxamine B and aerobactin to the surface of lepidocrocite (?-FeOOH), Geochimica Et Cosmochimica Acta, vol.73, issue.16, pp.4661-4672
Gaussian 09, Revision D. 01, Gaussian, 2009. ,
Speciation and structural study of U(IV) and -(VI) in perchloric and nitric acid solutions, Inorganic Chemistry, vol.48, issue.15, pp.7201-7210, 2009. ,
MAX: Multiplatform Applications for XAFS, 14th International Conference on X-Ray Absorption Fine Structure, vol.190, 2009. ,
Uranium speciation in drinking water from drilled wells in southern Finland and its potential links to health effects, Environmental science & Technology, vol.43, issue.10, pp.3941-3946, 2009. ,
, , 2009.
, Trace metal speciation by capillary electrophoresis hyphenated to inductively coupled plasma mass spectrometry: sulfate and chloride complexes of Np (V) and
, Analytical Chemistry, vol.81, issue.13, pp.5354-5363
Hydration and hydrolysis of thorium(IV) in aqueous solution and the structures of two crystalline thorium(IV) hydrates, Inorganic Chemistry, vol.48, issue.24, pp.11712-11723, 2009. ,
, , 2009.
, Radiochimica Acta, vol.97, issue.4-5, pp.199-207
Study of the interaction between chromium(III) and hydroxamic acids, Journal of Chemical and Engineering Data, vol.55, issue.6, pp.2252-2256, 2010. ,
Investigation of Pu (IV)-acetohydroxamic acid complex by solvent extraction with di (2-ethylhexyl) phosphoric acid, Paper presented at the IOP Conference Series: Materials Science and Engineering, 2010. ,
Actinides in Solution: Complexation and Kinetics. The Chemistry of the Actinide and Transactinide Elements, pp.2524-2611, 2010. ,
Solving the hydration structure of the heaviest actinide aqua ion known: the californium(III) case, Angewandte Chemie-International Edition, vol.49, issue.22, pp.3811-3815, 2010. ,
URL : https://hal.archives-ouvertes.fr/in2p3-00493001
Sources of anthropogenic radionuclides in the environment: a review, Journal of Environmental Radioactivity, vol.101, issue.6, pp.426-437, 2010. ,
Actinium. The chemistry of actinides and transactinides elements, pp.18-51, 2010. ,
Parameterfree calculations of X-ray spectra with FEFF9, Physical Chemistry Chemical Physics, vol.12, issue.21, pp.5503-5513, 2010. ,
The chemistry of the actinide and transactinide elements, pp.3475-3593, 2010. ,
Evidence for ligand hydrolysis and Fe(III) reduction in the dissolution of goethite by desferrioxamine-B, 2010. ,
, Geochimica Et Cosmochimica Acta, vol.74, issue.23, pp.6706-6720
Ab initio X-ray absorption spectroscopy study of the solvation structure of Th(IV), U(IV), and Np(IV) in aqueous solution, The Journal of Physical Chemistry A, vol.115, issue.11, pp.2345-2349, 2011. ,
Stability of YREE complexes with the trihydroxamate siderophore desferrioxamine B at seawater ionic strength. Geochimica Et Cosmochimica Acta, vol.75, pp.7047-7062, 2011. ,
Complexation of U(VI), Ce(III) and Nd(III) with acetohydroxamic acid in perchlorate aqueous solution, Journal of Radioanalytical and Nuclear Chemistry, vol.289, issue.2, pp.315-319, 2011. ,
Summary and comparison of properties of the actinide and transactinide elements. The chemistry of the Actinide and Transactinide Elements, pp.1753-1835, 2011. ,
Characterization of Mn(II) and Mn(III) binding capability of natural siderophores desferrioxamine B and desferricoprogen as well as model hydroxamic acids, Inorganica Chimica Acta, vol.376, issue.1, pp.500-508, 2011. ,
Stability of Metal Chelates of Some Hydroxamic Acid Ligands, Journal of Chemical and Engineering Data, vol.56, issue.5, pp.2337-2342, 2011. ,
Thorium(IV)-selenate clusters containing an octanuclear Th(IV) hydroxide/oxide core. Inorganic Chemistry, vol.51, pp.4239-4249, 2012. ,
Complexation of the actinides (III, IV and V) with organic acids. (Doctoral dissertation, vol.11, 2012. ,
URL : https://hal.archives-ouvertes.fr/tel-00762743
Dispersion stability and electrokinetic properties of intrinsic plutonium colloids: implications for subsurface transport, Environmental Science & Technology, vol.47, issue.11, pp.5626-5634, 2013. ,
Radionuclides in the Environment, 2013. ,
Plutonium transport in the environment, Inorganic Chemistry, vol.52, issue.7, pp.3533-3546, 2013. ,
Solution and solid-state structural chemistry of actinide hydrates and their hydrolysis and condensation products, Chemical Reviews, vol.113, issue.2, pp.944-994, 2013. ,
Environmental speciation of actinides, Inorganic Chemistry, vol.52, issue.7, pp.3510-3532, 2013. ,
MAX (multiplatform applications for XAFS) new features, Journal of Physics: Conference Series, 2013. ,
Lanthanide(III) complexes of some natural siderophores: A thermodynamic, kinetic and relaxometric study, Journal of Inorganic Biochemistry, vol.127, pp.53-61, 2013. ,
Siderophores in environmental research: roles and applications, Microbial Biotechnology, vol.7, issue.3, pp.196-208, 2014. ,
Nuclear magnetic resonance spectroscopy of aqueous plutonium (IV) desferrioxamine B complexes, European Journal of Inorganic Chemistry, vol.21, pp.3312-3321, 2014. ,
Nuclear accidents call for transdisciplinary nuclear energy research, Sustainability Science, vol.10, issue.1, pp.179-183, 2015. ,
XAS and TRLIF spectroscopy of uranium and neptunium in seawater, 2015. ,
, Dalton Transactions, vol.44, issue.12, pp.5417-5427
Affinity capillary electrophoresis in studying the complex formation equilibria of radionuclides in aqueous solutions, Electrophoresis, vol.37, issue.19, pp.2558-2566, 2016. ,
Concise Handbook Of Analytical Spectroscopy, The: Theory, Applications, And Reference Materials, 2016. ,
Principles of instrumental analysis. Cengage learning, 2017. ,
Sources and Behaviour of Actinide Elements in the Environment, 2018. ,
, , 2018.
, Evidence for the Heaviest Expected Halide Species in Aqueous Solution
, Electromobility Measurements. Inorganic Chemistry, vol.57, issue.9, pp.4926-4933
Reduction of Plutonium (VI) to (V) by Hydroxamate Compounds at Environmentally Relevant pH, Environmental Science & Technology, vol.52, issue.11, pp.6448-6456, 2018. ,
, International Union of Pure and Applied Chemistry
, Résumé en français
Ces éléments se caractérisent par une toxicité chimique et radiologique é levé e. Pour des raisons de sûreté , il est indispensable de disposer de données thermodynamiques et structurales sur les complexes d'actinides susceptibles d'être présents afin de disposer de modèles prédictifs de leur comportement dans l'environnement. Par ailleurs, ces actinides du dé but de sé rie se caracté risent par une chimie complexe en raison de leur aptitude à exister sous différents degrés d'oxydation (+III à +VI) en solution aqueuse, chacun pré sentant une ré activité spé cifique, Les applications civiles et militaires de l'énergie nucléaire sont à l'origine d'une dissémination d'actinides dans l'environnement ,
, La complexation des actinides par des ligands organiques en milieu aqueux a fait l'objet de nombreuses é tudes qui ont permis la cré ation de bases de donné es thermodynamiques. Cependant, des incohérences peuvent être relevées, notamment lorsqu'il s'agit d'acides organiques faibles pour lesquels il existe
, Ces composé s, sé cré té s par des microorganismes tels que des bacté ries et des levures, sont de puissants ché lateurs du fer qui, en permettant la solubilisation d'hydroxydes ferriques, assurent leur approvisionnement en fer. Les sidé rophores peuvent ê tre divisé s en trois classes principales selon leur groupe fonctionnel : hydroxamate (figure 1a), caté cholate et carboxylate. Les sidé rophores hydroxamates sont le plus souvent observé s dans les eaux naturelles. Ils forment des complexes trè s stables avec le fer(III), la complexation s'effectuant de manière bidentate. Le rapport charge/taille similaire pour Fe 3+ et Pu 4+ , et la ré activité des actinides té travalents, laissent supposer une coordination voisine pour les deux é lé ments et une stabilité é levé e des complexes formé s, en particulier avec la desferrioxamine B (DFB, figure 1b). La DFB possè de en effet trois groupes hydroxamates pouvant se lier aux ions mé talliques. La formation de ces ché lates trè s stables peut ainsi favoriser la migration des actinides dans la gé osphè re, Ce travail de thèse est axé sur l'étude de la complexation d'actinides tri-et té tra-valents avec un ligand organique naturel appartenant à la classe des sidé rophores
Study of the interaction between chromium(III) and hydroxamic acids, J. Chem. Eng. Data, issue.6, pp.2252-2256, 2010. ,
Stability of Metal Chelates of Some Hydroxamic Acid Ligands, J. Chem. Eng. Data, vol.56, issue.5, pp.2337-2342, 2011. ,
, Complexation of U(VI)
III) with acetohydroxamic acid in perchlorate aqueous solution, J. Radioanal. Nucl.Chem, vol.289, issue.2, pp.315-319, 2011. ,
